map_suite_services_edition_zooming_panning_moving_samples [2016/12/29 05:52] tgwikiupdate [Map Suite License File Generator] |
map_suite_services_edition_zooming_panning_moving_samples [2017/03/17 03:06] tgwikiupdate |
Line 70: | Line 70: | ||
[[Map Suite Samples Alternate Languages | Need it in another language?]] | [[Map Suite Samples Alternate Languages | Need it in another language?]] | ||
- | This project shows you how to set the current extent based on a collection of layers. You can use this technique for the common task of having the map set to the full extent. Instead of having to manually set the full extent, now you can pass all the layers you want the full extent to be based on. | + | The Map Suite License File Generator shows how to take the advantage of MapSuiteLicense.dll to create the Map Suite Production Server license in your application on the fly. When you activate a Map Suite Production Server license that you have purchased, that license is verified with ThinkGeo’s online servers as part of the activation process. The simple process ensures that you are activating a license that you are entitled to. ThinkGeo takes care of all the particulars, and the process is seamless if you have an internet connection. |
- | </div> | + | |
- | </div> | + | |
+ | NOTE: please ask support@thinkgeo.com for MapSuiteLicense.dll | ||
+ | </div> |
