map_suite_mobile_for_android [2017/03/03 09:57] tgwikiupdate |
map_suite_mobile_for_android [2020/05/19 21:24] benbai [Map Suite Mobile for Android] |
====== Map Suite Mobile for Android ====== | ====== Map Suite Mobile for Android ====== | ||
+ | <div msgbox> | ||
+ | **Note:** The page is for Map Suite 10. If you are using Map Suite 9.0 or previous versions of Map Suite product, please go to [[map_suite_android_edition|MapSuite 9.0 Wiki]]. We highly recommended you to upgrade to ThinkGeo 12.0 if possible which supports both .NET Framework and .NET Core, which is easier to use and get more features over the previous version. The majority of previously built code should work without modification assuming the new namespaces are added. For guidance on upgrading your existing code, please check out [[thinkgeo_12_upgrade_guide|ThinkGeo 12 Upgrade Guide]]. </div> | ||
ThinkGeo's Map Suite for Android™ is a powerful .NET control that lets you add interactive maps and professional-grade GIS to your Android apps. Using the power of the [[http://xamarin.com/|Xamarin]] mobile platform and Map Suite together, you can develop native Android apps using the C# language and .NET libraries you're already familiar with. | ThinkGeo's Map Suite for Android™ is a powerful .NET control that lets you add interactive maps and professional-grade GIS to your Android apps. Using the power of the [[http://xamarin.com/|Xamarin]] mobile platform and Map Suite together, you can develop native Android apps using the C# language and .NET libraries you're already familiar with. | ||
- | It's very easy to get started. You can start from getting the samples from GitHub, or start from creating a new application in your Visual Studio. GitHub samples run properly in MonoDevelop on Linux as well. Please have a quick look at the following short videos. | + | ===== Getting Started ===== |
+ | It's very easy to get started. You can start from getting the samples from GitHub, or start from creating a new application in your Visual Studio. Please have a quick look at the following short videos. | ||
- | [[media:map_suite_mobilde_for_android_quickstart|{{androidedition:screenshot:Introduction_to_the_MapSuite_ForAndroid.png?180x99|Map Suite Mobile for Android Quickstart On Windows}}]] | + | [[media:map_suite_mobilde_for_android_quickstart|{{mapsuite10:android:Map_Suite_Mobile_For_Android_Run_Github_Sample_on_Windows.png?180x99|Map Suite Mobile for Android Quickstart On Android}}]] |
- | Run GitHub Sample on Windows (2'30") | + | Run GitHub Sample on Android(4'00") |
- | [[media:map_suite_mobilde_for_android_hello_world|{{androidedition:screenshot:Introduction_to_the_MapSuite_ForAndroid.png?180x99|Map Suite Mobile for Android Hello World}}]] | + | [[media:map_suite_mobilde_for_android_hello_world|{{mapsuite10:android:map_suite_mobile_for_android_hello_world.png?180x99|Map Suite Mobile for Android Hello World}}]] |
- | Hello World on Windows (3'09") | + | Hello World on Android(4'27") |
- | ===== Product Guides ===== | + | \\ |
> [[Map Suite Mobile for Android Quick Start Guide|Quick Start Guide]] | > [[Map Suite Mobile for Android Quick Start Guide|Quick Start Guide]] | ||
Helps you get started building your first application with the Map Suite Mobile for Android. | Helps you get started building your first application with the Map Suite Mobile for Android. | ||
+ | ===== Product Guides ===== | ||
Line 65: | Line 72: | ||
Introduces what licenses are needed / how the license would work for debugging/deploying the Map Suite products | Introduces what licenses are needed / how the license would work for debugging/deploying the Map Suite products | ||
+ | <div dokuteaser> | ||
+ | > [[map_suite_10_upgrade_guide|Upgrade Guide]] | ||
+ | Introduces how to upgrade to Map Suite 10.0 from Map Suite 9.0 or previous version. | ||
+ | > [[map_suite_platform_coverage|Platform Coverage Guide]] | ||
+ | Show Map Suite features coverage of different product and different platfoms | ||
===== Learning Samples ===== | ===== Learning Samples ===== | ||
Line 75: | Line 93: | ||
Browse the demo applications to see the power of Map Suite Mobile for Android. | Browse the demo applications to see the power of Map Suite Mobile for Android. | ||
- | <div #learningmore>[[http://wiki.thinkgeo.com/wiki/map_suite_mobile_for_android_all_samples|Explore and Study "All Learning Sample" now →]]</div> | + | <div #learningmore>[[http://wiki.thinkgeo.com/wiki/map_suite_mobile_for_android_all_samples|Explore and Study "All Learning Sample" now →]] |
+ | <div #learningmore>[[http://wiki.thinkgeo.com/wiki/map_suite_all_samples|Explore and Study "All Samples Across all the Products" now →]]</div></div> | ||
Line 86: | Line 105: | ||
<div desc>[[https://github.com/ThinkGeo/GettingStartedSample-ForAndroid|Learn about what the Mobile for Android has to offer and how you can get started building Android applications.]]</div> | <div desc>[[https://github.com/ThinkGeo/GettingStartedSample-ForAndroid|Learn about what the Mobile for Android has to offer and how you can get started building Android applications.]]</div> | ||
- | <div medialist gallery> | + | |
- | [[https://github.com/ThinkGeo?utf8=%E2%9C%93&q=android%20layers&type=&language=|{{:no_screenshot_202px.jpg|Layers}}]] | + | |
- | <div gallery_title>Layers</div> | + | |
- | <div desc>[[https://github.com/ThinkGeo?utf8=%E2%9C%93&q=android%20layers&type=&language=|Explore all the different types of layers and data formats you can use to build up your map.]]</div> | + | |
- | </div> | + | |
<div medialist gallery>[[https://github.com/ThinkGeo/AnalyzingVisualizationSample-ForAndroid|{{androidedition:screenshot:visualization_android_202px.png|Visualizing Data}}]] | <div medialist gallery>[[https://github.com/ThinkGeo/AnalyzingVisualizationSample-ForAndroid|{{androidedition:screenshot:visualization_android_202px.png|Visualizing Data}}]] | ||
<div gallery_title>Visualizing Data</div> | <div gallery_title>Visualizing Data</div> | ||
Line 113: | Line 126: | ||
- | <div medialist gallery>[[https://github.com/ThinkGeo?utf8=%E2%9C%93&q=android%20project%20templates&type=&language=|{{androidedition:screenshot:siteselection_android_202px.png|Project Templates}}]] | + | <div medialist gallery>[[http://wiki.thinkgeo.com/wiki/map_suite_mobile_for_android_project_templates|{{androidedition:screenshot:siteselection_android_202px.png|Project Templates}}]] |
<div gallery_title>Project Templates</div> | <div gallery_title>Project Templates</div> | ||
- | <div desc>[[https://github.com/ThinkGeo?utf8=%E2%9C%93&q=android%20project%20templates&type=&language=|These project templates which combine several different concepts to make real world applications.]]</div> | + | <div desc>[[http://wiki.thinkgeo.com/wiki/map_suite_mobile_for_android_project_templates|These project templates which combine several different concepts to make real world applications.]]</div> |
Line 129: | Line 142: | ||
===== Package ===== | ===== Package ===== | ||
==== Standard ==== | ==== Standard ==== | ||
- | Standard version contains all packages that Map Suite supported on this platform which should meet most user's requirements. | + | The standard package contains all packages that Map Suite supported on this platform which should meet most user's requirements. |
[[map_suite_mobile_for_android_package_coverage|Compare with Barebone]] | [[map_suite_mobile_for_android_package_coverage|Compare with Barebone]] | ||
==== Barebone ==== | ==== Barebone ==== | ||
- | Barebone version is intended for experienced Map Suite developers who require fine grain control over their dependencies. All other developer please use the Standard Edition. | + | The barebone package is intended for experienced Map Suite developers who require adept control over their dependencies. All other developer please use the standard package. |
[[map_suite_mobile_for_android_package_coverage|Compare with Standard]] | [[map_suite_mobile_for_android_package_coverage|Compare with Standard]] | ||
Line 323: | Line 336: | ||
+ | ===== Frequently Asked Questions===== | ||
+ | * [[Map Suite Mobile for Android FAQ General Questions|General Questions]]<div>These frequently asked questions cover high level GIS and mapping topics that are not categorized in other areas. </div> | ||
