map_suite_gis_editor_control_plugin_samples [2015/09/18 04:08] admin |
map_suite_gis_editor_control_plugin_samples [2015/10/10 07:31] |
- | ====== Map Suite GIS Editor Control Plugin Samples ====== | ||
- | <div sampleitem> | ||
- | ==== Zoom To A Point ==== | ||
- | <div screenshot> | ||
- | {{:no_screenshot.jpg?300x180}} | ||
- | </div> | ||
- | <div content> | ||
- | <div download_viewsource_buttons> | ||
- | [[Source_Code_GISEditorSample_ZoomToAPoint_CS_121129.zip|View Source]] | ||
- | {{:File:GISEditorSample_ZoomToAPoint_CS_121129.zip|C# Download}} | ||
- | </div> | ||
- | <div sample_otherlinks> | ||
- | [[Map Suite Samples Applies To|Applies To: GIS Editor ]] | ||
- | [[Map Suite Samples Alternate Languages | Need it in another language?]] | ||
- | </div> | ||
- | This sample will show you how to create a UI plugin which uses the menu bar, map and has settings. In the sample we will add a button to the menu bar which when clicked will popup a dialog allow you to enter in X & Y coordinated. When you are finished the map will zoom to that location based on a zoom level that you set in its settings. We will create a setting control to hold the setting and persist it in the plugin between instantiations. | ||
- | </div> | ||
- | </div> | ||
