Both sides previous revision Previous revision | Next revision Both sides next revision | ||
map_suite_mobile_for_android [2017/05/08 03:06] tgwikiupdate Remove layers sample link. |
map_suite_mobile_for_android [2020/05/19 21:13] benbai [Map Suite Mobile for Android] |
Line 2: | Line 2: | ||
- | **Note:** If you are using Map Suite 9.0 or previous versions of Map Suite product, please go to [[map_suite_android_edition|MapSuite 9.0 Wiki]]. The current page is for Map Suite 10.0 and future versions. It has different assemblies, licensing strategy and ways of distribution, and more. although the majority of previously built code should work without modification assuming the new namespaces are added. For guidance on upgrading your existing code to Map Suite 10, please check out [[map_suite_10_upgrade_guide|MapSuite 10 Upgrade Guide]]. </div> | + | **Note:** The page is for Map Suite 10. If you are using Map Suite 9.0 or previous versions of Map Suite product, please go to [[map_suite_android_edition|MapSuite 9.0 Wiki]]. We highly recommended you to upgrade to ThinkGeo 12.0 if possible which supports both .NET Framework and .NET Core, which is easier to use and got more features over the previous version. The majority of previously built code should work without modification assuming the new namespaces are added. For guidance on upgrading your existing code, please check out [[thinkgeo_12_upgrade_guide|ThinkGeo 12 Upgrade Guide]]. </div> |
ThinkGeo's Map Suite for Android™ is a powerful .NET control that lets you add interactive maps and professional-grade GIS to your Android apps. Using the power of the [[http://xamarin.com/|Xamarin]] mobile platform and Map Suite together, you can develop native Android apps using the C# language and .NET libraries you're already familiar with. | ThinkGeo's Map Suite for Android™ is a powerful .NET control that lets you add interactive maps and professional-grade GIS to your Android apps. Using the power of the [[http://xamarin.com/|Xamarin]] mobile platform and Map Suite together, you can develop native Android apps using the C# language and .NET libraries you're already familiar with. |
