map_suite_main_page [2017/03/15 09:44] marklee created |
map_suite_main_page [2017/03/20 01:07] marklee created |
=====Welcome to the ThinkGeo Wiki===== | =====Welcome to the ThinkGeo Wiki===== | ||
+ | {{section>upgrade_map_suite_from_9.0#Upgrade Map Suite to 10.0}} | ||
The ThinkGeo Wiki is the central and official source of documentation, sample code and learning material for Map Suite users. It contains resources such as API reference, QuickStart Guides to get you started, sample projects with source code you can learn from, change logs for each version, and more. | The ThinkGeo Wiki is the central and official source of documentation, sample code and learning material for Map Suite users. It contains resources such as API reference, QuickStart Guides to get you started, sample projects with source code you can learn from, change logs for each version, and more. | ||
- | If you are using Map Suite 9.0 or previous versions of Map Suite product, please go to [[map_suite_legacy_main_page|MapSuite 9.0 Wiki]]. The current page is for Map Suite 10.0 and future versions. It has different assemblies, licensing strategy and ways of distribution, and more. although the majority of previous built code should work without modification assuming the new namespaces are added. For guidance on upgrading your existing code to Map Suite 10, please check out [[map_suite_10_upgrade_guide|MapSuite 10 Upgrade Guide]]. | ||
=====Products & Services===== | =====Products & Services===== | ||
- | The wiki's resources are categorized by product. So you can easily find the information you need for the Map Suite products you're working with. The products run on one or more platforms; the key features, which are shared by different products, runs on different platforms as well. Please check [[map_suite_platform_coverage|platform coverage]] for the details. | + | The wiki's resources are categorized by product, so you can easily find the information you need for the Map Suite products you're working with. The products run on one or more platforms; the key features, which are shared by different products, run on different platforms as well. Please check [[map_suite_platform_coverage|platform coverage]] for the details. |
> **For Mobile Platforms** | > **For Mobile Platforms** | ||
Line 65: | Line 66: | ||
<div productlist product_container title_brown> | <div productlist product_container title_brown> | ||
- | <div clearexternlink>[[map_suite_gis_server|GIS Server]]</div> | + | <div clearexternlink>[[map_suite_gis_server|GIS Server(Coming Soon)]]</div> |
<div product_desc>Cloud server which can be accessed from any REST capable client.</div> | <div product_desc>Cloud server which can be accessed from any REST capable client.</div> | ||
<div linkbutton>[[map_suite_gis_server|GIS Server]]</div> | <div linkbutton>[[map_suite_gis_server|GIS Server]]</div> | ||
Line 75: | Line 76: | ||
<div clearexternlink>[[map_suite_server_routing|Routing]]</div> | <div clearexternlink>[[map_suite_server_routing|Routing]]</div> | ||
- | <div product_desc>Adds turn-by-turn routing and directions</div> | + | <div product_desc>Find the shortest path between multiple locations, deliver turn-by-turn directions, avoid specified areas</div> |
<div linkbutton>[[map_suite_server_routing|Routing]]</div> | <div linkbutton>[[map_suite_server_routing|Routing]]</div> | ||
- | <div clearexternlink>[[map_suite_server_geocoder|Geocoder]]</div> | + | <div clearexternlink>[[map_suite_server_geocoding|Geocoding]]</div> |
<div product_desc>Convert addresses to coordinates and vice-versa</div> | <div product_desc>Convert addresses to coordinates and vice-versa</div> | ||
- | <div linkbutton>[[map_suite_server_geocoder|Geocoder]]</div> | + | <div linkbutton>[[map_suite_server_geocoding|Geocoding]]</div> |
- | <div clearexternlink>[[map_suite_server_world_streets|World Streets(Coming Soon)]]</div> | + | <div clearexternlink>[[map_suite_server_world_streets|World Streets]]</div> |
- | <div product_desc>World Streets</div> | + | <div product_desc>Royalty-free worldwide vector data ready to use in your application.</div> |
<div linkbutton>[[map_suite_server_world_streets|World Streets]]</div> | <div linkbutton>[[map_suite_server_world_streets|World Streets]]</div> | ||
- | <div clearexternlink>[[map_suite_server_world_imagery|World Imagery(Coming Soon)]]</div> | + | <div clearexternlink>[[map_suite_server_world_imagery|World Imagery]]</div> |
- | <div product_desc>World Imagery</div> | + | <div product_desc>Royalty-free high-level global imagery matched with highly-detailed US imagery.</div> |
<div linkbutton>[[map_suite_server_world_imagery|World Imagery]]</div> | <div linkbutton>[[map_suite_server_world_imagery|World Imagery]]</div> | ||
- | <div clearexternlink>[[map_suite_server_reverse_geocoder|Reverse-Geocoder (Coming Soon)]]</div> | + | <div clearexternlink>[[map_suite_server_reverse_geocoding|Reverse-Geocoding]]</div> |
- | <div product_desc>Reverse-Geocoder</div> | + | <div product_desc>Reverse-geocoding allows you to match a latitude and longitude location to a street address anywhere on earth.</div> |
- | <div linkbutton>[[map_suite_server_reverse_geocoder|Reverse-Geocoder]]</div> | + | <div linkbutton>[[map_suite_server_reverse_geocoding|Reverse-Geocoding]]</div> |
- | <div clearexternlink>[[map_suite_server_elevation|Elevation(Coming Soon)]]</div> | + | <div clearexternlink>[[map_suite_server_elevation|Elevation]]</div> |
- | <div product_desc>Elevation</div> | + | <div product_desc>Global elevation point, contour, and viewshed at your fingertips.</div> |
<div linkbutton>[[map_suite_server_elevation|Elevation]]</div> | <div linkbutton>[[map_suite_server_elevation|Elevation]]</div> | ||
</div> | </div> |
