map_suite_desktop_for_winforms_quick_start_guide [2017/03/15 03:27] tgwikiupdate |
map_suite_desktop_for_winforms_quick_start_guide [2017/03/15 05:16] tgwikiupdate |
Line 23: | Line 23: | ||
Let's start by creating a new Windows Forms Application in Microsoft Visual Studio (2015 or newer) named QuickstartSample(see Figure 1). We can create the project with .NET Framework 4.5 or higher. | Let's start by creating a new Windows Forms Application in Microsoft Visual Studio (2015 or newer) named QuickstartSample(see Figure 1). We can create the project with .NET Framework 4.5 or higher. | ||
- | {{mapsuite10:WinForms:Map_Suite_WinForms_QSG_NewProject.png}} | + | {{mapsuite10:desktop:Map_Suite_WinForms_QSG_NewProject.png}} |
//Figure 1. Creating a new project in Microsoft Visual Studio.// | //Figure 1. Creating a new project in Microsoft Visual Studio.// | ||
Line 32: | Line 32: | ||
After you created a QuickstartSample project, we will see a project in the solution, please see Figure 2. | After you created a QuickstartSample project, we will see a project in the solution, please see Figure 2. | ||
- | {{mapsuite10:WinForms:Map_Suite_WinForms_QSG_QuickstartProject.png}} | + | {{mapsuite10:desktop:Map_Suite_WinForms_QSG_QuickstartProject.png}} |
Line 44: | Line 44: | ||
Right-click the Reference in Solution Explorer and select “Manage NuGet Packages” (See Figure 3). | Right-click the Reference in Solution Explorer and select “Manage NuGet Packages” (See Figure 3). | ||
- | {{mapsuite10:WinForms:Map_Suite_WinForms_QSG_NuGetManager.png}} | + | {{mapsuite10:desktop:Map_Suite_WinForms_QSG_NuGetManager.png}} |
//Figure 3. Refer to Manage NuGet Packages.// | //Figure 3. Refer to Manage NuGet Packages.// | ||
Line 54: | Line 54: | ||
In that package list, please select “MapSuiteDesktopForWinForms-Standard” package and click the “Install” button in the right panel. | In that package list, please select “MapSuiteDesktopForWinForms-Standard” package and click the “Install” button in the right panel. | ||
- | {{mapsuite10:WinForms:Map_Suite_WinForms_QSG_InstallWinFormsPackage.png}} | + | {{mapsuite10:desktop:Map_Suite_WinForms_QSG_InstallWinFormsPackage.png}} |
//Figure 4. Refer to MapSuiteDesktopForWinForms-Standard.// | //Figure 4. Refer to MapSuiteDesktopForWinForms-Standard.// | ||
Line 60: | Line 60: | ||
Click “OK” if the message box like Figure 5 pops up. | Click “OK” if the message box like Figure 5 pops up. | ||
- | {{mapsuite10:WinForms:Map_Suite_WinForms_QSG_ReferenceRreview.png}} | + | {{mapsuite10:desktop:Map_Suite_WinForms_QSG_ReferenceRreview.png}} |
//Figure 5. Review package references.// | //Figure 5. Review package references.// | ||
Line 68: | Line 68: | ||
The "NetTopologySuite" is the third part assembly, so the license acceptance is required. You can click "I Accept" to agree the license.(See Figure 6) | The "NetTopologySuite" is the third part assembly, so the license acceptance is required. You can click "I Accept" to agree the license.(See Figure 6) | ||
- | {{mapsuite10:WinForms:Map_Suite_WinForms_QSG_PackageLicenseAcceptance.png}} | + | {{mapsuite10:desktop:Map_Suite_WinForms_QSG_PackageLicenseAcceptance.png}} |
//Figure 6. NuGet installation success.// | //Figure 6. NuGet installation success.// | ||
Line 78: | Line 78: | ||
Some Desktop assemblies have been added into the project references. (See Figure 7). | Some Desktop assemblies have been added into the project references. (See Figure 7). | ||
- | {{mapsuite10:WinForms:Map_Suite_WinForms_QSG_ProjectReferences.png}} | + | {{mapsuite10:desktop:Map_Suite_WinForms_QSG_ProjectReferences.png}} |
//Figure 7. NuGet installation result.// | //Figure 7. NuGet installation result.// | ||
Line 85: | Line 85: | ||
===== Adding the Map Control to Your Form ===== | ===== Adding the Map Control to Your Form ===== | ||
- | Open ".../QuickstartSample/packages/MapSuiteDesktopForWinForms-Standard.10.0.0/designtime" package folder and draw "ThinkGeo.MapSuite.WinForms.dll" assembly to the Toolbox of Visual Studio. | + | Open ".../QuickstartSample/packages/MapSuiteDesktopForWinForms-Standard.10.0.0/designtime" package folder and drag "ThinkGeo.MapSuite.WinForms.dll" assembly to the Toolbox of Visual Studio. |
- | {{mapsuite10:WinForms:Map_Suite_WinForms_QSG_ControlDesigntime.png}} | + | {{mapsuite10:desktop:Map_Suite_WinForms_QSG_ControlDesigntime.png}} |
Line 94: | Line 94: | ||
Map control as winformsMap1. Our map will display in this object. | Map control as winformsMap1. Our map will display in this object. | ||
- | {{mapsuite10:WinForms:Map_Suite_WinForms_QSG_AddMapControl.png}} | + | {{mapsuite10:desktop:Map_Suite_WinForms_QSG_AddMapControl.png}} |
===== Map Suite Desktop "QuickstartSample" ===== | ===== Map Suite Desktop "QuickstartSample" ===== | ||
Line 157: | Line 157: | ||
Once the developer license is ready, run the application. Your map should look like the one below: (see Figure 12). | Once the developer license is ready, run the application. Your map should look like the one below: (see Figure 12). | ||
- | {{mapsuite10:WinForms:Map_Suite_WinForms_QSG_ShowAreaStyle.png}} | + | {{mapsuite10:desktop:Map_Suite_WinForms_QSG_ShowAreaStyle.png}} |
//Figure 12. A sample map of Europe.// | //Figure 12. A sample map of Europe.// | ||
Line 214: | Line 214: | ||
And the result is as follows (Figure 13): | And the result is as follows (Figure 13): | ||
- | {{mapsuite10:WinForms:Map_Suite_WinForms_QSG_ShowPointStyle.png}} | + | {{mapsuite10:desktop:Map_Suite_WinForms_QSG_ShowPointStyle.png}} |
//Figure 13. Map of Europe with 2 layers.// | //Figure 13. Map of Europe with 2 layers.// | ||
Line 224: | Line 224: | ||
A TextStyle is used to label items on map. As every ShapeFile has a relative .dbf file that includes descriptions for every record, the most common way to use TextStyles is for labeling. For example, WorldCapital Shapefile's corresponding .dbf file contains the field "CITY_NAME". We can use this field to label the cities on our map. | A TextStyle is used to label items on map. As every ShapeFile has a relative .dbf file that includes descriptions for every record, the most common way to use TextStyles is for labeling. For example, WorldCapital Shapefile's corresponding .dbf file contains the field "CITY_NAME". We can use this field to label the cities on our map. | ||
- | {{mapsuite10:WinForms:Map_Suite_WinForms_QSG_DBFDetails.png}} | + | {{mapsuite10:desktop:Map_Suite_WinForms_QSG_DBFDetails.png}} |
Map Suite has many TextStyles built in to help us quickly design attractive labels for the cities on our map. We can just pick the TextStyle we like and use it. | Map Suite has many TextStyles built in to help us quickly design attractive labels for the cities on our map. We can just pick the TextStyle we like and use it. | ||
Line 287: | Line 287: | ||
The result is as follows (Figure 14): | The result is as follows (Figure 14): | ||
- | {{mapsuite10:WinForms:Map_Suite_WinForms_QSG_ShowTextStyle.png}} | + | {{mapsuite10:desktop:Map_Suite_WinForms_QSG_ShowTextStyle.png}} |
//Figure 14. Map of Europe with a TextStyle.// | //Figure 14. Map of Europe with a TextStyle.// | ||
Line 360: | Line 360: | ||
Can you imagine what the map will look like now? Below is the result. At first it appears like figure 15, and the map changes to figure 8 as you zoom in. | Can you imagine what the map will look like now? Below is the result. At first it appears like figure 15, and the map changes to figure 8 as you zoom in. | ||
- | {{mapsuite10:WinForms:Map_Suite_WinForms_QSG_ShowLowZoomLevel.png}} | + | {{mapsuite10:desktop:Map_Suite_WinForms_QSG_ShowLowZoomLevel.png}} |
//Figure 15. A map of Europe with two ZoomLevels, before zooming in.// | //Figure 15. A map of Europe with two ZoomLevels, before zooming in.// | ||
- | {{mapsuite10:WinForms:Map_Suite_WinForms_QSG_ShowHeightZoomLevel.png}} | + | {{mapsuite10:desktop:Map_Suite_WinForms_QSG_ShowHeightZoomLevel.png}} |
//Figure 16. The same map with two ZoomLevels, after zooming in.// | //Figure 16. The same map with two ZoomLevels, after zooming in.// |
