map_suite_ios_edition_features_bug_fixes_change_log [2015/09/15 03:18] admin |
map_suite_ios_edition_features_bug_fixes_change_log [2015/09/15 03:18] admin [Version 9.0.0.0] |
====== Map Suite iOS Edition Features & Bug Fixes Change Log ====== | ====== Map Suite iOS Edition Features & Bug Fixes Change Log ====== | ||
- | {{article rating}} | ||
=====Version 9.0.0.0===== | =====Version 9.0.0.0===== | ||
Release date: 06/24/2015 | Release date: 06/24/2015 | ||
Line 67: | Line 66: | ||
* Added Attribution to all layers and Overlays. | * Added Attribution to all layers and Overlays. | ||
* Fxied a bug where the MagneticDeclinationAdornmentLayer runs into memory issue. | * Fxied a bug where the MagneticDeclinationAdornmentLayer runs into memory issue. | ||
- | * Added the new API SetWellKnownBinary(byte[[]] wkb) to Feature class to allow changing the WKB of the feature. | + | * Added the new API SetWellKnownBinary(byte[] wkb) to Feature class to allow changing the WKB of the feature. |
- | * Improved the performance of method byte[[]] ShapeFile.ReadPolygon(byte[[]] dataBytes, int startIndex). | + | * Improved the performance of method byte[] ShapeFile.ReadPolygon(byte[] dataBytes, int startIndex). |
* Removed the using JTS in Feature to Shape conversion(BaseShape.FromWellKnownBinary, BaseShape.CreateShapeFromWellKnownData). | * Removed the using JTS in Feature to Shape conversion(BaseShape.FromWellKnownBinary, BaseShape.CreateShapeFromWellKnownData). | ||
* Added enhancements to OpenStreetMapLayer and OpenStreetMapOverlay to make sure the exception can be thrown out. | * Added enhancements to OpenStreetMapLayer and OpenStreetMapOverlay to make sure the exception can be thrown out. |
