map_suite_discussion_forum_guide
map_suite_discussion_forum_guide [2015/09/15 03:36]
admin [Flagging Your Topic as a Question]
map_suite_discussion_forum_guide [2015/09/15 03:37] (current)
admin [Adding Attachments]
Line 35: Line 35:
 To do this, first type your message as usual. When you're ready to paste in your source code, switch the message editor into "​Source"​ view by clicking the button shown below: To do this, first type your message as usual. When you're ready to paste in your source code, switch the message editor into "​Source"​ view by clicking the button shown below:
-{{wiki:​Map_Suite_Discussion_Forum_Guide_Source_Button.jpg}}+{{sourcekit:​Map_Suite_Discussion_Forum_Guide_Source_Button.jpg}}
 Then, add one of the following sets of tags, depending on the language of the source code you want to paste in: Then, add one of the following sets of tags, depending on the language of the source code you want to paste in:
Line 92: Line 92:
 To attach a file to a post you're writing, scroll down below the Submit button until you see the "​Attachments"​ panel, then click the arrow on the right side to expand it. Then you'll see these controls: To attach a file to a post you're writing, scroll down below the Submit button until you see the "​Attachments"​ panel, then click the arrow on the right side to expand it. Then you'll see these controls:
-{{wiki:​Map_Suite_Sending_Data_to_Support_Attachments_Panel.jpg}}+{{sourcekit:​Map_Suite_Sending_Data_to_Support_Attachments_Panel.jpg}}
 Simply select "​Browse,"​ find the file you want to attach, then press "​Upload."​ The file you attach will appear at the end of your post once it is submitted, with a link to download it. If you attach an image, you'll optionally be able to insert it into your message. Simply select "​Browse,"​ find the file you want to attach, then press "​Upload."​ The file you attach will appear at the end of your post once it is submitted, with a link to download it. If you attach an image, you'll optionally be able to insert it into your message.
map_suite_discussion_forum_guide.1442288205.txt.gz · Last modified: 2015/09/15 03:36 by admin
