map_suite_desktop_for_wpf_features_bug_fixes_change_log [2017/06/23 03:54] benbai |
map_suite_desktop_for_wpf_features_bug_fixes_change_log [2019/12/05 08:07] (current) tgwikiupdate [Version 10.6.0] |
====== Map Suite Desktop For Wpf Features & Bug Fixes Change Log ====== | ====== Map Suite Desktop For Wpf Features & Bug Fixes Change Log ====== | ||
+ | =====Version 10.6.0===== | ||
+ | ThinkGeo.MapSuite.Wpf Namespace: | ||
+ | * Enhanced to support high resolution screen for Google layer. | ||
+ | * Fixed a bug that ThinkGeoCloudRasterMapsOverlay can't support zoomlevels which are higher default max zoomlevel. | ||
+ | * Fixed a pinch zoom issue. When zoom in map, the target scale is smaller than expected. | ||
+ | * Changed DrawingExceptionMode of ThinkGeoCloudVectorMapsOverlay to DrawException. | ||
+ | * Fixed a pinch zoom issue when panning with 2 fingers map moves in the opposite direction. | ||
+ | * Improved the memory usage and performance WpfMap. | ||
+ | * Fixed a serialize issue. When GisEditor save project, it will throw "System.Windows.Controls.Canvas is not marked as serializable" exception. | ||
+ | * Fixed a performance issue that caused by frequent calling GC. | ||
+ | * Removed TileOverlay.SetTileMatrix method. | ||
+ | * Removed "GetZoomLevelSet" method from ThinkGeoCloudRasterMapsOverlay and ThinkGeoCloudVectorMapsOverlay. | ||
+ | * Added support of new class ThinkGeoCloudVectorMapsOverlay to consume Vector Tiles from ThinkGeo Cloud | ||
+ | * Enhanced to support sending web request event and sent web request event for ThinkGeoCloudMapsOverlay | ||
+ | * Fixed a bug that memory leak in AdornmentOverlay in certain scenario | ||
+ | * Fixed a bug that map met exception when tile cache is set to null for ThinkGeoCloudMapsOverlay | ||
+ | * Fixed a bug that overlay reorder after refresh in certain scenario | ||
+ | * Enhanced to support WrapDateLine for ThinkGeoCloudMapsOverlay | ||
+ | * Fixed a bug the BackgroundOverlay doesn't works correct | ||
+ | * Fixed a bug the map flicker when zoom out in certain scenario | ||
+ | * Fixed a bug the ThinkGeoCloudMapsOverlay throw exception after applying ClientId/ClientSecret | ||
+ | * Fixed a bug the ThinkGeoCloudMapsOverlay generate incorrect route in certain scenario | ||
+ | * Fixed a bug the ThinkGeoCloudMapsOverlay render two types tiles at the same after switch MapType to transparent background | ||
+ | * Fixed a bug the ClassBreaks in ClassBreakMarkerStyle doesn't works correct | ||
+ | *Improved GoogleMapsOverlay performance when using single tile mode | ||
+ | *Fixed a bug that WMS Client cannot deal with exception when WMS Server unavailable | ||
+ | *Supported 3D rendering for buildings(Overlay level) | ||
+ | *Fixed a bug where marker will be fuzzy in certain scenarios | ||
+ | *Fixed a bug where Wpf application throw null exception and stop work after few minutes in certain scenarios | ||
+ | {{page>Map_Suite_Core_10.2_Features_Bug_Fixes_Change_Log}} | ||
=====Version 10.1.0===== | =====Version 10.1.0===== |
