Map Suite Silverlight Edition is a .NET native GIS software control that lets .NET developers add rich, interactive maps to their Silverlight-based Web applications. Now you can harness the full power of a professional GIS control in the sleek, next-generation interfaces of Microsoft Silverlight. This is not a slimmed-down control — it's full-featured GIS for Silverlight!
Topic | Attachment | Description |
Screenshot Gallery | N/A | The Silverlight Edition screenshots gallery section showcases a wide range of screenshots covering various GIS features of the Silverlight Edition map control. |
Introduction to the Silverlight Edition | Video Presentation Q&A Screenshot | This introductory webinar demonstrates a host of exciting features in the all-new Map Suite Silverlight Edition. Take a look at the video presentation and download the Q&A session transcript below. |
Extending Map Suite | Video Presentation Q&A Sample Screenshot | In this webinar video, Map Suite Chief Architect David Rehagen demonstrates some of the many ways you can extend the Layer and RasterLayer classes, giving you near-infinite possibilities for beefing up your Map Suite projects. Download the sample project below to explore the source code. |
Best Practices: Silverlight Edition | Video (Part 1) Video (Part 2) Sample (C#) Screenshot | This informative video and code sample demonstrates the best practices for rendering and querying data that resides on the server or the client using Map Suite Silverlight Edition. The accompanying code gives you a ready-to-use sample that demonstrates both methods. |
Printing System Introduction | Video Sample Code: *WPF *WinForms Screenshot | In this video we will explore Map Suite's new printing system. Map Suite offers WYSIWYG map design that takes your Silverlight, desktop or web-based .NET mapping applications to the next level. Maps are printed using vector graphics so you can be sure the output will look great on anything from a PDF to a large plotter. It also includes low-level report building classes that make it easy to generate reports in the Web or Services environment. Check out the video and see how easy it is to integrate map printing into your GIS applications. |
Increasing Polygon Performance | Video Utility Source Performance Guide Screenshot | In this video we will explore how to greatly increase your rendering performance by gridding your high point-count polygons. This technique is especially useful when you use a high point-count polygon such as a country or regional area as the ground color for your maps. In many cases we see tile render times decrease from 500ms to under 5ms with this data optimization. Included along with the video is a utility to help you grid your polygons. |
Map Suite DynamoDB Extension Technology Preview | Video Sample Screenshot | This video will introduce you to the Map Suite DynamoDB Extension limited technology preview. This exciting new extension leverages Amazon's DynamoDB, a NoSQL cloud database technology, to store and serve GIS spatial data via the cloud. The extension's ability to use a few API calls to create a spatial table, import data and then access it without a traditional spatial database or hardware is a huge step forward. |
Tile Cache Generator | Video Sample Screenshot | This video will show you how to use the Tile Cache Generator utility to generate tile caches based on your own layers. Pre-generating tiles base on your data allows you to display the data faster than rending it from vector graphics files. It also allows you to protect your vector data by providing just the raster tiles for display purposes only. In the past pre-generating tiles required customers to build the process from scratch which was time consuming and often times inefficient. With the Tile Cache Generator we have packaged many of our best practices along with the source to allow you to tweak it to your specific situation. |
Topology Validation | Video Sample Screenshot | This video will give you a demonstration of Map Suite's topology validation functionality (available in version 6.0.113.0 and higher), as well as the Topology Validator sample application. The Topology Validator makes it simple to visualize and test topology rules. You simply select the case you want to test, use our drawing tools to create the shapes necessary, and then hit the play button to run the test. The error cases are highlighted on the screen and saved to the test, and their Well-Known Text (WKT) is copied to your clipboard. At any time, you can view or edit the WKT which makes up the case. We save our test cases as XML files that contain not only the test case features but also the errors. This makes it a snap for you to share your cases with us or other colleagues. |
In addition to the samples below, we have dozens of interactive Silverlight Edition sample applications available here.
All Samples
All samples about Map Suite Silverlight Edition.
Project Templates
These projects show various study cases based on Silverlight Edition.
Background Maps
InteractiveOverlays
Labeling
Layers & FeatureSources
Miscellaneous
Printing
Projection
Spatial Functions
Styles
Vehicle Tracking
Zooming Panning Moving
All the frequently asked questions about Map Suite Silverlight Edition.
These frequently asked questions cover showing how to incorporate 3rd part background map with your application.
These frequently asked questions cover various aspects of how to extend or create InteractiveOverlays. Examples of InteractiveOverlay functions are things such as drawing track shapes, shape editing and track extents.
These frequently asked questions cover various aspects of labeling features.
These frequently asked questions cover custom layers and feature sources from which you can get inspired to integrate your own data.
These frequently asked questions cover various of other technical features of the products that are not included in other categories.
These frequently asked questions cover various aspects of projection such as how to re-project your data.
These frequently asked questions cover various spatial functions such as union, buffer, merging data etc.
These frequently asked questions cover displaying your GIS data using various styles. Some examples of styles would include using class breaks, clustering points, heat maps, etc.
These frequently asked questions cover various features related to vehicle and asset tracking.
These frequently asked questions cover various ways to move the map.
The client side Silverlight Core API documentation covers the ThinkGeo.MapSuite.SilverlightCore namespace which resides in the SilverlightMapSuiteCore.dll assembly. It contains all of the core GIS classes that are used in Map Suite Silverlight Map Control on client. It includes such classes as Style, FeatureSource, Layer, Projection etc.
The Silverlight Edition API documentation covers the ThinkGeo.MapSuite.SilverlightEdition namespace which resides in the SilverlightEdition.dll and SilverlightConnector.dll assembly. It contains all of the Silverlight Edition specific classes such as the map control itself, Overlays, and supported map classes.
