New namespaces: 0
Types
Types added in new namespaces: 0
Types added to existing namespaces: 29
Total number of types added (in both new and existing namespaces): 29
Types removed from existing namespaces: 12
Members
Members added on new types: 347
Members added to existing types: 146
Members removed from existing types: 65
Members removed on removed types: 69
Attributes
Attributes added: 18
Attributes added and shown: 18
Attributes removed: 0
Attributes removed and shown: 0
Others
Parameter name changes: 17
MapSuiteCore, Version=7.0.0.0, Culture=neutral, PublicKeyToken=null
namespace ThinkGeo.MapSuite.Core {
[SerializableAttribute]
public enum AreaUnit {
Acres,
SquareMeters
public abstract class BaseShape {
public String GetGeoJson();
public Byte[] GetWellKnownBinary(RingOrder outerRingOrder);
public Byte[] GetWellKnownBinary(RingOrder outerRingOrder, WkbByteOrder byteOrder);
public String GetWellKnownText(RingOrder outerRingOrder);
protected virtual String GetGeoJsonCore();
[ObsoleteAttribute("This method is obsolete, please use GetWellKnownBinaryCore(RingOrder outerRingOrder, WkbByteOrder byteOrder) instead. This API is obsolete and may be removed in or after version 8.0.")]
protected virtual Byte[] GetWellKnownBinaryCore(WkbByteOrder byteOrder);
protected virtual Byte[] GetWellKnownBinaryCore(RingOrder outerRingOrder, WkbByteOrder byteOrder);
[ObsoleteAttribute("This method is obsolete, please use GetWellKnownTextCore(RingOrder outerRingOrder) instead. This API is obsolete and may be removed in or after version 8.0.")]
protected abstract String GetWellKnownTextCore();
protected abstract String GetWellKnownTextCore(RingOrder outerRingOrder);
public static BaseShape CreateShapeFromGeoJson(String geoJson);
public class BingMapsLayer : Layer {
[ObsoleteAttribute("This constructor is obsolete, please use other constructors instead. This API is obsolete and may be removed in or after Version 7.0.")]
public BingMapsLayer(String applicationId, BingMapsMapType mapType, String cacheDirectory, BingMapsLogoMode logoMode);
[ObsoleteAttribute("This property is obsolete, please use other structors instead. This API is obsolete and may be removed in or after Version 7.0.")]
public BingMapsLogoMode LogoMode { get; set; }
[ObsoleteAttribute("This event is obsolete, please use SendingWebRequest instead. This API is obsolete and may be removed in or after Version 7.0.")]
public event EventHandler
[ObsoleteAttribute("This event is obsolete, please use SentWebRequest instead. This API is obsolete and may be removed in or after Version 7.0.")]
public abstract class BitmapTileCache : TileCache {
protected virtual void OnGettingCacheImage(GettingCacheImageBitmapTileCacheEventArgs e);
protected virtual void OnGottenCacheImage(GottenCacheImageBitmapTileCacheEventArgs e);
public class CircularKrigingGridInterpolationModel : KrigingGridInterpolationModel {
public CircularKrigingGridInterpolationModel();
public CircularKrigingGridInterpolationModel(IDictionary
protected override Double GetSemivarianceCore(Double distance, EmpiricalFunctionCoefficients coefficients);
protected override Double GetSillSlopeCore(Double distance, Double range);
public class ClassBreakStyle : Style {
protected override void DrawSampleCore(GeoCanvas canvas, DrawingRectangleF drawingExtent);
public enum DatabaseConnectionMode {
Default,
AutoClose,
KeepOpen
public class DataGridPrinterLayer : PrinterLayer {
public DataGridPrinterLayer(DataTable dataTable, GeoFont textFont, GeoFont columnFont);
public DataGridResizeMode DataGridResizeMode { get; set; }
public GeoFont HeaderTextFont { get; set; }
public enum DataGridResizeMode {
Default,
AutoFit,
Fixed
public class DbfColumn : FeatureSourceColumn {
public String ColumnName { get; set; }
public static class DecimalDegreesHelper {
public static Double GetLatitudeDifferenceFromDistance(Double distance, DistanceUnit distanceUnit);
[ObsoleteAttribute("This method is obsoleted, please use GetLatitudeDifferenceFromDistance(double distance, DistanceUnit distanceUnit) instead. This API is obsolete and may be removed in or after Version 8.0.")]
public static Double GetLatitudeDifferenceFromDistance(Double distance, DistanceUnit distanceUnit, Double longitude);
public enum DistanceUnit {
Inch,
Link,
Chain,
Pole,
Rod,
Furlong,
Vara,
Arpent
public class DynamicIsoLineLayer : IsoLineLayer {
[ObsoleteAttribute("This method is obsolete, please use DynamicIsoLineLayer(IDictionary
public DynamicIsoLineLayer(Dictionary
public DynamicIsoLineLayer(IDictionary
public class EllipseShape : AreaBaseShape {
protected override Byte[] GetWellKnownBinaryCore(RingOrder outerRingOrder, WkbByteOrder byteOrder);
protected Byte[] GetWellKnownBinaryCore(RingOrder outerRingOrder, WkbByteOrder byteOrder, Int32 vertexCountInQuarter);
protected override String GetWellKnownTextCore();
protected override String GetWellKnownTextCore(RingOrder outerRingOrder);
protected String GetWellKnownTextCore(RingOrder outerRingOrder, Int32 vertexCountInQuarter);
protected override Byte[] GetWellKnownBinaryCore(WkbByteOrder byteOrder);
public class EmpiricalFunctionCoefficients {
public EmpiricalFunctionCoefficients();
public EmpiricalFunctionCoefficients(Double range, Double sill, Double nugget);
public Double Nugget { get; set; }
public Double Range { get; set; }
public Double Sill { get; set; }
public enum ExecutingSqlStatementType {
ExecuteSpatialQuery
public class ExponentialKrigingGridInterpolationModel : KrigingGridInterpolationModel {
public ExponentialKrigingGridInterpolationModel();
public ExponentialKrigingGridInterpolationModel(IDictionary
public class Feature {
public Feature();
public Feature(String wellKnownText);
public Feature(Vertex vertex);
public Feature(BaseShape baseShape);
public Feature(Byte[] wellKnownBinary);
public Feature(Double x, Double y);
public Feature(Vertex vertex, String id);
public Feature(BaseShape baseShape, IEnumerable
public Feature(String wellKnownText, String id);
public Feature(BaseShape baseShape, IDictionary
public Feature(Byte[] wellKnownBinary, String id);
public Feature(Double x, Double y, String id);
public Feature(Vertex vertex, String id, IDictionary
public Feature(Vertex vertex, String id, IEnumerable
public Feature(String wellKnownText, String id, IEnumerable
public Feature(String wellKnownText, String id, IDictionary
public Feature(Byte[] wellKnownBinary, String id, IDictionary
public Feature(Byte[] wellKnownBinary, String id, IEnumerable
public Feature(Double x, Double y, String id, IDictionary
public Feature(Double x, Double y, String id, IEnumerable
public Boolean CanMakeValid { get; }
[ObsoleteAttribute("This property is obsoleted, please use method GetWellKnownBinary instead. This property is obsolete and may be removed in or after version 8.0.")]
public Byte[] WellKnownBinary { get; set; }
public Dictionary
public Object Tag { get; set; }
public String Id { get; set; }
public Feature Buffer(Double distance, GeographyUnit featureUnit, DistanceUnit distanceUnit);
public Feature Buffer(Double distance, Int32 quadrantSegments, GeographyUnit featureUnit, DistanceUnit distanceUnit);
public Feature Buffer(Double distance, Int32 quadrantSegments, BufferCapType bufferCapType, GeographyUnit featureUnit, DistanceUnit distanceUnit);
public Feature CloneDeep();
public Feature CloneDeep(ReturningColumnsType returningColumnNamesType);
public Feature CloneDeep(IEnumerable
public Boolean Contains(Feature targetFeature);
public Boolean Crosses(Feature targetFeature);
public RectangleShape GetBoundingBox();
public Feature GetConvexHull();
public Feature GetDifference(Feature targetFeature);
public Feature GetIntersection(Feature targetFeature);
public String GetInvalidReason();
public BaseShape GetShape();
public Byte[] GetWellKnownBinary();
public Byte[] GetWellKnownBinary(WkbByteOrder byteOrder);
public String GetWellKnownText();
public WellKnownType GetWellKnownType();
public Boolean Intersects(Feature targetFeature);
public Boolean IsDisjointed(Feature targetFeature);
public Boolean IsTopologicallyEqual(Feature targetFeature);
public Boolean IsValid();
public Boolean IsWithin(Feature targetFeature);
public Feature MakeValid();
public Boolean Overlaps(Feature targetFeature);
public Boolean Touches(Feature targetFeature);
public Feature Union(Feature targetFeature);
public override String ToString();
protected virtual Byte[] GetWellKnownBinaryCore(RingOrder outerRingOrder);
protected virtual String GetWellKnownTextCore(RingOrder outerRingOrder);
public static Feature CreateFeatureFromGeoJson(String geoJson);
public static Feature CreateFeatureFromWellKnownData(String wellKnownText);
public static Feature CreateFeatureFromWellKnownData(Byte[] wellKnownBinary);
public abstract class FeatureSource {
public Boolean CanModifyColumnStructure { get; }
public void AddColumn(FeatureSourceColumn featureSourceColumn);
public void DeleteColumn(String columnName);
public void UpdateColumn(String columnName, FeatureSourceColumn newFeatureSourceColumn);
protected virtual Boolean CanModifyColumnStructureCore { get; set; }
public class FileGeoDatabaseFeatureLayer : FeatureLayer {
public FileGeoDatabaseFeatureLayer();
public FileGeoDatabaseFeatureLayer(String fileGeoDatabasePathName, String tableName);
public FileGeoDatabaseFeatureLayer(String fileGeoDatabasePathName, String tableName, String featureIdColumn);
public override Boolean HasBoundingBox { get; }
public String FeatureIdColumn { get; set; }
public String PathName { get; set; }
public String TableName { get; set; }
public String GetInternalProj4ProjectionParametersString();
public static void CreateFileGeoDatabase(String fileGeoDatabasePathName);
public static void CreateTable(String fileGeoDatabasePathName, String tableName, WellKnownType wellKnownType, IEnumerable
public static Collection
public class FileGeoDatabaseFeatureSource : FeatureSource {
public FileGeoDatabaseFeatureSource();
public FileGeoDatabaseFeatureSource(String fileGeoDatabasePathName, String tableName);
public FileGeoDatabaseFeatureSource(String fileGeoDatabasePathName, String tableName, String featureIdColumn);
public override Boolean IsEditable { get; }
protected override void CloseCore();
protected override TransactionResult CommitTransactionCore(TransactionBuffer transactions);
protected override Int32 ExecuteNonQueryCore(String sqlStatement);
protected override DataTable ExecuteQueryCore(String sqlStatement);
protected override Object ExecuteScalarCore(String sqlStatement);
protected override Collection
protected override RectangleShape GetBoundingBoxByIdCore(String id);
protected override RectangleShape GetBoundingBoxCore();
protected override Int32 GetCountCore();
protected override WellKnownType GetFirstFeaturesWellKnownTypeCore();
protected override void OpenCore();
public class GaussianKrigingGridInterpolationModel : KrigingGridInterpolationModel {
public GaussianKrigingGridInterpolationModel();
public GaussianKrigingGridInterpolationModel(IDictionary
public class GeneratingGridFeatureSourceEventArgs : EventArgs {
public GeneratingGridFeatureSourceEventArgs();
public GeneratingGridFeatureSourceEventArgs(Int32 gridCount, Int32 gridIndex, DateTime startProcessTime, Boolean isCanceled);
public GeneratingGridFeatureSourceEventArgs(Int32 gridCount, Int32 gridIndex, DateTime startProcessTime, Boolean isCanceled, String gridPathFileName);
public Boolean IsCanceled { get; set; }
public DateTime StartProcessTime { get; set; }
public Int32 GridCount { get; set; }
public Int32 GridIndex { get; set; }
public String GridPathFileName { get; set; }
public abstract class GeoCanvas {
[ObsoleteAttribute("This item is obsoleted, Clipping is always enabled if the ClippingArea property is set. This API is obsolete and may be removed in or after Version 8.0.")]
public Boolean EnableCliping { get; set; }
[ObsoleteAttribute("This item is obsoleted, please use ClippingArea instead. This API is obsolete and may be removed in or after Version 8.0.")]
public RectangleShape ClipingArea { get; set; }
public RectangleShape ClippingArea { get; set; }
public class GeoDbf : IDisposable {
public class GeometryCollectionShape : BaseShape {
protected override PointShape GetClosestPointToCore(BaseShape targetShape, GeographyUnit shapeUnit);
protected override void LoadFromWellKnownDataCore(Byte[] wellKnownBinary);
public class GettingCacheImageBitmapTileCacheEventArgs : EventArgs {
public GettingCacheImageBitmapTileCacheEventArgs();
public GettingCacheImageBitmapTileCacheEventArgs(BitmapTile bitmapTile);
public BitmapTile BitmapTile { get; set; }
public class GoogleMapsLayer : Layer {
public GoogleMapsLayer(String cacheDirectory, String apiKey);
public GoogleMapsLayer(String cacheDirectory, String apiKey, WebProxy webProxy);
public Int32 TileHeight { get; set; }
public Int32 TileWidth { get; set; }
public String ApiKey { get; set; }
public class GottenCacheImageBitmapTileCacheEventArgs : EventArgs {
public GottenCacheImageBitmapTileCacheEventArgs();
public GottenCacheImageBitmapTileCacheEventArgs(BitmapTile bitmapTile);
public class GridFeatureSource : FeatureSource {
public static event EventHandler
public class GridIsoLineLayer : IsoLineLayer {
public GridIsoLineLayer(String gridPathFileName gridPathFilename);
public GridIsoLineLayer(String gridPathFileName gridPathFilename, IEnumerable
public GridIsoLineLayer(String gridPathFileName, IEnumerable
public class HeatStyle : Style {
public HeatStyle(String intensityColumnName, Double intensityRangeStart, Double intensityRangeEnd);
public HeatStyle(Int32 alpha, String intensityColumnName, Double intensityRangeStart, Double intensityRangeEnd);
public HeatStyle(String intensityColumnName, Double intensityRangeStart, Double intensityRangeEnd, Double pointRadius, DistanceUnit pointRadiusUnit);
public HeatStyle(Int32 alpha, String intensityColumnName, Double intensityRangeStart, Double intensityRangeEnd, Double pointRadius, DistanceUnit pointRadiusUnit);
public HeatStyle(Int32 pointIntensity, Int32 alpha, String intensityColumnName, Double intensityRangeStart, Double intensityRangeEnd, Double pointRadius, DistanceUnit pointRadiusUnit);
public HeatStyle(Int32 alpha, String intensityColumnName, Double intensityRangeStart, Int32 intensityRangeEnd);
public HeatStyle(String intensityColumnName, Double intensityRangeStart, Int32 intensityRangeEnd);
public HeatStyle(String intensityColumnName, Double intensityRangeStart, Int32 intensityRangeEnd, Double pointRadius, DistanceUnit pointRadiusUnit);
public HeatStyle(Int32 pointIntensity, Int32 alpha, String intensityColumnName, Double intensityRangeStart, Int32 intensityRangeEnd, Double pointRadius, DistanceUnit pointRadiusUnit);
public HeatStyle(Int32 alpha, String intensityColumnName, Double intensityRangeStart, Int32 intensityRangeEnd, Double pointRadius, DistanceUnit pointRadiusUnit);
public class IconStyle : TextStyle {
public class IconValueStyle : PositionStyle {
public Boolean AllowLineCarriage { get; set; }
public Boolean BestPlacement { get; set; }
public LabelDuplicateRule DuplicateRule { get; set; }
public Boolean FittingPolygon { get; set; }
public Double FittingPolygonFactor { get; set; }
public Boolean ForceLineCarriage { get; set; }
public Int32 GridSize { get; set; }
public Boolean LabelAllLineParts { get; set; }
public Boolean LabelAllPolygonParts { get; set; }
public LabelOverlappingRule OverlappingRule { get; set; }
public PointPlacement PointPlacement { get; set; }
public PolygonLabelingLocationMode PolygonLabelingLocationMode { get; set; }
public Boolean SuppressPartialLabels { get; set; }
public Double TextLineSegmentRatio { get; set; }
public class InMemoryGridIsoLineLayer : IsoLineLayer {
public InMemoryGridIsoLineLayer(GridCell[,] gridMatrix, Double noDataValue);
public InMemoryGridIsoLineLayer(GridCell[,] gridMatrix, IEnumerable
public abstract class IsoLineLayer : Layer {
protected IsoLineLayer(IEnumerable
public Double NoDataValue { get; set; }
public IsoLineType IsoLineType { get; set; }
public abstract class KrigingGridInterpolationModel : GridInterpolationModel {
protected KrigingGridInterpolationModel();
protected KrigingGridInterpolationModel(IDictionary
public Dictionary
public Int32 NumberOfReferencedPoints { get; set; }
public EmpiricalFunctionCoefficients GetEmpiricalFunctionCoefficients(Int32 numberOfPoints, Double[,] distance, Double[,] semivariances, Double maxRange);
public Double GetSemivariance(Double distance, EmpiricalFunctionCoefficients coefficients);
protected virtual EmpiricalFunctionCoefficients GetEmpiricalFunctionCoefficientsCore(Int32 points, Double[,] distance, Double[,] semivariances, Double maxRange);
protected virtual Double GetSemivarianceCore(Double distance, EmpiricalFunctionCoefficients coefficients);
protected Double GetSillSlope(Double distance, Double range);
protected abstract Double GetSillSlopeCore(Double distance, Double range);
protected override Double InterpolateCore(RectangleShape cellExtent, GridDefinition gridDefinition);
public class LinealKrigingGridInterpolationModel : KrigingGridInterpolationModel {
public LinealKrigingGridInterpolationModel();
public LinealKrigingGridInterpolationModel(IDictionary
public class LineShape : LineBaseShape {
protected override PointShape GetCenterPointCore();
[ObsoleteAttribute("This API is obsolete, please use GetLineOnALineCore(StartingPoint startingPoint, double startingDistance, double distance, GeographyUnit shapeUnit, DistanceUnit distanceUnit) instead. This API is obsolete and may be removed in or after Version 7.0.")]
protected virtual LineBaseShape GetLineOnALineCore(StartingPoint startingPoint, PointShape endPointShape);
protected virtual LineBaseShape GetLineOnALineCore(StartingPoint startingPoint, Single percentageOfLine);
protected virtual LineBaseShape GetLineOnALineCore(PointShape startPointShape, PointShape endPointShape);
[ObsoleteAttribute("This API is obsolete, please use GetPointOnALineCore(StartingPoint startingPoint, double distance, GeographyUnit shapeUnit, DistanceUnit distanceUnit) instead. This API is obsolete and may be removed in or after Version 7.0.")]
protected virtual PointShape GetPointOnALineCore(StartingPoint startingPoint, Single percentageOfLine);
public class ManagedProj4Projection : Projection {
protected override RasterProjectionResult ConvertToExternalProjectionCore(GeoImage image, RectangleShape imageExtent);
public enum MapPrinterDrawingMode {
Default,
Raster,
Vector
public class MapPrinterLayer : PrinterLayer {
public MapPrinterDrawingMode DrawingMode { get; set; }
public class MsSql2008FeatureLayer : FeatureLayer {
public MsSql2008FeatureLayer(String connectionString, String tableName, String featureIdColumn, DatabaseConnectionMode databaseConnectionMode);
public MsSql2008FeatureLayer(String connectionString, String tableName, String featureIdColumn, Int32 srid, DatabaseConnectionMode databaseConnectionMode);
public DatabaseConnectionMode DatabaseConnectionMode { get; set; }
public class MsSql2008FeatureSource : FeatureSource {
public MsSql2008FeatureSource(String connectionString, String tableName, String featureIdColumn, DatabaseConnectionMode databaseConnectionMode);
public MsSql2008FeatureSource(String connectionString, String tableName, String featureIdColumn, Int32 srid, DatabaseConnectionMode databaseConnectionMode);
public class MultilineShape : LineBaseShape {
public class MultipointShape : PointBaseShape {
public class MultipolygonShape : AreaBaseShape {
public class OracleFeatureLayer : FeatureLayer {
public OracleFeatureLayer();
public OracleFeatureLayer(String connectionString, String tableName, String featureIdColumn);
public OracleFeatureLayer(String connectionString, String tableName, String featureIdColumn, DatabaseConnectionMode databaseConnectionMode);
public Int32 CommandTimeout { get; set; }
public String ConnectionString { get; set; }
public String WhereClause { get; set; }
public void BuildIndex();
public void BuildIndex(BuildIndexMode mode);
public Int32 ExecuteNonQuery(String sqlStatement);
public class OracleFeatureSource : FeatureSource {
public OracleFeatureSource();
public OracleFeatureSource(String connectionString, String tableName, String featureIdColumn);
public OracleFeatureSource(String connectionString, String tableName, String featureIdColumn, DatabaseConnectionMode databaseConnectionMode);
protected override Boolean CanExecuteSqlQueryCore { get; }
public class PointShape : PointBaseShape {
public class PolygonShape : AreaBaseShape {
public abstract class PositionStyle : Style {
public protected Boolean AllowLineCarriage { get; set; }
public protected Boolean BestPlacement { get; set; }
public protected Boolean FittingPolygon { get; set; }
public protected Boolean ForceLineCarriage { get; set; }
public protected Boolean LabelAllLineParts { get; set; }
public protected Boolean LabelAllPolygonParts { get; set; }
public protected Boolean SuppressPartialLabels { get; set; }
public protected Double FittingPolygonFactor { get; set; }
public protected Double TextLineSegmentRatio { get; set; }
public protected Int32 GridSize { get; set; }
public protected LabelDuplicateRule DuplicateRule { get; set; }
public protected LabelOverlappingRule OverlappingRule { get; set; }
public protected PointPlacement PointPlacement { get; set; }
public protected PolygonLabelingLocationMode PolygonLabelingLocationMode { get; set; }
protected Boolean FittingPolygonInScreen { get; set; }
public enum PrinterDragMode {
Draggable
Dragable
public class Proj4Projection : Projection, IDisposable {
public static String GetBingMapParametersString();
public static String GetSphericalMercatorParametersString();
public abstract class Projection {
public Boolean CanConvertRasterToExternalProjection { get; protected set; }
public RasterProjectionResult ConvertToExternalProjection(GeoImage image, RectangleShape imageExtent);
protected virtual RasterProjectionResult ConvertToExternalProjectionCore(GeoImage image, RectangleShape imageExtent);
public class RasterProjectionResult {
public RasterProjectionResult();
public RasterProjectionResult(GeoImage image, RectangleShape imageExtent);
public GeoImage Image { get; set; }
public RectangleShape ImageExtent { get; set; }
public abstract class RasterSource {
public Projection Projection { get; set; }
public class RectangleShape : AreaBaseShape {
public enum RingOrder {
Unknown,
Clockwise,
Counterclockwise
public class RingShape : AreaBaseShape {
public class ScaleBarAdornmentLayer : AdornmentLayer {
public String ProjectionParametersString { get; set; }
public class ScaleLineAdornmentLayer : AdornmentLayer {
public ScaleLineUnitSystem UnitSystem { get; set; }
public class ScaleLinePrinterLayer : PrinterLayer {
public enum ScaleLineUnitSystem {
Default,
MetricAndNauticalMile,
NauticalMileAndImperial,
ImperialAndMetric
public struct ScreenPointF {
public class ShapeFileFeatureLayer : FeatureLayer {
public class ShapeFileFeatureSource : FeatureSource {
public class SphericalKrigingGridInterpolationModel : KrigingGridInterpolationModel {
public SphericalKrigingGridInterpolationModel();
public SphericalKrigingGridInterpolationModel(IDictionary
public class SphericalMercatorZoomLevelSet : ZoomLevelSet {
public SphericalMercatorZoomLevelSet();
public static class SqlTypesGeometryHelper {
public static MultipolygonShape Buffer(BaseShape baseShape, Double distance, GeographyUnit shapeUnit, DistanceUnit distanceUnit);
public static Feature Buffer(Feature feature, Double distance, GeographyUnit featureUnit, DistanceUnit distanceUnit);
public static MultipolygonShape Buffer(BaseShape baseShape, Double distance, Int32 quadrantSegments, GeographyUnit shapeUnit, DistanceUnit distanceUnit);
public static Feature Buffer(Feature feature, Double distance, Int32 quadrantSegments, GeographyUnit featureUnit, DistanceUnit distanceUnit);
public static MultipolygonShape Buffer(BaseShape baseShape, Double distance, Int32 quadrantSegments, BufferCapType bufferCapType, GeographyUnit shapeUnit, DistanceUnit distanceUnit);
public static Feature Buffer(Feature feature, Double distance, Int32 quadrantSegments, BufferCapType bufferCapType, GeographyUnit featureUnit, DistanceUnit distanceUnit);
public static Boolean Contains(BaseShape shape, BaseShape targetShape);
public static Boolean Contains(BaseShape shape, Feature targetFeature);
public static Boolean Contains(Feature feature, Feature targetFeature);
public static Boolean Crosses(BaseShape shape, BaseShape targetShape);
public static Boolean Crosses(BaseShape shape, Feature targetFeature);
public static Boolean Crosses(Feature feature, Feature targetFeature);
public static PointShape GetCenterPoint(BaseShape shape);
public static RingShape GetConvexHull(BaseShape shape);
public static Feature GetConvexHull(Feature feature);
public static MultipointShape GetCrossing(LineBaseShape shape, BaseShape targetShape);
public static MultipolygonShape GetDifference(AreaBaseShape shape, Feature targetFeature);
public static MultipolygonShape GetDifference(AreaBaseShape shape, AreaBaseShape targetShape);
public static Feature GetDifference(Feature feature, Feature targetFeature);
public static Double GetDistanceTo(Feature feature, Feature targetFeature, GeographyUnit shapeUnit, DistanceUnit distanceUnit);
public static Double GetDistanceTo(BaseShape shape, Feature targetFeature, GeographyUnit shapeUnit, DistanceUnit distanceUnit);
public static Double GetDistanceTo(BaseShape shape, BaseShape targetShape, GeographyUnit shapeUnit, DistanceUnit distanceUnit);
public static Feature GetIntersection(Feature feature, Feature targetFeature);
public static BaseShape GetIntersection(BaseShape shape, AreaBaseShape targetShape);
public static String GetInvalidReason(Feature feature);
public static MultipolygonShape GetSymmetricalDifference(AreaBaseShape shape, AreaBaseShape targetShape);
public static MultipolygonShape GetSymmetricalDifference(AreaBaseShape shape, Feature targetFeature);
public static Boolean Intersects(BaseShape shape, BaseShape targetShape);
public static Boolean Intersects(BaseShape shape, Feature targetFeature);
public static Boolean Intersects(Feature feature, Feature targetFeature);
public static Boolean IsDisjointed(BaseShape shape, BaseShape targetShape);
public static Boolean IsDisjointed(BaseShape shape, Feature targetFeature);
public static Boolean IsDisjointed(Feature feature, Feature targetFeature);
public static Boolean IsTopologicallyEqual(BaseShape shape, BaseShape targetShape);
public static Boolean IsTopologicallyEqual(BaseShape shape, Feature targetFeature);
public static Boolean IsTopologicallyEqual(Feature feature, Feature targetFeature);
public static Boolean IsValid(Feature feature);
public static Boolean IsWithin(BaseShape shape, BaseShape targetShape);
public static Boolean IsWithin(BaseShape shape, Feature targetFeature);
public static Boolean IsWithin(Feature feature, Feature targetFeature);
public static Feature MakeValid(Feature feature);
public static Boolean Overlaps(BaseShape shape, BaseShape targetShape);
public static Boolean Overlaps(BaseShape shape, Feature targetFeature);
public static Boolean Overlaps(Feature feature, Feature targetFeature);
public static Boolean Touches(BaseShape shape, BaseShape targetShape);
public static Boolean Touches(BaseShape shape, Feature targetFeature);
public static Boolean Touches(Feature feature, Feature targetFeature);
public static MultipolygonShape Union(IEnumerable
public static MultilineShape Union(IEnumerable
public static Feature Union(IEnumerable
public static MultilineShape Union(LineBaseShape shape, Feature targetFeature);
public static MultilineShape Union(LineBaseShape shape, LineBaseShape targetShape);
public static Feature Union(Feature feature, Feature targetFeature);
public static MultipolygonShape Union(AreaBaseShape shape, Feature targetFeature);
public static MultipolygonShape Union(AreaBaseShape shape, AreaBaseShape targetShape);
public static ShapeValidationResult Validate(BaseShape shape, ShapeValidationMode validationMode);
public class TabFeatureLayer : FeatureLayer {
public TabFeatureLayer(String tabPathFileName tabPathFilename);
public TabFeatureLayer(String tabPathFileName tabPathFilename, TabFileReadWriteMode readWriteMode);
public static void BuildIndexFile(String tabPathFileName tabPathFilename);
public static void BuildIndexFile(String tabPathFileName tabPathFilename, BuildIndexMode buildIndexMode);
public static void BuildRecordIdColumn(String tabFileName, String fieldName, BuildRecordIdMode buildRecordIdMode);
public static void BuildRecordIdColumn(String tabFileName, String fieldName, BuildRecordIdMode buildRecordIdMode, Int32 startNumber);
public static void BuildRecordIdColumn(String tabFileName, String fieldName, BuildRecordIdMode buildRecordIdMode, Int32 startNumber, Encoding encoding);
public static void CreateTabFile(String tabPathFileName tabPathFilename, IEnumerable
public class TabFeatureSource : FeatureSource {
public TabFeatureSource(String tabPathFileName tabPathFilename);
public TabFeatureSource(String tabPathFileName tabPathFilename, TabFileReadWriteMode readWriteMode);
public class TextStyle : PositionStyle {
public Boolean FittingPolygonInScreen { get; set; }
public class TiledWmsLayer : Layer {
public TimeSpan CapabilitesCacheTimeout { get; set; }
public WmsAxisOrder AxisOrder { get; set; }
[ObsoleteAttribute("This method is obsolete, please use OnSendingWebRequest instead. This API is obsolete and may be removed in or after Version 7.0.")]
protected virtual void OnSendingRequest(SendingRequestTiledWmsLayerEventArgs e);
[ObsoleteAttribute("This method is obsolete, please use OnSentWebRequest instead. This API is obsolete and may be removed in or after Version 7.0.")]
protected virtual void OnSentRequest(SentRequestTiledWmsLayerEventArgs e);
public class TileMatrixSet {
public TileMatrixSet(String id, String crs);
public class TinyGeoFeatureLayer : FeatureLayer {
public TinyGeoFileType GetTinyGeoFileType();
public class TinyGeoFeatureSource : FeatureSource {
public enum TinyGeoFileType {
Point,
Polyline,
Polygon
public static class TopologyValidator {
public class TransactionBuffer {
public Collection
public Collection
public Dictionary
public class UnmanagedProj4Projection : Projection, IDisposable {
public class ValueStyle : Style {
public enum WmsAxisOrder {
Default,
XY,
YX
public class WmsRasterLayer : RasterLayer {
public TimeSpan CapabilitesCacheTimeOut { get; set; }
public class WmsRasterSource : RasterSource {
protected virtual void OnSendingRequest(SendingRequestWmsRasterSourceEventArgs e);
protected virtual void OnSentRequest(SentRequestWmsRasterSourceEventArgs e);
public class WmtsLayer : Layer {
public WmtsLayer();
public WmtsLayer(IEnumerable
public BitmapTileCache TileCache { get; set; }
public Collection
public Dictionary
public Double LowerScale { get; set; }
public Double UpperScale { get; set; }
public ICredentials Credentials { get; set; }
public Int32 TimeoutInSeconds { get; set; }
public String ActiveLayerName { get; set; }
public String ActiveStyleName { get; set; }
public String OutputFormat { get; set; }
public String TileMatrixSetName { get; set; }
public WebProxy WebProxy { get; set; }
public WmtsSeverEncodingType WmtsSeverEncodingType { get; set; }
public Collection
public Collection
public String GetServerCapabilitiesXml();
public Collection
public Collection
public Collection
protected override void DrawCore(GeoCanvas canvas, Collection
protected override void DrawExceptionCore(GeoCanvas canvas, Exception e);
protected virtual Collection
[ObsoleteAttribute("This method is obsoleted. This API is only used internally and will be replaced by a new API in the near future. Please do not call this API.")]
protected override ThreadSafetyLevel GetThreadSafetyLevelCore();
protected virtual void OnSendingWebRequest(SendingWebRequestEventArgs e);
protected virtual void OnSentWebRequest(SentWebRequestEventArgs e);
protected WebResponse SendWebRequest(WebRequest webRequest);
protected virtual WebResponse SendWebRequestCore(WebRequest webRequest);
public enum WmtsSeverEncodingType {
Kvp,
Restful
public class WmtsTileMatrix : TileMatrix {
public WmtsTileMatrix(String id, Double scale, Int32 tileWidth, Int32 tileHeight, GeographyUnit unit);
protected override Double GetResolutionFromScale(Double scale);
public sealed enum BingMapsLogoMode;
public struct Feature {
public Dictionary
[ObsoleteAttribute("This method is obsolete, please use property WellKnownBinary instead. This API is obsolete and may be removed in or after version 7.0.")]
public override Boolean Equals(Object obj);
public override Int32 GetHashCode();
public static Boolean operator==(Feature feature1, Feature feature2);
public static Boolean operator!=(Feature feature1, Feature feature2);
public class GoogleMapZoomLevelSet;
public class SendingRequestBingMapsLayerEventArgs;
public class SendingRequestWmsRasterSourceEventArgs;
public class SentRequestBingMapsLayerEventArgs;
public class SentRequestWmsRasterSourceEventArgs;
public static class SerializationHelper;
public class VirtualEarthZoomLevelSet;
public class YahooMapZoomLevelSet;
public class YahooMapsLayer;
public sealed enum YahooMapsPictureFormat;
