map_suite_geocoder_silverlight_howdoi_cs [2015/09/07 10:35] admin [Map Suite Geocoder Silverlight Edition How Do I Samples] |
map_suite_geocoder_silverlight_howdoi_cs [2015/10/10 07:31] |
- | ====== Map_Suite_Geocoder_Silverlight_HowDoI_CS ====== | ||
- | ====Map Suite Geocoder Silverlight Edition How Do I Samples==== | ||
- | <div sampleitem> | ||
- | {{geocoder:codesamples:GeocoderDesktopHowDoI Screenshot.png?300x180|screenshot}} | ||
- | {{:File:Geocoder_Silverlight_HowDoI_CS_141211.zip|C# Download}} | {{:File:Geocoder_Silverlight_HowDoI_VB.zip|VB Download}} | | ||
- | [[Map Suite Samples Alternate Languages|Need it in another language?]] \\ \\ | ||
- | [[Map Suite Samples Applies To|Applies To: MVC \ Web]] | ||
- | The Map Suite Geocoder "How Do I?" solution offers a series of useful how-to examples for using the Map Suite Geocoder component. The bundled solution comes with a small set of sample data from Chicago, IL and demonstrates geocoding, reverse geocoding, batch geocoding, use of fuzzy matching logic, getting the closest street number to a point, and much more. Full source code is included in both C# and VB.NET languages; simply select your preferred language to download the associated solution.\\ \\ Please note that you will need an evaluation (or full version) of both [[Map Suite Geocoder]] and [[Map Suite Desktop Edition]] to build and run these samples. | ||
- | </div> | ||
