thinkgeo.mapsuite.core.featuresource
Table of Contents
ThinkGeo.MapSuite.Core.FeatureSource
FeatureSource This is the default constructor for the abstract FeatureSource class.
AddColumnFeatureSourceColumn
AddFeatureFeature This method adds a new Feature to an existing transaction.
AddFeatureBaseShape This method adds a new Feature (composed of the passed-in BaseShape) to an existing transaction.
AddFeatureBaseShape,IDictionary<String,String>
ApplyFiltersIEnumerable<Feature>,IEnumerable<String>,IEnumerable<String>
BeginTransaction This method starts a new transaction if the FeasuteSource allows editing
CanGetBoundingBoxQuickly
CanGetCountQuickly
CloneDeep Create a copy of a FeatureSource using the deep clone process.
Close This method closes the FeatureSource and releases any resources it was using.
CommitTransaction This method will commit the existing transaction to its underlying source of data.
DeleteColumnString
DeleteFeatureString This method deletes a Feature from an existing transaction.
EqualsObjectObject
ExecuteNonQueryString Executes a SQL statement against a connection object.
ExecuteQueryString Executes the query and returns the result returned by the query.
ExecuteScalarString Executes the query and returns the first column of the first row in the result set returned by the query. All other columns and rows are ignored.
GetAllFeaturesIEnumerable<String> This method returns all of the InternalFeatures in the FeatureSource.
GetAllFeaturesReturningColumnsType This method returns all of the InternalFeatures in the FeatureSource.
GetAllFeaturesReturningColumnsType,Int32
GetAllFeaturesReturningColumnsType,Int32,Int32
GetAllFeaturesIEnumerable<String>,Int32,Int32
GetBoundingBox This method returns the bounding box which encompasses all of the features in the FeatureSource.
GetBoundingBoxByIdString This method returns a bounding box based on the InternalFeatures Id specified.
GetBoundingBoxByIdsIEnumerable<String> This method returns a collection of bounding boxes based on the Feature Ids specified.
GetBoundingBoxesByIdsIEnumerable<String> This method returns a collection of bounding boxes based on the Feature Ids specified.
GetColumns This method returns the columns available for the FeatureSource and caches them.
GetCount This method returns the count of the number of records in this FeatureSource.
GetDistinctColumnValuesString
GetFeatureByIdString,IEnumerable<String> This method returns a Feature by providing its Id in the FeatureSource.
GetFeatureByIdString,ReturningColumnsType This method returns a Feature by providing its Id in the FeatureSource.
GetFeaturesByColumnValueString,String,ReturningColumnsType Get all of the features by passing a columnName and a specified columValue.
GetFeaturesByColumnValueString,String,IEnumerable<String> Get all of the features by passing a columnName and a specified columValue.
GetFeaturesByColumnValueString,String Get all of the features by passing a columnName and a specified columValue.
GetFeaturesByIdsIEnumerable<String>,ReturningColumnsType This method returns a collection of InternalFeatures by providing a group of Ids.
GetFeaturesByIdsIEnumerable<String>,IEnumerable<String> This method returns a collection of InternalFeatures by providing a group of Ids.
GetFeaturesByIdsIEnumerable<String>,IEnumerable<String>,IEnumerable<String>
GetFeaturesForDrawingRectangleShape,Double,Double,IEnumerable<String> This method returns the InternalFeatures that will be used for drawing.
GetFeaturesForDrawingRectangleShape,Double,Double,IEnumerable<String>,IEnumerable<String>
GetFeaturesForDrawingRectangleShape,Double,Double,ReturningColumnsType This method returns the InternalFeatures that will be used for drawing.
GetFeaturesInsideBoundingBoxRectangleShape,ReturningColumnsType This method returns all of the InternalFeatures of this FeatureSource inside of the specified bounding box.
GetFeaturesInsideBoundingBoxRectangleShape,IEnumerable<String>,IEnumerable<String>
GetFeaturesInsideBoundingBoxRectangleShape,IEnumerable<String> This method returns all of the InternalFeatures of this FeatureSource inside of the specified bounding box.
GetFeaturesNearestToFeature,GeographyUnit,Int32,IEnumerable<String> This method returns a user defined number of InternalFeatures that are closest to the TargetShape.
GetFeaturesNearestToFeature,GeographyUnit,Int32,IEnumerable<String>,Double,DistanceUnit This method returns a user defined number of InternalFeatures that are closest to the TargetShape.
GetFeaturesNearestToBaseShape,GeographyUnit,Int32,IEnumerable<String>,Double,DistanceUnit This method returns a user defined number of InternalFeatures that are closest to the TargetShape.
GetFeaturesNearestToFeature,GeographyUnit,Int32,ReturningColumnsType This method returns a user defined number of InternalFeatures that are closest to the TargetShape.
GetFeaturesNearestToBaseShape,GeographyUnit,Int32,ReturningColumnsType This method returns a user defined number of InternalFeatures that are closest to the TargetShape.
GetFeaturesNearestToBaseShape,GeographyUnit,Int32,IEnumerable<String> This method returns a user defined number of InternalFeatures that are closest to the TargetShape.
GetFeaturesOutsideBoundingBoxRectangleShape,IEnumerable<String> This method returns all of the InternalFeatures of this FeatureSource outside of the specified bounding box.
GetFeaturesOutsideBoundingBoxRectangleShape,ReturningColumnsType This method returns all of the InternalFeatures of this FeatureSource outside of the specified bounding box.
GetFeaturesWithinDistanceOfFeature,GeographyUnit,DistanceUnit,Double,IEnumerable<String> This method returns a collection of InternalFeatures that are within a certain distance of the TargetShape.
GetFeaturesWithinDistanceOfBaseShape,GeographyUnit,DistanceUnit,Double,ReturningColumnsType This method returns a collection of InternalFeatures that are within a certain distance of the TargetShape.
GetFeaturesWithinDistanceOfBaseShape,GeographyUnit,DistanceUnit,Double,IEnumerable<String> This method returns a collection of InternalFeatures that are within a certain distance of the TargetShape.
GetFeaturesWithinDistanceOfFeature,GeographyUnit,DistanceUnit,Double,ReturningColumnsType This method returns a collection of InternalFeatures that are within a certain distance of the TargetShape.
GetFirstFeaturesWellKnownType This method returns the well known type that represents the first feature from FeatureSource.
GetHashCode Object
GetType Object
Open This method opens the FeatureSource so that it is initialized and ready to use.
RefreshColumns This method refresh the columns available for the FeatureSource and caches them.
RollbackTransaction This method will cancel an existing transaction. It will free up the internal memory cache of any InternalFeatures added, updated or deleted.
SpatialQueryBaseShape,QueryType,IEnumerable<String> This method returns all of the InternalFeatures based on the target Feature and the spatial query type specified.
SpatialQueryFeature,QueryType,IEnumerable<String> This method returns all of the InternalFeatures based on the target Feature and the spatial query type specified.
SpatialQueryFeature,QueryType,ReturningColumnsType This method returns all of the InternalFeatures based on the target Feature and the spatial query type specified.
SpatialQueryBaseShape,QueryType,ReturningColumnsType This method returns all of the InternalFeatures based on the target Feature and the spatial query type specified.
SpatialQueryBaseShape,QueryType,IEnumerable<String>,IEnumerable<String>
ToString Object
UpdateColumnString,FeatureSourceColumn
UpdateFeatureBaseShape,IDictionary<String,String>
UpdateFeatureBaseShape This method updates a Feature (composed of the passed-in BaseShape) in an existing transaction.
UpdateFeatureFeature This method updates a Feature in an existing transaction.
ApplyFiltersCoreIEnumerable<Feature>,IEnumerable<String>,String
ApplyLinkColumnValuesIEnumerable<Feature>,IEnumerable<String>,IEnumerable<String>,IEnumerable<String>
ApplyLinkColumnValuesIEnumerable<String>,Func<IEnumerable<String>,Collection<Feature»,IEnumerable<String>
CanGetBoundingBoxQuicklyCore
CanGetCountQuicklyCore
CheckHasLinkColumnsIEnumerable<String>,IEnumerable<String>
CheckIsLinkColumnString
CloneDeepCore Create a copy of a FeatureSource using the deep clone process. The default implementation uses serialization.
CloseCore This method closes the FeatureSource and releases any resources it was using.
CombineFieldValuesDictionary<String,String>,IEnumerable<String>
CommitTransactionCoreTransactionBuffer This method will commit the existing transaction to its underlying source of data.
ConvertToExternalProjectionRectangleShape This method projects items based on the Projection of the FeatureSource.
ConvertToExternalProjectionFeature This method projects items based on the Projection of the FeatureSource.
ConvertToExternalProjectionIEnumerable<Feature> This method projects items based on the Projection of the FeatureSource.
ConvertToExternalProjectionIEnumerable<RectangleShape> This method projects items based on the Projection of the FeatureSource.
ConvertToExternalProjectionIfNecessaryCollection<Feature>
ConvertToInternalProjectionRectangleShape This method de-projects items based on the Projection of the FeatureSource.
ConvertToInternalProjectionIEnumerable<RectangleShape> This method de-projects items based on the Projection of the FeatureSource.
ConvertToInternalProjectionBaseShape This method de-projects items based on the Projection of the FeatureSource.
ConvertToInternalProjectionIEnumerable<Feature> This method de-projects items based on the Projection of the FeatureSource.
ConvertToInternalProjectionFeature This method de-projects items based on the Projection of the FeatureSource.
ConvertToInternalProjectionCallRectangleShape
ExecuteNonQueryCoreString Executes a SQL statement against a connection object.
ExecuteQueryCoreString Executes the query and returns the result returned by the query.
ExecuteScalarCoreString Executes the query and returns the first column of the first row in the result set returned by the query. All other columns and rows are ignored.
Finalize Object
GetAllFeaturesCoreIEnumerable<String> This method returns all of the InternalFeatures in the FeatureSource.
GetAllFeaturesCoreIEnumerable<String>,Int32,Int32
GetBoundingBoxByIdCoreString
GetBoundingBoxCore This method returns the bounding box which encompasses all of the features in the FeatureSource.
GetColumnNameAliasString,ICollection<String>
GetColumnNamesInsideFeatureSourceIEnumerable<String> This method returns the field names that are in the FeatureSource from a list of provided field names.
GetColumnNamesOutsideFeatureSourceIEnumerable<String> This method returns the field names that are not in the FeatureSource from a list of provided field names.
GetColumnNamesOutsideFeatureSourceCallIEnumerable<String>
GetColumnsCore This method returns the columns available for the FeatureSource.
GetCountCore This method returns the count of the number of records in this FeatureSource.
GetDistinctColumnValuesCoreString
GetFeaturesByActionWithStyleFiltersIEnumerable<String>,IEnumerable<String>,ZoomLevel,Func<Collection<Feature»,IEnumerable<String>,RectangleShape
GetFeaturesByColumnValueCoreString,String,IEnumerable<String> Get all of the features by passing a columnName and a specified columValue.
GetFeaturesByIdsCoreIEnumerable<String>,IEnumerable<String> This method returns a collection of InternalFeatures by providing a group of Ids.
GetFeaturesForDrawingCoreRectangleShape,Double,Double,IEnumerable<String> This method returns the InternalFeatures that will be used for drawing.
GetFeaturesInsideBoundingBoxCoreRectangleShape,IEnumerable<String> This method returns all of the InternalFeatures of this FeatureSource that are inside of the specified bounding box.
GetFeaturesNearestFromCollection<Feature>,BaseShape,GeographyUnit,Int32
GetFeaturesNearestToCoreBaseShape,GeographyUnit,Int32,IEnumerable<String> This method returns a user defined number of InternalFeatures that are closest to the TargetShape.
GetFeaturesOutsideBoundingBoxCoreRectangleShape,IEnumerable<String> This method returns all of the InternalFeatures of this FeatureSource outside of the specified bounding box.
GetFeaturesWithinDistanceOfCoreBaseShape,GeographyUnit,DistanceUnit,Double,IEnumerable<String> This method returns a collection of InternalFeatures that are within a certain distance of the TargetShape.
GetFirstFeaturesWellKnownTypeCore This method returns the well known type that represents the first feature from FeatureSource.
GetFlatLinkSources
GetRequiredColumnNamesForLinkIEnumerable<String>
GetReturningColumnNamesReturningColumnsType Get returning columnNames according to the returningColumnType.
GetReturningColumnNamesForLinkIEnumerable<String>,IEnumerable<String>
GetWrappingFeaturesLeftRectangleShape,Double,Double,IEnumerable<String>,RectangleShape
GetWrappingFeaturesRightRectangleShape,Double,Double,IEnumerable<String>,RectangleShape
HasComplicateFieldsIEnumerable<String>
MemberwiseClone Object
OnAppliedFiltersAppliedFiltersFeatureSourceEventArgs
OnApplyingFiltersApplyingFiltersFeatureSourceEventArgs
OnClosedFeatureSourceClosedFeatureSourceEventArgs This method allows you to raise the ClosedFeatureSource event from a derived class.
OnClosingFeatureSourceClosingFeatureSourceEventArgs This method allows you to raise the ClosingFeatureSource event from a derived class.
OnCommittedTransactionCommittedTransactionEventArgs This method allows you to raise the CommittedTransaction event from a derived class.
OnCommittingTransactionCommittingTransactionEventArgs This method allows you to raise the CommittingTransaction event from a derived class.
OnCustomColumnFetchCustomColumnFetchEventArgs This method allows you to raise the CustomColumnFetch event from a derived class.
OnDrawingProgressChangedDrawingProgressChangedEventArgs
OnGettingColumnsGettingColumnsFeatureSourceEventArgs
OnGettingFeaturesByIdsGettingFeaturesByIdsFeatureSourceEventArgs
OnGettingFeaturesForDrawingGettingFeaturesForDrawingFeatureSourceEventArgs
OnGottenColumnsGottenColumnsFeatureSourceEventArgs
OnOpenedFeatureSourceOpenedFeatureSourceEventArgs This method allows you to raise the OpenedFeatureSource event from a derived class.
OnOpeningFeatureSourceOpeningFeatureSourceEventArgs This method allows you to raise the OpeningFeatureSource event from a derived class.
OpenCore This method opens the FeatureSource so that it is initialized and ready to use.
ProcessTransactionRectangleShape,Collection<Feature>,Boolean
RaiseCustomColumnFetchEventCollection<Feature>,Collection<String>,Boolean
RemoveEmptyAndExcludeFeaturesCollection<Feature>
ReplaceColumnValuesCollection<Feature>,IEnumerable<String>
SpatialQueryCoreBaseShape,QueryType,IEnumerable<String> This method returns all of the InternalFeatures based on the target Feature and the spatial query type specified.
SplitColumnNamesIEnumerable<String> This method will split the column names based on our column syntax.
SplitColumnNamesCallIEnumerable<String>
CanExecuteSqlQueryBoolean This property specifies whether the FeatureSource can excute a SQL query or not. If it is false, then it will throw exception when these APIs are calleds: ExecuteScalar, ExecuteNonQuery, ExecuteQuery
CanModifyColumnStructureBoolean
FeatureIdsToExcludeCollection<String> A collection of strings representing record id of features not to get in the Layer.
FiltersCollection<String>
GeoCacheFeatureCache The cache system.
GeometryValidationModeGeometryValidationMode
IdString
IsEditableBoolean This property returns whether the FeatureSource allows edits or is read-only.
IsInTransactionBoolean This property returns true if the FeatureSource is in a transaction and false if it is not.
IsOpenBoolean This property returns true if the FeatureSource is open and false if it is not.
IsTransactionLiveBoolean This property returns true if the features currently modified in a transaction are expected to reflect their state when calling other methods on the FeatureSource, such as spatial queries.
LinkExpressionsCollection<String>
LinkSourcesCollection<LinkSource>
MaxRecordsToDrawInt32
ProjectionProjection This property holds the projection object that is used within the FeatureSource to ensure that features inside of the FeatureSource are projected.
TransactionBufferTransactionBuffer The TransactionBuffer used in the Transaction System.
CanExecuteSqlQueryCoreBoolean This property specifies whether the FeatureSource can excute a SQL query or not. If it is false, then it will throw exception when these APIs are calleds: ExecuteScalar, ExecuteNonQuery, ExecuteQuery
CanModifyColumnStructureCoreBoolean
FeatureSourceColumnsCollection<FeatureSourceColumn> This property gets the columns of the feature source.
IsOpenCoreBoolean This property returns true if the FeatureSource is open and false if it is not.
ClosedFeatureSourceClosedFeatureSourceEventArgs This event is called after the closing of the FeatureSource.
ClosingFeatureSourceClosingFeatureSourceEventArgs This event is called before the closing of the FeatureSource.
CommittedTransactionCommittedTransactionEventArgs This event is raised after the CommitTransaction and the CommitTransactionCore are called and allows you access to the TransactionBuffer and the TransactionResults object before CommitTransaction method is returned.
CommittingTransactionCommittingTransactionEventArgs This event is raised after the CommitTransaction method is called, but before the CommitTransactionCore is called. This allows you access to the TransactionBuffer before the transaction is committed. It also allows you to cancel the pending commit of the transaction.
CustomColumnFetchCustomColumnFetchEventArgs This event is raised when fields are requested in a feature source method that do not exist in the feature source. It allows you to supplement the data from any outside source you have.
OpenedFeatureSourceOpenedFeatureSourceEventArgs This event is called after the opening of the FeatureSource.
OpeningFeatureSourceOpeningFeatureSourceEventArgs This event is called before the opening of the FeatureSource.
FeatureSource()
As this method is protected, you may only add code to this method if you override it from an inheriting class.
Name Type Description
Go Back
AddColumn(FeatureSourceColumn)
Return Type Description
Void
featureSourceColumnFeatureSourceColumn
Go Back
AddFeature(Feature)
This method adds a new Feature to an existing transaction. You will need to ensure that you have started a transaction by calling BeginTransaction. The Transaction System The transaction system of a FeatureSource sits on top of the inherited implementation of any specific source, such as Oracle Spatial or Shape files. In this way, it functions the same way for every FeatureSource. You start by calling BeginTransaction. This allocates a collection of in-memory change buffers that are used to store changes until you commit the transaction. So, for example, when you call the Add, Delete or Update method, the changes to the feature are stored in memory only. If for any reason you choose to abandon the transaction, you can call RollbackTransaction at any time and the in-memory buffer will be deleted and the changes will be lost. When you are ready to commit the transaction, you call CommitTransaction and the collections of changes are then passed to the CommitTransactionCore method and the implementer of the specific FeatureSource is responsible for integrating your changes into the underlying FeatureSource. By default the IsLiveTransaction property is set to false, which means that until you commit the changes, the FeatureSource API will not reflect any changes that are in the temporary editing buffer. In the case where the IsLiveTransaction is set to true, then things function slightly differently. The live transaction concept means that all of the modifications you perform during a transaction are live from the standpoint of the querying methods on the object. As an example, imagine that you have a FeatureSource that has 10 records in it. Next, you begin a transaction and then call GetAllFeatures. The result would be 10 records. After that, you call a delete on one of the records and call the GetAllFeatures again. This time you only get nine records, even though the transaction has not yet been committed. In the same sense, you could have added a new record or modified an existing one and those changes would be considered live, though not committed. In the case where you modify records – such as expanding the size of a polygon – those changes are reflected as well. For example, you expand a polygon by doubling its size and then do a spatial query that would not normally return the smaller record, but instead would return the larger records. In this case, the larger records are returned. You can set this property to be false, as well; in which case, all of the spatially related methods would ignore anything that is currently in the transaction buffer waiting to be committed. In such a case, only after committing the transaction would the FeatureSource reflect the changes.
StringThis string is the ID that will uniquely identify this Feature while it is in a transaction.
featureFeatureThis parameter represents the new Feature that will be added to the transaction.
Go Back
AddFeature(BaseShape)
This method adds a new Feature (composed of the passed-in BaseShape) to an existing transaction. You will need to ensure that you have started a transaction by calling BeginTransaction. The Transaction System The transaction system of a FeatureSource sits on top of the inherited implementation of any specific source, such as Oracle Spatial or Shape files. In this way, it functions the same way for every FeatureSource. You start by calling BeginTransaction. This allocates a collection of in-memory change buffers that are used to store changes until you commit the transaction. So, for example, when you call the Add, Delete or Update method, the changes to the feature are stored in memory only. If for any reason you choose to abandon the transaction, you can call RollbackTransaction at any time and the in-memory buffer will be deleted and the changes will be lost. When you are ready to commit the transaction, you call CommitTransaction and the collections of changes are then passed to the CommitTransactionCore method and the implementer of the specific FeatureSource is responsible for integrating your changes into the underlying FeatureSource. By default the IsLiveTransaction property is set to false, which means that until you commit the changes, the FeatureSource API will not reflect any changes that are in the temporary editing buffer. In the case where the IsLiveTransaction is set to true, then things function slightly differently. The live transaction concept means that all of the modifications you perform during a transaction are live from the standpoint of the querying methods on the object. As an example, imagine that you have a FeatureSource that has 10 records in it. Next, you begin a transaction and then call GetAllFeatures. The result would be 10 records. After that, you call a delete on one of the records and call the GetAllFeatures again. This time you only get nine records, even though the transaction has not yet been committed. In the same sense, you could have added a new record or modified an existing one and those changes would be considered live, though not committed. In the case where you modify records – such as expanding the size of a polygon – those changes are reflected as well. For example, you expand a polygon by doubling its size and then do a spatial query that would not normally return the smaller record, but instead would return the larger records. In this case, the larger records are returned. You can set this property to be false, as well; in which case, all of the spatially related methods would ignore anything that is currently in the transaction buffer waiting to be committed. In such a case, only after committing the transaction would the FeatureSource reflect the changes.
shapeBaseShapeThis parameter represents the BaseShape that will be used to make the new Feature that will be added to the transaction.
Go Back
AddFeature(BaseShape,IDictionary<String,String>)
String
shapeBaseShape
columnValuesIDictionary<String,String>
Go Back
ApplyFilters(IEnumerable<Feature>,IEnumerable<String>,IEnumerable<String>)
Collection<Feature>
featuresIEnumerable<Feature>
returningColumnNamesIEnumerable<String>
filtersIEnumerable<String>
Go Back
BeginTransaction()
This method is used to start a transaction, assuming that the FeatureSource allows editing. There are some additional prerequisites to beginning a transaction, such as ensuring that a transaction is not already in progress. You must also be sure that the FeatureSource has been opened. The Transaction System The transaction system of a FeatureSource sits on top of the inherited implementation of any specific source, such as Oracle Spatial or Shape files. In this way, it functions the same way for every FeatureSource. You start by calling BeginTransaction. This allocates a collection of in-memory change buffers that are used to store changes until you commit the transaction. So, for example, when you call the Add, Delete or Update method, the changes to the feature are stored in memory only. If for any reason you choose to abandon the transaction, you can call RollbackTransaction at any time and the in-memory buffer will be deleted and the changes will be lost. When you are ready to commit the transaction, you call CommitTransaction and the collections of changes are then passed to the CommitTransactionCore method and the implementer of the specific FeatureSource is responsible for integrating your changes into the underlying FeatureSource. By default the IsLiveTransaction property is set to false, which means that until you commit the changes, the FeatureSource API will not reflect any changes that are in the temporary editing buffer. In the case where the IsLiveTransaction is set to true, then things function slightly differently. The live transaction concept means that all of the modifications you perform during a transaction are live from the standpoint of the querying methods on the object. As an example, imagine that you have a FeatureSource that has 10 records in it. Next, you begin a transaction and then call GetAllFeatures. The result would be 10 records. After that, you call a delete on one of the records and call the GetAllFeatures again. This time you only get nine records, even though the transaction has not yet been committed. In the same sense, you could have added a new record or modified an existing one and those changes would be considered live, though not committed. In the case where you modify records – such as expanding the size of a polygon – those changes are reflected as well. For example, you expand a polygon by doubling its size and then do a spatial query that would not normally return the smaller record, but instead would return the larger records. In this case, the larger records are returned. You can set this property to be false, as well; in which case, all of the spatially related methods would ignore anything that is currently in the transaction buffer waiting to be committed. In such a case, only after committing the transaction would the FeatureSource reflect the changes.
VoidNone
Go Back
CanGetBoundingBoxQuickly()
Boolean
Go Back
CanGetCountQuickly()
Boolean
Go Back
CloneDeep()
FeatureSourceA cloned FeatureSource.
Go Back
Close()
This method is the concrete wrapper for the abstract method CloseCore. The Close method plays an important role in the life cycle of the FeatureSource. It may be called after drawing to release any memory and other resources that were allocated since the Open method was called. If you override the Core version of this method, it is recommended that you take the following things into account: This method may be called multiple times, so we suggest you write the method so that that a call to a closed FeatureSource is ignored and does not generate an error. We also suggest that in the Close you free all resources that have been opened. Remember that the object will not be destroyed, but will be re-opened possibly in the near future. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
VoidNone
Go Back
CommitTransaction()
This method is the concrete wrapper for the virtual method CommitTransactionCore. As this is the concrete version, the real work is done in the Core version of the method. It will commit the existing transaction to its underlying source of data. It will then pass back the results of the commit, including any error(s) received. Lastly, it will free up the internal memory cache of any InternalFeatures added, updated or deleted. You will need to ensure that you have started a transaction by calling BeginTransaction.The Transaction SystemThe transaction system of a FeatureSource sits on top of the inherited implementation of any specific source, such as Oracle Spatial or Shape files. In this way, it functions the same way for every FeatureSource. You start by calling BeginTransaction. This allocates a collection of in-memory change buffers that are used to store changes until you commit the transaction. So, for example, when you call the Add, Delete or Update method, the changes to the feature are stored in memory only. If for any reason you choose to abandon the transaction, you can call RollbackTransaction at any time and the in-memory buffer will be deleted and the changes will be lost. When you are ready to commit the transaction, you call CommitTransaction and the collections of changes are then passed to the CommitTransactionCore method and the implementer of the specific FeatureSource is responsible for integrating your changes into the underlying FeatureSource. By default the IsLiveTransaction property is set to false, which means that until you commit the changes, the FeatureSource API will not reflect any changes that are in the temporary editing buffer.In the case where the IsLiveTransaction is set to true, then things function slightly differently. The live transaction concept means that all of the modifications you perform during a transaction are live from the standpoint of the querying methods on the object.As an example, imagine that you have a FeatureSource that has 10 records in it. Next, you begin a transaction and then call GetAllFeatures. The result would be 10 records. After that, you call a delete on one of the records and call the GetAllFeatures again. This time you only get nine records, even though the transaction has not yet been committed. In the same sense, you could have added a new record or modified an existing one and those changes would be considered live, though not committed.In the case where you modify records – such as expanding the size of a polygon – those changes are reflected as well. For example, you expand a polygon by doubling its size and then do a spatial query that would not normally return the smaller record, but instead would return the larger records. In this case, the larger records are returned. You can set this property to be false, as well; in which case, all of the spatially related methods would ignore anything that is currently in the transaction buffer waiting to be committed. In such a case, only after committing the transaction would the FeatureSource reflect the changes. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
TransactionResultThe returned decimalDegreesValue of this method is a TransactionResult class, which gives you the status of the transaction you just committed. It includes how many of the updates, adds, and deletes were successful and any errors that were encountered during the committing of the transaction.
Go Back
DeleteColumn(String)
Void
columnNameString
Go Back
DeleteFeature(String)
This method deletes a Feature from an existing transaction. You will need to ensure that you have started a transaction by calling the BeginTransaction. The Transaction System The transaction system of a FeatureSource sits on top of the inherited implementation of any specific source, such as Oracle Spatial or Shape files. In this way, it functions the same way for every FeatureSource. You start by calling BeginTransaction. This allocates a collection of in-memory change buffers that are used to store changes until you commit the transaction. So, for example, when you call the Add, Delete or Update method, the changes to the feature are stored in memory only. If for any reason you choose to abandon the transaction, you can call RollbackTransaction at any time and the in-memory buffer will be deleted and the changes will be lost. When you are ready to commit the transaction, you call CommitTransaction and the collections of changes are then passed to the CommitTransactionCore method and the implementer of the specific FeatureSource is responsible for integrating your changes into the underlying FeatureSource. By default the IsLiveTransaction property is set to false, which means that until you commit the changes, the FeatureSource API will not reflect any changes that are in the temporary editing buffer. In the case where the IsLiveTransaction is set to true, then things function slightly differently. The live transaction concept means that all of the modifications you perform during a transaction are live from the standpoint of the querying methods on the object. As an example, imagine that you have a FeatureSource that has 10 records in it. Next, you begin a transaction and then call GetAllFeatures. The result would be 10 records. After that, you call a delete on one of the records and call the GetAllFeatures again. This time you only get nine records, even though the transaction has not yet been committed. In the same sense, you could have added a new record or modified an existing one and those changes would be considered live, though not committed. In the case where you modify records – such as expanding the size of a polygon – those changes are reflected as well. For example, you expand a polygon by doubling its size and then do a spatial query that would not normally return the smaller record, but instead would return the larger records. In this case, the larger records are returned. You can set this property to be false, as well; in which case, all of the spatially related methods would ignore anything that is currently in the transaction buffer waiting to be committed. In such a case, only after committing the transaction would the FeatureSource reflect the changes.
VoidNone
idStringThis string is the Id of the feature in the FeatureSource you wish to delete.
Go Back
Boolean
objObject
Go Back
ExecuteNonQuery(String)
You can use ExecuteNonQuery to perform catalog operations (for example, querying the structure of a database or creating database objects such as tables), or to change the data in a database by executing UPDATE, INSERT, or DELETE statements. Although ExecuteNonQuery does not return any rows, any output parameters or return values mapped to parameters are populated with data. For UPDATE, INSERT, and DELETE statements, the return value is the number of rows affected by the command.
Int32The number of rows affected.
sqlStatementStringThe sqlStatement to be excuted.
Go Back
ExecuteQuery(String)
Use the ExcuteScalar method to retrieve a single value from the database. This requires less code than using the ExcuteQuery method and then performing the operations necessary to generate the single value using the data.
DataTableThe result set in the format of dataTable.
Go Back
ExecuteScalar(String)
ObjectThe first column of the first row in the result set.
Go Back
GetAllFeatures(IEnumerable<String>)
This method returns all of the InternalFeatures in the FeatureSource. It will return whatever is returned by the GetAllFeaturesCore method, along with any of the additions or subtractions made if you are in a transaction and that transaction is configured to be live. The main purpose of this method is to be the anchor of all of our default virtual implementations within this class. We as the framework developers wanted to provide you the user with as much default virtual implementation as possible. To do this, we needed a way to get access to all of the features. For example, let's say we want to create a default implementation for finding all of the InternalFeatures in a bounding box. Because this is an abstract class, we do not know the specifics of the underlying data or how its spatial indexes work. What we do know is that if we get all of the records, then we can brute-force the answer. In this way, if you inherited from this class and only implemented this one method, we can provide default implementations for virtually every other API. While this is nice for you the developer if you decide to create your own FeatureSource, it comes with a price: namely, it is very inefficient. In the example we just discussed (about finding all of the InternalFeatures in a bounding box), we would not want to look at every record to fulfil this method. Instead, we would want to override the GetFeaturesInsideBoundingBoxCore and implement specific code that would be faster. For example, in Oracle Spatial there is a specific SQL statement to perform this operation very quickly. The same holds true with other specific FeatureSource examples. Most default implementations in the FeatureSource call the GetFeaturesInsideBoundingBoxCore, which by default calls the GetAllFeaturesCore. It is our advice that if you create your own FeatureSource that you ALWAYS override the GetFeatureInsideBoundingBox. This will ensure that nearly every other API will operate efficiently. Please see the specific API to determine what method it uses. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
Collection<Feature>The returned decimalDegreesValue is a collection of all of the InternalFeatures in the FeatureSource.
returningColumnNamesIEnumerable<String>This parameter allows you to select the field names of the column data you wish to return with each Feature.
Go Back
returningColumnNamesTypeReturningColumnsTypeThis parameter allows you to select a type from the ReturningColumnsType that you wish to return with each Feature.
Go Back
GetAllFeatures(ReturningColumnsType,Int32)
Collection<Feature>
returningColumnTypesReturningColumnsType
startIndexInt32
Go Back
GetAllFeatures(ReturningColumnsType,Int32,Int32)
Collection<Feature>
startIndexInt32
takeCountInt32
Go Back
GetAllFeatures(IEnumerable<String>,Int32,Int32)
Collection<Feature>
startIndexInt32
takeCountInt32
Go Back
GetBoundingBox()
This method is the concrete wrapper for the virtual method GetBoundingBoxCore. It will return whatever is returned by the GetBoundingBoxCore method, along with any additions or subtractions made if you are in a transaction and that transaction is configured to be live. To determine what the default implementation of the abstract GetBoundingBoxCore method is, please see the documentation for it. The default implementation of GetBoundingBoxCore uses the GetAllRecordsCore method to calculate the bounding box of the FeatureSource. We strongly recommend that you provide your own implementation for this method that will be more efficient. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
RectangleShapeThis method returns the bounding box which encompasses all of the features in the FeatureSource.
Go Back
GetBoundingBoxById(String)
This method returns a bounding box by providing an Id. The internal implementation calls the GetFeaturesByIdsCore and only passes one Id in the collection. That method in turn calls the GetAllFeaturesCore. Because of this, if you want a more efficient version of this method, then we highly suggest you override the GetFeaturesByIdsCore method and provide a fast way to find a group of InternalFeatures by their Id.
RectangleShapeThis method returns a bounding box based on the InternalFeatures Id specified.
idStringThis parameter represents the Id for the InternalFeatures whose bounding box you want.
Go Back
GetBoundingBoxByIds(IEnumerable<String>)
This method returns a bounding boxes by providing a goupd of Ids. The internal implementation calls the GetFeaturesByIdsCore. That method in turn calls the GetAllFeaturesCore. Because of this, if you want a more efficient version of this method, then we highly suggest you override the GetFeaturesByIdsCore method and provide a fast way to find a group of InternalFeatures by their Id.
RectangleShapeThis method returns a collection of bounding boxes based on the Feature Ids specified.
idsIEnumerable<String>This parameter represents the group of Ids for the InternalFeatures whose bounding boxes you want.
Go Back
GetBoundingBoxesByIds(IEnumerable<String>)
Collection<RectangleShape>This method returns a collection of bounding boxes based on the Feature Ids specified.
Go Back
GetColumns()
As this is the concrete method wrapping the GetColumnsCore, it is important to note that this method will cache the results to GetColumnsCore. What this means is that the first time this method is called it will call GetCollumnsCore, which is protected, and cache the results. The next time this method is called it will not call GetColumnsCore again. This was done to increase speed, as this is a critical method that is used very often in the internal code of the class. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
Collection<FeatureSourceColumn>This method returns the columns available for the FeatureSource.
Go Back
GetCount()
This method is the concrete wrapper for the virtual method GetCountCore. It will return whatever is returned by the GetCountCore method, along with any additions or subtractions made if you are in a transaction and that transaction is configured to be live. To determine what the default implementation of the abstract GetCountCore method is, please see the documentation for it. The default implementation of GetCountCore uses the GetAllRecordsCore method to calculate how many records there are in the FeatureSource. We strongly recommend that you provide your own implementation for this method that will be more efficient. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
Int32This method returns the count of the number of records in this FeatureSource.
Go Back
GetDistinctColumnValues(String)
Collection<DistinctColumnValue>
columnNameString
Go Back
GetFeatureById(String,IEnumerable<String>)
This method returns a collection of InternalFeatures by providing a group of Ids. The internal implementation calls the GetFeaturesByIdsCore and only passes one Id in the collection. That method in turn calls the GetAllFeaturesCore. Because of this, if you want a more efficient version of this method, we highly suggest you override the GetFeaturesByIdsCore method and provide a fast way to find a group of InternalFeatures by their Id.
FeatureThis method returns a Feature by providing its Id in the FeatureSource.
idStringThis parameter is the Id which uniquely identifies it in the FeatureSource.
Go Back
GetFeatureById(String,ReturningColumnsType)
This method returns a collection of InternalFeatures by providing a group of Ids. The internal implementation calls the GetFeaturesByIdsCore and only passes one Id in the collection. That method in turn calls the GetAllFeaturesCore. Because of this, if you want a more efficient version of this method, then we highly suggest you override the GetFeaturesByIdsCore method and provide a fast way to find a group of InternalFeatures by their Id.
Go Back
GetFeaturesByColumnValue(String,String,ReturningColumnsType)
Collection<Feature>The returnning features matches the columnValue.
columnNameStringThe specified columnName to match the columnValue.
columnValueStringThe specified columnValue to match those returning features.
returningColumnTypeReturningColumnsTypeThis parameter allows you to select a type from the ReturningColumnsType that you wish to return with each Feature.
Go Back
GetFeaturesByColumnValue(String,String,IEnumerable<String>)
Go Back
GetFeaturesByColumnValue(String,String)
Go Back
GetFeaturesByIds(IEnumerable<String>,ReturningColumnsType)
This method returns a collection of InternalFeatures by providing a group of Ids. The internal implementation calls the GetFeaturesByIdsCore. That method in turn calls the GetAllFeaturesCore. Because of this, if you want a more efficient version of this method, then we highly suggest you override the GetFeaturesByIdsCore method and provide a fast way to find a group of InternalFeatures by their Id. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
Collection<Feature>This method returns a collection of InternalFeatures by providing a group of Ids.
idsIEnumerable<String>This parameter represents the group of Ids which uniquely identifies the InternalFeatures in the FeatureSource.
Go Back
GetFeaturesByIds(IEnumerable<String>,IEnumerable<String>)
Go Back
GetFeaturesByIds(IEnumerable<String>,IEnumerable<String>,IEnumerable<String>)
Collection<Feature>
Go Back
GetFeaturesForDrawing(RectangleShape,Double,Double,IEnumerable<String>)
This method returns all of the InternalFeatures of this FeatureSource that are inside of the specified bounding box. If you are in a transaction and that transaction is live, this method will also take that into consideration. The default implementation of GetFeaturesForDrawing uses the GetFeaturesInsodeBoundingBoxCore with some optimizations based on the screen width and height. For example, we can determine if a feature is going to draw in only one to four pixels and in that case we may not draw the entire feature but just a subset of it instead. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
Collection<Feature>This method returns the InternalFeatures that will be used for drawing.
boundingBoxRectangleShapeThis parameter is the bounding box of the InternalFeatures you want to draw.
screenWidthDoubleThis parameter is the width of the canvas, in screen pixels, that you will draw on.
screenHeightDoubleThis parameter is the height of the canvas, in screen pixels, that you will draw on.
Go Back
GetFeaturesForDrawing(RectangleShape,Double,Double,IEnumerable<String>,IEnumerable<String>)
Collection<Feature>
screenWidthDouble
screenHeightDouble
Go Back
GetFeaturesForDrawing(RectangleShape,Double,Double,ReturningColumnsType)
boundingBoxRectangleShapeThis parameter is the bounding box of the InternalFeatures that you want to draw.
returningColumnNamesTypeReturningColumnsTypeThis parameter allows you to select a type from the ReturningColumnsType you wish to return with each Feature.
Go Back
GetFeaturesInsideBoundingBox(RectangleShape,ReturningColumnsType)
This method returns all of the InternalFeatures of this FeatureSource inside of the specified bounding box. If you are in a transaction and that transaction is live, this method will also take that into consideration. The default implementation of GetFeaturesInsideBoundingBoxCore uses the GetAllRecordsCore method to determine which InternalFeatures are inside of the bounding box. We strongly recommend that you provide your own implementation for this method that will be more efficient. That is especially important for this method, as many other default virtual methods use this for their calculations. When you override this method, we highly recommend that you use any spatial indexes you have at your disposal to make this method as fast as possible. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
Collection<Feature>The returned decimalDegreesValue is a collection of all of the InternalFeatures that are inside of the bounding box.
boundingBoxRectangleShapeThis parameter represents the bounding box that you wish to find InternalFeatures inside of.
Go Back
GetFeaturesInsideBoundingBox(RectangleShape,IEnumerable<String>,IEnumerable<String>)
Collection<Feature>
Go Back
GetFeaturesInsideBoundingBox(RectangleShape,IEnumerable<String>)
This method returns all of the InternalFeatures of this FeatureSource inside of the specified bounding box. If you are in a transaction and that transaction is live, this method will also take that into consideration. The default implementation of GetFeaturesInsideBoundingBoxCore uses the GetAllRecordsCore method to determine which InternalFeatures are inside of the bounding box. We strongly recommend that you provide your own implementation for this method that will be more efficient. That is especially important for this method, as many other default virtual methods use this for their calculations. When you override this method, we recommend that you use any spatial indexes you have at your disposal to make this method as fast as possible. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
Go Back
GetFeaturesNearestTo(Feature,GeographyUnit,Int32,IEnumerable<String>)
This method returns a user defined number of InternalFeatures that are closest to the TargetShape. It is important to note that the TargetShape and the FeatureSource must use the same unit, such as feet or meters. If they do not, then the results will not be predictable or correct. If there is a current transaction and it is marked as live, then the results will include any transaction Feature that applies. The implementation we provided creates a small bounding box around the TargetShape and then queries the features inside of it. If we reach the number of items to find, then we measure the returned InternalFeatures to find the nearest. If we do not find enough records, we scale up the bounding box and try again. As you can see, this is not the most efficient method. If your underlying data provider exposes a more efficient way, we recommend you override the Core version of this method and implement it. The default implementation of GetFeaturesNearestCore uses the GetFeaturesInsideBoundingBoxCore method for speed. We strongly recommend that you provide your own implementation for this method that will be more efficient. When you override GetFeaturesInsideBoundingBoxCore method, we recommend that you use any spatial indexes you have at your disposal to make this method as fast as possible. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
Collection<Feature>This method returns a user defined number of InternalFeatures that are closest to the TargetShape.
targetFeatureFeatureThis parameter is the feature you want to find InternalFeatures close to.
unitOfDataGeographyUnitThis parameter is the unit of measurement that the TargetShape and the FeatureSource are in, such as feet, meters, etc.
maxItemsToFindInt32This parameter defines how many close InternalFeatures to find around the TargetShape.
Go Back
GetFeaturesNearestTo(Feature,GeographyUnit,Int32,IEnumerable<String>,Double,DistanceUnit)
targetFeatureFeatureThis parameter is feature you want to find InternalFeatures close to.
searchRadiusDoubleLimit the maximize distance proximately to search closest records.
unitOfSearchRadiusDistanceUnitThe unit of distanceLimits parameter.
Go Back
GetFeaturesNearestTo(BaseShape,GeographyUnit,Int32,IEnumerable<String>,Double,DistanceUnit)
targetShapeBaseShapeThis parameter is the shape you want to find InternalFeatures close to.
unitOfSearchRadiusDistanceUnitThe unit of searchRadius parameter.
Go Back
GetFeaturesNearestTo(Feature,GeographyUnit,Int32,ReturningColumnsType)
targetFeatureFeatureThis parameter is the target feature you want to find InternalFeatures close to.
Go Back
GetFeaturesNearestTo(BaseShape,GeographyUnit,Int32,ReturningColumnsType)
Go Back
GetFeaturesNearestTo(BaseShape,GeographyUnit,Int32,IEnumerable<String>)
unitOfFeatureSourceGeographyUnitThis parameter is the unit of measurement that the TargetShape and the FeatureSource are in, such as feet, meters, etc.
Go Back
GetFeaturesOutsideBoundingBox(RectangleShape,IEnumerable<String>)
This method returns all of the InternalFeatures of this FeatureSource outside of the specified bounding box. If you are in a transaction and that transaction is live, this method will also take that into consideration. The default implementation of GetFeaturesOutsideBoundingBoxCore uses the GetAllRecordsCore method to determine which InternalFeatures are outside of the bounding box. We strongly recommend that you provide your own implementation for this method that will be more efficient. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
Collection<Feature>This method returns all of the InternalFeatures of this FeatureSource outside of the specified bounding box.
boundingBoxRectangleShapeThis parameter represents the bounding box that you wish to find InternalFeatures outside of.
Go Back
GetFeaturesOutsideBoundingBox(RectangleShape,ReturningColumnsType)
Go Back
GetFeaturesWithinDistanceOf(Feature,GeographyUnit,DistanceUnit,Double,IEnumerable<String>)
This method returns a collection of InternalFeatures that are within a certain distance of the TargetShape. It is important to note that the TargetShape and the FeatureSource must use the same unit, such as feet or meters. If they do not, then the results will not be predictable or correct. If there is a current transaction and it is marked as live, then the results will include any transaction Feature that applies. The implementation we provided creates a bounding box around the TargetShape using the distance supplied and then queries the features inside of it. This may not be the most efficient method for this operation. If your underlying data provider exposes a more efficient way, we recommend you override the Core version of this method and implement it. The default implementation of GetFeaturesWithinDistanceOfCore uses the GetFeaturesInsideBoundingBoxCore method for speed. We strongly recommend that you provide your own implementation for this method that will be more efficient. When you override GetFeaturesInsideBoundingBoxCore method, we recommend that you use any spatial indexes you have at your disposal to make this method as fast as possible.
Collection<Feature>This method returns a collection of InternalFeatures that are within a certain distance of the TargetShape.
targetFeatureFeatureThe feature you wish to find InternalFeatures within a distance of.
unitOfDataGeographyUnitThis parameter is the unit of data that the FeatureSource and TargetShape are in.
distanceUnitDistanceUnitThis parameter specifies the measurement unit for the distance parameter, such as feet, miles, kilometers, etc.
distanceDoubleThis parameter specifies the distance in which to find InternalFeatures around the TargetShape.
Go Back
GetFeaturesWithinDistanceOf(BaseShape,GeographyUnit,DistanceUnit,Double,ReturningColumnsType)
targetShapeBaseShapeThe shape you wish to find InternalFeatures within a distance of.
Go Back
GetFeaturesWithinDistanceOf(BaseShape,GeographyUnit,DistanceUnit,Double,IEnumerable<String>)
This method returns a collection of InternalFeatures that are within a certain distance of the TargetShape. It is important to note that the TargetShape and the FeatureSource must use the same unit, such as feet or meters. If they do not, then the results will not be predictable or correct. If there is a current transaction and it is marked as live, then the results will include any transaction Feature that applies. The implementation we provided creates a bounding box around the TargetShape using the distance supplied and then queries the features inside of it. This may not be the most efficient method for this operation. If your underlying data provider exposes a more efficient way, we recommend you override the Core version of this method and implement it. The default implementation of GetFeaturesWithinDistanceOfCore uses the GetFeaturesInsideBoundingBoxCore method for speed. We strongly recommend that you provide your own implementation for this method that will be more efficient. When you override GetFeaturesInsideBoundingBoxCore method, we recommend that you use any spatial indexes you have at your disposal to make this method as fast as possible. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
Go Back
GetFeaturesWithinDistanceOf(Feature,GeographyUnit,DistanceUnit,Double,ReturningColumnsType)
Go Back
GetFirstFeaturesWellKnownType()
This method is the concrete wrapper for the virtual method GetFirstFeaturesWellKnownTypeCore. It will return whatever is returned by the GetFirstFeaturesWellKnownTypeCore method, along with any additions or subtractions made if you are in a transaction and that transaction is configured to be live. To determine what the default implementation of the abstract GetCountCore method is, please see the documentation for it. The default implementation of GetFirstFeaturesWellKnownTypeCore uses the GetAllFeaturesCore method to get WellKnownType of the first feature from all features. We strongly recommend that you provide your own implementation for this method that will be more efficient. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
WellKnownTypeThis method returns the well known type that represents the first feature from FeatureSource.
Go Back
Int32
Go Back
Type
Go Back
Open()
This method is the concrete wrapper for the abstract method OpenCore. The Open method plays an important role, as it is responsible for initializing the FeatureSource. Most methods on the FeatureSource will throw an exception if the state of the FeatureSource is not opened. When the map draws each layer, it will open the FeatureSource as one of its first steps, then after it is finished drawing with that layer it will close it. In this way we are sure to release all resources used by the FeatureSource. When implementing the abstract method, consider opening files for file-based sources, connecting to databases in the database-based sources and so on. You will get a chance to close these in the Close method of the FeatureSource. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
VoidNone
Go Back
RefreshColumns()
None.
VoidThis method refresh the columns available for the FeatureSource.
Go Back
RollbackTransaction()
This method will cancel an existing transaction. It will free up the internal memory cache of any InternalFeatures added, updated or deleted. You will need to ensure that you have started a transaction by calling BeginTransaction.The Transaction SystemThe transaction system of a FeatureSource sits on top of the inherited implementation of any specific source, such as Oracle Spatial or Shape files. In this way, it functions the same way for every FeatureSource. You start by calling BeginTransaction. This allocates a collection of in-memory change buffers that are used to store changes until you commit the transaction. So, for example, when you call the Add, Delete or Update method, the changes to the feature are stored in memory only. If for any reason you choose to abandon the transaction, you can call RollbackTransaction at any time and the in-memory buffer will be deleted and the changes will be lost. When you are ready to commit the transaction, you call CommitTransaction and the collections of changes are then passed to the CommitTransactionCore method and the implementer of the specific FeatureSource is responsible for integrating your changes into the underlying FeatureSource. By default the IsLiveTransaction property is set to false, which means that until you commit the changes, the FeatureSource API will not reflect any changes that are in the temporary editing buffer.In the case where the IsLiveTransaction is set to true, then things function slightly differently. The live transaction concept means that all of the modifications you perform during a transaction are live from the standpoint of the querying methods on the object.As an example, imagine that you have a FeatureSource that has 10 records in it. Next, you begin a transaction and then call GetAllFeatures. The result would be 10 records. After that, you call a delete on one of the records and call the GetAllFeatures again. This time you only get nine records, even though the transaction has not yet been committed. In the same sense, you could have added a new record or modified an existing one and those changes would be considered live, though not committed.In the case where you modify records – such as expanding the size of a polygon – those changes are reflected as well. For example, you expand a polygon by doubling its size and then do a spatial query that would not normally return the smaller record, but instead would return the larger records. In this case, the larger records are returned. You can set this property to be false, as well; in which case, all of the spatially related methods would ignore anything that is currently in the transaction buffer waiting to be committed. In such a case, only after committing the transaction would the FeatureSource reflect the changes.
VoidNone
Go Back
SpatialQuery(BaseShape,QueryType,IEnumerable<String>)
This method returns all of the InternalFeatures based on the target Feature and the spatial query type specified below. If there is a current transaction and it is marked as live, then the results will include any transaction Feature that applies.Spatial Query Types:Disjoint - This method returns InternalFeatures where the specific Feature and the targetShape have no points in common.Intersects - This method returns InternalFeatures where the specific Feature and the targetShape have at least one point in common.Touches - This method returns InternalFeatures where the specific Feature and the targetShape have at least one boundary point in common, but no interior points.Crosses - This method returns InternalFeatures where the specific Feature and the targetShape share some but not all interior points.Within - This method returns InternalFeatures where the specific Feature lies within the interior of the targetShape.Contains - This method returns InternalFeatures where the specific Feature lies within the interior of the current shape.Overlaps - This method returns InternalFeatures where the specific Feature and the targetShape share some but not all points in common.TopologicalEqual - This method returns InternalFeatures where the specific Feature and the target Shape are topologically equal. The default implementation of SpatialQueryCore uses the GetFeaturesInsideBoundingBoxCore method to pre-filter the spatial query. We strongly recommend that you provide your own implementation for this method that will be more efficient. When you override this method, we recommend that you use any spatial indexes you have at your disposal to make this method as fast as possible. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
Collection<Feature>The returned decimalDegreesValue is a collection of InternalFeatures that match the spatial query you executed based on the TargetShape.
targetShapeBaseShapeThis parameter specifies the target shape used in the spatial query.
queryTypeQueryTypeThis parameter specifies what kind of spatial query you wish to perform.
Go Back
SpatialQuery(Feature,QueryType,IEnumerable<String>)
featureFeatureThis parameter specifies the target feature used in the spatial query.
Go Back
SpatialQuery(Feature,QueryType,ReturningColumnsType)
Go Back
SpatialQuery(BaseShape,QueryType,ReturningColumnsType)
Collection<Feature>The return decimalDegreesValue is a collection of InternalFeatures that match the spatial query you executed based on the TargetShape.
Go Back
SpatialQuery(BaseShape,QueryType,IEnumerable<String>,IEnumerable<String>)
Collection<Feature>
queryTypeQueryType
Go Back
String
Go Back
UpdateColumn(String,FeatureSourceColumn)
Void
columnNameString
newFeatureSourceColumnFeatureSourceColumn
Go Back
UpdateFeature(BaseShape,IDictionary<String,String>)
Void
shapeBaseShape
Go Back
UpdateFeature(BaseShape)
This method updates a Feature (composed of the passed-in BaseShape) in an existing transaction.
This method updates a Feature (composed of the passed-in BaseShape) in an existing transaction. You will need to ensure that you have started a transaction by calling BeginTransaction.The Transaction SystemThe transaction system of a FeatureSource sits on top of the inherited implementation of any specific source, such as Oracle Spatial or Shape files. In this way, it functions the same way for every FeatureSource. You start by calling BeginTransaction. This allocates a collection of in-memory change buffers that are used to store changes until you commit the transaction. So, for example, when you call the Add, Delete or Update method, the changes to the feature are stored in memory only. If for any reason you choose to abandon the transaction, you can call RollbackTransaction at any time and the in-memory buffer will be deleted and the changes will be lost. When you are ready to commit the transaction, you call CommitTransaction and the collections of changes are then passed to the CommitTransactionCore method and the implementer of the specific FeatureSource is responsible for integrating your changes into the underlying FeatureSource. By default the IsLiveTransaction property is set to false, which means that until you commit the changes, the FeatureSource API will not reflect any changes that are in the temporary editing buffer.In the case where the IsLiveTransaction is set to true, then things function slightly differently. The live transaction concept means that all of the modifications you perform during a transaction are live from the standpoint of the querying methods on the object.As an example, imagine that you have a FeatureSource that has 10 records in it. Next, you begin a transaction and then call GetAllFeatures. The result would be 10 records. After that, you call a delete on one of the records and call the GetAllFeatures again. This time you only get nine records, even though the transaction has not yet been committed. In the same sense, you could have added a new record or modified an existing one and those changes would be considered live, though not committed.In the case where you modify records – such as expanding the size of a polygon – those changes are reflected as well. For example, you expand a polygon by doubling its size and then do a spatial query that would not normally return the smaller record, but instead would return the larger records. In this case, the larger records are returned. You can set this property to be false, as well; in which case, all of the spatially related methods would ignore anything that is currently in the transaction buffer waiting to be committed. In such a case, only after committing the transaction would the FeatureSource reflect the changes.
VoidNone
shapeBaseShapeThe shape that will be used to make the new Feature that you wish to update in the transaction.
Go Back
UpdateFeature(Feature)
This method updates a Feature in an existing transaction.
This method updates a Feature in an existing transaction. You will need to ensure that you have started a transaction by calling the BeginTransaction.The Transaction SystemThe transaction system of a FeatureSource sits on top of the inherited implementation of any specific source, such as Oracle Spatial or Shape files. In this way, it functions the same way for every FeatureSource. You start by calling BeginTransaction. This allocates a collection of in-memory change buffers that are used to store changes until you commit the transaction. So, for example, when you call the Add, Delete or Update method, the changes to the feature are stored in memory only. If for any reason you choose to abandon the transaction, you can call RollbackTransaction at any time and the in-memory buffer will be deleted and the changes will be lost. When you are ready to commit the transaction, you call CommitTransaction and the collections of changes are then passed to the CommitTransactionCore method and the implementer of the specific FeatureSource is responsible for integrating your changes into the underlying FeatureSource. By default the IsLiveTransaction property is set to false, which means that until you commit the changes, the FeatureSource API will not reflect any changes that are in the temporary editing buffer.In the case where the IsLiveTransaction is set to true, then things function slightly differently. The live transaction concept means that all of the modifications you perform during a transaction are live from the standpoint of the querying methods on the object.As an example, imagine that you have a FeatureSource that has 10 records in it. Next, you begin a transaction and then call GetAllFeatures. The result would be 10 records. After that, you call a delete on one of the records and call the GetAllFeatures again. This time you only get nine records, even though the transaction has not yet been committed. In the same sense, you could have added a new record or modified an existing one and those changes would be considered live, though not committed.In the case where you modify records – such as expanding the size of a polygon – those changes are reflected as well. For example, you expand a polygon by doubling its size and then do a spatial query that would not normally return the smaller record, but instead would return the larger records. In this case, the larger records are returned. You can set this property to be false, as well; in which case, all of the spatially related methods would ignore anything that is currently in the transaction buffer waiting to be committed. In such a case, only after committing the transaction would the FeatureSource reflect the changes.
Return Type Description
VoidNone
Name Type Description
featureFeatureThe Feature you wish to update in the transaction.
Go Back
ApplyFiltersCore(IEnumerable<Feature>,IEnumerable<String>,String)
Collection<Feature>
linkExpressionString
Go Back
ApplyLinkColumnValues(IEnumerable<Feature>,IEnumerable<String>,IEnumerable<String>,IEnumerable<String>)
Collection<Feature>
linkingColumnNamesIEnumerable<String>
Go Back
ApplyLinkColumnValues(IEnumerable<String>,Func<IEnumerable<String>,Collection<Feature>>,IEnumerable<String>)
Collection<Feature>
getFeaturesFunc<IEnumerable<String>,Collection<Feature»
Go Back
CanGetBoundingBoxQuicklyCore()
Boolean
Go Back
CanGetCountQuicklyCore()
Boolean
Go Back
CheckHasLinkColumns(IEnumerable<String>,IEnumerable<String>)
Boolean
Go Back
CheckIsLinkColumn(String)
Boolean
columnNameString
Go Back
CloneDeepCore()
Create a copy of a FeatureSource using the deep clone process. The default implementation uses serialization.
Go Back
CloseCore()
This method closes the FeatureSource and releases any resources it was using.
This protected virtual method is called from the concrete public method Close. The close method plays an important role in the life cycle of the FeatureSource. It may be called after drawing to release any memory and other resources that were allocated since the Open method was called. If you override this method, it is recommended that you take the following things into account: This method may be called multiple times, so we suggest you write the method so that that a call to a closed FeatureSource is ignored and does not generate an error. We also suggest that in the Close you free all resources that have been opened. Remember that the object will not be destroyed, but will be re-opened possibly in the near future.
VoidNone
Go Back
CombineFieldValues(Dictionary<String,String>,IEnumerable<String>)
columnValuesDictionary<String,String>
originalColumnNamesIEnumerable<String>
Go Back
CommitTransactionCore(TransactionBuffer)
This method will commit the existing transaction to its underlying source of data.
This method will commit the existing transaction to its underlying source of data. It will then pass back the results of the commit, including any error(s) received. If you are implementing your own FeatureSource, this is one of the crucial methods you must create. It should be fairly straightforward that you will loop through the transaction buffer and add, edit or delete the InternalFeatures in your underlying data source. Remember to build and pass back the TransactionResult class so that users of your FeatureSource can respond to failures you may encounter while committing the InternalFeatures. We will handle the end of the transaction and also the cleanup of the transaction buffer. Your task will be to commit the records and produce a TransactionResult return.The Transaction SystemThe transaction system of a FeatureSource sits on top of the inherited implementation of any specific source, such as Oracle Spatial or Shape files. In this way, it functions the same way for every FeatureSource. You start by calling BeginTransaction. This allocates a collection of in-memory change buffers that are used to store changes until you commit the transaction. So, for example, when you call the Add, Delete or Update method, the changes to the feature are stored in memory only. If for any reason you choose to abandon the transaction, you can call RollbackTransaction at any time and the in-memory buffer will be deleted and the changes will be lost. When you are ready to commit the transaction, you call CommitTransaction and the collections of changes are then passed to the CommitTransactionCore method and the implementer of the specific FeatureSource is responsible for integrating your changes into the underlying FeatureSource. By default the IsLiveTransaction property is set to false, which means that until you commit the changes, the FeatureSource API will not reflect any changes that are in the temporary editing buffer.In the case where the IsLiveTransaction is set to true, then things function slightly differently. The live transaction concept means that all of the modifications you perform during a transaction are live from the standpoint of the querying methods on the object.As an example, imagine that you have a FeatureSource that has 10 records in it. Next, you begin a transaction and then call GetAllFeatures. The result would be 10 records. After that, you call a delete on one of the records and call the GetAllFeatures again. This time you only get nine records, even though the transaction has not yet been committed. In the same sense, you could have added a new record or modified an existing one and those changes would be considered live, though not committed.In the case where you modify records – such as expanding the size of a polygon – those changes are reflected as well. For example, you expand a polygon by doubling its size and then do a spatial query that would not normally return the smaller record, but instead would return the larger records. In this case, the larger records are returned. You can set this property to be false, as well; in which case, all of the spatially related methods would ignore anything that is currently in the transaction buffer waiting to be committed. In such a case, only after committing the transaction would the FeatureSource reflect the changes.
TransactionResultThe returned decimalDegreesValue of this method is a TransactionResult class which gives you the status of the transaction you just committed. It includes how many of the updates, adds, and deletes were successful, as well as any error(s) that were encountered during the committing of the transaction.
transactionsTransactionBufferThis parameter encapsulates all of the adds, edits and deletes that make up the transaction. You will use this data to write the changes to your underlying data source.
Go Back
This method projects items based on the Projection of the FeatureSource.
This is a protected method that is intended to help developers who want to implement or extend one of our FeatureSources. It is important to note that projection, as a general rule, happens inside the non-Core methods and we usually take care of it. However, as a developer, if you wish to add a new public method, then you will need to handle the projection yourself. With these projection methods it is very easy to handle the projection and de-projection. Remember that when adding your own public methods you always de-project incoming shapes and alway project outgoing shapes. Also remember that the Core methods do not consider projection, and they assume the data being passed into them and out of them is the same unit as the underlying data. Example of a New Public Method: public Feature ProcessFeature(Feature incomingFeature) { Be sure that you use the FromProjection on the incomingFeatureParameter as the first thing you do in this method. Call a Core Method or do your own processing Be sure that you call the ToProjection on the return result of the method before you pass it out. }
RectangleShapeThis method projects a RectangleShape based on the Projection of the FeatureSource.
rectangleRectangleShapeThis parameter represents the rectangle you wish to project.
Go Back
ConvertToExternalProjection(Feature)
FeatureThis method projects a Feature based on the Projection of the FeatureSource.
featureFeatureThis parameter represents the Feature you wish to project.
Go Back
ConvertToExternalProjection(IEnumerable<Feature>)
Collection<Feature>This method projects a Feature based on the Projection of the FeatureSource.
featuresIEnumerable<Feature>This parameter represents a group of Features that you wish to project.
Go Back
ConvertToExternalProjection(IEnumerable<RectangleShape>)
Collection<RectangleShape>This method projects a Feature based on the Projection of the FeatureSource.
rectanglesIEnumerable<RectangleShape>This parameter represents a group of RectangleShapes that you wish to project.
Go Back
ConvertToExternalProjectionIfNecessary(Collection<Feature>)
Collection<Feature>
returnFeaturesCollection<Feature>
Go Back
ConvertToInternalProjection(RectangleShape)
This method de-projects items based on the Projection of the FeatureSource.
RectangleShapeThis method de-projects a RectangleShape based on the Projection of the FeatureSource.
rectangleRectangleShapeThis parameter represents the rectangle you wish to de-project.
Go Back
ConvertToInternalProjection(IEnumerable<RectangleShape>)
Collection<RectangleShape>This method de-projects a BaseShape based on the Projection of the FeatureSource.
rectanglesIEnumerable<RectangleShape>This parameter represents a group of RectangleShapes that you wish to de-project.
Go Back
BaseShapeThis method de-projects a BaseShape based on the Projection of the FeatureSource.
baseShapeBaseShapeThis parameter represents the BaseShape you wish to de-project.
Go Back
ConvertToInternalProjection(IEnumerable<Feature>)
Collection<Feature>This method de-projects a Feature based on the Projection of the FeatureSource.
featuresIEnumerable<Feature>This parameter represents the group of Features that you wish to de-project.
Go Back
ConvertToInternalProjection(Feature)
FeatureThis method de-projects a Feature based on the Projection of the FeatureSource.
featureFeatureThis parameter represents the Feature you wish to de-project.
Go Back
ConvertToInternalProjectionCall(RectangleShape)
RectangleShape
Go Back
ExecuteNonQueryCore(String)
Executes a SQL statement against a connection object.
Go Back
ExecuteQueryCore(String)
Executes the query and returns the result returned by the query.
Go Back
ExecuteScalarCore(String)
Executes the query and returns the first column of the first row in the result set returned by the query. All other columns and rows are ignored.
Go Back
Void
Go Back
GetAllFeaturesCore(IEnumerable<String>)
This method returns all of the InternalFeatures in the FeatureSource. You will not need to consider anything about pending transactions, as this will be handled in the non-Core version of the method. The main purpose of this method is to be the anchor of all of our default virtual implementations within this class. We as the framework developers wanted to provide you the user with as much default virtual implementation as possible. To do this, we needed a way to get access to all of the features. For example, let's say we want to create a default implementation for finding all of the InternalFeatures in a bounding box. Because this is an abstract class, we do not know the specifics of the underlying data or how its spatial indexes work. What we do know is that if we get all of the records, then we can brute-force the answer. In this way, if you inherited from this class and only implemented this one method, we can provide default implementations for virtually every other API. While this is nice for you the developer if you decide to create your own FeatureSource, it comes with a price: namely, it is very inefficient. In the example we just discussed (about finding all of the InternalFeatures in a bounding box), we would not want to look at every record to fulfil this method. Instead, we would want to override the GetFeaturesInsideBoundingBoxCore and implement specific code that would be faster. For example, in Oracle Spatial there is a specific SQL statement to perform this operation very quickly. The same holds true with other specific FeatureSource examples. Most default implementations in the FeatureSource call the GetFeaturesInsideBoundingBoxCore, which by default calls the GetAllFeaturesCore. It is our advice that if you create your own FeatureSource that you ALWAYS override the GetFeatureInsideBoundingBox. This will ensure that nearly every other API will operate efficiently. Please see the specific API to determine what method it uses.
Go Back
GetAllFeaturesCore(IEnumerable<String>,Int32,Int32)
Collection<Feature>
startIndexInt32
takeCountInt32
Go Back
GetBoundingBoxByIdCore(String)
RectangleShape
idString
Go Back
GetBoundingBoxCore()
This protected virtual method is called from the concrete public method GetBoundingBox. It does not take into account any transaction activity, as this is the responsibility of the concrete public method GetBoundingBox. In this way, as a developer, if you choose to override this method you do not have to consider transactions at all. The default implementation of GetBoundingBoxCore uses the GetAllRecordsCore method to calculate the bounding box of the FeatureSource. We strongly recommend that you provide your own implementation for this method that will be more efficient. If you do not override this method, it will get the BoundingBox by calling the GetAllFeatureCore method and deriving it from each feature. This is a very inefficient way to get the BoundingBox in most data sources. It is highly recommended that you override this method and replace it with a highly optimized version. For example, in a ShapeFile the BoundingBox is in the main header of the file. Similarly, if you are using Oracle Spatial, you can execute a simple query to get the BoundingBox of all the records without returning them. In these ways you can greatly improve the performance of this method.
Go Back
GetColumnNameAlias(String,ICollection<String>)
String
columnNameString
columnNamesICollection<String>
Go Back
GetColumnNamesInsideFeatureSource(IEnumerable<String>)
This method returns the field names that are in the FeatureSource from a list of provided field names.
This is a protected method that is intended to help developers who want to implement or extend one of our FeatureSources. It is important to note that, as a general rule, returning column data of a Feature or a set of InternalFeatures happens inside the non-Core methods and we usually take care of it. However, as a developer, if you wish to add a new public method, then you will need to handle the projection yourself. Let's say, for example, that you want to add a new Find method called FindLargeFeatures. You pass in a group of columns to return. Most of the time, the requested columns will actually be in the FeatureSource, but sometimes they will not. The way we allow users to get data from outside of the Feature Source is by raising an event called CustomColumnFetch. This way, we allow people to provide data that is outside of the FeatureSource. Since you will be implementing your own public method, you will want to support this as all of our other public methods do. When you first enter the public method, you will want to separate out the fields that are in the FeatureSource from those that are not. You can call this method and the GetColumnNamesOutsideFeatureSource. If inside your public method you need to call any of our Core methods, then you need to make sure that you only pass in the list of column names that are in the FeatureSource. We assume that Core methods are simple and they do not handle this complexity. With the list of non-FeatureSource column names, you simply loop through each column name for each record and call the OnCustomColumnFetch method while passing in the proper parameters. This will allow you give the user a chance to provide the values for the Feature's fields that were not in the FeatureSource. After that, you combine your results and pass them back out as the return. public Collection<Feature> FindLargeFeatures(double AreaSize, IEnumerable <string> columnsToReturn) {Step 1: Separate the columns that are in the FeatureSource from those that are not. Step 2: Call any Core Methods and only pass in the columns that are in the FeatureSourceStep3: For Each feature/column name combination, call the OnCustomFiedlFetch and allow your user to provide the custom data. Step4: Integrate the custom data with the result of the Core method plus any processing you did. Then return the consolidated result. }
Collection<String>This method returns the field names that are in the FeatureSource from a list of provided field names.
returningColumnNamesIEnumerable<String>This parameter is a list of column names, where not every field name may be in the FeatureSource.
Go Back
GetColumnNamesOutsideFeatureSource(IEnumerable<String>)
This method returns the field names that are not in the FeatureSource from a list of provided field names.
Collection<String>This method returns the field names that are not in the FeatureSource from a list of provided field names.
returningColumnNamesIEnumerable<String>This parameter is a list of field names, where not every field name may be in the FeatureSource.
Go Back
GetColumnNamesOutsideFeatureSourceCall(IEnumerable<String>)
Collection<String>
Go Back
GetColumnsCore()
As this is the virtual core version of the Columns method, it is intended to be overridden in inherited version of the class. When overriding, you will be responsible for getting a list of all of the columns supported by the FeatureSource. In this way, the FeatureSource will know what columns are available and will remove any extra columns when making calls to other core methods. For example, if you have a FeatureSource that has three columns of information and the user calls a method that requests four columns of information (something they can do with custom fields), we will first compare what they are asking for to the results of the GetColumnsCore. This way we can strip out custom columns before calling other Core methods, which are only responsible for returning data in the FeatureSource. For more information on custom fields, please see the documentation on OnCustomFieldsFetch.
Go Back
GetCountCore()
This protected virtual method is called from the concrete public method GetCount. It does not take into account any transaction activity, as this is the responsibility of the concrete public method GetCount. This way, as a developer, if you choose to override this method you do not have to consider transactions at all. The default implementation of GetCountCore uses the GetAllRecordsCore method to calculate how many records there are in the FeatureSource. We strongly recommend that you provide your own implementation for this method that will be more efficient. If you do not override this method, it will get the count by calling the GetAllFeatureCore method and counting each feature. This is a very inefficient way to get the count in most data sources. It is highly recommended that you override this method and replace it with a highly optimized version. For example, in a ShapeFile the record count is in the main header of the file. Similarly, if you are using Oracle Spatial, you can execute a simple query to get the count of all of the records without returning them. In these ways you can greatly improve the performance of this method.
Go Back
GetDistinctColumnValuesCore(String)
columnNameString
Go Back
GetFeaturesByActionWithStyleFilters(IEnumerable<String>,IEnumerable<String>,ZoomLevel,Func<Collection<Feature>>,IEnumerable<String>,RectangleShape)
Dictionary<String,Collection<Feature»
styleFiltersIEnumerable<String>
currentZoomLevelZoomLevel
funcFunc<Collection<Feature»
extentRectangleShape
Go Back
GetFeaturesByColumnValueCore(String,String,IEnumerable<String>)
Get all of the features by passing a columnName and a specified columValue.
Go Back
GetFeaturesByIdsCore(IEnumerable<String>,IEnumerable<String>)
This method returns a collection of InternalFeatures by providing a group of Ids. The internal implementation calls the GetAllFeaturesCore. Because of this, if you want a more efficient version of this method, then we highly suggest you override the GetFeaturesByIdsCore method and provide a fast way to find a group of InternalFeatures by their Id.
idsIEnumerable<String>This parameter represents the group of Ids which uniquely identified the InternalFeatures in the FeatureSource.
Go Back
GetFeaturesForDrawingCore(RectangleShape,Double,Double,IEnumerable<String>)
This method returns all of the InternalFeatures of this FeatureSource that are inside of the specified bounding box. If you are overriding this method you will not need to consider anything about transactions, as this is handled by the concrete version of this method. The default implementation of GetFeaturesForDrawingCore uses the GetFeaturesInsodeBoundingBoxCore with some optimizations based on the screen width and height. For example, we can determine if a feature is going to draw in only one to four pixels and in that case we may not draw the entire feature but just a subset of it instead.
returningColumnNamesIEnumerable<String>This parameter allows you to select the field names of the column data you wish to return with each Feature.
Go Back
GetFeaturesInsideBoundingBoxCore(RectangleShape,IEnumerable<String>)
This method returns all of the InternalFeatures of this FeatureSource that are inside of the specified bounding box. If you are overriding this method you will not need to consider anything about transactions, as this is handled by the concrete version of this method. The default implementation of GetFeaturesInsideBoundingBoxCore uses the GetAllRecordsCore method to determine which InternalFeatures are inside of the bounding box. We strongly recommend that you provide your own implementation for this method that will be more efficient. That is especially important for this method, as many other default virtual methods use this for their calculations. When you override this method, we highly recommend that you use any spatial indexes you have at your disposal to make this method as fast as possible.
returningColumnNamesIEnumerable<String>This parameter allows you to select the field names of the column data that you wish to return with each Feature.
Go Back
GetFeaturesNearestFrom(Collection<Feature>,BaseShape,GeographyUnit,Int32)
Collection<Feature>
possibleResultsCollection<Feature>
maxItemsToFindInt32
Go Back
GetFeaturesNearestToCore(BaseShape,GeographyUnit,Int32,IEnumerable<String>)
Go Back
GetFeaturesOutsideBoundingBoxCore(RectangleShape,IEnumerable<String>)
Go Back
GetFeaturesWithinDistanceOfCore(BaseShape,GeographyUnit,DistanceUnit,Double,IEnumerable<String>)
Go Back
GetFirstFeaturesWellKnownTypeCore()
This protected virtual method is called from the concrete public method GetFirstFeaturesWellKnownType. It does not take into account any transaction activity, as this is the responsibility of the concrete public method GetFirstFeaturesWellKnownType. This way, as a developer, if you choose to override this method you do not have to consider transactions at all. The default implementation of GetCountCore uses the GetAllRFeaturesCore method to get WellKnownType of the first feature from all features. We strongly recommend that you provide your own implementation for this method that will be more efficient. If you do not override this method, it will get the count by calling the GetAllFeaturesCore method and get WellKnownType of the first feature from all features. This is a very inefficient way to get the count in most data sources. It is highly recommended that you override this method and replace it with a highly optimized version. For example, in a ShapeFile the record count is in the main header of the file. Similarly, if you are using Oracle Spatial, you can execute a simple query to get the count of all of the records without returning them. In these ways you can greatly improve the performance of this method.
Go Back
GetFlatLinkSources()
IEnumerable<LinkSource>
Go Back
Collection<String>
Go Back
GetReturningColumnNames(ReturningColumnsType)
Get returning columnNames according to the returningColumnType.
The concreted FeatureSource can override this logic if needed.
Collection<String>The returning ColumnNames based on the given returningColumnNamesType.
returningColumnNamesTypeReturningColumnsTypeThe passed in returningColumnType.
Go Back
Collection<String>
filtersIEnumerable<String>
Go Back
GetWrappingFeaturesLeft(RectangleShape,Double,Double,IEnumerable<String>,RectangleShape)
Collection<Feature>
screenWidthDouble
screenHeightDouble
wrappingExtentRectangleShape
Go Back
GetWrappingFeaturesRight(RectangleShape,Double,Double,IEnumerable<String>,RectangleShape)
Collection<Feature>
screenWidthDouble
screenHeightDouble
Go Back
HasComplicateFields(IEnumerable<String>)
Boolean
originalComlumnNamesIEnumerable<String>
Go Back
Object
Go Back
OnAppliedFilters(AppliedFiltersFeatureSourceEventArgs)
Void
OnApplyingFilters(ApplyingFiltersFeatureSourceEventArgs)
Void
OnClosedFeatureSource(ClosedFeatureSourceEventArgs)
This method allows you to raise the ClosedFeatureSource event from a derived class.
You can call this method from a derived class to enable it to raise the ClosedFeatureSource event. This may be useful if you plan to extend the FeatureSource and you need access to the event. Details on the event: This event is called after the closing of the FeatureSource. Technically, this event is called after the calling of the Close method on the FeatureSource and after the protected CloseCore method. It is typical that the FeatureSource may be opened and closed may times during the life cycle of your application. The type of control the MapEngine is embedded in will dictate how often this happens. For example, in the case of the Web Edition, each time a FeatureSource is in the Ajax or Post Back part of the page cycle, it will close the FeatureSource before returning back to the client. This is to conserve resources, as the web is a connection-less environment. In the case of the Desktop Edition, we can keep the FeaureSources open, knowing that we can maintain a persistent connection.
VoidNone
eClosedFeatureSourceEventArgsThis parameter is the event arguments which define the parameters passed to the recipient of the event.
Go Back
OnClosingFeatureSource(ClosingFeatureSourceEventArgs)
This method allows you to raise the ClosingFeatureSource event from a derived class.
You can call this method from a derived class to enable it to raise the ClosingFeatureSource event. This may be useful if you plan to extend the FeatureSource and you need access to the event. Details on the event: This event is called before the closing of the FeatureSource. Technically, this event is called after the calling of the Close method on the FeatureSource, but before the protected CloseCore method. It is typical that the FeatureSource may be opened and closed may times during the life cycle of your application. The type of control the MapEngine is embedded in will dictate how often this happens. For example, in the case of the Web Edition, each time a FeatureSource is in the Ajax or Post Back part of the page cycle, it will close the FeatureSource before returning back to the client. This is to conserve resources, as the web is a connection-less environment. In the case of the Desktop Edition, we can keep the FeaureSources open, knowing that we can maintain a persistent connection.
VoidNone
eClosingFeatureSourceEventArgsThis parameter is the event arguments which define the parameters passed to the recipient of the event.
Go Back
OnCommittedTransaction(CommittedTransactionEventArgs)
This method allows you to raise the CommittedTransaction event from a derived class.
You can call this method from a derived class to enable it to raise the CommittedTransaction event. This may be useful if you plan to extend the FeatureSource and you need access to the event. Details on the event:This event is raised after the CommitTransactionCore is called and allows you access to the TransactionBuffer and the TransactionResults object before CommitTransaction method is returned. With this event, you can analyze the results of the transaction and do any cleanup code necessary. In the event some of the records did not commit, you can handle these items here. The TransactionResults object is passed out of the CommitTransaction method so you could analyze it then; however, this is the only place where you have access to both the TransactionResults object and the TransactionBuffer object at the same time. These are useful together to try and determine what went wrong and possibly try and re-commit them. At the time of this event, you will technically be out of the current transaction.
VoidNone
eCommittedTransactionEventArgsThis parameter is the event arguments which define the parameters passed to the recipient of the event.
Go Back
OnCommittingTransaction(CommittingTransactionEventArgs)
This method allows you to raise the CommittingTransaction event from a derived class.
You can call this method from a derived class to enable it to raise the CommittingTransaction event. This may be useful if you plan to extend the FeatureSource and you need access to the event. Details on the event: This event is raised before the CommitTransactionCore is called and allows you access to the TransactionBuffer before the transaction is committed. It also allows you to cancel the pending transaction. The TransactionBuffer is the object that stores all of the pending transactions and is accessible through this event to allow you either add, remove or modify transactions. In the event that you cancel the CommitTransaction method, the transaction remains intact and you will still be editing. This makes it a nice place to possibly check for connectivity before the TransactionCore code is run, which is where the records are actually committed. Calling the RollBackTransaction method is the only way to permanently cancel a pending transaction without committing it.
VoidNone
eCommittingTransactionEventArgsThis parameter is the event arguments which define the parameters passed to the recipient of the event.
Go Back
OnCustomColumnFetch(CustomColumnFetchEventArgs)
This method allows you to raise the CustomColumnFetch event from a derived class.
You can call this method from a derived class to enable it to raise the CustomColumnFetch event. This may be useful if you plan to extend the FeatureSource and you need access to user-definable field data. Details on the event: This event is raised when fields are requested in a feature source method that do not exist in the feature source. It allows you supplement the data from any outside source you may have. It is used primarily when you have data relating to a particular feature or set of features that is not within source of the data. For example, you may have a shape file of the world whose .dbf component describes the area and population of each country. Additionally, in an outside SQL Server table, you may also have data about the countries, and it is this data that you wish to use for determining how you want to color each country. To integrate this SQL data, you simply create a file name that does not exist in the .dbf file. Whenever Map Suite is queried to return records that specifically require this field, the FeatureSource will raise this event and allow you the developer to supply the data. In this way, you can query the SQL table and store the data in some sort of collection, and then when the event is raised, simply supply that data. As this is an event, it will raise for each feature and field combination requested. This means that the event can be raised quite often, and we suggest that you cache the data you wish to supply in memory. We recommend against sending out a new SQL query each time this event is raised. Image that you are supplementing two columns and your query returns 2,000 rows. This means that if you requested those fields, the event would be raised 4,000 times.
VoidNone
eCustomColumnFetchEventArgsThis parameter is the event arguments which define the parameters passed to the recipient of the event.
Go Back
Void
eDrawingProgressChangedEventArgs
Go Back
OnGettingColumns(GettingColumnsFeatureSourceEventArgs)
Void
OnGettingFeaturesByIds(GettingFeaturesByIdsFeatureSourceEventArgs)
Void
OnGettingFeaturesForDrawing(GettingFeaturesForDrawingFeatureSourceEventArgs)
Void
OnGottenColumns(GottenColumnsFeatureSourceEventArgs)
Void
OnOpenedFeatureSource(OpenedFeatureSourceEventArgs)
This method allows you to raise the OpenedFeatureSource event from a derived class.
You can call this method from a derived class to enable it to raise the OpenedFeatureSource event. This may be useful if you plan to extend the FeatureSource and you need access to the event. Details on the event: This event is called after the opening of the FeatureSource. Technically, this event is called after the calling of the Open method on the FeatureSource and after the protected OpenCore method is called. It is typical that the FeatureSource may be opened and closed may times during the life cycle of your application. The type of control the MapEngine is embedded in will dictate how often this happens. For example, in the case of the Web Edition, each time a FeatureSource is in the Ajax or Post Back part of the page cycle, it will close the FeatureSource before returning back to the client. This is to conserve resources, as the web is a connection-less environment. In the case of the Desktop Edition, we can keep the FeaureSources open, knowing that we can maintain a persistent connection.
VoidNone
eOpenedFeatureSourceEventArgsThis parameter is the event arguments which define the parameters passed to the recipient of the event.
Go Back
OnOpeningFeatureSource(OpeningFeatureSourceEventArgs)
This method allows you to raise the OpeningFeatureSource event from a derived class.
You can call this method from a derived class to enable it to raise the OpeningFeatureSource event. This may be useful if you plan to extend the FeatureSource and you need access to the event. Details on the event: This event is called before the opening of the FeatureSource. Technically, this event is called after the calling of the Open method on the FeatureSource, but before the protected OpenCore method. It is typical that the FeatureSource may be opened and closed may times during the life cycle of your application. The type of control the MapEngine is embedded in will dictate how often this happens. For example, in the case of the Web Edition, each time a FeatureSource is in the Ajax or Post Back part of the page cycle, it will close the FeatureSource before returning back to the client. This is to conserve resources, as the web is a connection-less environment. In the case of the Desktop Edition, we can keep the FeaureSources open, knowing that we can maintain a persistent connection.
VoidNone
eOpeningFeatureSourceEventArgsThis parameter is the event arguments which define the parameters passed to the recipient of the event.
Go Back
OpenCore()
This method opens the FeatureSource so that it is initialized and ready to use.
This protected virtual method is called from the concrete public method Open. The Open method plays an important role, as it is responsible for initializing the FeatureSource. Most methods on the FeatureSource will throw an exception if the state of the FeatureSource is not opened. When the map draws each layer, it will open the FeatureSource as one of its first steps, then after it is finished drawing with that layer it will close it. In this way we are sure to release all resources used by the FeatureSource. When implementing this virtual method ,consider opening files for file-based sources, connecting to databases in the database-based sources and so on. You will get a chance to close these in the Close method of the FeatureSource.
VoidNone
Go Back
ProcessTransaction(RectangleShape,Collection<Feature>,Boolean)
Void
needUpdateProjectionBoolean
Go Back
RaiseCustomColumnFetchEvent(Collection<Feature>,Collection<String>,Boolean)
Collection<Feature>
sourceFeaturesCollection<Feature>
fieldNamesOutsideOfSourceCollection<String>
forceRaiseEventBoolean
Go Back
RemoveEmptyAndExcludeFeatures(Collection<Feature>)
Void
Go Back
ReplaceColumnValues(Collection<Feature>,IEnumerable<String>)
Collection<Feature>
orginalFeaturesCollection<Feature>
Go Back
SpatialQueryCore(BaseShape,QueryType,IEnumerable<String>)
This method returns all of the InternalFeatures based on the target Feature and the spatial query type specified.
This method returns all of the InternalFeatures based on the target Feature and the spatial query type specified below. If you override this method, you do not need to consider transactions. It is suggested that if you are looking to speed up this method that you first override the GetFeaturesInsideBoundingBoxCore and then re-test this method, as it relies heavily on that method internally. See more information below.Spatial Query Types:Disjoint - This method returns InternalFeatures where the specific Feature and the targetShape have no points in common.Intersects - This method returns InternalFeatures where the specific Feature and the targetShape have at least one point in common.Touches - This method returns InternalFeatures where the specific Feature and the targetShape have at least one boundary point in common, but no interior points.Crosses - This method returns InternalFeatures where the specific Feature and the targetShape share some but not all interior points.Within - This method returns InternalFeatures where the specific Feature lies within the interior of the targetShape.Contains - This method returns InternalFeatures where the specific Feature lies within the interior of the current shape.Overlaps - This method returns InternalFeatures where the specific Feature and the targetShape share some but not all points in common.TopologicalEqual - This method returns InternalFeatures where the specific Feature and the target Shape are topologically equal. The default implementation of SpatialQueryCore uses the GetFeaturesInsideBoundingBoxCore method to pre-filter the spatial query. We strongly recommend that you provide your own implementation for this method that will be more efficient. When you override this method, we recommend that you use any spatial indexes you have at your disposal to make this method as fast as possible.
Go Back
SplitColumnNames(IEnumerable<String>)
This method will split the column names based on our column syntax.
This method is meant to be used by advanced users who are creating their own new methods on the FeatureSource. We have a system where you can concatenate column names you specify anywhere in the system to create a unique string. For example, let's say you have a dataset that has the following columns: Name, Grade and Class, and you want to create a custom label for it. Whenever you specify the column you wanted to use in the label, you could use a string like this: “[Name] received a [Grade] in [Class]” and this would be valid. Behind the scenes, this method parses the string and returns the column names separately. Then, after we have the data, there is another helper method called CombineFieldValues that will add them back together again. All of this happens normally in the concrete methods of the FeatureSource and inheriting classes; however, if you want to extend the classes and create your own concrete methods, then we suggest you use this to be compliant with the concatenation system.
Collection<String>This returns a single list of column names.
returningColumnNamesIEnumerable<String>This parameter represents the column names you want to split.
Go Back
SplitColumnNamesCall(IEnumerable<String>)
Collection<String>
Go Back
CanExecuteSqlQuery
This property specifies whether the FeatureSource can excute a SQL query or not. If it is false, then it will throw exception when these APIs are calleds: ExecuteScalar, ExecuteNonQuery, ExecuteQuery
The default implementation is false.
Return Type
Boolean
Go Back
CanModifyColumnStructure
Return Type
Boolean
Go Back
FeatureIdsToExclude
A collection of strings representing record id of features not to get in the Layer.
Return Type
Collection<String>
Go Back
Filters
Return Type
Collection<String>
Go Back
GeoCache
The cache system.
You must set IsActive to true for the Cache system. The default is not active.
Return Type
FeatureCache
Go Back
GeometryValidationMode
Id
Return Type
String
Go Back
IsEditable
This property returns whether the FeatureSource allows edits or is read-only.
This property is useful to check if a specific FeatureSource accepts editing. If you call BeginTransaction and this property is false, then an exception will be raised. For developers who are creating or extending a FeatureSource, it is expected that you override this virtual method if the new FeatureSource you are creating allows edits. By default, the decimalDegreesValue is false, meaning that if you want to allow edits you must override this method and return true.
Return Type
Boolean
Go Back
IsInTransaction
This property returns true if the FeatureSource is in a transaction and false if it is not.
To enter a transaction, you must first call the BeginTransaction method of the FeatureSource. It is possible that some FeatureSources are read-only and do not allow edits. To end a transaction, you must either call CommitTransaction or RollbackTransaction.
Return Type
Boolean
Go Back
IsOpen
This property returns true if the FeatureSource is open and false if it is not.
Various methods on the FeatureSource require that it be in an open state. If one of those methods is called when the state is not open, then the method will throw an exception. To enter the open state, you must call the FeatureSource's Open method. The method will raise an exception if the current FeatureSource is already open.
Return Type
Boolean
Go Back
IsTransactionLive
This property returns true if the features currently modified in a transaction are expected to reflect their state when calling other methods on the FeatureSource, such as spatial queries.
The live transaction concept means that all of the modifications you perform during a transaction are live from the standpoint of the querying methods on the object. As an example, imagine that you have a FeatureSource that has 10 records in it. Next, you begin a transaction and then call GetAllFeatures. The result would be 10 records. After that, you call a delete on one of the records and call the GetAllFeatures again. This time you only get nine records, even though the transaction has not yet been committed. In the same sense, you could have added a new record or modified an existing one and those changes would be considered live, though not committed. In the case where you modify records – such as expanding the size of a polygon – those changes are reflected as well. For example, you expand a polygon by doubling its size and then do a spatial query that would not normally return the smaller record, but instead would return the larger records. In this case, the larger records are returned. You can set this property to be false, as well; in which case, all of the spatially related methods would ignore anything that is currently in the transaction buffer waiting to be committed. In such a case, only after committing the transaction would the FeatureSource reflect the changes.
Return Type
Boolean
Go Back
LinkExpressions
Return Type
Collection<String>
Go Back
LinkSources
Return Type
Collection<LinkSource>
Go Back
MaxRecordsToDraw
Return Type
Int32
Go Back
Projection
This property holds the projection object that is used within the FeatureSource to ensure that features inside of the FeatureSource are projected.
By default this property is null, meaning that the data being passed back from any methods on the FeatureSource will be in the coordinate system of the raw data. When you specify a projection object in the property, all incoming and outgoing method calls will subject the features to projection. For example, if the spatial database you are using has all of its data stored in decimal degrees, but you want to see the data in UTM, you would create a projection object that goes from decimal degrees to UTM and set that as the projection. With this one property set, we will ensure that it will seem to you the developer that all of the data in the FeatureSource is in UTM. That means every spatial query will return UTM projected shapes. You can even pass in UTM shapes for the parameters. Internally, we will ensure that the shapes are converted to and from the projection without any intervention on the developer's part. In fact, even when you override virtual or abstract core methods in the FeatureSource, you will not need to know about projections at all. Simply work with the data in its native coordinate system. We will handle all of the projection at the high level method.
Return Type
Projection
Go Back
TransactionBuffer
The TransactionBuffer used in the Transaction System.
The Transaction System The transaction system of a FeatureSource sits on top of the inherited implementation of any specific source, such as Oracle Spatial or Shape files. In this way, it functions the same way for every FeatureSource. You start by calling BeginTransaction. This allocates a collection of in-memory change buffers that are used to store changes until you commit the transaction. So, for example, when you call the Add, Delete or Update method, the changes to the feature are stored in memory only. If for any reason you choose to abandon the transaction, you can call RollbackTransaction at any time and the in-memory buffer will be deleted and the changes will be lost. When you are ready to commit the transaction, you call CommitTransaction and the collections of changes are then passed to the CommitTransactionCore method and the implementer of the specific FeatureSource is responsible for integrating your changes into the underlying FeatureSource. By default the IsLiveTransaction property is set to false, which means that until you commit the changes, the FeatureSource API will not reflect any changes that are in the temporary editing buffer. In the case where the IsLiveTransaction is set to true, then things function slightly differently. The live transaction concept means that all of the modifications you perform during a transaction are live from the standpoint of the querying methods on the object. As an example, imagine that you have a FeatureSource that has 10 records in it. Next, you begin a transaction and then call GetAllFeatures. The result would be 10 records. After that, you call a delete on one of the records and call the GetAllFeatures again. This time you only get nine records, even though the transaction has not yet been committed. In the same sense, you could have added a new record or modified an existing one and those changes would be considered live, though not committed. In the case where you modify records – such as expanding the size of a polygon – those changes are reflected as well. For example, you expand a polygon by doubling its size and then do a spatial query that would not normally return the smaller record, but instead would return the larger records. In this case, the larger records are returned. You can set this property to be false, as well; in which case, all of the spatially related methods would ignore anything that is currently in the transaction buffer waiting to be committed. In such a case, only after committing the transaction would the FeatureSource reflect the changes.
CanExecuteSqlQueryCore
Return Type
Boolean
Go Back
CanModifyColumnStructureCore
Return Type
Boolean
Go Back
FeatureSourceColumns
This property gets the columns of the feature source.
None.
Return Type
Collection<FeatureSourceColumn>
Go Back
IsOpenCore
Return Type
Boolean
Go Back
AppliedFilters
Event Arguments
ApplyingFilters
Event Arguments
ClosedFeatureSource
Event Arguments
Event Arguments
This event is raised after the CommitTransaction and the CommitTransactionCore are called and allows you access to the TransactionBuffer and the TransactionResults object before CommitTransaction method is returned.
This event is raised after the CommitTransactionCore is called and allows you access to the TransactionBuffer and the TransactionResults object before CommitTransaction method is returned. With this event, you can analyse the results of the transaction and do any cleanup code necessary. In the event some of the records did not commit, you can handle those items here. The TransactionResults object is passed out of the CommitTransaction method so you could analyze it then; however, this is the only place where you have access to both the TransactionResults object and the TransactionBuffer object at the same time. These are useful together to try and determine what went wrong and possibly try and re-commit them. At the time of this event you will technically be out of the current transaction.
Event Arguments
This event is raised after the CommitTransaction method is called, but before the CommitTransactionCore is called. This allows you access to the TransactionBuffer before the transaction is committed. It also allows you to cancel the pending commit of the transaction.
This event is raised before the CommitTransactionCore is called and allows you access to the TransactionBuffer before the transaction is committed. It also allows you to cancel the pending transaction. The TransactionBuffer is the object that stores all of the pending transactions and is accessible through this event to allow you to either add, remove or modify transactions. In the event that you cancel the CommitTransaction method, the transaction remains intact and you will still be editing. This makes it a nice place to possibly check for connectivity before the TransactionCore code is run, which is where the records are actually committed. Calling the RollBackTransaction method is the only way to permanently cancel a pending transaction without committing it.
Event Arguments
CustomColumnFetch
This event is raised when fields are requested in a feature source method that do not exist in the feature source. It allows you to supplement the data from any outside source you have.
This event is raised when fields are requested in a feature source method that do not exist in the feature source. It allows you to supplement the data from any outside source you have. It is used primarily when you have data relating to a particular feature or set of features that is not within source of the data. For example, you may have a shape file of the world whose .dbf component describes the area and population of each country. Additionally, in an outside SQL Server table, you may also have data about the countries, and it is this data that you wish to use for determining how you want to color each country. To integrate this SQL data, you simply create a file name that does not exist in the .dbf file. Whenever Map Suite is queried to return records that specifically require this field, the FeatureSource will raise this event and allow you the developer to supply the data. In this way, you can query the SQL table and store the data in some sort of collection, and then when the event is raised, simply supply that data. As this is an event, it will raise for each feature and field combination requested. This means that the event can be raised quite often, and we suggest that you cache the data you wish to supply in memory. We recommend against sending out a new SQL query each time this event is raised. Image that you are supplementing two columns and your query returns 2,000 rows. This means that if you requested those fields, the event would be raised 4,000 times.
Event Arguments
Event Arguments
GettingColumns
Event Arguments
Event Arguments
Event Arguments
GottenColumns
Event Arguments
OpenedFeatureSource
Event Arguments
Event Arguments
thinkgeo.mapsuite.core.featuresource.1442298896.txt.gz · Last modified: 2015/09/15 06:34 by admin
