map_suite_desktop_for_wpf_features_bug_fixes_change_log [2017/10/27 09:19] tgwikiupdate |
map_suite_desktop_for_wpf_features_bug_fixes_change_log [2019/12/05 07:53] tgwikiupdate |
====== Map Suite Desktop For Wpf Features & Bug Fixes Change Log ====== | ====== Map Suite Desktop For Wpf Features & Bug Fixes Change Log ====== | ||
+ | =====Version 10.6.0===== | ||
+ | ThinkGeo.MapSuite.Wpf Namespace: | ||
+ | * Added support of new class ThinkGeoCloudVectorMapsOverlay to consume Vector Tiles from ThinkGeo Cloud | ||
+ | * Enhanced to support sending web request event and sent web request event for ThinkGeoCloudMapsOverlay | ||
+ | * Fixed a bug that memory leak in AdornmentOverlay in certain scenario | ||
+ | * Fixed a bug that map met exception when tile cache is set to null for ThinkGeoCloudMapsOverlay | ||
+ | * Fixed a bug that overlay reorder after refresh in certain scenario | ||
+ | * Enhanced to support WrapDateLine for ThinkGeoCloudMapsOverlay | ||
+ | * Fixed a bug the BackgroundOverlay doesn't works correct | ||
+ | * Fixed a bug the map flicker when zoom out in certain scenario | ||
+ | * Fixed a bug the ThinkGeoCloudMapsOverlay throw exception after applying ClientId/ClientSecret | ||
+ | * Fixed a bug the ThinkGeoCloudMapsOverlay generate incorrect route in certain scenario | ||
+ | * Fixed a bug the ThinkGeoCloudMapsOverlay render two types tiles at the same after switch MapType to transparent background | ||
+ | * Fixed a bug the ClassBreaks in ClassBreakMarkerStyle doesn't works correct | ||
+ | *Improved GoogleMapsOverlay performance when using single tile mode | ||
+ | *Fixed a bug that WMS Client cannot deal with exception when WMS Server unavailable | ||
=====Version 10.2.0===== | =====Version 10.2.0===== | ||
Line 5: | Line 58: | ||
ThinkGeo.MapSuite.Wpf Namespace: | ThinkGeo.MapSuite.Wpf Namespace: | ||
- | *Fixed a bug the drawing position of Marker is not precious enough | + | |
- | *Fixed a bug the application stops working after few minutes with null exception | + | *Supported 3D rendering for buildings(Overlay level) |
- | *Added Building feature support for OSM 3D Building | + | *Fixed a bug where marker will be fuzzy in certain scenarios |
+ | *Fixed a bug where Wpf application throw null exception and stop work after few minutes in certain scenarios | ||
{{page>Map_Suite_Core_10.2_Features_Bug_Fixes_Change_Log}} | {{page>Map_Suite_Core_10.2_Features_Bug_Fixes_Change_Log}} |
