map_suite_discussion_forum_guide
map_suite_discussion_forum_guide [2015/08/20 03:08]
map_suite_discussion_forum_guide [2015/09/15 03:37] (current)
admin [Adding Attachments]
-====== ​Map_Suite_Discussion_Forum_Guide ​======+====== ​Map Suite Discussion Forum Guide ======
-{{article rating}}
 The ThinkGeo Developer Community is your hub for support, ideas and tips for developing with Map Suite. The ThinkGeo Developer Community is your hub for support, ideas and tips for developing with Map Suite.
Line 7: Line 6:
 We have just a few simple rules that you must adhere to when posting, as well as some guidelines for making your contributions the most helpful for others. We have just a few simple rules that you must adhere to when posting, as well as some guidelines for making your contributions the most helpful for others.
-#Your first post in the discussion forums will be held for moderator approval. Once your message has been approved, you will be able to make future posts without moderation. +  -Your first post in the discussion forums will be held for moderator approval. Once your message has been approved, you will be able to make future posts without moderation.
-#If you need help with or want to discuss a particular Map Suite product, please post in the Support Forum for that product. Map Suite 2.0 and Map Suite 3.0 products have their own set of support forums. Make sure you're posting in the right one! +  -If you need help with or want to discuss a particular Map Suite product, please post in the Support Forum for that product. Map Suite 2.0 and Map Suite 3.0 products have their own set of support forums. Make sure you're posting in the right one!
-#If you want to ask a specific question, you can flag your topic to make it easier for others see that you need help. For information on how to flag your topic as a question, see the instructions below. +  -If you want to ask a specific question, you can flag your topic to make it easier for others see that you need help. For information on how to flag your topic as a question, see the instructions below.
-#If you're looking for documentation and other reference information on how to use Map Suite, please browse our online Support Center. +  -If you're looking for documentation and other reference information on how to use Map Suite, please browse our online Support Center.
-#Absolutely no flaming or personal attacks will be tolerated. +  -Absolutely no flaming or personal attacks will be tolerated.
-#Above all, enjoy sharing your ideas, learning from others, and working with Map Suite. We're glad you're with us!+  -Above all, enjoy sharing your ideas, learning from others, and working with Map Suite. We're glad you're with us!
 ==== Flagging Your Topic as a Question ==== ==== Flagging Your Topic as a Question ====
Line 19: Line 18:
 To mark your topic as a question, select "Not Resolved"​ from the Topic Status drop-down: To mark your topic as a question, select "Not Resolved"​ from the Topic Status drop-down:
-{{wiki:​Map_Suite_Sending_Data_to_Support_Not_Resolved.jpg}}+{{sourcekit:​Map_Suite_Sending_Data_to_Support_Not_Resolved.jpg}}
Line 26: Line 25:
 When you receive a response that answers your question, you can mark that response as the correct answer by clicking the "​Correct Answer"​ button above that post: When you receive a response that answers your question, you can mark that response as the correct answer by clicking the "​Correct Answer"​ button above that post:
-{{wiki:​Map_Suite_Sending_Data_to_Support_Correct_Answer.jpg}}+{{sourcekit:​Map_Suite_Sending_Data_to_Support_Correct_Answer.jpg}}
Line 36: Line 35:
 To do this, first type your message as usual. When you're ready to paste in your source code, switch the message editor into "​Source"​ view by clicking the button shown below: To do this, first type your message as usual. When you're ready to paste in your source code, switch the message editor into "​Source"​ view by clicking the button shown below:
-{{wiki:​Map_Suite_Discussion_Forum_Guide_Source_Button.jpg}}+{{sourcekit:​Map_Suite_Discussion_Forum_Guide_Source_Button.jpg}}
 Then, add one of the following sets of tags, depending on the language of the source code you want to paste in: Then, add one of the following sets of tags, depending on the language of the source code you want to paste in:
 If you're posting C# code, use: If you're posting C# code, use:
-<source lang="​xml">​
-<code lang="​csharp">​
-</code> +  ​<​code ​ ​lang="​csharp"​
-</source>+
 +  ​</code>
 If you're posting VB code, use: If you're posting VB code, use:
-<source lang="​xml">​ +  ​<code lang="​vb">​
-<code lang="​vb">​ +
- +  </​code>​
-</code+
-</source>+
 If you're posting HTML, use: If you're posting HTML, use:
-<source lang="​xml">​ +  ​<code lang="​html">​
-<code lang="​html">​ +
- +  </​code>​
-</code+
-</source>+
 If you're posting JavaScript, use: If you're posting JavaScript, use:
-<source lang="​xml">​ +  ​<code lang="​script">​
-<code lang="​script">​ +
- +  </​code>​
-</code+
-</source>+
 Once you add one of these sets of code tags, paste your source code in between them. Once you add one of these sets of code tags, paste your source code in between them.
Line 79: Line 72:
 Here is an example of what your formatted source code snippet will look like: Here is an example of what your formatted source code snippet will look like:
-<source lang="csharp">+<code csharp>
 protected void Button1_Click(object sender, EventArgs e) protected void Button1_Click(object sender, EventArgs e)
Line 92: Line 85:
-</source>+</code>
 ===== Adding Attachments ===== ===== Adding Attachments =====
Line 99: Line 92:
 To attach a file to a post you're writing, scroll down below the Submit button until you see the "​Attachments"​ panel, then click the arrow on the right side to expand it. Then you'll see these controls: To attach a file to a post you're writing, scroll down below the Submit button until you see the "​Attachments"​ panel, then click the arrow on the right side to expand it. Then you'll see these controls:
-{{wiki:​Map_Suite_Sending_Data_to_Support_Attachments_Panel.jpg}}+{{sourcekit:​Map_Suite_Sending_Data_to_Support_Attachments_Panel.jpg}}
 Simply select "​Browse,"​ find the file you want to attach, then press "​Upload."​ The file you attach will appear at the end of your post once it is submitted, with a link to download it. If you attach an image, you'll optionally be able to insert it into your message. Simply select "​Browse,"​ find the file you want to attach, then press "​Upload."​ The file you attach will appear at the end of your post once it is submitted, with a link to download it. If you attach an image, you'll optionally be able to insert it into your message.
Line 117: Line 110:
 | .xml   ​| ​   |    |    | | .xml   ​| ​   |    |    |
-[[Category:​Map Suite Services Edition]] [[Category:​Map Suite Desktop Edition]] [[Category:​Map Suite WPF Desktop Edition]] [[Category:​Map Suite Web Edition]] [[Category:​Map Suite Silverlight Edition]] [[Category:​Map Suite WMS Server Edition]] [[Category:​Map Suite Geocoder]] [[Category:​Map Suite Routing]] [[Category:​Web GIS]] [[Category:​Desktop GIS]] [[Category:​GIS]] [[Category:​.NET]]
map_suite_discussion_forum_guide.1440040123.txt.gz · Last modified: 2015/08/31 08:06 (external edit)
