map_suite_services_edition_zooming_panning_moving_samples [2015/09/08 03:12] admin [Custom Zoom Levels] |
map_suite_services_edition_zooming_panning_moving_samples [2017/03/17 03:06] tgwikiupdate |
- | ====== Map Suite Services Edition Zooming Panning Moving Samples ====== | + | ====== Map Suite Services Edition Zooming Panning Moving Samples ====== |
- | ==== Centering and Rotating ==== | + | |
+ | ==== Centering and Rotating ==== | ||
+ | <div screenshot> | ||
{{servicesedition:codesamples:Map Suite Services Edition Sample Centering and Rotating.jpg?300x180}} | {{servicesedition:codesamples:Map Suite Services Edition Sample Centering and Rotating.jpg?300x180}} | ||
- | \\ | + | </div> |
- | [[Source_Code_ServicesEditionSample_CenteringAndRotating_CS_100225.zip|View Source]] | | + | <div content> |
- | {{:File:ServicesEditionSample_CenteringAndRotating_CS_100225.zip|C# Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\ | + | <div download_viewsource_buttons> |
+ | [[Source_Code_ServicesEditionSample_CenteringAndRotating_CS_100225.zip|View Source]] | ||
+ | {{filehistory:ServicesEditionSample_CenteringAndRotating_CS_100225.zip|C# Download}} | ||
[[Map Suite Samples Applies To|Applies To: Desktop \ Web \ Silverlight \ Services \ Wpf ]] | [[Map Suite Samples Applies To|Applies To: Desktop \ Web \ Silverlight \ Services \ Wpf ]] | ||
In the project “Centering On Moving Vehicle”, we learned how to have the map always centered on a moving vehicle. In this project, we go one step further and show how to have the map also rotating according to the direction of the moving vehicle. In this project, you will also see how to use the CompassAdornmentLayer that always indicates the north as the map rotates. | In the project “Centering On Moving Vehicle”, we learned how to have the map always centered on a moving vehicle. In this project, we go one step further and show how to have the map also rotating according to the direction of the moving vehicle. In this project, you will also see how to use the CompassAdornmentLayer that always indicates the north as the map rotates. | ||
- | ==== Custom Zoom Levels ==== | ||
+ | ==== Custom Zoom Levels ==== | ||
{{:No_screenshot.jpg?300x180}} | {{:No_screenshot.jpg?300x180}} | ||
- | [[Source_Code_ServicesEditionSample_CustomZoomLevels_CS_100430.zip|View Source]] | | + | <div content> |
- | {{:File:ServicesEditionSample_CustomZoomLevels_CS_100430.zip|C# Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\ | + | <div download_viewsource_buttons> |
+ | [[Source_Code_ServicesEditionSample_CustomZoomLevels_CS_100430.zip|View Source]] | ||
+ | {{filehistory:ServicesEditionSample_CustomZoomLevels_CS_100430.zip|C# Download}} | ||
In the project, “Zoom Levels Partitioning”, we showed how to partition the existing predefined zoom levels to have a finer level of control on how to display layers based on scale. In today’s project, we show how to set your own ten zoom levels based on a reference scale, each zoom level being half in scale of the previous one. So, in this case, we limit the number of zoom levels to ten instead of the twenty predefined ones. | In the project, “Zoom Levels Partitioning”, we showed how to partition the existing predefined zoom levels to have a finer level of control on how to display layers based on scale. In today’s project, we show how to set your own ten zoom levels based on a reference scale, each zoom level being half in scale of the previous one. So, in this case, we limit the number of zoom levels to ten instead of the twenty predefined ones. | ||
- | ==== Zoom to Full extent ==== | ||
+ | ==== Zoom to Full extent ==== | ||
{{servicesedition:codesamples:Map Suite Services Edition Sample Zoom To FullExtent Service.jpg?300x180}} | {{servicesedition:codesamples:Map Suite Services Edition Sample Zoom To FullExtent Service.jpg?300x180}} | ||
- | [[Source_Code_ServicesEditionSample_ZoomToFullExtent_CS_100415.zip|View Source]] | | + | <div content> |
- | {{:File:ServicesEditionSample_ZoomToFullExtent_CS_100415.zip|C# Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\ | + | <div download_viewsource_buttons> |
+ | [[Source_Code_ServicesEditionSample_ZoomToFullExtent_CS_100415.zip|View Source]] | ||
+ | {{filehistory:ServicesEditionSample_ZoomToFullExtent_CS_100415.zip|C# Download}} | ||
This project shows you how to set the current extent based on a collection of layers. You can use this technique for the common task of having the map set to the full extent. Instead of having to manually set the full extent, now you can pass all the layers you want the full extent to be based on. | This project shows you how to set the current extent based on a collection of layers. You can use this technique for the common task of having the map set to the full extent. Instead of having to manually set the full extent, now you can pass all the layers you want the full extent to be based on. | ||
+ | ==== Map Suite License File Generator ==== | ||
+ | {{servicesedition:codesamples:mapsuiitefilelicensegenerator.png?300x180}} | ||
+ | <div content> | ||
+ | <div download_viewsource_buttons> | ||
+ | {{filehistory:mapsuitelicensefilegenerator.zip|C# Download}} | ||
+ | [[Map Suite Samples Applies To|Applies To: Desktop \ Web \ Silverlight \ Services \ Wpf ]] | ||
+ | The Map Suite License File Generator shows how to take the advantage of MapSuiteLicense.dll to create the Map Suite Production Server license in your application on the fly. When you activate a Map Suite Production Server license that you have purchased, that license is verified with ThinkGeo’s online servers as part of the activation process. The simple process ensures that you are activating a license that you are entitled to. ThinkGeo takes care of all the particulars, and the process is seamless if you have an internet connection. | ||
- | ---- | + | NOTE: please ask support@thinkgeo.com for MapSuiteLicense.dll |
+ | </div> |
