map_suite_geocoder_performance_guide [2019/03/20 10:17] tgwikiupdate |
map_suite_geocoder_performance_guide [2019/03/21 02:42] tgwikiupdate |
Line 3: | Line 3: | ||
The purpose of this guide is to help you to know following things: | The purpose of this guide is to help you to know following things: | ||
- | * A simple introduction for inner structure and workflow of Map Suite Geocoder. | + | * A simple introduction for best practice of Map Suite Geocoder. |
- | * What is the bottleneck of Map Suite Geocoder performance. | + | * Using multi-thread to improve the performance of batch query. |
- | * How to improve the performance of batch query. | + | * The bottleneck of Map Suite Geocoder performance. |
- | ===== Structure & Workflow ===== | + | ===== Best Practice ===== |
- | This section will introduce the structure and workflow of Map Suite Geocoder roughly. | + | This section will introduce the best practice of Map Suite Geocoder. |
==== Data Source ==== | ==== Data Source ==== | ||
- | The Geocoder uses a native data source with an optimized set of United States street based on the [[https://www.census.gov/geo/maps-data/data/tiger.html|TIGER® data]] from the [[https://www.census.gov|U.S. Census Bureau]]. Below Figure 1 shows a partial source data files. | + | The Geocoder uses a native source data with an optimized set of United States street based on the [[https://www.census.gov/geo/maps-data/data/tiger.html|TIGER® data]] from the [[https://www.census.gov|U.S. Census Bureau]]. Below Figure 1 shows a partial source data files. |
{{:map_suite_geocoder_performance_guide_001.png}} | {{:map_suite_geocoder_performance_guide_001.png}} | ||
Line 24: | Line 24: | ||
usaGeocoder.Close(); | usaGeocoder.Close(); | ||
</code> | </code> | ||
- | When opening a Geocoder, some source data you specified would be preprocessed and loaded into memory, most of them are index data that would be read frequently in match query. These data would be released from memory after close Geocoder. | + | When opening a Geocoder, some source data you specified would be preprocessed and loaded into memory, most of them are index data that would be read frequently in match query. These data would be released from memory after closing Geocoder. |
You may see the //**MatchMode**// and //**StreetNumberMatchingMode**// parameters when initializing the //**UsaGeocoder**//, they can be used to specify different match policies. It's important that the more strict policy, the less match query time, and vice versa. All code snippets in this guide use //**Default MatchMode**// with //**ExactMatch**// and //**Default StreetNumberMatchingMode**// with //**ExactMatch**//. | You may see the //**MatchMode**// and //**StreetNumberMatchingMode**// parameters when initializing the //**UsaGeocoder**//, they can be used to specify different match policies. It's important that the more strict policy, the less match query time, and vice versa. All code snippets in this guide use //**Default MatchMode**// with //**ExactMatch**// and //**Default StreetNumberMatchingMode**// with //**ExactMatch**//. | ||
Line 41: | Line 41: | ||
To test the ultimate performance of Geocoder, we use the 2nd call in this guide. | To test the ultimate performance of Geocoder, we use the 2nd call in this guide. | ||
- | ===== Bottleneck of Performance ===== | + | ===== Benchmark ===== |
- | In this section we will discuss what is the bottleneck of Map Suite Geocoder performance. | + | In this section we will help you to use multi-thread to improve the geocoding when doing huge queries, then show you the benchmark results that we did. |
- | ==== I/O ==== | + | |
- | The most time spent of Geocoder is on I/O. Due to the size of source data is about 9.06 GB, Geocoder cannot load all of them into memory when opening, if we do that, it will spend a lot of time to open Geocoder. We already had optimized and made the Geocoder to load necessary source data when opening, and added in memory cache to increase the data read speed, it still would read data from files when doing match query, the I/O is the one of a bottleneck of performance. | + | |
- | ==== Normalize Text ==== | + | |
- | The another bottleneck is input/output text normalization, customer wants to input various of texts to do the match query, Geocoder have to split and explain them at first, then compare the normalized text cluster with cache or file data to do the match. The matched results also need to be normalized as the Geocoder result. We always keep to update our normalization algorithm to make it more faster and accurate. | + | |
- | ==== Performance Test ==== | + | |
- | Below Figure 2 is the test result that did 1,000 queries, the execution time is 4.669 seconds: | + | |
- | {{:map_suite_geocoder_performance_guide_002.png}} | + | |
- | //Figure 2. Performance Test With 1,000 Queries.// | + | |
- | And the below Figure 3 is the test result that did 10,000 queries, the execution time is 16.588 seconds: | + | |
- | {{:map_suite_geocoder_performance_guide_003.png}} | + | |
- | //Figure 3. Performance Test With 10,000 Queries.// | + | |
- | It's obvious that the most time spent is on I/O (includes file or cache data read), then normalization. | + | |
- | ===== Performance Improvement ===== | + | |
- | In this section we will help you to improve the geocoding when doing huge queries. | + | |
==== Using Multi-thread ==== | ==== Using Multi-thread ==== | ||
With the limitation of cache and file data read, Geocoder doesn't support inner multi-thread to do the batch query. But it's bad if customer wants to do a huge query with more than 100,000 input texts, below code snippet will help you to improve the query performance: | With the limitation of cache and file data read, Geocoder doesn't support inner multi-thread to do the batch query. But it's bad if customer wants to do a huge query with more than 100,000 input texts, below code snippet will help you to improve the query performance: | ||
Line 132: | Line 112: | ||
Task.WaitAll(tasks.ToArray()); | Task.WaitAll(tasks.ToArray()); | ||
- | We preprocess the input texts to split them to 8 chunks, then generate 8 tasks to do the batch queries, each task maintains independent Geocoder to avoid multi-thread error. Below Figure 4 shows the elapsed time compare: | + | We preprocess the input texts to split them to eight chunks, then generate eight tasks to do the batch queries, each task maintains independent Geocoder to avoid multi-thread error. |
- | {{:map_suite_geocoder_performance_guide_004.png}} | + | |
+ | ==== Benchmark Reports ==== | ||
+ | To compare the performance between single thread and multi-thread, we used the following (Figure 2) machine hardware device to do the benchmark: | ||
+ | {{:map_suite_geocoder_performance_guide_001.png}} | ||
- | //Figure 4. Query Compare.// | + | //Figure 2. Machine Hardware Device Information.// |
- | It shows that we improved about three times speed after using multi-thread. | + | Below Figure 3 shows the benchmark result: |
- | ==== Hardware Performance ==== | + | |
- | We used the following machine hardware device to do the test in Figure 4. | + | |
- | * CPU: Intel® Core™ i7-4790 CPU @ 3.60GHz | + | |
- | * Memory: 8.00 GB | + | |
- | * Disk: Crucial CT500MX200SSD1 | + | |
- | * System: Windows 10 64-bit | + | |
- | And the hardware usage when querying is: | + | |
- | * CPU: 70% - 90% | + | |
- | * Memory: 300 MB + | + | |
- | * IO: 30 MB/Seconds | + | |
- | To dig the limitation of the Geocoder with multi-thread we also created different [[https://aws.amazon.com/ec2/instance-types|Amazon® instances]] to do the same test in Figure 4. Below Figure 5 is the test results: | + | {{:map_suite_geocoder_performance_guide_001.png}} |
+ | //Figure 3. Single Thread & Multi-Thread Benchmark Result.// | ||
- | {{:map_suite_geocoder_performance_guide_005.png}} | + | It shows that we improved about three times speed after using multi-thread. And the below Figure 4 shows the hardware usage when using multi-thread: |
- | //Figure 5. Performance Test Result on Amazon® Instance.// | + | //Figure 4. Hardware Usage Using Multi-Thread.// |
- | Note that we set the thread count to 8 because we always tend to make the thread count to match the CPU core count, if you start too much threads, the query speed would decrease instead. | + | To dig the limitation of the Geocoder with multi-thread we also created different [[https://aws.amazon.com/ec2/instance-types|Amazon® instances]] to do the same benchmark. Below Figure 5 is the test result: |
+ | //Figure 5. Amazon® Instance Benchmark Result.// | ||
+ | The match query speed increased significantly after using high performance hardware device. Note that we set the thread count to eight because we always tend to make the thread count to equal with or less than the CPU core count, if you start too much threads, the query speed would decrease instead. | ||
+ | ===== Bottleneck of Performance ===== | ||
+ | In this section we will discuss what is the bottleneck of Map Suite Geocoder performance. | ||
+ | ==== I/O ==== | ||
+ | The most time spent of Geocoder is on I/O. Due to the size of source data is about 9.06 GB, Geocoder cannot load all of them into memory when opening, if we do that, it will spend a lot of time to open Geocoder. We already had optimized and made the Geocoder to load necessary source data when opening, and added in memory cache to increase the data read speed, it still would read data from files when doing match query, the I/O is the one of a bottleneck of performance. | ||
+ | ==== Normalize Text ==== | ||
+ | The another bottleneck is input/output text normalization, customer wants to input various of texts to do the match query, Geocoder has to split and explain them at first, then compare the normalized text cluster with cache or file data to do the match. The matched results also need to be normalized as the Geocoder result. We always keep to update our normalization algorithm to make it more faster and accurate. | ||
+ | ==== Performance Test ==== | ||
+ | Below Figure 6 is the analysis result that did **1,000** queries one by one, the execution time is **4.669** seconds: | ||
+ | //Figure 6. Analysis Result With 1,000 Queries.// | ||
+ | And the below Figure 7 is the analysis result that did **10,000** queries one by one, the execution time is **16.588** seconds: | ||
+ | //Figure 7. Analysis Test With 10,000 Queries.// | ||
+ | It's obvious that the most time spent is on I/O (includes file or cache data read), then normalization. |
