Both sides previous revision Previous revision | Last revision Both sides next revision | ||
map_suite_mobile_for_android [2020/05/19 21:13] benbai [Map Suite Mobile for Android] |
map_suite_mobile_for_android [2020/05/19 21:24] benbai [Map Suite Mobile for Android] |
Line 2: | Line 2: | ||
- | **Note:** The page is for Map Suite 10. If you are using Map Suite 9.0 or previous versions of Map Suite product, please go to [[map_suite_android_edition|MapSuite 9.0 Wiki]]. We highly recommended you to upgrade to ThinkGeo 12.0 if possible which supports both .NET Framework and .NET Core, which is easier to use and got more features over the previous version. The majority of previously built code should work without modification assuming the new namespaces are added. For guidance on upgrading your existing code, please check out [[thinkgeo_12_upgrade_guide|ThinkGeo 12 Upgrade Guide]]. </div> | + | **Note:** The page is for Map Suite 10. If you are using Map Suite 9.0 or previous versions of Map Suite product, please go to [[map_suite_android_edition|MapSuite 9.0 Wiki]]. We highly recommended you to upgrade to ThinkGeo 12.0 if possible which supports both .NET Framework and .NET Core, which is easier to use and get more features over the previous version. The majority of previously built code should work without modification assuming the new namespaces are added. For guidance on upgrading your existing code, please check out [[thinkgeo_12_upgrade_guide|ThinkGeo 12 Upgrade Guide]]. </div> |
