map_suite_routing [2015/09/11 06:03] admin [Code Samples] |
map_suite_routing [2017/03/16 09:07] tgwikiupdate |
====== Map Suite Routing ====== | ====== Map Suite Routing ====== | ||
Let your mapping applications start taking you places! Map Suite Routing is an extension for Map Suite Desktop, Web, Services or Silverlight Edition that calculates routes and driving directions. This native .NET component gives your Map Suite applications the power to find the shortest path from A to B, deliver turn-by-turn directions, avoid specified areas, and much more. | Let your mapping applications start taking you places! Map Suite Routing is an extension for Map Suite Desktop, Web, Services or Silverlight Edition that calculates routes and driving directions. This native .NET component gives your Map Suite applications the power to find the shortest path from A to B, deliver turn-by-turn directions, avoid specified areas, and much more. | ||
+ | <div mockline></div> | ||
Line 9: | Line 11: | ||
**[[http://samples.thinkgeo.com/RoutingEdition/HowDoISamples/|Explore the Demos]]** | **[[http://samples.thinkgeo.com/RoutingEdition/HowDoISamples/|Explore the Demos]]** | ||
- | </div> | ||
- | <div shortcuts> | ||
- | **[[:map_suit_Routing_edition_videos_screenshots|Videos & Screenshots]]** | ||
Line 59: | Line 57: | ||
- | ** In addition to the samples below, we have dozens of interactive Routing Edition sample applications available [[http://routingsamples.thinkgeo.com/|here]]. ** | + | ** In addition to the samples below, we have dozens of interactive Map Suite Routing sample applications available [[http://routingsamples.thinkgeo.com/|here]]. ** |
We have provided several .Net code samples in C# & VB.NET to help you get going quickly. We have categorized them to allow you to quickly find what you are looking for. Each code sample includes an overview, complete code online to review and the ability to download the sample to run it yourself. | We have provided several .Net code samples in C# & VB.NET to help you get going quickly. We have categorized them to allow you to quickly find what you are looking for. Each code sample includes an overview, complete code online to review and the ability to download the sample to run it yourself. | ||
Line 70: | Line 68: | ||
- | <faicon fa fa-navicon fa-lg> [[Map Suite Routing Project Templates|Project Templates]] | + | <faicon fa fa-copy fa-lg> [[Map Suite Routing Project Templates|Project Templates]] |
These projects show various study cases based on Routing. | These projects show various study cases based on Routing. | ||
Line 76: | Line 74: | ||
- | <faicon fa fa-navicon fa-lg> [[Map Suite Routing Layers & FeatureSources Samples|Layers & FeatureSources]] | + | <faicon fa fa-road fa-lg> [[Map Suite Routing Layers & FeatureSources Samples|Layers & FeatureSources]] |
These samples show custom layers and feature sources from which you can get inspired to integrate your own data. | These samples show custom layers and feature sources from which you can get inspired to integrate your own data. | ||
Line 82: | Line 80: | ||
- | <faicon fa fa-navicon fa-lg> [[Map Suite Routing Miscellaneous Samples|Miscellaneous]] | + | <faicon fa fa-folder-open fa-lg> [[Map Suite Routing Miscellaneous Samples|Miscellaneous]] |
These samples show other miscellaneous features for the product. | These samples show other miscellaneous features for the product. | ||
Line 88: | Line 86: | ||
- | <faicon fa fa-navicon fa-lg> [[Map Suite Routing Styles Samples|Styles]] | + | <faicon fa fa-paint-brush fa-lg> [[Map Suite Routing Styles Samples|Styles]] |
These samples show various kinds of styles such as styles that scale or adjust based on time of day. | These samples show various kinds of styles such as styles that scale or adjust based on time of day. | ||
+ | ===== Videos ===== | ||
+ | ==== Routing Edition Sample App Walkthrough Video Series ==== | ||
+ | Step through the Routing Edition sample applications and see how they're put together. We'll demonstrate how to use each app, then take you through every part of the source code and show you how it works.\\ | ||
+ | **Tip**: //You'll want to select "Fullscreen" to properly read the source code.// | ||
+ | <div play medialist> | ||
+ | [[routing:Introduction to the Routing|{{routing:screenshot:Introduction_to_the_Routing_Extension.png?180x99|Introduction to the Routing Edition}}]] | ||
+ | Introduction to the Routing Edition | ||
+ | ===== Screenshots ===== | ||
+ | The Routing Extension screenshots gallery section showcases a wide range of screenshots covering various GIS features. | ||
+ | <div medialist imagewithremaker> | ||
+ | {{routing:screenshot:Map_Suite_Routing_Screenshot_Gallery_Simple_Routing.jpg?180|Shortest length or fastest time | ||
+ | Just a few lines of code}} | ||
+ | Shortest length or fastest time | ||
+ | Just a few lines of code | ||
+ | {{routing:screenshot:Map_Suite_Routing_Screenshot_Gallery_Road_Information.jpg?180|Road type | ||
+ | Road length | ||
+ | Start/end point}} | ||
+ | Road type | ||
+ | Start/end point | ||
+ | {{routing:screenshot:Map_Suite_Routing_Screenshot_Gallery_Avoid_Areas.jpg?180|Draw your own areas | ||
+ | Routes adjust automatically}} | ||
+ | Draw your own areas | ||
+ | Routes adjust automatically | ||
+ | {{routing:screenshot:Map_Suite_Routing_Screenshot_Gallery_Get_Directions.jpg?180|Turn-by-turn | ||
+ | By intersection}} | ||
+ | Turn-by-turn | ||
+ | By intersection | ||
+ | {{routing:screenshot:Map_Suite_Routing_Screenshot_Gallery_Add_Stops.jpg?180|Add a stop with a single click | ||
+ | Unlimited stops}} | ||
+ | Add a stop with a single click | ||
+ | Unlimited stops | ||
+ | {{routing:screenshot:Map_Suite_Routing_Screenshot_Gallery_Route_Around_Roadblocks.jpg?180|Intelligently find the most efficient route around point-based roadblocks}} | ||
+ | Intelligently find the most efficient route around point-based roadblocks | ||
+ | {{routing:screenshot:Map_Suite_Routing_Screenshot_Gallery_Service_Areas.jpg?180|Based on average speed and drive time}} | ||
+ | Based on average speed and drive time | ||
+ | {{routing:screenshot:Map_Suite_Routing_Screenshot_Gallery_Travelling_Salesman_Problem.jpg?180|Generate an optimal route for visiting a set of locations}} | ||
+ | Generate an optimal route for visiting a set of locations | ||
+ | {{routing:screenshot:Map_Suite_Routing_Screenshot_Gallery_Sample_Apps_Included.jpg?180|Easy to see and learn | ||
+ | Source code available for every sample}} | ||
+ | Easy to see and learn | ||
+ | Source code available for every sample | ||
+ | <div newline></div> | ||
- | * [[Map Suite Routing Release Change Log|Release Change Log]]<div>This change log details the changes made to the product for each major release cycle.</div> | + | * [[Map Suite Routing Release Change Log|API Change Log]]<div>This change log details the changes made to the product for each major release cycle.</div> |
* [[Map Suite Routing Features & Bug Fixes Change Log|Features & Bug Fixes Change Log]]<div>This change log details the new features and bug fixes applied to the product for each major release cycle.</div> | * [[Map Suite Routing Features & Bug Fixes Change Log|Features & Bug Fixes Change Log]]<div>This change log details the new features and bug fixes applied to the product for each major release cycle.</div> | ||
Line 109: | Line 198: | ||
- | {{#lsth:Map Suite Services Edition|Help & Support Guides}} | + | {{page>help_support_guides}} |
