map_suite_desktop_edition_release_change_log_version_9.0.0.0 [2015/08/20 03:08] 127.0.0.1 external edit |
map_suite_desktop_edition_release_change_log_version_9.0.0.0 [2015/09/08 08:19] admin |
- | ====== Map_Suite_Desktop_Edition_Release_Change_Log_Version_9.0.0.0 ====== | + | ====== Map Suite Desktop Edition Release Change Log Version 9.0.0.0 ====== |
+ | <html> | ||
<div class=WordSection1> | <div class=WordSection1> | ||
Line 22: | Line 23: | ||
normal;mso-pagination:none;mso-layout-grid-align:none;text-autospace:none'><span | normal;mso-pagination:none;mso-layout-grid-align:none;text-autospace:none'><span | ||
style='font-size:9.0pt;font-family:Consolas'><span style='mso-spacerun:yes'> | style='font-size:9.0pt;font-family:Consolas'><span style='mso-spacerun:yes'> | ||
- | </span>[[<span|style='color:olive'>SerializableAttribute</span>]]</span></p> | + | </span>[<span|style='color:olive'>SerializableAttribute</span>]</span></p> |
<p class=MsoNormal style='margin-bottom:0in;margin-bottom:.0001pt;line-height: | <p class=MsoNormal style='margin-bottom:0in;margin-bottom:.0001pt;line-height: | ||
Line 33: | Line 34: | ||
style='font-size:9.0pt;font-family:Consolas'><span | style='font-size:9.0pt;font-family:Consolas'><span | ||
- | style='mso-spacerun:yes'> </span>[[<span|style='color:red'>ObsoleteAttribute</span>(<span | + | style='mso-spacerun:yes'> </span>[<span|style='color:red'>ObsoleteAttribute</span>(<span |
style='color:red'>"This property is obsoleted, please use the property | style='color:red'>"This property is obsoleted, please use the property | ||
RequestedTileCacheDirectory instead. This property is obsolete and may be | RequestedTileCacheDirectory instead. This property is obsolete and may be | ||
- | removed in or after version 8.0."</span>)]]</span></p> | + | removed in or after version 8.0."</span>)]</span></p> |
Line 48: | Line 49: | ||
TileCache.ImageFormat instead. This property is obsolete and may be removed in | TileCache.ImageFormat instead. This property is obsolete and may be removed in | ||
- | or after version 8.0."</span>)]]</span></p> | + | or after version 8.0."</span>)]</span></p> |
Line 72: | Line 73: | ||
Line 84: | Line 85: | ||
- | style='mso-spacerun:yes'> </span>[[<span|style='color:green'>ObsoleteAttribute</span>(<span | + | style='mso-spacerun:yes'> </span>[<span|style='color:green'>ObsoleteAttribute</span>(<span |
style='color:green'>"This method is obsoleted and will be removed in the | style='color:green'>"This method is obsoleted and will be removed in the | ||
- | near future. Please call TileCache.ClearCache() instead."</span>)]]</span></p> | + | near future. Please call TileCache.ClearCache() instead."</span>)]</span></p> |
Line 97: | Line 98: | ||
near future. Please call | near future. Please call | ||
((FileBitmapTileCache)TileCache).ClearCache(expiration, maxSizeInMegabytes) | ((FileBitmapTileCache)TileCache).ClearCache(expiration, maxSizeInMegabytes) | ||
- | instead."</span>)]]</span></p> | + | instead."</span>)]</span></p> |
Line 118: | Line 119: | ||
TileCache instead. This property is obsolete and may be removed in or after | TileCache instead. This property is obsolete and may be removed in or after | ||
- | version 9.0."</span>)]]</span></p> | + | version 9.0."</span>)]</span></p> |
Line 133: | Line 134: | ||
Line 157: | Line 158: | ||
Line 168: | Line 169: | ||
Line 192: | Line 193: | ||
Line 328: | Line 329: | ||
- | </span>[[<span|style='color:green'>SerializableAttribute</span>]]</span></p> | + | </span>[<span|style='color:green'>SerializableAttribute</span>]</span></p> |
Line 439: | Line 440: | ||
Line 557: | Line 558: | ||
Line 568: | Line 569: | ||
style='color:red'>"This item is obsoleted, please use CapabilitiesCacheTimeout | style='color:red'>"This item is obsoleted, please use CapabilitiesCacheTimeout | ||
- | instead. This API is obsolete and may be removed in or after Version 9.0."</span>)]]</span></p> | + | instead. This API is obsolete and may be removed in or after Version 9.0."</span>)]</span></p> |
Line 591: | Line 592: | ||
Line 619: | Line 620: | ||
Line 647: | Line 648: | ||
+ | </html> | ||
- | + | {{page>Map_Suite_Services_Edition_Release_Change_Log_Version_9.0.0.0}} | |
- | {{:Map_Suite_Services_Edition_Release_Change_Log_Version_9.0.0.0}} | + | |
