map_suite_silverlight_edition [2015/09/15 01:59] admin [Map Suite Silverlight Edition] |
map_suite_silverlight_edition [2017/03/15 03:42] tgwikiupdate |
====== Map Suite Silverlight Edition ====== | ====== Map Suite Silverlight Edition ====== | ||
Map Suite Silverlight Edition is a .NET native GIS software control that lets .NET developers add rich, interactive maps to their Silverlight-based Web applications. Now you can harness the full power of a professional GIS control in the sleek, next-generation interfaces of Microsoft Silverlight. This is not a slimmed-down control — it's full-featured GIS for Silverlight! | Map Suite Silverlight Edition is a .NET native GIS software control that lets .NET developers add rich, interactive maps to their Silverlight-based Web applications. Now you can harness the full power of a professional GIS control in the sleek, next-generation interfaces of Microsoft Silverlight. This is not a slimmed-down control — it's full-featured GIS for Silverlight! | ||
- | + | <div mockline></div> | |
Line 11: | Line 11: | ||
**[[http://thinkgeo.com/map-suite-developer-gis/silverlight-edition/#svl-demos|Explore the Demos]]** | **[[http://thinkgeo.com/map-suite-developer-gis/silverlight-edition/#svl-demos|Explore the Demos]]** | ||
Line 21: | Line 19: | ||
> [[Map Suite Silverlight Edition Quick Start Guide|Quick Start Guide]] | > [[Map Suite Silverlight Edition Quick Start Guide|Quick Start Guide]] | ||
- | This guide helps you get you up to speed with integrating the Map Suite Silverlight Edition map control into your your GIS software. | + | Helps you get you up to speed with integrating the Map Suite Silverlight Edition map control into your your GIS software. |
> [[Map Suite Style Guide|Style Guide]] | > [[Map Suite Style Guide|Style Guide]] | ||
- | This guide explains how to use styles in Map Suite to beautifully represent your GIS mapping data. The guide includes an overview of styles, a detailed explanation of the various styles that ship with Map Suite, as well as a step by step guide of creating your own custom styles. | + | Explains how to use styles to beautifully represent your GIS mapping data. It includes an overview of styles, a detailed explanation of the various styles that ship with Map Suite, as well as a step by step guide of creating your own custom styles. |
> [[Map Suite Silverlight Edition Installation Guide|Installation Guide]] | > [[Map Suite Silverlight Edition Installation Guide|Installation Guide]] | ||
- | This guide walks you through installing the map control on your system and creating a simple GIS application. | + | Walks you through installing the map control on your system and creating a simple GIS application. |
> [[Map Suite Silverlight Edition Deployment Guide|Deployment Guide]] | > [[Map Suite Silverlight Edition Deployment Guide|Deployment Guide]] | ||
- | This guide walks you through deploying your GIS software using the map control into a production environment. | + | Walks you through deploying your GIS software using the map control into a production environment. |
> [[Map Suite Data Format Guide|Data Format Guide]] | > [[Map Suite Data Format Guide|Data Format Guide]] | ||
- | This guide walks the various GIS data format that are supported in the map control. It also list any caveats related to the use of that format in your mapping application. | + | Walks the various GIS data format that are supported in the map control. It also list any caveats related to the use of that format in your mapping application. |
> [[Map Suite Silverlight Edition Dependencies Guide|Dependencies Guide]] | > [[Map Suite Silverlight Edition Dependencies Guide|Dependencies Guide]] | ||
- | This guide introduces the dependencies Map Suite Silverlight Edition needs with their features, versions and source websites. | + | Introduces the dependencies Map Suite Silverlight Edition needs with their features, versions and source websites. |
> [[Map Suite Performance Guide|Performance Guide]] | > [[Map Suite Performance Guide|Performance Guide]] | ||
- | This guide walks you through various ways you can increase performance in your .Net GIS application. | + | Walks you through various ways you can increase performance in your .Net GIS application. |
Line 149: | Line 147: | ||
===== Videos ===== | ===== Videos ===== | ||
- | ==== • Silverlight Edition Sample App Walkthrough Video Series ==== | + | > ** Silverlight Edition Sample App Walkthrough Video Series ** |
Step through the Silverlight Edition sample applications and see how they're put together. We'll demonstrate how to use each app, then take you through every part of the source code and show you how it works.\\ | Step through the Silverlight Edition sample applications and see how they're put together. We'll demonstrate how to use each app, then take you through every part of the source code and show you how it works.\\ | ||
Line 157: | Line 155: | ||
- | [[silverlightedition:Introduction to the Silverlight Edition|{{silverlightedition:screenshot:Introduction_to_the_Silverlight_Edition.png?180x99|Screenshot}}]] | + | [[silverlightedition:Introduction to the Silverlight Edition|{{silverlightedition:screenshot:Introduction_to_the_Silverlight_Edition.png?180x99|Introduction to the Silverlight Edition}}]] |
Introduction to the Silverlight Edition | Introduction to the Silverlight Edition | ||
- | ==== • Extending Map Suite Video Series==== | + | <div newline></div> |
+ | > ** Extending Map Suite Video Series ** | ||
{{page>map_suit_extending_map_suite_video_series}} | {{page>map_suit_extending_map_suite_video_series}} | ||
Line 171: | Line 170: | ||
<div medialist imagewithremaker> | <div medialist imagewithremaker> | ||
- | {{silverlightedition:screenshot:Map_Suite_Silverlight_Edition_Screenshot_Gallery_IntegratedControls.png?180|Screenshot}} | + | {{silverlightedition:screenshot:Map_Suite_Silverlight_Edition_Screenshot_Gallery_IntegratedControls.png?180|No extra coding necessary |
+ | Includes panning, zooming, scale bar, mini map & more}} | ||
No extra coding necessary | No extra coding necessary | ||
Line 179: | Line 179: | ||
- | {{silverlightedition:screenshot:Map_Suite_Silverlight_Edition_Screenshot_Gallery_SpatialQueries.png?180|Screenshot}} | + | {{silverlightedition:screenshot:Map_Suite_Silverlight_Edition_Screenshot_Gallery_SpatialQueries.png?180|Queries include Within, Containing, Disjointed, Intersecting and more}} |
Queries include Within, Containing, Disjointed, Intersecting and more | Queries include Within, Containing, Disjointed, Intersecting and more | ||
Line 185: | Line 185: | ||
- | {{silverlightedition:screenshot:Map_Suite_Silverlight_Edition_Screenshot_Gallery_Projections.png?180|Screenshot}} | + | {{silverlightedition:screenshot:Map_Suite_Silverlight_Edition_Screenshot_Gallery_Projections.png?180|Project your spatial data |
+ | Many different projections available}} | ||
Project your spatial data | Project your spatial data | ||
Line 193: | Line 194: | ||
- | {{silverlightedition:screenshot:Map_Suite_Silverlight_Edition_Screenshot_Gallery_DrawShapes.png?180|Screenshot}} | + | {{silverlightedition:screenshot:Map_Suite_Silverlight_Edition_Screenshot_Gallery_DrawShapes.png?180|Draw areas right on the map |
+ | Points, lines, polygons, ellipses and more}} | ||
Draw areas right on the map | Draw areas right on the map | ||
Line 201: | Line 203: | ||
- | {{silverlightedition:screenshot:Map_Suite_Silverlight_Edition_Screenshot_Gallery_EditShapes.png?180|Screenshot}} | + | {{silverlightedition:screenshot:Map_Suite_Silverlight_Edition_Screenshot_Gallery_EditShapes.png?180|Shape editing in your browser |
+ | Reshape, rotate, resize and drag}} | ||
Shape editing in your browser | Shape editing in your browser | ||
Line 209: | Line 212: | ||
- | {{silverlightedition:screenshot:Map_Suite_Silverlight_Edition_Screenshot_Gallery_Popups.png?180|Screenshot}} | + | {{silverlightedition:screenshot:Map_Suite_Silverlight_Edition_Screenshot_Gallery_Popups.png?180|Design your own tooltips with custom HTML |
+ | Include images}} | ||
Design your own tooltips with custom HTML | Design your own tooltips with custom HTML | ||
Line 217: | Line 221: | ||
- | {{silverlightedition:screenshot:Map_Suite_Silverlight_Edition_Screenshot_Gallery_VehicleTracking.png?180|Screenshot}} | + | {{silverlightedition:screenshot:Map_Suite_Silverlight_Edition_Screenshot_Gallery_VehicleTracking.png?180|Show points in motion |
+ | Can be used for mobile asset tracking}} | ||
Show points in motion | Show points in motion | ||
Line 225: | Line 230: | ||
- | {{silverlightedition:screenshot:Map_Suite_Silverlight_Edition_Screenshot_Gallery_SelectiveDrawing.png?180|Screenshot}} | + | {{silverlightedition:screenshot:Map_Suite_Silverlight_Edition_Screenshot_Gallery_SelectiveDrawing.png?180|Render based on data points |
+ | Draw or exclude features based on conditions}} | ||
Render based on data points | Render based on data points | ||
Line 232: | Line 238: | ||
- | {{silverlightedition:screenshot:Map_Suite_Silverlight_Edition_Screenshot_Gallery_DistanceCalculations.png?180|Screenshot}} | + | {{silverlightedition:screenshot:Map_Suite_Silverlight_Edition_Screenshot_Gallery_DistanceCalculations.png?180|Connect points using the Great Circle model |
+ | Show accurate distances}} | ||
Connect points using the Great Circle model | Connect points using the Great Circle model | ||
Line 239: | Line 246: | ||
- | {{silverlightedition:screenshot:Map_Suite_Silverlight_Edition_Screenshot_Gallery_PointsWithBitmaps.png?180|Screenshot}} | + | {{silverlightedition:screenshot:Map_Suite_Silverlight_Edition_Screenshot_Gallery_PointsWithBitmaps.png?180|Draw an image at a point |
+ | Additional options include vector symbols}} | ||
Draw an image at a point | Draw an image at a point | ||
Line 247: | Line 255: | ||
- | {{silverlightedition:screenshot:Map_Suite_Silverlight_Edition_Screenshot_Gallery_SampleApps.png?180|Screenshot}} | + | {{silverlightedition:screenshot:Map_Suite_Silverlight_Edition_Screenshot_Gallery_SampleApps.png?180|Dozens of interactive sample applications |
+ | Source code in C# & VB.NET}} | ||
Dozens of interactive sample applications | Dozens of interactive sample applications | ||
Line 258: | Line 267: | ||
+ | <div newline></div> | ||
Line 281: | Line 292: | ||
