map_suite_installation_guide [2015/09/06 07:13] admin |
map_suite_installation_guide [2015/09/25 07:19] admin [Environment Preparation] |
Line 35: | Line 35: | ||
If you are using Visual Studio 2010 or Express 2010, then you may need to install additional toolsets depending on the edition of Map Suite you intend to use. Refer to the table below to see if your preferred Map Suite edition requires this. If you are using Visual Studio 2012 or newer, you do not need to install any of these additional tools. | If you are using Visual Studio 2010 or Express 2010, then you may need to install additional toolsets depending on the edition of Map Suite you intend to use. Refer to the table below to see if your preferred Map Suite edition requires this. If you are using Visual Studio 2012 or newer, you do not need to install any of these additional tools. | ||
- | ^ Map Suite Product ^ Additional Tools Needed ^ | + | ^ Map Suite Product ^ Additional Tools Needed ^ |
- | | Map Suite MVC Edition |* [[http://www.microsoft.com/en-us/download/details.aspx?id=30683|ASP.NET MVC 4 for Visual Studio 2010 SP1]] | | + | | Map Suite MVC Edition | [[http://www.microsoft.com/en-us/download/details.aspx?id=30683|ASP.NET MVC 4 for Visual Studio 2010 SP1]] | |
- | | Map Suite Silverlight Edition | * [[http://www.microsoft.com/en-us/download/details.aspx?id=18149|Silverlight 4 Tools for Visual Studio 2010]], or \\ * [[http://www.microsoft.com/en-us/download/details.aspx?id=28358|Silverlight 5 Tools for Visual Studio 2010 SP1]] | | + | | Map Suite Silverlight Edition | [[http://www.microsoft.com/en-us/download/details.aspx?id=18149|Silverlight 4 Tools for Visual Studio 2010]], or \\ [[http://www.microsoft.com/en-us/download/details.aspx?id=28358|Silverlight 5 Tools for Visual Studio 2010 SP1]] | |
