thinkgeo.mapsuite.desktopedition.vertexremovingeditinteractiveoverlayeventargs
ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs
Provides data for the VertexRemoving event.
      • ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs
VertexRemovingEditInteractiveOverlayEventArgs()
VertexRemovingEditInteractiveOverlayEventArgs(Boolean,Feature,Vertex)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#VertexRemovingEditInteractiveOverlayEventArgs.28Boolean.2C_Feature.2C_Vertex.29
  • cancel
    • Description:This parameter specifies the cancel property.
  • affectedVertexFeature
    • Type:Feature
    • Description:This parameter specifies the affectedVertex feature property.
  • removingVertex
    • Type:Vertex
    • Description:This parameter specifies the target vertex to be removed.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.DesktopEdition.VertexRemovingEditInteractiveOverlayEventArgs#MemberwiseClone.28.29
AffectedVertexFeature
  • This property gets or sets the Feature from which the vertex will be removed.
Cancel
  • This property gets or sets whether or not the action will be canceled.
thinkgeo.mapsuite.desktopedition.vertexremovingeditinteractiveoverlayeventargs.1442966542.txt.gz · Last modified: 2015/09/23 00:02 by admin
