map_suite_desktop_edition_faq_projection [2015/08/20 03:08] 127.0.0.1 external edit |
map_suite_desktop_edition_faq_projection [2015/09/08 08:55] admin |
- | ====== Map_Suite_Desktop_Edition_FAQ_Projection ====== | + | ====== Map Suite Desktop Edition FAQ Projection ====== |
- | <noinclude> | ||
- | {{article rating}} | ||
- | </noinclude> | ||
====How do I display world coordinate on a map?==== | ====How do I display world coordinate on a map?==== | ||
This question has a corresponding sample application(s) associated with it. | This question has a corresponding sample application(s) associated with it. | ||
Line 164: | Line 161: | ||
This sample uses the example of BNG to demonstrate the problem and how to fix it. The Map Suite development team will offer a permanent solution to this projection issue but in the meantime, as a rule of thumb, if your data shows some inaccuracies when going to Spherical Mercator, use the method you find this sample. This is a Desktop app but the concept shown applies to all editions of Map Suite. | This sample uses the example of BNG to demonstrate the problem and how to fix it. The Map Suite development team will offer a permanent solution to this projection issue but in the meantime, as a rule of thumb, if your data shows some inaccuracies when going to Spherical Mercator, use the method you find this sample. This is a Desktop app but the concept shown applies to all editions of Map Suite. | ||
- | [[Category:Map Suite Desktop Edition]] [[Category:Desktop GIS]] [[Category:Winforms]] [[Category:GIS]] [[Category:.NET]] | + | |
