map_suite_routing_features_bug_fixes_change_log [2015/09/09 08:57] admin [Version 5.5.0.0] |
map_suite_routing_features_bug_fixes_change_log [2015/09/11 03:41] (current) admin [Version 3.1.299] |
| Line 63: | Line 63: | ||
| ThinkGeo.MapSuite.Routing Namespace: | ThinkGeo.MapSuite.Routing Namespace: | ||
| - | *Fixed a bug in RoutingEngine.GetRouteViaVisitStops method which would throws exceptions for some cases due to not passing simple shape validations. | + | *Fixed a bug in RoutingEngine.GetRouteViaVisitStops method which would throws exceptions for some cases due to not passing simple shape validations. |
| - | *Added validations to check if the file extension is allowed. | + | *Added validations to check if the file extension is allowed. |
| - | *Added support for routing results as a single lineshape or as multiple lineshapes. | + | *Added support for routing results as a single lineshape or as multiple lineshapes. |
| - | *Added GenerateRoutableShapeFile method to create routable shapefiles. | + | *Added GenerateRoutableShapeFile method to create routable shapefiles. |
| Line 73: | Line 73: | ||
| - | *Upgraded the Routing Index Format to speed up performance. | + | *Upgraded the Routing Index Format to speed up performance. |
| - | *Added override method GetRouteViaStops, which allows you to get the route using feature IDs. | + | *Added override method GetRouteViaStops, which allows you to get the route using feature IDs. |
| - | *Added many validations for the public API, such as checking file extension, etc. | + | *Added many validations for the public API, such as checking file extension, etc. |
| - | *Fixed an issue with TSP initial route distance. | + | *Fixed an issue with TSP initial route distance. |
| - | *Fixed an issue with the GetRouteDirections sample. | + | *Fixed an issue with the GetRouteDirections sample. |
| Line 84: | Line 84: | ||
| - | *Updated assembly version to 4.0.0.0; included strong-named and weak-named assemblies. Please see the latest post in the Developer Blog for full details. | + | *Updated assembly version to 4.0.0.0; included strong-named and weak-named assemblies. Please see the latest post in the Developer Blog for full details. |
| Line 91: | Line 91: | ||
| - | *Added Visual Studio 2010 support. | + | *Added Visual Studio 2010 support. |
| - | *Added routing support for the Travelling Salesman Problem with fixed start and end points. | + | *Added routing support for the Travelling Salesman Problem with fixed start and end points. |
| - | *Added more sample applications for new scenarios. | + | *Added more sample applications for new scenarios. |
| - | *Fixed issue where an unexpected error would occur when routing on complex road networks. | + | *Fixed issue where an unexpected error would occur when routing on complex road networks. |
| - | *Fixed issue that optimizes the route on the last point for Travelling Salesman. | + | *Fixed issue that optimizes the route on the last point for Travelling Salesman. |
| - | *Fixed issue with TSP initial route distance. | + | *Fixed issue with TSP initial route distance. |
| - | *Several API additions. See the API change log for complete details. | + | *Several API additions. See the API change log for complete details. |
| - | *Updated the API documentation. | + | *Updated the API documentation. |
| Line 105: | Line 105: | ||
| - | *Concluded public beta and moved to final release. | + | *Concluded public beta and moved to final release. |
| - | *Added support for the Traveling Salesman Problem. | + | *Added support for the Traveling Salesman Problem. |
| - | *Added a set of Silverlight-based "How Do I?" sample apps. | + | *Added a set of Silverlight-based "How Do I?" sample apps. |
| - | *Added a set of Web-based "How Do I?" sample apps including VB.NET and C# source code. | + | *Added a set of Web-based "How Do I?" sample apps including VB.NET and C# source code. |
| - | *Some API revisions, including one breaking change. See the API change log for complete details. | + | *Some API revisions, including one breaking change. See the API change log for complete details. |
| - | [[Category:Map Suite Routing]] [[Category:Web GIS]] [[Category:Desktop GIS]] [[Category:GIS]] [[Category:.NET]] | ||
