This class represents the map control.
This constructor is used to programmatically create a new instance of UIView with the specified dimension in the frame. The object will only be displayed once it has been added to a view hierarchy by calling AddSubview in a containing view.This constructor is not invoked when deserializing objects from storyboards or XIB filesinstead the constructor that takes an NSCoder parameter is invoked.
Locates the map center to the specified feature.
Locates the map center to the specified world point.
Pans the specified direction.
Refreshes the specified overlays.
Zooms the map in by the provided percentage.
Zooms the map to specified feature.
Zooms the map to specified scale.
This method zooms current map to a specified position and scale.
When calling this method, it doesn't refresh existing Tiles on the current map. For example, if using a TileOverlay such as LayerOverlay; a layer style is changed, Refresh method is proper to call.
ZoomInByAnchorPoint(ScreenPointF)
Zooms the in by anchor point.
ToWorldCoordinate(ScreenPointF)
Converts the provided screen points to world points.
ToScreenCoordinate(PointShape)
Converts the provided world points to screen points.
Zooms to previous extent.
ConvertPointFromCoordinateSpace(CGPoint,IUICoordinateSpace)
ConvertPointFromView(CGPoint,UIView)
ConvertPointToCoordinateSpace(CGPoint,IUICoordinateSpace)
ConvertPointToView(CGPoint,UIView)
ConvertRectFromCoordinateSpace(CGRect,IUICoordinateSpace)
ConvertRectFromView(CGRect,UIView)
ConvertRectToCoordinateSpace(CGRect,IUICoordinateSpace)
ConvertRectToView(CGRect,UIView)
DecodeRestorableState(NSCoder)
DrawViewHierarchy(CGRect,Boolean)
EncodeRestorableState(NSCoder)
GetConstraintsAffectingLayout(UILayoutConstraintAxis)
InsertSubviewAbove(UIView,UIView)
InsertSubviewBelow(UIView,UIView)
InvalidateIntrinsicContentSize()
RemoveConstraint(NSLayoutConstraint)
SetContentCompressionResistancePriority(Single,UILayoutConstraintAxis)
SetContentHuggingPriority(Single,UILayoutConstraintAxis)
MakeTextWritingDirectionLeftToRight(NSObject)
MotionCancelled(UIEventSubtype,UIEvent)
MotionEnded(UIEventSubtype,UIEvent)
TouchesCancelled(NSSet,UIEvent)
UpdateUserActivityState(NSUserActivity)
PerformSelector(Selector,NSThread,NSObject,Boolean,NSString[])
PerformSelector(Selector,NSObject,NSObject)
RemoveObserver(NSObject,NSString,IntPtr)
RemoveObserver(NSObject,String,IntPtr)
RemoveObserver(NSObject,NSString)
RemoveObserver(NSObject,String)
SetValueForKeyPath(NSObject,NSString)
SetValueForUndefinedKey(NSObject,NSString)
SetValuesForKeysWithDictionary(NSDictionary)
WillChange(NSString,NSKeyValueSetMutationKind,NSSet)
InvokeOnMainThread(Selector,NSObject)
BeginInvokeOnMainThread(Action)
AddObserver(String,NSKeyValueObservingOptions,Action<NSObservedChange>)
AddObserver(NSString,NSKeyValueObservingOptions,Action<NSObservedChange>)
AddObserver(NSObject,String,NSKeyValueObservingOptions,IntPtr)
DidChange(NSString,NSKeyValueSetMutationKind,NSSet)
PerformSelector(Selector,NSObject,Double,NSString[])
PerformSelector(Selector,NSObject,Double)
PerformSelector(Selector,NSThread,NSObject,Boolean)
OnSingleTap(UIGestureRecognizer)
Called when [single tap].
OnDoubleTap(UIGestureRecognizer)
Called when [double tap].
OnTouchMove(UIGestureRecognizer)
Called when [touch move].
OnTouchUp(UIGestureRecognizer)
Called when [touch up].
OnTouchDown(UIGestureRecognizer)
Called when [touch down].
OnTouchPinch(UIGestureRecognizer)
Called when [touch pinch].
Releases the resources used by the UIView object.
This Dispose method releases the resources used by the UIView class.This method is called by both the Dispose() method and the object finalizer (Finalize). When invoked by the Dispose method, the parameter disposing is set to and any managed object references that this object holds are also disposed or released; when invoked by the object finalizer, on the finalizer thread the value is set to . Calling the Dispose method when you are finished using the UIView ensures that all external resources used by this managed object are released as soon as possible. Once you have invoked the Dispose method, the object is no longer useful and you should no longer make any calls to it. For more information on how to override this method and on the Dispose/IDisposable pattern, read the ``Implementing a Dispose Method'' document at http:msdn.microsoft.com/en-us/library/fs2xkftw.aspx
This function will pan the currentExtent based on a direction and percentage.
This method will change the current extent by panning according to the direction and percentage specified.
Refreshes current map control.
Refreshes all the existing overlays and map tools.
Zooms the map out by the provided percentage.
ZoomInByAnchorPointCore(ScreenPointF)
Zooms the in by anchor point core.
Zooms the map in by the provided extent and locates to extent.
This method zooms current map to a specified scale.
OnCurrentExtentChanged(CurrentExtentChangedMapViewEventArgs)
Raises the event.
OnCurrentExtentChanging(CurrentExtentChangingMapViewEventArgs)
Raises the event.
OnCurrentScaleChanging(CurrentScaleChangingMapViewEventArgs)
Raises the event.
OnCurrentScaleChanged(CurrentScaleChangedMapViewEventArgs)
Raises the event.
Gets or sets the extent overlay for the MapControl.
Gets the map tools for the MapControl.
Gets the event view for the MapControl.
This property gets and sets a minimum scale when navigating the map. When you keep zooming in, and the target scale is smaller than the minimum scale, the zooming operation will be stopped.
This property gets and sets a maximum scale when navigating the map. When you keep zooming out, and the target scale is bigger than the maximum scale, the zooming operation will be stopped.
Event Arguments:CurrentScaleChangedMapViewEventArgs
Event Arguments:UIGestureRecognizer
