map_suite_project_template_guide [2017/04/24 05:53] tgwikiupdate |
map_suite_project_template_guide [2017/04/26 20:16] (current) mwolffer |
====== Map Suite Project Template Guide ====== | ====== Map Suite Project Template Guide ====== | ||
+ | This guide shows how to quickly create a simple project using ThinkGeo's Map Suite online project templates. | ||
+ | ===== Detailed Steps ===== | ||
+ | ==== Installing Project Template ==== | ||
+ | Open Visual Studio 2015 or 2017 and create a new project: "File"->"New"->"Project", select "Online" and search keyword "MapSuite". | ||
- | This guide shows how to create a simple project based on ThinkGeo MapSuite online project template. | + | {{:map_suite_project_template_guide_1.png|}} |
+ | Download and install a template, for example: "Map Suite Desktop for WinForms App Template". | ||
+ | {{:map_suite_project_template_guide_2.png|}} | ||
+ | ==== Create a Project with the Installed Template ==== | ||
+ | Once the template has been installed it will automatically download the necessary package(s) from NuGet. | ||
- | ==== Steps ==== | + | {{:map_suite_project_template_guide_3.png|}} |
+ | ==== Build and Run the Default Application ==== | ||
+ | The first time you create a new project, the ThinkGeo Product Center will open. | ||
- | Open Visual Studio 2015 or 2017, create a new project: "File"->"New"->"Project", then select "Online" and search "MapSuite" | + | If you don't have a license, you will automatically start your free 60 day evaluation. |
+ | If you have a licensed version for the product, you will be asked to activate your license. | ||
- | {{:map_suite_project_template_guide_1.png|}} | ||
- | {{:map_suite_project_template_guide_2.png|}} | ||
- | {{:map_suite_project_template_guide_3.png|}} | ||
{{:map_suite_project_template_guide_4.png|}} | {{:map_suite_project_template_guide_4.png|}} | ||
+ | Activation success, continue debugging. | ||
{{:map_suite_project_template_guide_5.png|}} | {{:map_suite_project_template_guide_5.png|}} | ||
+ | After these steps, you can easily run the template project. | ||
{{:map_suite_project_template_guide_6.png|}} | {{:map_suite_project_template_guide_6.png|}} | ||
+ | You can easily customize the template. | ||
{{:map_suite_project_template_guide_7.png|}} | {{:map_suite_project_template_guide_7.png|}} | ||
+ | ==== Uninstalling the Project Template ==== | ||
+ | Find the installed template in "Extensions and Updates" under "Tools" menu, click "Uninstall" to remove the project template. | ||
+ | {{:map_suite_project_template_guide_8.png|}} | ||
