Both sides previous revision Previous revision | Next revision Both sides next revision | ||
map_suite_ios_edition_all_samples [2015/09/10 08:47] admin |
map_suite_ios_edition_all_samples [2015/09/17 13:29] admin |
- | ====== Map Suite iOS Edition All Samples ====== | + | ====== Map Suite iOS Edition All Samples ====== |
- | ==== GettingStarted ==== | + | |
+ | ==== GettingStarted ==== | ||
+ | <div screenshot> | ||
{{iosedition:codesamples:GettingStarted_IPAD.png?300x180}} | {{iosedition:codesamples:GettingStarted_IPAD.png?300x180}} | ||
- | \\ | + | </div> |
- | [[Source_Code_iOSEditionSample_GettingStarted.zip|View Source]] | | + | <div content> |
- | {{:File:iOSEditionSample_GettingStarted_141211.zip|C# Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\ | + | <div download_viewsource_buttons> |
+ | [[Source_Code_iOSEditionSample_GettingStarted.zip|View Source]] | ||
+ | {{:File:iOSEditionSample_GettingStarted_141211.zip|C# Download}} | ||
[[Map Suite Samples Applies To|Applies To: iOS]] | [[Map Suite Samples Applies To|Applies To: iOS]] | ||
Learn some of the basics about mapping such as coordinates, scale and zoom levels, setting extents and handling click and other events on the map. | Learn some of the basics about mapping such as coordinates, scale and zoom levels, setting extents and handling click and other events on the map. | ||
- | ==== AnalyzeVisual ==== | ||
+ | ==== AnalyzeVisual ==== | ||
{{iosedition:codesamples:Visualization_IPAD.png?300x180}} | {{iosedition:codesamples:Visualization_IPAD.png?300x180}} | ||
- | [[Source_Code_iOSEditionSample_AnalyzeVisual.zip|View Source]] | | + | <div content> |
- | {{:File:iOSEditionSample_AnalyzeVisual_141211.zip|C# Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\ | + | <div download_viewsource_buttons> |
+ | [[Source_Code_iOSEditionSample_AnalyzeVisual.zip|View Source]] | ||
+ | {{:File:iOSEditionSample_AnalyzeVisual_141211.zip|C# Download}} | ||
Explore the different styles available to help you analyze and visualize your data. | Explore the different styles available to help you analyze and visualize your data. | ||
- | ==== LabelStyling ==== | ||
+ | ==== LabelStyling ==== | ||
{{iosedition:codesamples:LabelStyling IPAD.png?300x180}} | {{iosedition:codesamples:LabelStyling IPAD.png?300x180}} | ||
- | [[Source_Code_iOSEditionSample_Labeling.zip|View Source]] | | + | <div content> |
- | {{:File:iOSEditionSample_Labeling_141211.zip|C# Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\ | + | <div download_viewsource_buttons> |
+ | [[Source_Code_iOSEditionSample_Labeling.zip|View Source]] | ||
+ | {{:File:iOSEditionSample_Labeling_141211.zip|C# Download}} | ||
This samples shows you how to examine different labeling techniques to make your map informative. | This samples shows you how to examine different labeling techniques to make your map informative. | ||
- | ==== Drawing & Editing ==== | ||
+ | ==== Drawing & Editing ==== | ||
{{iosedition:codesamples:Draw_Edit_Features_IPAD.png?300x180}} | {{iosedition:codesamples:Draw_Edit_Features_IPAD.png?300x180}} | ||
- | [[Source_Code_iOSEditionSample_DrawEditFeatures.zip|View Source]] | | + | <div content> |
- | {{:File:iOSEditionSample_DrawEditFeatures_141211.zip|C# Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\ | + | <div download_viewsource_buttons> |
+ | [[Source_Code_iOSEditionSample_DrawEditFeatures.zip|View Source]] | ||
+ | {{:File:iOSEditionSample_DrawEditFeatures_141211.zip|C# Download}} | ||
This samples shows you how to implement drawing and editing shapes into your iOS application. | This samples shows you how to implement drawing and editing shapes into your iOS application. | ||
- | ==== GeometricFunctions ==== | ||
+ | ==== GeometricFunctions ==== | ||
{{iosedition:codesamples:GeoFunctions_IPAD.png?300x180}} | {{iosedition:codesamples:GeoFunctions_IPAD.png?300x180}} | ||
- | [[Source_Code_iOSEditionSample_GeometricFunctions.zip|View Source]] | | + | <div content> |
- | {{:File:iOSEditionSample_GeometricFunctions_141211.zip|C# Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\ | + | <div download_viewsource_buttons> |
+ | [[Source_Code_iOSEditionSample_GeometricFunctions.zip|View Source]] | ||
+ | {{:File:iOSEditionSample_GeometricFunctions_141211.zip|C# Download}} | ||
This samples shows you how to use geometric functions to analyze your map informative. | This samples shows you how to use geometric functions to analyze your map informative. | ||
- | ==== US Earthquake Statistics ==== | ||
+ | ==== US Earthquake Statistics ==== | ||
{{iosedition:codesamples:Map Suite iOS Edition USEarthquakeStatics.png?300x180}} | {{iosedition:codesamples:Map Suite iOS Edition USEarthquakeStatics.png?300x180}} | ||
- | [[Source Code iOS Edition ProjectTemplates USEarthquakeStatics CS.zip|View Source]] | | + | <div content> |
- | {{:File:iOS Edition ProjectTemplates UsEarthquakeStatistics CS_141211.zip|C# Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] | + | <div download_viewsource_buttons> |
+ | [[Source Code iOS Edition ProjectTemplates USEarthquakeStatics CS.zip|View Source]] | ||
+ | {{:File:iOS Edition ProjectTemplates UsEarthquakeStatistics CS_141211.zip|C# Download}} | ||
The Earthquake Statistics sample template is a statistical report system for earthquakes that have occurred in the past few years across the United States. It can help you generate infographics and analyze the severely afflicted areas, or used as supporting evidence when recommending measures to minimize the damage in future quakes. | The Earthquake Statistics sample template is a statistical report system for earthquakes that have occurred in the past few years across the United States. It can help you generate infographics and analyze the severely afflicted areas, or used as supporting evidence when recommending measures to minimize the damage in future quakes. | ||
- | ==== Site Selection ==== | ||
+ | ==== Site Selection ==== | ||
{{iosedition:codesamples:Map Suite for iOS Edition SiteSelection.png?300x180}} | {{iosedition:codesamples:Map Suite for iOS Edition SiteSelection.png?300x180}} | ||
- | [[Source Code iOS ProjectTemplates SiteSelection CS.zip|View Source]] | | + | <div content> |
- | {{:File:iOS Edition ProjectTemplates SiteSelection CS_141211.zip|C# Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] | + | <div download_viewsource_buttons> |
+ | [[Source Code iOS ProjectTemplates SiteSelection CS.zip|View Source]] | ||
+ | {{:File:iOS Edition ProjectTemplates SiteSelection CS_141211.zip|C# Download}} | ||
The Site Selection sample template allows you to view, understand, interpret, and visualize spatial data in many ways that reveal relationships, patterns, and trends. In the example illustrated, the user can apply the features of GIS to analyze spatial data to efficiently choose a suitable site for a new retail outlet. | The Site Selection sample template allows you to view, understand, interpret, and visualize spatial data in many ways that reveal relationships, patterns, and trends. In the example illustrated, the user can apply the features of GIS to analyze spatial data to efficiently choose a suitable site for a new retail outlet. | ||
- | ====How Do I?==== | ||
+ | ==== How Do I? ==== | ||
{{iosedition:codesamples:How_Do_I_IPAD.png?300x180}} | {{iosedition:codesamples:How_Do_I_IPAD.png?300x180}} | ||
- | {{:File:iOSEditionSample_HowDoI_141211.zip|C# Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] | + | <div download_viewsource_buttons> |
- | \\ \\ | + | [[Source Code iOS ProjectTemplates SiteSelection CS.zip|View Source]] |
+ | {{:File:iOSEditionSample_HowDoI_141211.zip|C# Download}} | ||
The "How Do I?" samples collection is a comprehensive set containing dozens of interactive samples. Available in C#, these samples are designed to hit all the highlights of Map Suite, from simply adding a layer to a map to performing spatial queries and applying a thematic style. Consider this collection your "encyclopedia" of all the Map Suite basics and a great starting place for new users. | The "How Do I?" samples collection is a comprehensive set containing dozens of interactive samples. Available in C#, these samples are designed to hit all the highlights of Map Suite, from simply adding a layer to a map to performing spatial queries and applying a thematic style. Consider this collection your "encyclopedia" of all the Map Suite basics and a great starting place for new users. | ||
