map_suite_serialization_guide [2015/08/31 07:08] admin [Attributes] |
map_suite_serialization_guide [2019/10/21 07:07] tgwikiupdate [Map Suite Serialization Guide] |
====== Map Suite Serialization Guide ====== | ====== Map Suite Serialization Guide ====== | ||
=====Serialization & Deserialization===== | =====Serialization & Deserialization===== | ||
====Using a File==== | ====Using a File==== | ||
For example, if we want to serialize a layer and save it to the hard disk, then we can use the GeoSerializer using the code below. | For example, if we want to serialize a layer and save it to the hard disk, then we can use the GeoSerializer using the code below. | ||
- | <code lang="csharp"> | + | <code csharp> |
Layer layer = GetLayer(); | Layer layer = GetLayer(); | ||
GeoSerializer serializer = new GeoSerializer(); | GeoSerializer serializer = new GeoSerializer(); | ||
Line 12: | Line 15: | ||
The layer can be recreated from the file like this: | The layer can be recreated from the file like this: | ||
Layer deserializedLayer = (Layer)serializer.Deserialize(@"C:\layer.xml", FileAccess.Read); | Layer deserializedLayer = (Layer)serializer.Deserialize(@"C:\layer.xml", FileAccess.Read); | ||
</code> | </code> | ||
Line 20: | Line 23: | ||
To a Stream: | To a Stream: | ||
using (MemoryStream memoryStream = new MemoryStream()) | using (MemoryStream memoryStream = new MemoryStream()) | ||
Line 28: | Line 31: | ||
From a Stream: | From a Stream: | ||
using (FileStream fileStream = File.Create(@"C:\layer.xml")) | using (FileStream fileStream = File.Create(@"C:\layer.xml")) | ||
Line 37: | Line 40: | ||
====Using a String==== | ====Using a String==== | ||
To a string: | To a string: | ||
string serializationResult = serializer.Serialize(layer); | string serializationResult = serializer.Serialize(layer); | ||
Or from a string: | Or from a string: | ||
Layer deserializedLayer = (Layer)serializer.Deserialize(serializationResult); | Layer deserializedLayer = (Layer)serializer.Deserialize(serializationResult); | ||
Line 53: | Line 56: | ||
The GeoSerializer can only serialize and deserialize types that are decorated with SerializableAttribute, like this: | The GeoSerializer can only serialize and deserialize types that are decorated with SerializableAttribute, like this: | ||
- | [Serializable] | + | [Serializable] |
- | public class Test | + | public class Test |
- | <nowiki>//</nowiki>…… | + | //…… |
Line 67: | Line 70: | ||
Example: | Example: | ||
- | [[OnSerializing]] | + | [OnSerializing] |
private void SetValuesOnSerializing(StreamingContext context) | private void SetValuesOnSerializing(StreamingContext context) | ||
- | <nowiki>//</nowiki> …… | + | // …… |
Line 79: | Line 82: | ||
- | [[OnSerialized]] | + | [OnSerialized] |
private void SetValuesOnSerialized(StreamingContext context) | private void SetValuesOnSerialized(StreamingContext context) | ||
Line 91: | Line 94: | ||
- | [[OnDeserializing]] | + | [OnDeserializing] |
private void SetValuesOnDeserializing(StreamingContext context) | private void SetValuesOnDeserializing(StreamingContext context) | ||
Line 103: | Line 106: | ||
- | [[OnDeserialized]] | + | [OnDeserialized] |
private void SetValuesOnDeserialized(StreamingContext context) | private void SetValuesOnDeserialized(StreamingContext context) | ||
Line 114: | Line 117: | ||
The NonSerializableBaseTypeAttribute is useful when your type inherits from a type that is not serializable, for example: | The NonSerializableBaseTypeAttribute is useful when your type inherits from a type that is not serializable, for example: | ||
- | [[Serializable]] | + | [Serializable] |
public class MyControl : Control | public class MyControl : Control | ||
Line 127: | Line 130: | ||
- | The type "MyControl" inherits from System.Window.Control.Control. Now if we try to serialize an instance of MyControl, the serializer will throw an exception because the type "Control" contains fields of types that are not serializable. The NonSerializedAttribute we mentioned before does not help here, because we don't own the type "Control", so we can't put attributes to its fields. At this point, our only solution is to put [[NonSerializableBaseType]] on "MyControl": | + | The type "MyControl" inherits from System.Window.Control.Control. Now if we try to serialize an instance of MyControl, the serializer will throw an exception because the type "Control" contains fields of types that are not serializable. The NonSerializedAttribute we mentioned before does not help here, because we don't own the type "Control", so we can't put attributes to its fields. At this point, our only solution is to put [NonSerializableBaseType] on "MyControl": |
- | [[NonSerializableBaseType]] | + | [NonSerializableBaseType] |
[Serializable] | [Serializable] | ||
Line 173: | Line 176: | ||
Here is a sample of how to make your own serializer. | Here is a sample of how to make your own serializer. | ||
public class MyGeoObjectModeler : GeoObjectModeler | public class MyGeoObjectModeler : GeoObjectModeler | ||
protected override Collection<MemberInfo> GetMembers(Type type, GeoObjectModelerMemberTypes memberTypes) | protected override Collection<MemberInfo> GetMembers(Type type, GeoObjectModelerMemberTypes memberTypes) | ||
- | <nowiki>//</nowiki>...... | + | //...... |
Line 185: | Line 188: | ||
memberOwner, GeoObjectNode memberNode) | memberOwner, GeoObjectNode memberNode) | ||
Line 192: | Line 195: | ||
GeoObjectNode memberNode) | GeoObjectNode memberNode) | ||
Line 248: | Line 251: | ||
===LoadCore=== | ===LoadCore=== | ||
Recreates a GeoObjectModel from a stream. | Recreates a GeoObjectModel from a stream. | ||
- | [[Category:Map Suite Services Edition]] [[Category:Web GIS]] [[Category:Desktop GIS]] [[Category:GIS]] [[Category:.NET]] | ||
