map_suite_desktop_for_wpf_release_change_log [2017/06/23 03:41] marklee |
map_suite_desktop_for_wpf_release_change_log [2019/04/03 08:09] (current) tgwikiupdate |
====== Map Suite Desktop For Wpf Release Change Log ====== | ====== Map Suite Desktop For Wpf Release Change Log ====== | ||
- | [[Map Suite WPF Desktop Edition Release Change Log All Versions|All Versions]] | + | [[Map Suite Desktop for Wpf Release Change Log Version 10.5.0|Version 10.5.0]] |
+ | [[Map Suite Desktop for Wpf Release Change Log Version 10.4.0|Version 10.4.0]] | ||
+ | [[Map Suite Desktop for Wpf Release Change Log Version 10.3.0|Version 10.3.0]] | ||
+ | [[Map Suite Desktop for Wpf Release Change Log Version 10.2.0|Version 10.2.0]] | ||
[[Map Suite Desktop for Wpf Release Change Log Version 10.1.0|Version 10.1.0]] | [[Map Suite Desktop for Wpf Release Change Log Version 10.1.0|Version 10.1.0]] | ||
Line 7: | Line 13: | ||
[[Map Suite Desktop for Wpf Release Change Log Version 10.0.0|Version 10.0.0]] | [[Map Suite Desktop for Wpf Release Change Log Version 10.0.0|Version 10.0.0]] | ||
+ | [[Map Suite WPF Desktop Edition Release Change Log All Versions|All Versions]] | ||
** The following was created before Map Suite 10. Map Suite 10 organized many classes into new namespaces and assemblies as well as had a few minor breaks in compatibility. The majority of previously built code should work without modification assuming the new namespaces are added. For guidance on upgrading your existing code check out this wiki article. http://wiki.thinkgeo.com/wiki/map_suite_10_update_guide | ** The following was created before Map Suite 10. Map Suite 10 organized many classes into new namespaces and assemblies as well as had a few minor breaks in compatibility. The majority of previously built code should work without modification assuming the new namespaces are added. For guidance on upgrading your existing code check out this wiki article. http://wiki.thinkgeo.com/wiki/map_suite_10_update_guide |
