map_suite_mvc_edition_spatial_functions_samples [2015/09/17 13:29] admin |
map_suite_mvc_edition_spatial_functions_samples [2015/09/18 03:50] admin |
Line 175: | Line 175: | ||
[[Map Suite Samples Alternate Languages | Need it in another language?]] | [[Map Suite Samples Alternate Languages | Need it in another language?]] | ||
- | version 7.0.318.0 or later. | + | This sample will show you how to find the closest line between two features by using the **GetShortestLineTo** API and how to split a line at a given point using the **GetLineOnALine** API. These APIs can be very useful when doing spatial analysis and editing of features. This sample also allows you to dynamically alter the test features using the **EditOverlay** so you can try out different scenarios and see the results quickly. A MapShapes layer is used to display and style the individual results.\\ \\ \\ \\ **Note:** This sample requires that you reference DLLs from the Map Suite WPF Desktop Edition [[Map Suite Daily Builds Guide|daily development build]] version 7.0.318.0 or later. |
Line 200: | Line 200: | ||
+ | {{page>map_suite_services_edition_spatial_functions_samples}} |
