map_suite_routing [2017/03/02 08:30] tgwikiupdate [Code Samples] |
map_suite_routing [2017/03/15 03:49] tgwikiupdate |
====== Map Suite Routing ====== | ====== Map Suite Routing ====== | ||
Let your mapping applications start taking you places! Map Suite Routing is an extension for Map Suite Desktop, Web, Services or Silverlight Edition that calculates routes and driving directions. This native .NET component gives your Map Suite applications the power to find the shortest path from A to B, deliver turn-by-turn directions, avoid specified areas, and much more. | Let your mapping applications start taking you places! Map Suite Routing is an extension for Map Suite Desktop, Web, Services or Silverlight Edition that calculates routes and driving directions. This native .NET component gives your Map Suite applications the power to find the shortest path from A to B, deliver turn-by-turn directions, avoid specified areas, and much more. | ||
Line 55: | Line 56: | ||
- | ** In addition to the samples below, we have dozens of interactive Routing Edition sample applications available [[http://routingsamples.thinkgeo.com/|here]]. ** | + | ** In addition to the samples below, we have dozens of interactive Map Suite Routing sample applications available [[http://routingsamples.thinkgeo.com/|here]]. ** |
We have provided several .Net code samples in C# & VB.NET to help you get going quickly. We have categorized them to allow you to quickly find what you are looking for. Each code sample includes an overview, complete code online to review and the ability to download the sample to run it yourself. | We have provided several .Net code samples in C# & VB.NET to help you get going quickly. We have categorized them to allow you to quickly find what you are looking for. Each code sample includes an overview, complete code online to review and the ability to download the sample to run it yourself. | ||
Line 66: | Line 67: | ||
- | <faicon fa fa-copy fa-lg> [[map_suite_server_for_routing_project_templates|Project Templates]] | + | <faicon fa fa-copy fa-lg> [[Map Suite Routing Project Templates|Project Templates]] |
These projects show various study cases based on Routing. | These projects show various study cases based on Routing. | ||
Line 72: | Line 73: | ||
- | <faicon fa fa-road fa-lg> [[map_suite_server_for_routing_layers_featureSources_samples|Layers & FeatureSources]] | + | <faicon fa fa-road fa-lg> [[Map Suite Routing Layers & FeatureSources Samples|Layers & FeatureSources]] |
These samples show custom layers and feature sources from which you can get inspired to integrate your own data. | These samples show custom layers and feature sources from which you can get inspired to integrate your own data. | ||
Line 78: | Line 79: | ||
- | <faicon fa fa-folder-open fa-lg> [[map_suite_server_for_routing_miscellaneous_samples|Miscellaneous]] | + | <faicon fa fa-folder-open fa-lg> [[Map Suite Routing Miscellaneous Samples|Miscellaneous]] |
These samples show other miscellaneous features for the product. | These samples show other miscellaneous features for the product. | ||
Line 84: | Line 85: | ||
- | <faicon fa fa-paint-brush fa-lg> [[map_suite_server_for_routing_styles_samples|Styles]] | + | <faicon fa fa-paint-brush fa-lg> [[Map Suite Routing Styles Samples|Styles]] |
These samples show various kinds of styles such as styles that scale or adjust based on time of day. | These samples show various kinds of styles such as styles that scale or adjust based on time of day. | ||
Line 197: | Line 198: | ||
