Both sides previous revision Previous revision Next revision | Previous revision Next revision Both sides next revision | ||
map_suite_project_template_guide [2017/04/24 05:53] tgwikiupdate |
map_suite_project_template_guide [2017/04/26 20:04] mwolffer [Map Suite Project Template Guide] |
====== Map Suite Project Template Guide ====== | ====== Map Suite Project Template Guide ====== | ||
+ | This guide shows how to quickly create a simple project using ThinkGeo's Map Suite online project template. | ||
+ | ===== Detail Steps ===== | ||
+ | ==== Install project template ==== | ||
+ | Open Visual Studio 2015 or 2017 and create a new project: "File"->"New"->"Project", then select "Online" and search keyword "MapSuite". | ||
- | This guide shows how to create a simple project based on ThinkGeo MapSuite online project template. | + | {{:map_suite_project_template_guide_1.png|}} |
+ | You should want to download a template and install it now, for example: "Map Suite Desktop for WinForms App Template". | ||
+ | {{:map_suite_project_template_guide_2.png|}} | ||
+ | ==== Create project with the installed template ==== | ||
+ | Template is installed, it start to download necessary package from NuGet automatic. | ||
- | ==== Steps ==== | + | {{:map_suite_project_template_guide_3.png|}} |
+ | ==== Build and run the default application ==== | ||
+ | The first time you create a new project of one product, the "product center" will popup. | ||
- | Open Visual Studio 2015 or 2017, create a new project: "File"->"New"->"Project", then select "Online" and search "MapSuite" | + | If you don't have a license, it will automatic to start evaluation. |
+ | If you have license for this product, you will be asked to activate your license. | ||
- | {{:map_suite_project_template_guide_1.png|}} | ||
- | {{:map_suite_project_template_guide_2.png|}} | ||
- | {{:map_suite_project_template_guide_3.png|}} | ||
{{:map_suite_project_template_guide_4.png|}} | {{:map_suite_project_template_guide_4.png|}} | ||
+ | Activation success, continue debugging. | ||
{{:map_suite_project_template_guide_5.png|}} | {{:map_suite_project_template_guide_5.png|}} | ||
+ | After these steps, you had easily created and run a template project. | ||
{{:map_suite_project_template_guide_6.png|}} | {{:map_suite_project_template_guide_6.png|}} | ||
+ | You can write your code based on it now. | ||
{{:map_suite_project_template_guide_7.png|}} | {{:map_suite_project_template_guide_7.png|}} | ||
+ | ==== Uninstall the project template ==== | ||
+ | Find the installed template in "Extensions and Updates" under "Tools" menu, click "Uninstall" and you can remove it. | ||
+ | {{:map_suite_project_template_guide_8.png|}} | ||
