map_suite_project_template_guide [2017/04/24 06:39] tgwikiupdate |
map_suite_project_template_guide [2017/04/26 20:16] (current) mwolffer |
Line 4: | Line 4: | ||
- | This guide shows how to quickly create a simple project based on "ThinkGeo MapSuite online project template". | + | This guide shows how to quickly create a simple project using ThinkGeo's Map Suite online project templates. |
- | ===== Detail Steps ===== | + | ===== Detailed Steps ===== |
- | ==== Install project template ==== | + | ==== Installing Project Template ==== |
- | Open Visual Studio 2015 or 2017 and create a new project: "File"->"New"->"Project", then select "Online" and search keyword "MapSuite". | + | Open Visual Studio 2015 or 2017 and create a new project: "File"->"New"->"Project", select "Online" and search keyword "MapSuite". |
{{:map_suite_project_template_guide_1.png|}} | {{:map_suite_project_template_guide_1.png|}} | ||
- | You should want to download a template and install it now, for example: "Map Suite Desktop for WinForms App Template". | + | Download and install a template, for example: "Map Suite Desktop for WinForms App Template". |
{{:map_suite_project_template_guide_2.png|}} | {{:map_suite_project_template_guide_2.png|}} | ||
- | ==== Create project with the installed template ==== | + | ==== Create a Project with the Installed Template ==== |
- | Template is installed, it start to download necessary package from NuGet automatic. | + | Once the template has been installed it will automatically download the necessary package(s) from NuGet. |
{{:map_suite_project_template_guide_3.png|}} | {{:map_suite_project_template_guide_3.png|}} | ||
- | ==== Build and run the default application ==== | + | ==== Build and Run the Default Application ==== |
- | The first time you create a new project of one product, the "product center" will popup. | + | The first time you create a new project, the ThinkGeo Product Center will open. |
- | If you don't have a license, it will automatic to start evaluation. | + | If you don't have a license, you will automatically start your free 60 day evaluation. |
- | If you have license for this product, you will be asked to activate your license. | + | If you have a licensed version for the product, you will be asked to activate your license. |
{{:map_suite_project_template_guide_4.png|}} | {{:map_suite_project_template_guide_4.png|}} | ||
Line 43: | Line 43: | ||
- | After these steps, you had easily created and run a template project. | + | After these steps, you can easily run the template project. |
{{:map_suite_project_template_guide_6.png|}} | {{:map_suite_project_template_guide_6.png|}} | ||
- | You can write your code based on it now. | + | You can easily customize the template. |
{{:map_suite_project_template_guide_7.png|}} | {{:map_suite_project_template_guide_7.png|}} | ||
- | ==== Uninstall the project template ==== | + | ==== Uninstalling the Project Template ==== |
- | Find the installed template in "Extensions and Updates" under "Tools" menu, click "Uninstall" and you can remove target template. | + | Find the installed template in "Extensions and Updates" under "Tools" menu, click "Uninstall" to remove the project template. |
{{:map_suite_project_template_guide_8.png|}} | {{:map_suite_project_template_guide_8.png|}} | ||
