map_suite_services_edition_features_bug_fixes_change_log [2015/09/09 08:36] admin [Version 5.0.0.0] |
map_suite_services_edition_features_bug_fixes_change_log [2015/09/16 06:59] (current) admin [Version 3.1.0] |
| - | ====== Map_Suite_Services_Edition_Features_&_Bug_Fixes_Change_Log ====== | + | ====== Map Suite Services Edition Features & Bug Fixes Change Log ====== |
| - | {{article rating}} | ||
| =====Version 9.0.0.0===== | =====Version 9.0.0.0===== | ||
| Release date: 06/24/2015 | Release date: 06/24/2015 | ||
| Line 55: | Line 54: | ||
| *Added Attribution to all layers and Overlays. | *Added Attribution to all layers and Overlays. | ||
| *Fixed a bug where the MagneticDeclinationAdornmentLayer runs into memory issue. | *Fixed a bug where the MagneticDeclinationAdornmentLayer runs into memory issue. | ||
| - | *Added the new API SetWellKnownBinary(byte[[]] wkb) to Feature class to allow changing the WKB of the feature. | + | *Added the new API SetWellKnownBinary(byte[] wkb) to Feature class to allow changing the WKB of the feature. |
| - | *Improved the performance of method byte[[]] ShapeFile.ReadPolygon(byte[[]] dataBytes, int startIndex). | + | *Improved the performance of method byte[] ShapeFile.ReadPolygon(byte[] dataBytes, int startIndex). |
| *Removed the using JTS in Feature to Shape conversion(BaseShape.FromWellKnownBinary, BaseShape.CreateShapeFromWellKnownData). | *Removed the using JTS in Feature to Shape conversion(BaseShape.FromWellKnownBinary, BaseShape.CreateShapeFromWellKnownData). | ||
| *Added enhancements to OpenStreetMapLayer and OpenStreetMapOverlay to make sure the exception can be thrown out. | *Added enhancements to OpenStreetMapLayer and OpenStreetMapOverlay to make sure the exception can be thrown out. | ||
| Line 506: | Line 505: | ||
| - | *Fixed the problem not encrypted for some private functions | + | *Fixed the problem not encrypted for some private functions |
| - | *Optimized the retrieving twice for MSSqlFeatureSource geometry column. | + | *Optimized the retrieving twice for MSSqlFeatureSource geometry column. |
| - | *Provided support for VS2010 and samples. | + | *Provided support for VS2010 and samples. |
| - | *Fixed a rounding bug in GetPointOnALine API of LineShape. | + | *Fixed a rounding bug in GetPointOnALine API of LineShape. |
| - | *Fixed an issue when using a Chinese font | + | *Fixed an issue when using a Chinese font |
| - | *Functions of MSSqlServer2008FeatureSource or Layer run to error in some specified culture. | + | *Functions of MSSqlServer2008FeatureSource or Layer run to error in some specified culture. |
| - | *Bad performance with SQLServer2008 when using Geography type and large data size. | + | *Bad performance with SQLServer2008 when using Geography type and large data size. |
| - | *Fixed an issue when using the UpdateColumnName API in dbf module. | + | *Fixed an issue when using the UpdateColumnName API in dbf module. |
| - | *Fixed an issue throwing exception when calling BuildIndex in Turkey enviroment. | + | *Fixed an issue throwing exception when calling BuildIndex in Turkey enviroment. |
| - | *Point Placement Affected by Label Length | + | *Point Placement Affected by Label Length |
| - | *WmsRasterLayer cannot work when deserialized | + | *WmsRasterLayer cannot work when deserialized |
| - | *Support .NET 3.5 Client Profiler | + | *Support .NET 3.5 Client Profiler |
| - | *Implemented INotifyCollectionChanged, INotifyPropertyChanged interface in GeoCollection | + | *Implemented INotifyCollectionChanged, INotifyPropertyChanged interface in GeoCollection |
| - | *Replaced the Proj4Projection into ManagedProj4Projection used internally | + | *Replaced the Proj4Projection into ManagedProj4Projection used internally |
| - | *Fixed the issue the RasterLayer is not drawn in the PrinterGeoCanvas. | + | *Fixed the issue the RasterLayer is not drawn in the PrinterGeoCanvas. |
| - | *Added OpenStreetMapLayer to support OpenStreetMap | + | *Added OpenStreetMapLayer to support OpenStreetMap |
| - | *Added Managed GeoTiffRasterSource | + | *Added Managed GeoTiffRasterSource |
| - | *Added GetFeatureInfo functions for WmsRasterLayer | + | *Added GetFeatureInfo functions for WmsRasterLayer |
| - | *Enhanced performance for GdiPlusRasterLayer | + | *Enhanced performance for GdiPlusRasterLayer |
| - | *Added ClusterPointStyle | + | *Added ClusterPointStyle |
| - | *Added DrawingProgressChanged event | + | *Added DrawingProgressChanged event |
| Line 532: | Line 533: | ||
| Release date: 6/15/2010 | Release date: 6/15/2010 | ||
| - | *Updated assembly version to 4.0.0.0; included strong-named and weak-named assemblies. Please see the latest post in the Developer Blog for full details. | + | *Updated assembly version to 4.0.0.0; included strong-named and weak-named assemblies. Please see the latest post in the Developer Blog for full details. |
| - | *Fixed issue with the ScaleTo API in BaseShape when called by a Rectangle Shape. | + | *Fixed issue with the ScaleTo API in BaseShape when called by a Rectangle Shape. |
| - | *Fixed issue where an exception would be thrown when calling BuildIndex in a Turkish enviroment. | + | *Fixed issue where an exception would be thrown when calling BuildIndex in a Turkish enviroment. |
| - | *Fixed issue when using the UpdateColumnName API in DBF module. | + | *Fixed issue when using the UpdateColumnName API in DBF module. |
| - | *Fixed issue involving use of Chinese fonts | + | *Fixed issue involving use of Chinese fonts |
| - | *Fixed a rounding bug in the GetPointOnALine API of LineShape. | + | *Fixed a rounding bug in the GetPointOnALine API of LineShape. |
| - | *Some minor API changes. See the API change log for complete details. | + | *Some minor API changes. See the API change log for complete details. |
| Line 547: | Line 548: | ||
| - | *Added additional helper methods to the GeoCollection class. | + | *Added additional helper methods to the GeoCollection class. |
| - | *Added better support for labeling with Asian characters. | + | *Added better support for labeling with Asian characters. |
| - | *Added support for Google Static Maps API v2. | + | *Added support for Google Static Maps API v2. |
| - | *Added simple support for Yahoo Maps. | + | *Added simple support for Yahoo Maps. |
| - | *Added support for heat map layers. | + | *Added support for heat map layers. |
| - | *Added support for 100% managed proj Projection Library. | + | *Added support for 100% managed proj Projection Library. |
| - | *Added direct support for Map Shapes. | + | *Added direct support for Map Shapes. |
| - | *Added API to modify the column name in ShapeFileFeatureSource and ShapeFileFeatureLayer. | + | *Added API to modify the column name in ShapeFileFeatureSource and ShapeFileFeatureLayer. |
| - | *Added new API BuildIndex for MultipleShapeFileFeatureLayer | + | *Added new API BuildIndex for MultipleShapeFileFeatureLayer |
| - | *Included GraticuleLineLayer support and a sample application for it. | + | *Included GraticuleLineLayer support and a sample application for it. |
| - | *Enhanced the MultiShapeFileFeaturesLayer class to allow you to use files in multiple folders. | + | *Enhanced the MultiShapeFileFeaturesLayer class to allow you to use files in multiple folders. |
| - | *Enhanced the distance measuring method to use the Haversine formula. | + | *Enhanced the distance measuring method to use the Haversine formula. |
| - | *Improved GeoCache performance. | + | *Improved GeoCache performance. |
| - | *Updated the PostgreSQL Assembly versions. | + | *Updated the PostgreSQL Assembly versions. |
| - | *Exposed the DBaseFile class library. | + | *Exposed the DBaseFile class library. |
| - | *Exposed the disk-based RTree Spatial Index. | + | *Exposed the disk-based RTree Spatial Index. |
| - | *Split up the Map Suite MergeModule into smaller and more manageable pieces. | + | *Split up the Map Suite MergeModule into smaller and more manageable pieces. |
| - | *Fixed issue where GetCenterPoint using NTS would return an invalid value when the polygon's width and height is 0. | + | *Fixed issue where GetCenterPoint using NTS would return an invalid value when the polygon's width and height is 0. |
| - | *Fixed issue regarding GetBoundingBox of GroupLayer. | + | *Fixed issue regarding GetBoundingBox of GroupLayer. |
| - | *Fixed issue where GetAllColumns also returns the Geometries column. | + | *Fixed issue where GetAllColumns also returns the Geometries column. |
| - | *Many API additions. See the API change log for complete details. | + | *Many API additions. See the API change log for complete details. |
| - | *Updated the API documentation. | + | *Updated the API documentation. |
| Line 575: | Line 576: | ||
| - | *Fixed issue where SaveToProjection is incorrect for some data. | + | *Fixed issue where SaveToProjection is incorrect for some data. |
| - | *Fixed issue with the DecimalDegreesHelper API GetDecimalDegreeFromDegreesMinutesSeconds. | + | *Fixed issue with the DecimalDegreesHelper API GetDecimalDegreeFromDegreesMinutesSeconds. |
| - | *Fixed caculation issue in DecimalDegreeHelper.GetDistanceFromDecimalDegrees when passing particular data. | + | *Fixed caculation issue in DecimalDegreeHelper.GetDistanceFromDecimalDegrees when passing particular data. |
| - | *Fixed issue where an exception is thrown for TAB files when the column name starts with an underscore(_). | + | *Fixed issue where an exception is thrown for TAB files when the column name starts with an underscore(_). |
| Line 587: | Line 588: | ||
| - | *Added Haversine formula to calculate distance. | + | *Added Haversine formula to calculate distance. |
| - | *Added DrawException method to draw exceptions rather than throwing them in the Overlay and Layer. | + | *Added DrawException method to draw exceptions rather than throwing them in the Overlay and Layer. |
| - | *Added IndexedInMemoryFeatureLayer Class. | + | *Added IndexedInMemoryFeatureLayer Class. |
| - | *Added ReadOnly logic to ClearCache and DeleteTile methods. | + | *Added ReadOnly logic to ClearCache and DeleteTile methods. |
| - | *Added the schema supported in PostgreFeatureSource. | + | *Added the schema supported in PostgreFeatureSource. |
| - | *Added API overloads for GetFeaturesByColumnValue method. | + | *Added API overloads for GetFeaturesByColumnValue method. |
| - | *Added API to detect the feature type in FeatureSource. | + | *Added API to detect the feature type in FeatureSource. |
| - | *Added API BuildIndex in InMemoryFeatureLayer. | + | *Added API BuildIndex in InMemoryFeatureLayer. |
| - | *Enhanced the Sql2008FeatureSource, PostgreFeatureSource and OracleFeatureSource by adding one event ExecutingSqlStatement. | + | *Enhanced the Sql2008FeatureSource, PostgreFeatureSource and OracleFeatureSource by adding one event ExecutingSqlStatement. |
| - | *Extended the KeyColor from one color to an array of colors or a range of colors. | + | *Extended the KeyColor from one color to an array of colors or a range of colors. |
| - | *Fixed a memory leak when calling OpenAllLayers multiple times. | + | *Fixed a memory leak when calling OpenAllLayers multiple times. |
| - | *Fixed issue where ApplyUntilZoomLevel doesn't work right when using CustomZoomLevel. | + | *Fixed issue where ApplyUntilZoomLevel doesn't work right when using CustomZoomLevel. |
| - | *Fixed OutofMemory exception issue in WFSFeatureSource. | + | *Fixed OutofMemory exception issue in WFSFeatureSource. |
| - | *Fixed issue where SaveToProjection in ShapeFileFeatureSource would throw an out of memory exception. | + | *Fixed issue where SaveToProjection in ShapeFileFeatureSource would throw an out of memory exception. |
| - | *Fixed issue with the Stream_Loading event in ShapeFileFeatureSource. | + | *Fixed issue with the Stream_Loading event in ShapeFileFeatureSource. |
| - | *Fixed issue with obfuscation in autobuild. | + | *Fixed issue with obfuscation in autobuild. |
| - | *Fixed issue where the WMS cannot work properly when the network is unavailable. | + | *Fixed issue where the WMS cannot work properly when the network is unavailable. |
| - | *Fixed issue where GetRandomColor always get the same color. | + | *Fixed issue where GetRandomColor always get the same color. |
| - | *Fixed issue where CloneDeep of InMemoryFeatureSource does not work. | + | *Fixed issue where CloneDeep of InMemoryFeatureSource does not work. |
| - | *Fixed issue where InmemoryFeatureSource cannot be serialized correctly. | + | *Fixed issue where InmemoryFeatureSource cannot be serialized correctly. |
| - | *Fixed issue where you could not parse the parent layer in a WMS server. | + | *Fixed issue where you could not parse the parent layer in a WMS server. |
| - | *Fixed issue where an OutOfMemory error occurs while drawing. | + | *Fixed issue where an OutOfMemory error occurs while drawing. |
| - | *Fixed issue with support for Geography type data in MsSqlFeatureSource. | + | *Fixed issue with support for Geography type data in MsSqlFeatureSource. |
| - | *Fixed issue with the GetFeaturesInsideBoundingBox method of MultipleShapeFileFeatureSource. | + | *Fixed issue with the GetFeaturesInsideBoundingBox method of MultipleShapeFileFeatureSource. |
| - | *Fixed issue where GetCenterPoint using NTS will return an invalid value when the polygon's width and height is 0. | + | *Fixed issue where GetCenterPoint using NTS will return an invalid value when the polygon's width and height is 0. |
| - | *Fixed issue regarding thrown exception ORA-00936: Missing Expression. | + | *Fixed issue regarding thrown exception ORA-00936: Missing Expression. |
| - | *Fixed issue where GetPointOnALine returns the wrong value. | + | *Fixed issue where GetPointOnALine returns the wrong value. |
| - | *Fixed issue where GdiPlusRasterLayer has a black line in tile mode. | + | *Fixed issue where GdiPlusRasterLayer has a black line in tile mode. |
| - | *Fixed issue with the GetFeatureById API in WfsFeatureLayer. | + | *Fixed issue with the GetFeatureById API in WfsFeatureLayer. |
| - | *Fixed very low performance issue with GetColumnsCore. | + | *Fixed very low performance issue with GetColumnsCore. |
| - | *Fixed issue with missing tag information in InMemoryFeatureLayer. | + | *Fixed issue with missing tag information in InMemoryFeatureLayer. |
| - | *Fixed non-serializable issue for WFSFeatureLayer. | + | *Fixed non-serializable issue for WFSFeatureLayer. |
| - | *Fixed issue where an exception was thrown when building an index for an empty shape file. | + | *Fixed issue where an exception was thrown when building an index for an empty shape file. |
| - | *A number of API changes. See the API change log for complete details. | + | *A number of API changes. See the API change log for complete details. |
| =====Version 3.1.182===== | =====Version 3.1.182===== | ||
| Line 627: | Line 627: | ||
| - | *Added some APIs for ScaleBar in order to implement the same functionality as in ScaleLine. | + | *Added some APIs for ScaleBar in order to implement the same functionality as in ScaleLine. |
| - | *Fixed issue with setting a different DPI for canvas. | + | *Fixed issue with setting a different DPI for canvas. |
| - | *Fixed issue where the Matrix system did not consider the MapUnit. | + | *Fixed issue where the Matrix system did not consider the MapUnit. |
| - | *Fixed issue where the OverrideMode did not work correctly for the ShapeFileFeatureLayer.SaveToProjection API. | + | *Fixed issue where the OverrideMode did not work correctly for the ShapeFileFeatureLayer.SaveToProjection API. |
| - | *Fixed issue where an exception would be thrown when using a MaskBrush for the ScaleBar. | + | *Fixed issue where an exception would be thrown when using a MaskBrush for the ScaleBar. |
| - | *Fixed issue where bool field cannot be updated in the DBF. | + | *Fixed issue where bool field cannot be updated in the DBF. |
| - | *Fixed the Out of Memory Exception thrown when calling the ShapeFileFeatureLayer.SaveToProjection API on very large shape file data. | + | *Fixed the Out of Memory Exception thrown when calling the ShapeFileFeatureLayer.SaveToProjection API on very large shape file data. |
| Line 641: | Line 641: | ||
| - | *Added an API to CheckForUnSupportedShapeTypes(string shapeFilePath). | + | *Added an API to CheckForUnSupportedShapeTypes(string shapeFilePath). |
| - | *Added support for a Polygon record that contains 0 parts. | + | *Added support for a Polygon record that contains 0 parts. |
| - | *Added an overload for BuildIndexFile. | + | *Added an overload for BuildIndexFile. |
| - | *Added ExecuteQuery support for Postgre. | + | *Added ExecuteQuery support for Postgre. |
| - | *Added property to show whether the assembly is the Full Version or Evaluation Version. | + | *Added property to show whether the assembly is the Full Version or Evaluation Version. |
| - | *Added an overload to CreateShapeFile so that user can choose whether they want to override. | + | *Added an overload to CreateShapeFile so that user can choose whether they want to override. |
| - | *Added polygon simplification to AreaShapes. | + | *Added polygon simplification to AreaShapes. |
| - | *Added line simplification to LineShapes. | + | *Added line simplification to LineShapes. |
| - | *Added obsolete to the AllowSpline property in text style. | + | *Added obsolete to the AllowSpline property in text style. |
| - | *Added GetFirstGeometryType in Postgre, Oracle and SQL layers. | + | *Added GetFirstGeometryType in Postgre, Oracle and SQL layers. |
| - | *Added "Simplify" sample application. | + | *Added "Simplify" sample application. |
| - | *Added an overload to GetFeaturesNeareastTo with a distance limitation. | + | *Added an overload to GetFeaturesNeareastTo with a distance limitation. |
| - | *Added documentation for DashPattern. | + | *Added documentation for DashPattern. |
| - | *Added ToGdiPlusColor method in GeoColor. | + | *Added ToGdiPlusColor method in GeoColor. |
| - | *Added a way to build a spatial index based on another projection, not using a feature list. | + | *Added a way to build a spatial index based on another projection, not using a feature list. |
| - | *Added DPI support for the GeoCanvas. | + | *Added DPI support for the GeoCanvas. |
| - | *Improved the TIFF quality for GeoTiffRasterLayer. | + | *Improved the TIFF quality for GeoTiffRasterLayer. |
| - | *Changed the logic of GetZoomLevelForDrawing by considering the IsActive. | + | *Changed the logic of GetZoomLevelForDrawing by considering the IsActive. |
| - | *Changed the proj4.GetEpsgParameters(srid) method from instant to static. | + | *Changed the proj4.GetEpsgParameters(srid) method from instant to static. |
| - | *Changed the Layer.IsVisible to virtual. | + | *Changed the Layer.IsVisible to virtual. |
| - | *Checked the IdFieldColumn for all spatial databases like Postgre, Sql2008 and Oracle. | + | *Checked the IdFieldColumn for all spatial databases like Postgre, Sql2008 and Oracle. |
| - | *Fixed issue when modifying the inner logical of DbfColumn constructor. | + | *Fixed issue when modifying the inner logical of DbfColumn constructor. |
| - | *Fixed issue where GeoTiff was not supported. | + | *Fixed issue where GeoTiff was not supported. |
| - | *Fixed issue where the parameter name is wrong for the postgreFeatureLayer's constructor. | + | *Fixed issue where the parameter name is wrong for the postgreFeatureLayer's constructor. |
| - | *Fixed issue where TextStyle.Format did not work. | + | *Fixed issue where TextStyle.Format did not work. |
| - | *Fixed issue involving uppercase conversion when executing SQL in shape file feature source. | + | *Fixed issue involving uppercase conversion when executing SQL in shape file feature source. |
| - | *Fixed issue with GetFeaturesForDrawing logic. | + | *Fixed issue with GetFeaturesForDrawing logic. |
| - | *Fixed issue with TextStyle.DrawCore DPI. | + | *Fixed issue with TextStyle.DrawCore DPI. |
| - | *Fixed issue where RasterLayer does not work when the DPI is not 96. | + | *Fixed issue where RasterLayer does not work when the DPI is not 96. |
| - | *Fixed issue where a Postgre Layer will throw "Object reference not set to an instance of an object" exception. | + | *Fixed issue where a Postgre Layer will throw "Object reference not set to an instance of an object" exception. |
| - | *Fixed issue involving the first Rotation when setting Rotation projection. | + | *Fixed issue involving the first Rotation when setting Rotation projection. |
| - | *Fixed issue where PointStyle.DrawSample() did not work. | + | *Fixed issue where PointStyle.DrawSample() did not work. |
| - | *Fixed issue where the drawing order is not correct when adding multiple types of features to one feature layer. | + | *Fixed issue where the drawing order is not correct when adding multiple types of features to one feature layer. |
| - | *Fixed issue in GetFeaturesByColumnValue. | + | *Fixed issue in GetFeaturesByColumnValue. |
| - | *Fixed issue where custom column did not work for the spatial query methods. | + | *Fixed issue where custom column did not work for the spatial query methods. |
| - | *Fixed issue where the gdiPlusGeoCanvas.DrawCircle() result is not correct. | + | *Fixed issue where the gdiPlusGeoCanvas.DrawCircle() result is not correct. |
| - | *Fixed issue where ExecuteQuery did not work properly. | + | *Fixed issue where ExecuteQuery did not work properly. |
| - | *Improved some exception descriptions. | + | *Improved some exception descriptions. |
| - | *Fixed issue where featureLayer.Columns exists, but the featureSource.Columns property does not. | + | *Fixed issue where featureLayer.Columns exists, but the featureSource.Columns property does not. |
| - | *Fixed issue with GroupLayer display order. | + | *Fixed issue with GroupLayer display order. |
| - | *Fixed issue where GetRandomGeoColor was missing. | + | *Fixed issue where GetRandomGeoColor was missing. |
| - | *Fixed issue involving sorting classBreaks internally. | + | *Fixed issue involving sorting classBreaks internally. |
| - | *Fixed issue involving support for all other types like (PolyM) for ShapeFile Layer. | + | *Fixed issue involving support for all other types like (PolyM) for ShapeFile Layer. |
| - | *Fixed issue involving exposure of static API from ShapeFileFeatureSource to ShapeFileFeatureLayer. | + | *Fixed issue involving exposure of static API from ShapeFileFeatureSource to ShapeFileFeatureLayer. |
| - | *Fixed issue where the Transparency property does not work in RasterLayer. | + | *Fixed issue where the Transparency property does not work in RasterLayer. |
| - | *Fixed issue where DotDensityStyle was not drawing after CloneDeep. | + | *Fixed issue where DotDensityStyle was not drawing after CloneDeep. |
| - | *Fixed issue in Map Suite Explorer. | + | *Fixed issue in Map Suite Explorer. |
| - | *Fixed issue where creating a shapeFileLayer by streamloading event would throw an exception in layer.close(). | + | *Fixed issue where creating a shapeFileLayer by streamloading event would throw an exception in layer.close(). |
| - | *Fixed issue involving consideration of the DoNotDraw property or FeaturesToExclude. | + | *Fixed issue involving consideration of the DoNotDraw property or FeaturesToExclude. |
| - | *Fixed issue where TestLayerStyle.DrawSample did not work properly with the haloPen. | + | *Fixed issue where TestLayerStyle.DrawSample did not work properly with the haloPen. |
| - | *Fixed issue where GetBoundingBoxOfItems did not work properly. | + | *Fixed issue where GetBoundingBoxOfItems did not work properly. |
| - | *Fixed issue involving label drawing even if the line was visible on the screen. | + | *Fixed issue involving label drawing even if the line was visible on the screen. |
| - | *Fixed issue where the CustomFieldFetch event did not work in a ShapeFileFeatureLayer. | + | *Fixed issue where the CustomFieldFetch event did not work in a ShapeFileFeatureLayer. |
| - | *Fixed issue where GeoPen does not act on symbol Diamond, Diamond2, Star or Star1. | + | *Fixed issue where GeoPen does not act on symbol Diamond, Diamond2, Star or Star1. |
| - | *Fixed issue where some shape files cannot build an index. | + | *Fixed issue where some shape files cannot build an index. |
| - | *Fixed issue where GeoPen and GeoBrush constructors did not work. | + | *Fixed issue where GeoPen and GeoBrush constructors did not work. |
| Line 705: | Line 705: | ||
| - | *Added an API(ZoomToOffsetPoint) in ExtentHelper. | + | *Added an API(ZoomToOffsetPoint) in ExtentHelper. |
| - | *Added Overloads GetFeaturesInsideBoundingBoxCore and GetFeaturesOutsideBoundingBoxCore. | + | *Added Overloads GetFeaturesInsideBoundingBoxCore and GetFeaturesOutsideBoundingBoxCore. |
| - | *Added a more descriptive message for a ShapeFile validation. | + | *Added a more descriptive message for a ShapeFile validation. |
| - | *Added SaveToProjection in ShapeFileFeatureSource and ShapeFileFeatureLayer. | + | *Added SaveToProjection in ShapeFileFeatureSource and ShapeFileFeatureLayer. |
| - | *Added a protected virtual property for the cached featureSourceColumns. | + | *Added a protected virtual property for the cached featureSourceColumns. |
| - | *Added an API in the FeatureSource to refresh the cached columns. | + | *Added an API in the FeatureSource to refresh the cached columns. |
| - | *Added the API CheckForUnSupportedShapeTypes(string shapeFilePath). | + | *Added the API CheckForUnSupportedShapeTypes(string shapeFilePath). |
| - | *Changed the logic to use the InMemoryFeatureSource and InMemoryFeatureLayer. | + | *Changed the logic to use the InMemoryFeatureSource and InMemoryFeatureLayer. |
| - | *Resolved an issue with style.DrawSample. | + | *Resolved an issue with style.DrawSample. |
| - | *Resolved System.AccessViolationException when the map is redrawn. | + | *Resolved System.AccessViolationException when the map is redrawn. |
| - | *A number of API additions. See the API change log for complete details. | + | *A number of API additions. See the API change log for complete details. |
| Line 722: | Line 722: | ||
| - | *Added a parameter check to the Projection class. | + | *Added a parameter check to the Projection class. |
| - | *Added a CustomZoomLevels collection to the ZoomLevelSet to allow for custom zoom levels. | + | *Added a CustomZoomLevels collection to the ZoomLevelSet to allow for custom zoom levels. |
| - | *Added a more descriptive exception message if a PolygonShape or MultiPolygonShape does not pass the validation test. | + | *Added a more descriptive exception message if a PolygonShape or MultiPolygonShape does not pass the validation test. |
| - | *Added HasProjectionText and ProjectionText properties to RasterSource and RasterLayer. | + | *Added HasProjectionText and ProjectionText properties to RasterSource and RasterLayer. |
| - | *Added validation checks on each member of the QueryTools to ensure that the Layer has been opened. | + | *Added validation checks on each member of the QueryTools to ensure that the Layer has been opened. |
| - | *Added a new API for getting features based on the value in a column. | + | *Added a new API for getting features based on the value in a column. |
| - | *Added another parameter to BeginDrawing in GeoCanvas. | + | *Added another parameter to BeginDrawing in GeoCanvas. |
| - | *Added ExecuteSqlQuery and CanExecuteSqlQuery methods to QueryTools and FeatureSource. | + | *Added ExecuteSqlQuery and CanExecuteSqlQuery methods to QueryTools and FeatureSource. |
| - | *Added two overloads for the method LineShape.GetLineOnLine. | + | *Added two overloads for the method LineShape.GetLineOnLine. |
| - | *Added encoding tests. | + | *Added encoding tests. |
| - | *Added MrSid support in 64-bit environments. | + | *Added MrSid support in 64-bit environments. |
| - | *Created JPEG2000RasterLayer/JPEG2000RasterSource to make it easier to load JPEG2000 images. | + | *Created JPEG2000RasterLayer/JPEG2000RasterSource to make it easier to load JPEG2000 images. |
| - | *Provided an API in ShapeFileFeatureSource and ShapeFileLayer. | + | *Provided an API in ShapeFileFeatureSource and ShapeFileLayer. |
| - | *Updated the documentation for class name changes and for classes that did not previously have documentation. | + | *Updated the documentation for class name changes and for classes that did not previously have documentation. |
| - | *Changed PathFileName to PathFilename. | + | *Changed PathFileName to PathFilename. |
| - | *Changed the ReadMe to Readme. | + | *Changed the ReadMe to Readme. |
| - | *Changed the MapSuiteCore class to take advantage of re-projecting an array of points. | + | *Changed the MapSuiteCore class to take advantage of re-projecting an array of points. |
| - | *Changed the internalFeatures from a Dictionary to a GeoCollection. | + | *Changed the internalFeatures from a Dictionary to a GeoCollection. |
| - | *Modified ShapeFileFeatureSource.ExecuteSqlQuery() to throw exception if filename is longer than 8 characters. | + | *Modified ShapeFileFeatureSource.ExecuteSqlQuery() to throw exception if filename is longer than 8 characters. |
| - | *Enhanced the Projection classes and members. | + | *Enhanced the Projection classes and members. |
| - | *Improved performance in GdiPlusRasterLayer. | + | *Improved performance in GdiPlusRasterLayer. |
| - | *Improved the Union Sample logic. | + | *Improved the Union Sample logic. |
| - | *Improved the exception description for Layer.QueryTools/Layer.EditTools. | + | *Improved the exception description for Layer.QueryTools/Layer.EditTools. |
| - | *Improved the documentation for EditTools.Union. | + | *Improved the documentation for EditTools.Union. |
| - | *Improved speed of spatial queries with a polygon-based layer when using a MultiPolygonShape as the target shape. | + | *Improved speed of spatial queries with a polygon-based layer when using a MultiPolygonShape as the target shape. |
| - | *Improved speed of the Proj4Projection class by removing the locking code. | + | *Improved speed of the Proj4Projection class by removing the locking code. |
| - | *When building an index, all features are now loaded into memory. | + | *When building an index, all features are now loaded into memory. |
| - | *Fixed missing overload for static method CreateSimpleAreaStyle. | + | *Fixed missing overload for static method CreateSimpleAreaStyle. |
| - | *Fixed ZoomIn bug. | + | *Fixed ZoomIn bug. |
| - | *Fixed the PointStyle, AreaStyle and LineStyle DrawSample methods so that they return the sample in the middle of the image. | + | *Fixed the PointStyle, AreaStyle and LineStyle DrawSample methods so that they return the sample in the middle of the image. |
| - | *Fixed an outstanding issue with style.DrawSample. | + | *Fixed an outstanding issue with style.DrawSample. |
| - | *Reviewed all of the the Try...Catch code. | + | *Reviewed all of the the Try...Catch code. |
| - | *Resolved issue where the static function BuildRecordIdColumn required a spatial index on the Layer first. | + | *Resolved issue where the static function BuildRecordIdColumn required a spatial index on the Layer first. |
| - | *Resolved issue where a System.AccessViolationException would be thrown when redrawing the map. | + | *Resolved issue where a System.AccessViolationException would be thrown when redrawing the map. |
| - | *Resolved issue with WMS when using a Web Proxy. | + | *Resolved issue with WMS when using a Web Proxy. |
| - | *Resolved issue where dragging two raster layers to Explorer throws an exception. | + | *Resolved issue where dragging two raster layers to Explorer throws an exception. |
| - | *Resolved issue when a Layer's zoom level did not work under a projection other than WGS 84. | + | *Resolved issue when a Layer's zoom level did not work under a projection other than WGS 84. |
| - | *Resolved issue with ScalebarAdornmentLayer. | + | *Resolved issue with ScalebarAdornmentLayer. |
| - | *Resolved issue with RectangleShape.ExpandToInclude. | + | *Resolved issue with RectangleShape.ExpandToInclude. |
| - | *Resolved issue where WmsService would not work with HTTPS/SSL. | + | *Resolved issue where WmsService would not work with HTTPS/SSL. |
| - | *Resolved issue where mapEngine.OpenAllLayers() would not open an AdornmentLayer. | + | *Resolved issue where mapEngine.OpenAllLayers() would not open an AdornmentLayer. |
| - | *Resolved issue where the Geographic.Unit and DistanceUnit in BaseShape.Buffer() were reversed. | + | *Resolved issue where the Geographic.Unit and DistanceUnit in BaseShape.Buffer() were reversed. |
| - | *Resolved issue with BuildIndex where getting all features would not work. | + | *Resolved issue with BuildIndex where getting all features would not work. |
| - | *Resolved issue where QueryTools.GetFeaturesContaining would not work when features are in the transaction buffer. | + | *Resolved issue where QueryTools.GetFeaturesContaining would not work when features are in the transaction buffer. |
| - | *Reintroduced the AreaShape.GetCrossings method (which was previously present in Map Suite 2.0). | + | *Reintroduced the AreaShape.GetCrossings method (which was previously present in Map Suite 2.0). |
| - | *Reintroduced support for raster files (ECW, MrSid, BMP, etc.) in Map Suite Explorer. | + | *Reintroduced support for raster files (ECW, MrSid, BMP, etc.) in Map Suite Explorer. |
| - | *Removed the obsolete target framework for .NET 2.0. | + | *Removed the obsolete target framework for .NET 2.0. |
| - | *A number of API additions and changes. See the API change log for complete details. | + | *A number of API additions and changes. See the API change log for complete details. |
| - | [[Category:Map Suite Services Edition]] [[Category:Web GIS]] [[Category:Desktop GIS]] [[Category:GIS]] [[Category:.NET]] | ||
