map_suite_mvc_edition_features_bug_fixes_change_log [2015/08/28 05:55] admin [Version 8.0.0.0] |
map_suite_mvc_edition_features_bug_fixes_change_log [2015/08/28 05:56] (current) admin [Version 6.0.0.0] |
| Line 269: | Line 269: | ||
| ThinkGeo.MapSuite.MvcEdition Namespace: | ThinkGeo.MapSuite.MvcEdition Namespace: | ||
| - | *Added the documentation for new APIs | + | *Added the documentation for new APIs |
| - | *Added GeoCanvas as map's control property | + | *Added GeoCanvas as map's control property |
| - | *Added the Wiki page on wiki.thinkgeo.com | + | *Added the Wiki page on wiki.thinkgeo.com |
| - | *Fixed a bug that the tiles are not displayed when connected to WMS Servers | + | *Fixed a bug that the tiles are not displayed when connected to WMS Servers |
| - | *Fixed a bug that there was a loading image location offset which is on map’s left bottom | + | *Fixed a bug that there was a loading image location offset which is on map’s left bottom |
| - | *Fixed a bug that it would cause memory leak in Internet Explorer 9 | + | *Fixed a bug that it would cause memory leak in Internet Explorer 9 |
| - | *Fixed a bug that ClassBreak is not used when ColumnValue matches BreakValue and BreakValueInclusion = IncludeValue | + | *Fixed a bug that ClassBreak is not used when ColumnValue matches BreakValue and BreakValueInclusion = IncludeValue |
| - | *Added a ClearCache method to MapPrinterLayer to delete the cache image | + | *Added a ClearCache method to MapPrinterLayer to delete the cache image |
| - | *Added a spatial index status cache for MsSql2008FeatureSource | + | *Added a spatial index status cache for MsSql2008FeatureSource |
| - | *Added LinearGradient brush to MapPrinterLayer | + | *Added LinearGradient brush to MapPrinterLayer |
| - | *Added support the FileGeoDatabase | + | *Added support the FileGeoDatabase |
| - | *Added support write white paper on Printing | + | *Added support write white paper on Printing |
| - | *Added support the GRD/GRI grid format | + | *Added support the GRD/GRI grid format |
| - | *Added the FittingPolygonInScreen property to "PositionStyle to fit the labels as best as it can on part of a polygon | + | *Added the FittingPolygonInScreen property to "PositionStyle to fit the labels as best as it can on part of a polygon |
| - | *Added to create an overload for GeoImage constructor to accept a Bitmap | + | *Added to create an overload for GeoImage constructor to accept a Bitmap |
| - | *Added to support the static maps API for GoogleMapsLayer | + | *Added to support the static maps API for GoogleMapsLayer |
| - | *Fixed accuracy issues when converting UTC to WGS84 coordinates zone 30 | + | *Fixed accuracy issues when converting UTC to WGS84 coordinates zone 30 |
| - | *Fixed a bug when using the "GetClosestPointToCore" of GeometryCollectionShape runs into endless loop | + | *Fixed a bug when using the "GetClosestPointToCore" of GeometryCollectionShape runs into endless loop |
| - | *Fixed a bug that it would throw an exception when using a proj4 parameter with ManagedProj4Projection | + | *Fixed a bug that it would throw an exception when using a proj4 parameter with ManagedProj4Projection |
| - | *Fixed a bug in OracleFeatureLayer that it would throw exception when the column is not surround with ‘ ” ’ | + | *Fixed a bug in OracleFeatureLayer that it would throw exception when the column is not surround with ‘ ” ’ |
| - | *Fixed a bug in PrinterLayer that it would make the polygon’s edge follow by the ClippingArea | + | *Fixed a bug in PrinterLayer that it would make the polygon’s edge follow by the ClippingArea |
| - | *Fixed a bug in GDIPlusGeoCanvas that the star symbol’s offset is incorrect | + | *Fixed a bug in GDIPlusGeoCanvas that the star symbol’s offset is incorrect |
| - | *Fixed a bug in ClassBreakStyle that it would cause an IndexOutOfRange exception | + | *Fixed a bug in ClassBreakStyle that it would cause an IndexOutOfRange exception |
| - | *Fixed a bug in AreaBaseShape.GetIntersection that it would throw exception when the result is not AreaBaseShape | + | *Fixed a bug in AreaBaseShape.GetIntersection that it would throw exception when the result is not AreaBaseShape |
| - | *Fixed a bug in openStreetMapLayer that it would get an invalid image | + | *Fixed a bug in openStreetMapLayer that it would get an invalid image |
| - | *Fixed a bug in PdfGeoCanvas that the label’s offset is incorrect | + | *Fixed a bug in PdfGeoCanvas that the label’s offset is incorrect |
| - | *Fixed a bug that the Feature.GeometryLibrary is not synchronized with the BaseShape. GeometryLibrary | + | *Fixed a bug that the Feature.GeometryLibrary is not synchronized with the BaseShape. GeometryLibrary |
| - | *Fixed a bug in IconStyle that if the image is null, it would throw an exception | + | *Fixed a bug in IconStyle that if the image is null, it would throw an exception |
| - | *Fixed a bug in LineShape.GetLineOnALine when the distance is very small | + | *Fixed a bug in LineShape.GetLineOnALine when the distance is very small |
| - | *Fixed a bug in BingmapsLayer that it would display no image when the zoomlevel is larger than 20 | + | *Fixed a bug in BingmapsLayer that it would display no image when the zoomlevel is larger than 20 |
| - | *Fixed a bug in LineShape.GetPointOnALine that it would return a wrong point | + | *Fixed a bug in LineShape.GetPointOnALine that it would return a wrong point |
| - | *Fixed a bug in GeoSerializer that it couldn’t serialize the KeyedColletion type | + | *Fixed a bug in GeoSerializer that it couldn’t serialize the KeyedColletion type |
| - | *Fixed a bug in GDIPlusGeoCanvas and PrinterGeoCanvas when outlinepen.Width = 0, it will still draw the edge | + | *Fixed a bug in GDIPlusGeoCanvas and PrinterGeoCanvas when outlinepen.Width = 0, it will still draw the edge |
| - | *Fixed a bug that the GetPointOnALine doesn't return the correct point if the y coordinates of the vertex are the same | + | *Fixed a bug that the GetPointOnALine doesn't return the correct point if the y coordinates of the vertex are the same |
| - | *Fixed a bug that it's unable to install MapSuite products on Windows 8 | + | *Fixed a bug that it's unable to install MapSuite products on Windows 8 |
| - | *Fixed a bug that CLR types doesn't work on the clean machine | + | *Fixed a bug that CLR types doesn't work on the clean machine |
| - | *Fixed a bug that the BaseShape.Buffer runs into exception when the specified distance is too small | + | *Fixed a bug that the BaseShape.Buffer runs into exception when the specified distance is too small |
| - | *Fixed a bug in GeoSerializer that it may get an exception when serialize and deserialize a multi-dimension array type | + | *Fixed a bug in GeoSerializer that it may get an exception when serialize and deserialize a multi-dimension array type |
| - | *Fixed a bug that it loses accuracy when converting between epsg:27700 and epsg:900013 | + | *Fixed a bug that it loses accuracy when converting between epsg:27700 and epsg:900013 |
| - | *Fixed a bug that something is wrong with the clipping of MapPrinterLayer | + | *Fixed a bug that something is wrong with the clipping of MapPrinterLayer |
| - | *Fixed a bug that some style will throw exception incorrectly | + | *Fixed a bug that some style will throw exception incorrectly |
| - | *Fixed a bug that the scale line would throw exception when the extent out of range | + | *Fixed a bug that the scale line would throw exception when the extent out of range |
| - | *Fixed a bug that EditTools.UpdateFeature is not working in MsSql2008FeatureLayer | + | *Fixed a bug that EditTools.UpdateFeature is not working in MsSql2008FeatureLayer |
| - | *Fixed a bug that 2163 projection will not be converted correctly with UnmanagedProjection | + | *Fixed a bug that 2163 projection will not be converted correctly with UnmanagedProjection |
| - | *Fixed a bug that it would throw "Cannot insert items into an STR packed R-tree after it has been built" exception when using edit tools with multithread | + | *Fixed a bug that it would throw "Cannot insert items into an STR packed R-tree after it has been built" exception when using edit tools with multithread |
| - | *Fixed a bug that the GetIntersection for RectangleShape returns incorrect result | + | *Fixed a bug that the GetIntersection for RectangleShape returns incorrect result |
| - | *Fixed a bug that TextSytle of LegendAdormentLayer doesn't take effect | + | *Fixed a bug that TextSytle of LegendAdormentLayer doesn't take effect |
| - | *Fixed a bug that LegendItems is not respecting TextStyle's GeoFont definitions | + | *Fixed a bug that LegendItems is not respecting TextStyle's GeoFont definitions |
| - | *Fixed a bug that MsSql2008FeatureLayer.CreateTable would throw an exception | + | *Fixed a bug that MsSql2008FeatureLayer.CreateTable would throw an exception |
| - | *Fixed a bug that the features are not displaying by the edge of the full extent if the featureSource is applying a projection | + | *Fixed a bug that the features are not displaying by the edge of the full extent if the featureSource is applying a projection |
| - | *Fixed a bug that open an SDF files with zooming in or zooming out will throw out of array index range issue | + | *Fixed a bug that open an SDF files with zooming in or zooming out will throw out of array index range issue |
| - | *Fixed a bug that the GetDistance would throw exception | + | *Fixed a bug that the GetDistance would throw exception |
| - | *Fixed a bug that the Label should not be so sparse | + | *Fixed a bug that the Label should not be so sparse |
| - | *Fixed Proj4 issue with EPSG 27700 | + | *Fixed Proj4 issue with EPSG 27700 |
| - | *Improved IsoLine that solve some of the input points have no values issue | + | *Improved IsoLine that solve some of the input points have no values issue |
| - | *Improved Map Suite geometric functions to increase processing speed, accuracy and reliability | + | *Improved Map Suite geometric functions to increase processing speed, accuracy and reliability |
| - | *Improved some incorrect comments of the public APIs | + | *Improved some incorrect comments of the public APIs |
| - | *Improved SQL query under x64 mode in ShapeFileFeatureLayer | + | *Improved SQL query under x64 mode in ShapeFileFeatureLayer |
| - | *Improved support the NauticalMile's transformation | + | *Improved support the NauticalMile's transformation |
| - | *Improved the performance of SpatialQuery method for Ms2008SqlServerFeatureSource | + | *Improved the performance of SpatialQuery method for Ms2008SqlServerFeatureSource |
| - | *Improved the result and performance of IsoLine by applying Kringing Grid and tracking algorithm | + | *Improved the result and performance of IsoLine by applying Kringing Grid and tracking algorithm |
| - | *Improved the way of loading the unmanaged assemblies | + | *Improved the way of loading the unmanaged assemblies |
| - | *Improved the "ScaleBarAdornmentLayer" to support setting threshold value for switching scale bar unit | + | *Improved the "ScaleBarAdornmentLayer" to support setting threshold value for switching scale bar unit |
| - | *Improved the LegendPrinterLayer that there is a big blank paging at the top and bottom | + | *Improved the LegendPrinterLayer that there is a big blank paging at the top and bottom |
| - | *Improved the Memory and CPU usage when using OracleFeatureSoruce | + | *Improved the Memory and CPU usage when using OracleFeatureSoruce |
| - | *Improved to look for the assemblies in the same folder first and then check the system32 folder | + | *Improved to look for the assemblies in the same folder first and then check the system32 folder |
| - | *Improved upgrade the FDOExtension to 3.7 and GDAL to 1.9 | + | *Improved upgrade the FDOExtension to 3.7 and GDAL to 1.9 |
| - | *Modified FileBitmapTileCache to use GUID for initial CacheID | + | *Modified FileBitmapTileCache to use GUID for initial CacheID |
| - | *Modified the logic of GetZoomLevelForDrawing by considering the IsActive | + | *Modified the logic of GetZoomLevelForDrawing by considering the IsActive |
| - | *Removed the hard coded spatial index in MSSql2008FeatureSource | + | *Removed the hard coded spatial index in MSSql2008FeatureSource |
| - | *Removed some exception handling with ToScreenCoordinate, ToWorldCoordinate and GetWorldDistanceBetweenTwoScreenPoints | + | *Removed some exception handling with ToScreenCoordinate, ToWorldCoordinate and GetWorldDistanceBetweenTwoScreenPoints |
| Line 350: | Line 350: | ||
| - | *Added Google Map's StreetView to GoogleMapOverlay | + | *Added Google Map's StreetView to GoogleMapOverlay |
| - | *Fixed an issue where certain styles don't call the GetRequiredColumnNames for child styles. | + | *Fixed an issue where certain styles don't call the GetRequiredColumnNames for child styles. |
| - | *Fixed an issue where GeoTiffRasterLayer’s HasBoundingBox always returns true. | + | *Fixed an issue where GeoTiffRasterLayer’s HasBoundingBox always returns true. |
| - | *Implemented GeometryCollection.GetDitanceTo() method. | + | *Implemented GeometryCollection.GetDitanceTo() method. |
| - | *Fixed an spelling issue, rename "Dragable" to "Draggable" | + | *Fixed an spelling issue, rename "Dragable" to "Draggable" |
| - | *Added the ability to use custom servers in OpenStreetMaps. | + | *Added the ability to use custom servers in OpenStreetMaps. |
| - | *Added the support of Nautical Miles to ScaleBarAdornmentLayer. | + | *Added the support of Nautical Miles to ScaleBarAdornmentLayer. |
| - | *Fixed an issue where the first feature is always removed when deleting multiple features in MsSql2008FeatureLayer. | + | *Fixed an issue where the first feature is always removed when deleting multiple features in MsSql2008FeatureLayer. |
| - | *Fixed an issue where an exception is thrown in PrinterGeoCanvas.DrawTextCache method when RotationAngle is not 0. | + | *Fixed an issue where an exception is thrown in PrinterGeoCanvas.DrawTextCache method when RotationAngle is not 0. |
| - | *Improved the Exception Description in FeatureSource.GetAllFeatures method | + | *Improved the Exception Description in FeatureSource.GetAllFeatures method |
| - | *Added the implementation of PostgreSqlFeatureSource GetFeaturesByColumnValueCore. | + | *Added the implementation of PostgreSqlFeatureSource GetFeaturesByColumnValueCore. |
| - | *Fixed an serialization issue where the keys to a GeoCollection were not being added back correctly when de-serializing. | + | *Fixed an serialization issue where the keys to a GeoCollection were not being added back correctly when de-serializing. |
| - | *Fixed an spelling issue, rename GoogleMapZoomLevelSet to GoogleMapsZoomLevelSet. | + | *Fixed an spelling issue, rename GoogleMapZoomLevelSet to GoogleMapsZoomLevelSet. |
| - | *Fixed an issue where shapefile's bounding box is not updated after removing a feature. | + | *Fixed an issue where shapefile's bounding box is not updated after removing a feature. |
| - | *Fixed an issue where multi features cannot be correct deleted at the same time. | + | *Fixed an issue where multi features cannot be correct deleted at the same time. |
| - | *Fixed an issue where ShapeFileFeatureSource.GetBoundingBoxById() doesn't call GetFeaturesByIdsCore() internally. | + | *Fixed an issue where ShapeFileFeatureSource.GetBoundingBoxById() doesn't call GetFeaturesByIdsCore() internally. |
| - | *Improved the creating shape performance by moving some logic from BaseShape constructor to property. | + | *Improved the creating shape performance by moving some logic from BaseShape constructor to property. |
| - | *Removed the TabFeatureLayer from FdoExtension as we've added it in MapSuiteCore. | + | *Removed the TabFeatureLayer from FdoExtension as we've added it in MapSuiteCore. |
| - | *Fixed an issue where WorldMapKitLayer couldn't export to Pdf by using PdfExtension. | + | *Fixed an issue where WorldMapKitLayer couldn't export to Pdf by using PdfExtension. |
| - | *Fixed an issue where an exception is thrown in BingMapsLayer when zooming to an area where no imagery is available. | + | *Fixed an issue where an exception is thrown in BingMapsLayer when zooming to an area where no imagery is available. |
| - | *Added Clear() method into InMemoryFeatureLayer and InMemoryFeatureSource. | + | *Added Clear() method into InMemoryFeatureLayer and InMemoryFeatureSource. |
| - | *Improved the performance of MsSql2008FeatureSource GetBoundingBox | + | *Improved the performance of MsSql2008FeatureSource GetBoundingBox |
| - | *Fixed an issue where files with big case ".SHP" extension are not accepted. | + | *Fixed an issue where files with big case ".SHP" extension are not accepted. |
| - | *Added the support of WMS 1.3.0. | + | *Added the support of WMS 1.3.0. |
| - | *Fixed an issue where PagePrinterLayer automatically changes the orientation.. | + | *Fixed an issue where PagePrinterLayer automatically changes the orientation.. |
| - | *Added StreamLoading event to GridIsoLineLayer | + | *Added StreamLoading event to GridIsoLineLayer |
| - | *Upgraded all the 3rd part DLLs referenced to the latest version | + | *Upgraded all the 3rd part DLLs referenced to the latest version |
| - | *Fixed the issue where the features returned by GetFeaturesInsideBoundingBox shouldn’t contain the ones removed. | + | *Fixed the issue where the features returned by GetFeaturesInsideBoundingBox shouldn’t contain the ones removed. |
| - | *Improved the map object XML Serialization. | + | *Improved the map object XML Serialization. |
| - | *Improved Speed Improvements by introducing MapSuite WicBitmap extension. | + | *Improved Speed Improvements by introducing MapSuite WicBitmap extension. |
| - | *Added the support of Layer Transparency. | + | *Added the support of Layer Transparency. |
| - | *Improved the Memory Usage for ShapeFileFeatureSource. | + | *Improved the Memory Usage for ShapeFileFeatureSource. |
| - | *Upgraded MrSid & Ecw to the latest version. | + | *Upgraded MrSid & Ecw to the latest version. |
| - | *Improved drawing performance. | + | *Improved drawing performance. |
| - | *Added the support of Code Generator. | + | *Added the support of Code Generator. |
| - | *Fixed the issue where the "out of memory" exception is thrown when loading a large .tiff image. | + | *Fixed the issue where the "out of memory" exception is thrown when loading a large .tiff image. |
| - | *Improved the drawing quality of TiffRasterLayer by optimizing the reading logic | + | *Improved the drawing quality of TiffRasterLayer by optimizing the reading logic |
| - | *Improved Label Formatting by adding Formatting and Formatted events to TextStyle. | + | *Improved Label Formatting by adding Formatting and Formatted events to TextStyle. |
