map_suite_mvc_edition_release_change_log_version_8.0.0.160
Map_Suite_Mvc_Edition_Release_Change_Log_Version_8.0.0.160
<p class=MsoNormal style='margin-bottom:0cm;margin-bottom:.0001pt;line-height: normal;text-autospace:none'><b>MvcEdition, Version=8.0.0.0, Culture=neutral, PublicKeyToken=null</b></p>
<p class=MsoNormal style='margin-bottom:0cm;margin-bottom:.0001pt;line-height: normal;text-autospace:none'>&nbsp;</p>
<p class=MsoNormal style='margin-bottom:0cm;margin-bottom:.0001pt;line-height: normal;text-autospace:none'>namespace <b>ThinkGeo.MapSuite.MvcEdition</b> {</p>
<p class=MsoNormal style='margin-bottom:0cm;margin-bottom:.0001pt;line-height: normal;text-autospace:none'>    style='color:olive'>SerializableAttribute</span></p>
<p class=MsoNormal style='margin-bottom:0cm;margin-bottom:.0001pt;line-height: normal;text-autospace:none'>    public class <b>EntityModelBinder : </b> IModelBinder {</p>
<p class=MsoNormal style='margin-bottom:0cm;margin-bottom:.0001pt;line-height: normal;text-autospace:none'>        public virtual sealed Object <b>BindModel</b>(ControllerContext <b>controllerContext</b>, ModelBindingContext <b>bindingContext</b>);</p>
<p class=MsoNormal style='margin-bottom:0cm;margin-bottom:.0001pt;line-height: normal;text-autospace:none'>    }</p>
<p class=MsoNormal style='margin-bottom:0cm;margin-bottom:.0001pt;line-height: normal;text-autospace:none'>    public class <b>MapActionFilterAttribute : </b> ActionFilterAttribute, IActionFilter, IResultFilter {</p>
<p class=MsoNormal style='margin-bottom:0cm;margin-bottom:.0001pt;line-height: normal;text-autospace:none'>    public abstract class <b>Overlay : </b>IRequireId, IJsonSerialization {</p>
<p class=MsoNormal style='margin-bottom:0cm;margin-bottom:.0001pt;line-height: normal;text-autospace:none'>        public String <b>Attribution</b> { get; set; }</p>
<p class=MsoNormal style='margin-bottom:0cm;margin-bottom:.0001pt;line-height: normal;text-autospace:none'>    public class <b>WorldMapKitWmsWebOverlay : </b> Overlay, IRequireId, IJsonSerialization {</p>
<p class=MsoNormal style='margin-bottom:0cm;margin-bottom:.0001pt;line-height: normal;text-autospace:none'>        public <b>WorldMapKitWmsWebOverlay</b>(WorldMapKitLayerType <b>layerType</b>);</p>
<p class=MsoNormal style='margin-bottom:0cm;margin-bottom:.0001pt;line-height: normal;text-autospace:none'>        public <b>WorldMapKitWmsWebOverlay</b>(String <b>id</b>, WorldMapKitLayerType <b>layerType</b>);</p>
<p class=MsoNormal style='margin-bottom:0cm;margin-bottom:.0001pt;line-height: normal;text-autospace:none'>        public <b>WorldMapKitWmsWebOverlay</b>(String <b>id</b>, TileType <b>tileType</b>, WorldMapKitLayerType <b>layerType</b>);</p>
<p class=MsoNormal style='margin-bottom:0cm;margin-bottom:.0001pt;line-height: normal;text-autospace:none'>        public WorldMapKitLayerType <b>LayerType</b> { get; set; }</p>
<p class=MsoNormal style='margin-bottom:0cm;margin-bottom:.0001pt;line-height: normal;text-autospace:none'>} //end of namespace ThinkGeo.MapSuite.MvcEdition</p>
map_suite_mvc_edition_release_change_log_version_8.0.0.160.1440040123.txt.gz · Last modified: 2015/09/01 07:54 (external edit)
