map_suite_mono_environment_setup_guide_on_linux [2017/03/28 19:44] bradrollins [Map Suite Mono Environment Setup Guide on Linux] |
map_suite_mono_environment_setup_guide_on_linux [2017/03/28 19:46] (current) bradrollins [For Winforms:] |
| Line 12: | Line 12: | ||
| * Prepare a clean Ubuntu environment with version [[https://www.ubuntu.com/download/desktop|16.04.01 LTS]]. | * Prepare a clean Ubuntu environment with version [[https://www.ubuntu.com/download/desktop|16.04.01 LTS]]. | ||
| * Press Ctrl + Alt + T to open a terminal window. | * Press Ctrl + Alt + T to open a terminal window. | ||
| - | * Install the IDE MonoDevelop as it is recommended to develop on Linux. Run the following command to install Mono Develop on your computer. | + | * Install the MonoDevelop IDE as it is recommended to develop on Linux. Run the following command to install Mono Develop on your computer. |
| <code asp> | <code asp> | ||
| sudo apt-get install monodevelop | sudo apt-get install monodevelop | ||
| </code> | </code> | ||
| - | * Use monodevelop command in terminal to open MonoDevelop or you can click on the left top corner of task bar to search MonoDevelop and run it. You can open the Visual Studio solution file via MonoDevelop. | + | * Type monodevelop in the terminal to open MonoDevelop or you can click on the left top corner of task bar to search MonoDevelop and run it. You can open the Visual Studio solution file via MonoDevelop. |
| ====WebAPI / WebForms:==== | ====WebAPI / WebForms:==== | ||
