<!– Class –> This class represents the map control.
The map class inherits from the UIView, so it can be dragged onto the page or be created and added to a contoller via code like the popular control itself. You also need to configure the properties of the map. The most important step is adding overlays, which generate images and stack them over each other to form a map image. The map control has many methods and events through which you can interact with the map.
*System.Object MonoTouch.Foundation.NSObject *MonoTouch.UIKit.UIResponder MonoTouch.UIKit.UIView *ThinkGeo.MapSuite.iOSEdition.MapView
![]() | UIView | ||
![]() | UIResponder | ||
![]() | NSObject | ||
![]() | UIAccessibilityScrollDirection | UIResponder | |
![]() | UIAccessibilityScrollDirection | NSObject | |
![]() | UIView | UIView | |
![]() | NSLayoutConstraint | UIView | |
![]() | NSLayoutConstraint[] | UIView | |
![]() | UIGestureRecognizer | UIView | |
![]() | UIMotionEffect | UIView | |
![]() | NSObject, String, NSKeyValueObservingOptions, IntPtr | NSObject | |
![]() | NSObject, NSString, NSKeyValueObservingOptions, IntPtr | NSObject | |
![]() | NSString, NSKeyValueObservingOptions, Action<NSObservedChange> | NSObject | |
![]() | String, NSKeyValueObservingOptions, Action<NSObservedChange> | NSObject | |
![]() | UIView[] | UIView | |
![]() | RectangleF | UIView | |
![]() | NSAction | NSObject | |
![]() | Selector, NSObject | NSObject | |
![]() | Selector, NSObject | UIResponder | |
![]() | PointShape | Locates the map center to the specified world point. | |
![]() | Double, Double | Locates the map center to the specified world point. | |
![]() | Feature | Locates the map center to the specified feature. | |
![]() | Closes this instance. | ||
![]() | IntPtr | NSObject | |
![]() | UILayoutConstraintAxis | UIView | |
![]() | PointF, IUICoordinateSpace | UIView | |
![]() | PointF, UIView | UIView | |
![]() | RectangleF, IUICoordinateSpace | UIView | |
![]() | RectangleF, UIView | UIView | |
![]() | NSObject | UIResponder | |
![]() | NSCoder | UIView | |
![]() | NSKeyValueChange, NSIndexSet, NSString | NSObject | |
![]() | NSString, NSKeyValueSetMutationKind, NSSet | NSObject | |
![]() | String | NSObject | |
![]() | Selector | NSObject | |
![]() | RectangleF, UIViewPrintFormatter | UIView | |
![]() | String, PointF, UIFont | UIView | |
![]() | String, PointF, Single, UIFont, UILineBreakMode | UIView | |
![]() | String, PointF, Single, UIFont, Single, UILineBreakMode, UIBaselineAdjustment | UIView | |
![]() | String, PointF, Single, UIFont, Single, ref Single, UILineBreakMode, UIBaselineAdjustment | UIView | |
![]() | String, RectangleF, UIFont | UIView | |
![]() | String, RectangleF, UIFont, UILineBreakMode | UIView | |
![]() | String, RectangleF, UIFont, UILineBreakMode, UITextAlignment | UIView | |
![]() | String, PointF, Single, UIFont, Single, Single, UILineBreakMode, UIBaselineAdjustment | UIView | |
![]() | RectangleF, Boolean | UIView | |
![]() | NSCoder | NSObject | |
![]() | Boolean | UIView | |
![]() | Object | Object | |
![]() | Int32, Int32 | UIView | |
![]() | UIView | ||
![]() | NSString[] | NSObject | |
![]() | UIView | ||
![]() | Object | ||
![]() | Double | Gets the index of the snapped zoom level. | |
![]() | Object | ||
![]() | PointF, UIEvent | UIView | |
![]() | UIView, Int32 | UIView | |
![]() | UIView, UIView | UIView | |
![]() | UIView | ||
![]() | NSAction, TimeSpan | NSObject | |
![]() | NSAction, Double | NSObject | |
![]() | UIView | ||
![]() | UIView | ||
![]() | UIView | ||
![]() | UIEventSubtype, UIEvent | UIResponder | |
![]() | UIView | ||
![]() | UIView | ||
![]() | UIView | ||
![]() | NSString, NSObject, NSDictionary, IntPtr | NSObject | |
![]() | PanDirection, Int32 | Pans the specified direction. | |
![]() | Selector, NSObject, Double | NSObject | |
![]() | Selector, NSObject, Double, NSString[] | NSObject | |
![]() | Selector, NSThread, NSObject, Boolean | NSObject | |
![]() | Selector, NSThread, NSObject, Boolean, NSString[] | NSObject | |
![]() | Selector, NSObject, Single | NSObject | |
![]() | Refreshes this instance. | ||
![]() | IEnumerable<Overlay> | Refreshes the specified overlays. | |
![]() | UIEvent | UIResponder | |
![]() | UIView | ||
![]() | NSObject, String | NSObject | |
![]() | NSObject, NSString | NSObject | |
![]() | NSObject, String, IntPtr | NSObject | |
![]() | NSObject, NSString, IntPtr | NSObject | |
![]() | RectangleF, Boolean, UIEdgeInsets | UIView | |
![]() | NSUserActivity | UIResponder | |
![]() | Single, UILayoutConstraintAxis | UIView | |
![]() | String, NSObject | NSObject | |
![]() | UIView | ||
![]() | UIView | ||
![]() | UIView | ||
![]() | NSString | NSObject | |
![]() | IntPtr, NSString | NSObject | |
![]() | NSDictionary | NSObject | |
![]() | SizeF | UIView | |
![]() | UIView | ||
![]() | String, UIFont | UIView | |
![]() | String, UIFont, SizeF | UIView | |
![]() | String, UIFont, Single, UILineBreakMode | UIView | |
![]() | String, UIFont, SizeF, UILineBreakMode | UIView | |
![]() | String, UIFont, Single, ref Single, Single, UILineBreakMode | UIView | |
![]() | SizeF, Single, Single | UIView | |
![]() | UIView | ||
![]() | PointShape | Converts the provided world points to screen points. | |
![]() | Object(overriden) | ||
![]() | ScreenPointF | Converts the provided screen points to world points. | |
![]() | NSSet, UIEvent | UIResponder | |
![]() | UITraitCollection | UIView | |
![]() | UIView | ||
![]() | UIView | ||
![]() | Int32 | UIView | |
![]() | UIWindow | UIView | |
![]() | Int32 | Zooms the map in for one level. | |
![]() | ScreenPointF | Zooms the in by anchor point. | |
![]() | Int32 | Zooms the map in by the provided percentage. | |
![]() | PointShape, Double | This method zooms current map to a specified position and scale. | |
![]() | BaseShape | Zooms the map to specified feature. | |
![]() | Feature | Zooms the map to specified feature. | |
![]() | Zooms to next extent. | ||
![]() | Zooms to previous extent. | ||
![]() | Double | Zooms the map to specified scale. |
![]() | Boolean | NSObject(overriden) | Releases the resources used by the UIView object. |
![]() | IntPtr, String | NSObject | |
![]() | Object | ||
![]() | CurrentExtentChangedMapViewEventArgs | Raises the event. | |
![]() | CurrentExtentChangingMapViewEventArgs | Raises the event. | |
![]() | CurrentScaleChangedMapViewEventArgs | Raises the event. | |
![]() | CurrentScaleChangingMapViewEventArgs | Raises the event. | |
![]() | UIGestureRecognizer | Called when tap. | |
![]() | UIGestureRecognizer | Called when press. | |
![]() | UIGestureRecognizer | Called when down. | |
![]() | UIGestureRecognizer | Called when move. | |
![]() | UIGestureRecognizer | Called when pinch. | |
![]() | UIGestureRecognizer | Called when up. | |
![]() | PanDirection, Int32 | This function will pan the currentExtent based on a direction and percentage. | |
![]() | Refreshes current map control. | ||
![]() | ScreenPointF | Zooms the in by anchor point core. | |
![]() | Int32 | Zooms the map out by the provided percentage. | |
![]() | RectangleShape | Zooms the map in by the provided extent and locates to extent. | |
![]() | Double | This method zooms current map to a specified scale. |
![]() | PointF | UIView | |
![]() | UIAccessibilityCustomAction[] | UIResponder | |
![]() | String | UIView | |
![]() | UIAccessibilityNavigationStyle | UIView | |
![]() | UIBezierPath | UIView | |
![]() | UIAccessibilityTrait | UIView | |
![]() | AdornmentOverlay | Gets the adornment overlay for the MapControl. | |
![]() | UIEdgeInsets | UIView | |
![]() | Single | UIView | |
![]() | UIViewAutoresizing | UIView | |
![]() | UIColor | UIView | |
![]() | Boolean | UIResponder | |
![]() | IntPtr | NSObject(overriden) | |
![]() | UIViewContentMode | UIView | |
![]() | RectangleShape | Gets or sets the current extent for the MapControl. | |
![]() | Double | Gets the current scale for the MapControl. | |
![]() | EditInteractiveOverlay | Gets or sets the edit overlay for the MapControl. | |
![]() | UIView | Gets the event view for the MapControl. | |
![]() | ExtentInteractiveOverlay | Gets or sets the extent overlay for the MapControl. | |
![]() | RectangleF | UIView(overriden) | Coordinates of the view relative to its container. |
![]() | UIGestureRecognizer[] | UIView | |
![]() | UIView | UIResponder | |
![]() | UIInputViewController | UIResponder | |
![]() | GeoCollection<InteractiveOverlay> | Gets or sets the extent overlay for the MapControl. | |
![]() | UIKeyCommand[] | UIResponder | |
![]() | CALayer | UIView | |
![]() | MapTools | Gets the map tools for the MapControl. | |
![]() | GeographyUnit | Gets or sets the map unit for the MapControl. | |
![]() | UIMotionEffect[] | UIView | |
![]() | UIResponder | UIResponder | |
![]() | GeoCollection<Overlay> | Gets the overlays for the MapControl. | |
![]() | Int32 | NSObject | |
![]() | NSString | UIResponder | |
![]() | UITextInputMode | UIResponder | |
![]() | UIViewTintAdjustmentMode | UIView | |
![]() | TrackInteractiveOverlay | Gets or sets the track overlay for the MapControl. | |
![]() | CGAffineTransform | UIView | |
![]() | NSUndoManager | UIResponder | |
![]() | UIViewPrintFormatter | UIView | |
![]() | ZoomLevelSet | Gets or sets the zoom level set for the MapControl. |
![]() | CurrentExtentChangedMapViewEventArgs | ||
![]() | CurrentExtentChangingMapViewEventArgs | ||
![]() | CurrentScaleChangedMapViewEventArgs | ||
![]() | CurrentScaleChangingMapViewEventArgs | ||
![]() | UIGestureRecognizer | This event raises when double tap. | |
![]() | UIGestureRecognizer | This event raises when long press. | |
![]() | UIGestureRecognizer | This event raises when single tap. | |
![]() | UIGestureRecognizer | This event raises when touch down. | |
![]() | UIGestureRecognizer | This event raises when touch move. | |
![]() | UIGestureRecognizer | This event raises when touch pinch. | |
![]() | UIGestureRecognizer | This event raises when touch up. |
Name | Type | Description |
This constructor is used to programmatically create a new instance of UIView with the specified dimension in the frame. The object will only be displayed once it has been added to a view hierarchy by calling AddSubview in a containing view.
This constructor is not invoked when deserializing objects from storyboards or XIB filesinstead the constructor that takes an NSCoder parameter is invoked.
frame | RectangleF<!– System.Drawing.RectangleF –> | Frame used by the view, expressed in iOS points. |
Return Type | Description |
<!– MonoTouch.UIKit.UIView –> Go Back
Void<!– System.Void –> |
<!– MonoTouch.UIKit.UIResponder –> Go Back
<!– MonoTouch.Foundation.NSObject –> Go Back
direction | UIAccessibilityScrollDirection<!– MonoTouch.UIKit.UIAccessibilityScrollDirection –> |
view | UIView<!– MonoTouch.UIKit.UIView –> |
constraint | NSLayoutConstraint<!– MonoTouch.UIKit.NSLayoutConstraint –> |
constraints | NSLayoutConstraint[]<!– MonoTouch.UIKit.NSLayoutConstraintthinkgeo.mapsuite.iosedition.mapview –> |
gestureRecognizer | UIGestureRecognizer<!– MonoTouch.UIKit.UIGestureRecognizer –> |
effect | UIMotionEffect<!– MonoTouch.UIKit.UIMotionEffect –> |
observer | NSObject<!– MonoTouch.Foundation.NSObject –> | |
keyPath | String<!– System.String –> | |
options | NSKeyValueObservingOptions<!– MonoTouch.Foundation.NSKeyValueObservingOptions –> | |
context | IntPtr<!– System.IntPtr –> |
keyPath | NSString<!– MonoTouch.Foundation.NSString –> | |
IDisposable<!– System.IDisposable –> |
key | NSString<!– MonoTouch.Foundation.NSString –> | |
observer | Action<NSObservedChange><!– System.Action{MonoTouch.Foundation.NSObservedChange} –> |
key | String<!– System.String –> | |
views | UIView[]<!– MonoTouch.UIKit.UIViewthinkgeo.mapsuite.iosedition.mapview –> |
action | NSAction<!– MonoTouch.Foundation.NSAction –> |
sel | Selector<!– MonoTouch.ObjCRuntime.Selector –> | |
obj | NSObject<!– MonoTouch.Foundation.NSObject –> |
action | Selector<!– MonoTouch.ObjCRuntime.Selector –> | |
withSender | NSObject<!– MonoTouch.Foundation.NSObject –> |
worldCenter | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | The world center. |
<!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back
worldX | Double<!– System.Double –> | The world x. |
worldY | Double<!– System.Double –> | The world y. |
feature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | The feature. |
protocol | IntPtr<!– System.IntPtr –> |
Single<!– System.Single –> |
axis | UILayoutConstraintAxis<!– MonoTouch.UIKit.UILayoutConstraintAxis –> |
PointF<!– System.Drawing.PointF –> |
point | PointF<!– System.Drawing.PointF –> | |
coordinateSpace | IUICoordinateSpace<!– MonoTouch.UIKit.IUICoordinateSpace –> |
fromView | UIView<!– MonoTouch.UIKit.UIView –> |
toView | UIView<!– MonoTouch.UIKit.UIView –> |
rect | RectangleF<!– System.Drawing.RectangleF –> | |
sender | NSObject<!– MonoTouch.Foundation.NSObject –> |
coder | NSCoder<!– MonoTouch.Foundation.NSCoder –> |
changeKind | NSKeyValueChange<!– MonoTouch.Foundation.NSKeyValueChange –> | |
indexes | NSIndexSet<!– MonoTouch.Foundation.NSIndexSet –> | |
forKey | NSString<!– MonoTouch.Foundation.NSString –> |
forKey | NSString<!– MonoTouch.Foundation.NSString –> | |
mutationKind | NSKeyValueSetMutationKind<!– MonoTouch.Foundation.NSKeyValueSetMutationKind –> | |
objects | NSSet<!– MonoTouch.Foundation.NSSet –> |
forKey | String<!– System.String –> |
area | RectangleF<!– System.Drawing.RectangleF –> | |
formatter | UIViewPrintFormatter<!– MonoTouch.UIKit.UIViewPrintFormatter –> |
SizeF<!– System.Drawing.SizeF –> |
str | String<!– System.String –> | |
font | UIFont<!– MonoTouch.UIKit.UIFont –> |
width | Single<!– System.Single –> | |
font | UIFont<!– MonoTouch.UIKit.UIFont –> | |
breakMode | UILineBreakMode<!– MonoTouch.UIKit.UILineBreakMode –> |
fontSize | Single<!– System.Single –> | |
breakMode | UILineBreakMode<!– MonoTouch.UIKit.UILineBreakMode –> | |
adjustment | UIBaselineAdjustment<!– MonoTouch.UIKit.UIBaselineAdjustment –> |
minFontSize | Single<!– System.Single –> | |
actualFontSize | ref Single<!– System.Single –> | |
mode | UILineBreakMode<!– MonoTouch.UIKit.UILineBreakMode –> |
mode | UILineBreakMode<!– MonoTouch.UIKit.UILineBreakMode –> | |
alignment | UITextAlignment<!– MonoTouch.UIKit.UITextAlignment –> |
actualFontSize | Single<!– System.Single –> | |
afterScreenUpdates | Boolean<!– System.Boolean –> |
force | Boolean<!– System.Boolean –> |
atIndex | Int32<!– System.Int32 –> | |
withSubviewAtIndex | Int32<!– System.Int32 –> |
alignmentRect | RectangleF<!– System.Drawing.RectangleF –> |
NSDictionary<!– MonoTouch.Foundation.NSDictionary –> |
keys | NSString[]<!– MonoTouch.Foundation.NSStringthinkgeo.mapsuite.iosedition.mapview –> |
IEnumerator<!– System.Collections.IEnumerator –> |
name | String<!– System.String –> |
scale | Double<!– System.Double –> | The scale. |
Type<!– System.Type –> |
uievent | UIEvent<!– MonoTouch.UIKit.UIEvent –> |
view | UIView<!– MonoTouch.UIKit.UIView –> | |
siblingSubview | UIView<!– MonoTouch.UIKit.UIView –> |
action | NSAction<!– MonoTouch.Foundation.NSAction –> | |
delay | TimeSpan<!– System.TimeSpan –> |
delay | Double<!– System.Double –> |
motion | UIEventSubtype<!– MonoTouch.UIKit.UIEventSubtype –> | |
evt | UIEvent<!– MonoTouch.UIKit.UIEvent –> |
ofObject | NSObject<!– MonoTouch.Foundation.NSObject –> | |
change | NSDictionary<!– MonoTouch.Foundation.NSDictionary –> | |
direction | PanDirection<!– ThinkGeo.MapSuite.Core.PanDirection –> | The direction. |
percentage | Int32<!– System.Int32 –> | The percentage. |
selector | Selector<!– MonoTouch.ObjCRuntime.Selector –> | |
withObject | NSObject<!– MonoTouch.Foundation.NSObject –> | |
afterDelay | Double<!– System.Double –> | |
nsRunLoopModes | NSString[]<!– MonoTouch.Foundation.NSStringthinkgeo.mapsuite.iosedition.mapview –> |
onThread | NSThread<!– MonoTouch.Foundation.NSThread –> | |
waitUntilDone | Boolean<!– System.Boolean –> |
waitUntilDone | Boolean<!– System.Boolean –> | |
obj | NSObject<!– MonoTouch.Foundation.NSObject –> | |
delay | Single<!– System.Single –> |
overlays | IEnumerable<Overlay><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.iOSEdition.Overlay} –> | The overlays. |
theEvent | UIEvent<!– MonoTouch.UIKit.UIEvent –> |
afterScreenUpdates | Boolean<!– System.Boolean –> | |
capInsets | UIEdgeInsets<!– MonoTouch.UIKit.UIEdgeInsets –> |
activity | NSUserActivity<!– MonoTouch.Foundation.NSUserActivity –> |
priority | Single<!– System.Single –> | |
name | String<!– System.String –> | |
value | NSObject<!– MonoTouch.Foundation.NSObject –> |
value | NSObject<!– MonoTouch.Foundation.NSObject –> | |
handle | IntPtr<!– System.IntPtr –> | |
undefinedKey | NSString<!– MonoTouch.Foundation.NSString –> |
keyedValues | NSDictionary<!– MonoTouch.Foundation.NSDictionary –> |
size | SizeF<!– System.Drawing.SizeF –> |
constrainedToSize | SizeF<!– System.Drawing.SizeF –> |
forWidth | Single<!– System.Single –> | |
constrainedToSize | SizeF<!– System.Drawing.SizeF –> | |
lineBreakMode | UILineBreakMode<!– MonoTouch.UIKit.UILineBreakMode –> |
uiview | UIView<!– MonoTouch.UIKit.UIView –> |
targetSize | SizeF<!– System.Drawing.SizeF –> | |
horizontalFittingPriority | Single<!– System.Single –> | |
verticalFittingPriority | Single<!– System.Single –> |
ScreenPointF<!– ThinkGeo.MapSuite.Core.ScreenPointF –> | A screen coordinate that is converted. |
worldCoordinate | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | World point to be converted. |
PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | A world coordinate that is converted. |
screenCoordinate | ScreenPointF<!– ThinkGeo.MapSuite.Core.ScreenPointF –> | Screen point to be converted. |
touches | NSSet<!– MonoTouch.Foundation.NSSet –> | |
previousTraitCollection | UITraitCollection<!– MonoTouch.UIKit.UITraitCollection –> |
tag | Int32<!– System.Int32 –> |
newsuper | UIView<!– MonoTouch.UIKit.UIView –> |
window | UIWindow<!– MonoTouch.UIKit.UIWindow –> |
touchPosition | ScreenPointF<!– ThinkGeo.MapSuite.Core.ScreenPointF –> | The touch position. |
When calling this method, it doesn't refresh existing Tiles on the current map. For example, if using a TileOverlay such as LayerOverlay; a layer style is changed, Refresh method is proper to call.
worldCenter | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | A world center to zoom the map to. |
scale | Double<!– System.Double –> | A double value indicates the scale to zoom the map to. |
targetShape | BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> | The target shape. |
targetScale | Double<!– System.Double –> | The target scale. |
This Dispose method releases the resources used by the UIView class.
This method is called by both the Dispose() method and the object finalizer (Finalize). When invoked by the Dispose method, the parameter disposing <paramref name=“disposing” /> is set to <see langword=“true” /> and any managed object references that this object holds are also disposed or released; when invoked by the object finalizer, on the finalizer thread the value is set to <see langword=“false” />.
Calling the Dispose method when you are finished using the UIView ensures that all external resources used by this managed object are released as soon as possible. Once you have invoked the Dispose method, the object is no longer useful and you should no longer make any calls to it.
For more information on how to override this method and on the Dispose/IDisposable pattern, read the ``Implementing a Dispose Method document at http://msdn.microsoft.com/en-us/library/fs2xkftw.aspx === Return Value === ^ Return Type ^ Description ^ | Void<!– System.Void –> | | === Parameters === ^ Name ^ Type ^ Description ^ | disposing | Boolean<!– System.Boolean –> | If set to , the method is invoked directly and will dispose manage and unmanaged resources; If set to the method is being called by the garbage collector finalizer and should only release unmanaged resources. | <!– MonoTouch.Foundation.NSObject(overriden) –> Go Back ==== Finalize() ==== === Return Value === ^ Return Type ^ Description ^ | Void<!– System.Void –> | | === Parameters === ^ Name ^ Type ^ Description ^ <!– System.Object(overriden) –> Go Back ==== InitializeHandle(IntPtr, String) ==== === Return Value === ^ Return Type ^ Description ^ | Void<!– System.Void –> | | === Parameters === ^ Name ^ Type ^ Description ^ | handle | IntPtr<!– System.IntPtr –> | | | initSelector | String<!– System.String –> | | <!– MonoTouch.Foundation.NSObject –> Go Back ==== InitializeHandle(IntPtr) ==== === Return Value === ^ Return Type ^ Description ^ | Void<!– System.Void –> | | === Parameters === ^ Name ^ Type ^ Description ^ | handle | IntPtr<!– System.IntPtr –> | | <!– MonoTouch.Foundation.NSObject –> Go Back ==== MarkDirty() ==== === Return Value === ^ Return Type ^ Description ^ | Void<!– System.Void –> | | === Parameters === ^ Name ^ Type ^ Description ^ <!– MonoTouch.Foundation.NSObject –> Go Back ==== MemberwiseClone() ==== === Return Value === ^ Return Type ^ Description ^ | Object<!– System.Object –> | | === Parameters === ^ Name ^ Type ^ Description ^ <!– System.Object –> Go Back ==== OnCurrentExtentChanged(CurrentExtentChangedMapViewEventArgs) ==== Raises the event. === Return Value === ^ Return Type ^ Description ^ | Void<!– System.Void –> | | === Parameters === ^ Name ^ Type ^ Description ^ | e | CurrentExtentChangedMapViewEventArgs<!– ThinkGeo.MapSuite.iOSEdition.CurrentExtentChangedMapViewEventArgs –> | The instance containing the event data. | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== OnCurrentExtentChanging(CurrentExtentChangingMapViewEventArgs) ==== Raises the event. === Return Value === ^ Return Type ^ Description ^ | Void<!– System.Void –> | | === Parameters === ^ Name ^ Type ^ Description ^ | e | CurrentExtentChangingMapViewEventArgs<!– ThinkGeo.MapSuite.iOSEdition.CurrentExtentChangingMapViewEventArgs –> | The instance containing the event data. | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== OnCurrentScaleChanged(CurrentScaleChangedMapViewEventArgs) ==== Raises the event. === Return Value === ^ Return Type ^ Description ^ | Void<!– System.Void –> | | === Parameters === ^ Name ^ Type ^ Description ^ | e | CurrentScaleChangedMapViewEventArgs<!– ThinkGeo.MapSuite.iOSEdition.CurrentScaleChangedMapViewEventArgs –> | The instance containing the event data. | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== OnCurrentScaleChanging(CurrentScaleChangingMapViewEventArgs) ==== Raises the event. === Return Value === ^ Return Type ^ Description ^ | Void<!– System.Void –> | | === Parameters === ^ Name ^ Type ^ Description ^ | e | CurrentScaleChangingMapViewEventArgs<!– ThinkGeo.MapSuite.iOSEdition.CurrentScaleChangingMapViewEventArgs –> | The instance containing the event data. | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== OnDoubleTap(UIGestureRecognizer) ==== Called when tap. === Return Value === ^ Return Type ^ Description ^ | Void<!– System.Void –> | | === Parameters === ^ Name ^ Type ^ Description ^ | e | UIGestureRecognizer<!– MonoTouch.UIKit.UIGestureRecognizer –> | The e. | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== OnLongPress(UIGestureRecognizer) ==== Called when press. === Return Value === ^ Return Type ^ Description ^ | Void<!– System.Void –> | | === Parameters === ^ Name ^ Type ^ Description ^ | e | UIGestureRecognizer<!– MonoTouch.UIKit.UIGestureRecognizer –> | The e. | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== OnSingleTap(UIGestureRecognizer) ==== Called when tap. === Return Value === ^ Return Type ^ Description ^ | Void<!– System.Void –> | | === Parameters === ^ Name ^ Type ^ Description ^ | e | UIGestureRecognizer<!– MonoTouch.UIKit.UIGestureRecognizer –> | The e. | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== OnTouchDown(UIGestureRecognizer) ==== Called when down. === Return Value === ^ Return Type ^ Description ^ | Void<!– System.Void –> | | === Parameters === ^ Name ^ Type ^ Description ^ | e | UIGestureRecognizer<!– MonoTouch.UIKit.UIGestureRecognizer –> | The e. | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== OnTouchMove(UIGestureRecognizer) ==== Called when move. === Return Value === ^ Return Type ^ Description ^ | Void<!– System.Void –> | | === Parameters === ^ Name ^ Type ^ Description ^ | e | UIGestureRecognizer<!– MonoTouch.UIKit.UIGestureRecognizer –> | The e. | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== OnTouchPinch(UIGestureRecognizer) ==== Called when pinch. === Return Value === ^ Return Type ^ Description ^ | Void<!– System.Void –> | | === Parameters === ^ Name ^ Type ^ Description ^ | e | UIGestureRecognizer<!– MonoTouch.UIKit.UIGestureRecognizer –> | The e. | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== OnTouchUp(UIGestureRecognizer) ==== Called when up. === Return Value === ^ Return Type ^ Description ^ | Void<!– System.Void –> | | === Parameters === ^ Name ^ Type ^ Description ^ | e | UIGestureRecognizer<!– MonoTouch.UIKit.UIGestureRecognizer –> | The e. | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== PanCore(PanDirection, Int32) ==== This function will pan the currentExtent based on a direction and percentage. === Overloads === This overload allows you to pass a degree and percentage. === Remarks === This method will change the current extent by panning according to the direction and percentage specified. === Return Value === ^ Return Type ^ Description ^ | Void<!– System.Void –> | | === Parameters === ^ Name ^ Type ^ Description ^ | direction | PanDirection<!– ThinkGeo.MapSuite.Core.PanDirection –> | This parameter is the direction in which you want to pan. | | percentage | Int32<!– System.Int32 –> | This parameter is the percentage by which you want to pan. | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== RefreshCore() ==== Refreshes current map control. === Remarks === Refreshes all the existing overlays and map tools. === Return Value === ^ Return Type ^ Description ^ | Void<!– System.Void –> | | === Parameters === ^ Name ^ Type ^ Description ^ <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== ZoomInByAnchorPointCore(ScreenPointF) ==== Zooms the in by anchor point core. === Return Value === ^ Return Type ^ Description ^ | Void<!– System.Void –> | | === Parameters === ^ Name ^ Type ^ Description ^ | touchPosition | ScreenPointF<!– ThinkGeo.MapSuite.Core.ScreenPointF –> | The touch position. | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== ZoomInCore(Int32) ==== Zooms the map in by the provided percentage. === Return Value === ^ Return Type ^ Description ^ | Void<!– System.Void –> | | === Parameters === ^ Name ^ Type ^ Description ^ | percentage | Int32<!– System.Int32 –> | A scale to zoom the map in. | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== ZoomOutCore(Int32) ==== Zooms the map out by the provided percentage. === Return Value === ^ Return Type ^ Description ^ | Void<!– System.Void –> | | === Parameters === ^ Name ^ Type ^ Description ^ | percentage | Int32<!– System.Int32 –> | A scale to zoom the map in. | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== ZoomToCore(RectangleShape) ==== Zooms the map in by the provided extent and locates to extent. === Return Value === ^ Return Type ^ Description ^ | Void<!– System.Void –> | | === Parameters === ^ Name ^ Type ^ Description ^ | extent | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | The extent. | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== ZoomToScaleCore(Double) ==== This method zooms current map to a specified scale. === Remarks === When calling this method, it doesn't refresh existing Tiles on the current map. For example, if using a TileOverlay such as LayerOverlay; a layer style is changed, Refresh method is proper to call. === Return Value === ^ Return Type ^ Description ^ | Void<!– System.Void –> | | === Parameters === ^ Name ^ Type ^ Description ^ | targetScale | Double<!– System.Double –> | A double value indicates the scale to zoom the map to. | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ===== Public Properties ===== ==== AccessibilityActivationPoint ==== === Return Value === ^ Return Type ^ | PointF<!– System.Drawing.PointF –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== AccessibilityCustomActions ==== === Return Value === ^ Return Type ^ | UIAccessibilityCustomAction[]<!– MonoTouch.UIKit.UIAccessibilityCustomActionthinkgeo.mapsuite.iosedition.mapview –> | <!– MonoTouch.UIKit.UIResponder –> Go Back ==== AccessibilityElementsHidden ==== === Return Value === ^ Return Type ^ | Boolean<!– System.Boolean –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== AccessibilityFrame ==== === Return Value === ^ Return Type ^ | RectangleF<!– System.Drawing.RectangleF –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== AccessibilityHint ==== === Return Value === ^ Return Type ^ | String<!– System.String –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== AccessibilityIdentifier ==== === Return Value === ^ Return Type ^ | String<!– System.String –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== AccessibilityLabel ==== === Return Value === ^ Return Type ^ | String<!– System.String –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== AccessibilityLanguage ==== === Return Value === ^ Return Type ^ | String<!– System.String –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== AccessibilityNavigationStyle ==== === Return Value === ^ Return Type ^ | UIAccessibilityNavigationStyle<!– MonoTouch.UIKit.UIAccessibilityNavigationStyle –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== AccessibilityPath ==== === Return Value === ^ Return Type ^ | UIBezierPath<!– MonoTouch.UIKit.UIBezierPath –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== AccessibilityTraits ==== === Return Value === ^ Return Type ^ | UIAccessibilityTrait<!– MonoTouch.UIKit.UIAccessibilityTrait –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== AccessibilityValue ==== === Return Value === ^ Return Type ^ | String<!– System.String –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== AccessibilityViewIsModal ==== === Return Value === ^ Return Type ^ | Boolean<!– System.Boolean –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== AdornmentOverlay ==== Gets the adornment overlay for the MapControl. === Return Value === ^ Return Type ^ | AdornmentOverlay<!– ThinkGeo.MapSuite.iOSEdition.AdornmentOverlay –> | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== AlignmentRectInsets ==== === Return Value === ^ Return Type ^ | UIEdgeInsets<!– MonoTouch.UIKit.UIEdgeInsets –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== Alpha ==== === Return Value === ^ Return Type ^ | Single<!– System.Single –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== AutoresizingMask ==== === Return Value === ^ Return Type ^ | UIViewAutoresizing<!– MonoTouch.UIKit.UIViewAutoresizing –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== AutosizesSubviews ==== === Return Value === ^ Return Type ^ | Boolean<!– System.Boolean –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== BackgroundColor ==== === Return Value === ^ Return Type ^ | UIColor<!– MonoTouch.UIKit.UIColor –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== Bounds ==== === Return Value === ^ Return Type ^ | RectangleF<!– System.Drawing.RectangleF –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== CanBecomeFirstResponder ==== === Return Value === ^ Return Type ^ | Boolean<!– System.Boolean –> | <!– MonoTouch.UIKit.UIResponder –> Go Back ==== CanResignFirstResponder ==== === Return Value === ^ Return Type ^ | Boolean<!– System.Boolean –> | <!– MonoTouch.UIKit.UIResponder –> Go Back ==== Center ==== === Return Value === ^ Return Type ^ | PointF<!– System.Drawing.PointF –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== ClassHandle ==== === Return Value === ^ Return Type ^ | IntPtr<!– System.IntPtr –> | <!– MonoTouch.Foundation.NSObject(overriden) –> Go Back ==== ClearsContextBeforeDrawing ==== === Return Value === ^ Return Type ^ | Boolean<!– System.Boolean –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== ClipsToBounds ==== === Return Value === ^ Return Type ^ | Boolean<!– System.Boolean –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== Constraints ==== === Return Value === ^ Return Type ^ | NSLayoutConstraint[]<!– MonoTouch.UIKit.NSLayoutConstraintthinkgeo.mapsuite.iosedition.mapview –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== ContentMode ==== === Return Value === ^ Return Type ^ | UIViewContentMode<!– MonoTouch.UIKit.UIViewContentMode –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== ContentScaleFactor ==== === Return Value === ^ Return Type ^ | Single<!– System.Single –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== CurrentExtent ==== Gets or sets the current extent for the MapControl. === Return Value === ^ Return Type ^ | RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== CurrentScale ==== Gets the current scale for the MapControl. === Return Value === ^ Return Type ^ | Double<!– System.Double –> | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== DebugDescription ==== === Return Value === ^ Return Type ^ | String<!– System.String –> | <!– MonoTouch.Foundation.NSObject –> Go Back ==== Description ==== === Return Value === ^ Return Type ^ | String<!– System.String –> | <!– MonoTouch.Foundation.NSObject –> Go Back ==== EditOverlay ==== Gets or sets the edit overlay for the MapControl. === Return Value === ^ Return Type ^ | EditInteractiveOverlay<!– ThinkGeo.MapSuite.iOSEdition.EditInteractiveOverlay –> | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== EnableInputClicksWhenVisible ==== === Return Value === ^ Return Type ^ | Boolean<!– System.Boolean –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== EventView ==== Gets the event view for the MapControl. === Return Value === ^ Return Type ^ | UIView<!– MonoTouch.UIKit.UIView –> | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== ExclusiveTouch ==== === Return Value === ^ Return Type ^ | Boolean<!– System.Boolean –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== ExtentOverlay ==== Gets or sets the extent overlay for the MapControl. === Return Value === ^ Return Type ^ | ExtentInteractiveOverlay<!– ThinkGeo.MapSuite.iOSEdition.ExtentInteractiveOverlay –> | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== Frame ==== Coordinates of the view relative to its container. === Remarks === When changes are done to this property, the <see cref=“P:MonoTouch.UIKit.UIView.Center” /> is updated with the new location and the <see cref=“P:MonoTouch.UIKit.UIView.Bounds” /> is updated with the new dimensions and a re-layout of the subviews is performed. Changing this property will not trigger a call to <see cref=“M:MonoTouch.UIKit.UIView.Draw(System.Drawing.RectangleF)” /> unless you set the <see cref=“P:MonoTouch.UIKit.UIView.ContentMode” /> property to <see cref=“E:MonoTouch.UIKit.UIViewContentMode.Redraw” />. At least on iOS 6, changing this property causes the a re-layout of the subviews, even if the dimensions are the same. This can cause performance problems as some views (like UITableView) can perform some very expensive computations when they are laid out. If your <see cref=“P:MonoTouch.UIKit.UIView.ContentMode” /> property is set to <see cref=“E:MonoTouch.UIKit.UIViewContentMode.Redraw” />, you can avoid a redraw of your view if you update the <see cref=“P:MonoTouch.UIKit.UIView.Center” /> property instead of updating the Frame as that one will merely move the view without triggering a call to <see cref=“M:MonoTouch.UIKit.UIView.LayoutSubviews()” />. <para id=“animatable”> This property participates in the implicit animation protocol, changing it outside of a transaction will trigger an implicit animation for its values. If you change the <see cref=“P:MonoTouch.UIKit.UIView.Transform” /> property to a matrix that does not represent the identity matrix, changing this property can have unintended consequences. In those cases, you should instead update <see cref=“P:MonoTouch.UIKit.UIView.Center” /> and <see cref=“P:MonoTouch.UIKit.UIView.Bounds” /> directly. === Return Value === ^ Return Type ^ | RectangleF<!– System.Drawing.RectangleF –> | <!– MonoTouch.UIKit.UIView(overriden) –> Go Back ==== GestureRecognizers ==== === Return Value === ^ Return Type ^ | UIGestureRecognizer[]<!– MonoTouch.UIKit.UIGestureRecognizerthinkgeo.mapsuite.iosedition.mapview –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== Handle ==== === Return Value === ^ Return Type ^ | IntPtr<!– System.IntPtr –> | <!– MonoTouch.Foundation.NSObject –> Go Back ==== HasAmbiguousLayout ==== === Return Value === ^ Return Type ^ | Boolean<!– System.Boolean –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== Hidden ==== === Return Value === ^ Return Type ^ | Boolean<!– System.Boolean –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== InputAccessoryView ==== === Return Value === ^ Return Type ^ | UIView<!– MonoTouch.UIKit.UIView –> | <!– MonoTouch.UIKit.UIResponder –> Go Back ==== InputAccessoryViewController ==== === Return Value === ^ Return Type ^ | UIInputViewController<!– MonoTouch.UIKit.UIInputViewController –> | <!– MonoTouch.UIKit.UIResponder –> Go Back ==== InputView ==== === Return Value === ^ Return Type ^ | UIView<!– MonoTouch.UIKit.UIView –> | <!– MonoTouch.UIKit.UIResponder –> Go Back ==== InputViewController ==== === Return Value === ^ Return Type ^ | UIInputViewController<!– MonoTouch.UIKit.UIInputViewController –> | <!– MonoTouch.UIKit.UIResponder –> Go Back ==== InteractiveOverlays ==== Gets or sets the extent overlay for the MapControl. === Return Value === ^ Return Type ^ | GeoCollection<InteractiveOverlay><!– ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.iOSEdition.InteractiveOverlay} –> | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== IntrinsicContentSize ==== === Return Value === ^ Return Type ^ | SizeF<!– System.Drawing.SizeF –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== IsAccessibilityElement ==== === Return Value === ^ Return Type ^ | Boolean<!– System.Boolean –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== IsFirstResponder ==== === Return Value === ^ Return Type ^ | Boolean<!– System.Boolean –> | <!– MonoTouch.UIKit.UIResponder –> Go Back ==== KeyCommands ==== === Return Value === ^ Return Type ^ | UIKeyCommand[]<!– MonoTouch.UIKit.UIKeyCommandthinkgeo.mapsuite.iosedition.mapview –> | <!– MonoTouch.UIKit.UIResponder –> Go Back ==== Layer ==== === Return Value === ^ Return Type ^ | CALayer<!– MonoTouch.CoreAnimation.CALayer –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== LayoutMargins ==== === Return Value === ^ Return Type ^ | UIEdgeInsets<!– MonoTouch.UIKit.UIEdgeInsets –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== MapTools ==== Gets the map tools for the MapControl. === Return Value === ^ Return Type ^ | MapTools<!– ThinkGeo.MapSuite.iOSEdition.MapTools –> | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== MapUnit ==== Gets or sets the map unit for the MapControl. === Return Value === ^ Return Type ^ | GeographyUnit<!– ThinkGeo.MapSuite.Core.GeographyUnit –> | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== MaskView ==== === Return Value === ^ Return Type ^ | UIView<!– MonoTouch.UIKit.UIView –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== MotionEffects ==== === Return Value === ^ Return Type ^ | UIMotionEffect[]<!– MonoTouch.UIKit.UIMotionEffectthinkgeo.mapsuite.iosedition.mapview –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== MultipleTouchEnabled ==== === Return Value === ^ Return Type ^ | Boolean<!– System.Boolean –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== NextResponder ==== === Return Value === ^ Return Type ^ | UIResponder<!– MonoTouch.UIKit.UIResponder –> | <!– MonoTouch.UIKit.UIResponder –> Go Back ==== Opaque ==== === Return Value === ^ Return Type ^ | Boolean<!– System.Boolean –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== Overlays ==== Gets the overlays for the MapControl. === Return Value === ^ Return Type ^ | GeoCollection<Overlay><!– ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.iOSEdition.Overlay} –> | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== PreservesSuperviewLayoutMargins ==== === Return Value === ^ Return Type ^ | Boolean<!– System.Boolean –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== RestorationIdentifier ==== === Return Value === ^ Return Type ^ | String<!– System.String –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== RetainCount ==== === Return Value === ^ Return Type ^ | Int32<!– System.Int32 –> | <!– MonoTouch.Foundation.NSObject –> Go Back ==== ShouldGroupAccessibilityChildren ==== === Return Value === ^ Return Type ^ | Boolean<!– System.Boolean –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== Subviews ==== === Return Value === ^ Return Type ^ | UIView[]<!– MonoTouch.UIKit.UIViewthinkgeo.mapsuite.iosedition.mapview –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== SuperHandle ==== === Return Value === ^ Return Type ^ | IntPtr<!– System.IntPtr –> | <!– MonoTouch.Foundation.NSObject –> Go Back ==== Superview ==== === Return Value === ^ Return Type ^ | UIView<!– MonoTouch.UIKit.UIView –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== Tag ==== === Return Value === ^ Return Type ^ | Int32<!– System.Int32 –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== TextInputContextIdentifier ==== === Return Value === ^ Return Type ^ | NSString<!– MonoTouch.Foundation.NSString –> | <!– MonoTouch.UIKit.UIResponder –> Go Back ==== TextInputMode ==== === Return Value === ^ Return Type ^ | UITextInputMode<!– MonoTouch.UIKit.UITextInputMode –> | <!– MonoTouch.UIKit.UIResponder –> Go Back ==== TintAdjustmentMode ==== === Return Value === ^ Return Type ^ | UIViewTintAdjustmentMode<!– MonoTouch.UIKit.UIViewTintAdjustmentMode –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== TintColor ==== === Return Value === ^ Return Type ^ | UIColor<!– MonoTouch.UIKit.UIColor –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== TrackOverlay ==== Gets or sets the track overlay for the MapControl. === Return Value === ^ Return Type ^ | TrackInteractiveOverlay<!– ThinkGeo.MapSuite.iOSEdition.TrackInteractiveOverlay –> | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== TraitCollection ==== === Return Value === ^ Return Type ^ | UITraitCollection<!– MonoTouch.UIKit.UITraitCollection –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== Transform ==== === Return Value === ^ Return Type ^ | CGAffineTransform<!– MonoTouch.CoreGraphics.CGAffineTransform –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== TranslatesAutoresizingMaskIntoConstraints ==== === Return Value === ^ Return Type ^ | Boolean<!– System.Boolean –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== UndoManager ==== === Return Value === ^ Return Type ^ | NSUndoManager<!– MonoTouch.Foundation.NSUndoManager –> | <!– MonoTouch.UIKit.UIResponder –> Go Back ==== UserActivity ==== === Return Value === ^ Return Type ^ | NSUserActivity<!– MonoTouch.Foundation.NSUserActivity –> | <!– MonoTouch.UIKit.UIResponder –> Go Back ==== UserInteractionEnabled ==== === Return Value === ^ Return Type ^ | Boolean<!– System.Boolean –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== ViewForBaselineLayout ==== === Return Value === ^ Return Type ^ | UIView<!– MonoTouch.UIKit.UIView –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== ViewPrintFormatter ==== === Return Value === ^ Return Type ^ | UIViewPrintFormatter<!– MonoTouch.UIKit.UIViewPrintFormatter –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== Window ==== === Return Value === ^ Return Type ^ | UIWindow<!– MonoTouch.UIKit.UIWindow –> | <!– MonoTouch.UIKit.UIView –> Go Back ==== ZoomLevelSet ==== Gets or sets the zoom level set for the MapControl. === Return Value === ^ Return Type ^ | ZoomLevelSet<!– ThinkGeo.MapSuite.Core.ZoomLevelSet –> | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ===== Protected Properties ===== ===== Public Events ===== ==== CurrentExtentChanged ==== === Event Arguments === ^ Event Arguments ^ | CurrentExtentChangedMapViewEventArgs<!– ThinkGeo.MapSuite.iOSEdition.CurrentExtentChangedMapViewEventArgs –> | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== CurrentExtentChanging ==== === Event Arguments === ^ Event Arguments ^ | CurrentExtentChangingMapViewEventArgs<!– ThinkGeo.MapSuite.iOSEdition.CurrentExtentChangingMapViewEventArgs –> | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== CurrentScaleChanged ==== === Event Arguments === ^ Event Arguments ^ | CurrentScaleChangedMapViewEventArgs<!– ThinkGeo.MapSuite.iOSEdition.CurrentScaleChangedMapViewEventArgs –> | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== CurrentScaleChanging ==== === Event Arguments === ^ Event Arguments ^ | CurrentScaleChangingMapViewEventArgs<!– ThinkGeo.MapSuite.iOSEdition.CurrentScaleChangingMapViewEventArgs –> | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== MapDoubleTap ==== This event raises when double tap. === Event Arguments === ^ Event Arguments ^ | UIGestureRecognizer<!– MonoTouch.UIKit.UIGestureRecognizer –> | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== MapLongPress ==== This event raises when long press. === Event Arguments === ^ Event Arguments ^ | UIGestureRecognizer<!– MonoTouch.UIKit.UIGestureRecognizer –> | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== MapSingleTap ==== This event raises when single tap. === Event Arguments === ^ Event Arguments ^ | UIGestureRecognizer<!– MonoTouch.UIKit.UIGestureRecognizer –> | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== MapTouchDown ==== This event raises when touch down. === Event Arguments === ^ Event Arguments ^ | UIGestureRecognizer<!– MonoTouch.UIKit.UIGestureRecognizer –> | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== MapTouchMove ==== This event raises when touch move. === Event Arguments === ^ Event Arguments ^ | UIGestureRecognizer<!– MonoTouch.UIKit.UIGestureRecognizer –> | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== MapTouchPinch ==== This event raises when touch pinch. === Event Arguments === ^ Event Arguments ^ | UIGestureRecognizer<!– MonoTouch.UIKit.UIGestureRecognizer –> | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back ==== MapTouchUp ==== This event raises when touch up. === Event Arguments === ^ Event Arguments ^ | UIGestureRecognizer<!– MonoTouch.UIKit.UIGestureRecognizer –> | <!– ThinkGeo.MapSuite.iOSEdition.MapView –> Go Back NOTOC iOSEdition ThinkGeo.MapSuite.iOSEdition UpdateDocumentation
