map_suite_desktop_edition_faq_layers_featuresources
map_suite_desktop_edition_faq_layers_featuresources [2015/09/09 06:05]
map_suite_desktop_edition_faq_layers_featuresources [2015/09/15 06:28] (current)
admin [Can I create isolines (a.k.a. contour lines) with Map Suite?]
Line 216: Line 216:
 [[Map_Suite_Desktop_Edition_Layers_FeatureSources_Samples#​Isolines|Sample:​Isolines]] [[Map_Suite_Desktop_Edition_Layers_FeatureSources_Samples#​Isolines|Sample:​Isolines]]
-Yes. Starting with build 5.0.87.0 of Map Suite, you can add isolines to your applications with Map Suite -- please see the code sample linked above. For the uninitiated,​ isolines are a way to visualize breaks between different groups of data such as elevation levels, soil properties, or just about anything else you can imagine. ​ The above code sample also shows the various steps in creating isolines, including the gathering of point data, creating a grid using interpolation,​ and finally, picking your isoline break levels. ​ We also quickly dive into some more advanced options such as generating isolines on the fly. To bring this all together, check out our [[Media:​ServicesEditionSample_Isolines_110809.wmv|instructional video]] that will walk you through the process of setting up and working with isolines in Map Suite.+Yes. Starting with build 5.0.87.0 of Map Suite, you can add isolines to your applications with Map Suite -- please see the code sample linked above. For the uninitiated,​ isolines are a way to visualize breaks between different groups of data such as elevation levels, soil properties, or just about anything else you can imagine. ​ The above code sample also shows the various steps in creating isolines, including the gathering of point data, creating a grid using interpolation,​ and finally, picking your isoline break levels. ​ We also quickly dive into some more advanced options such as generating isolines on the fly. To bring this all together, check out our [[http://​wiki.thinkgeo.com//​mediawiki/​images/​8/​8c/​ServicesEditionSample_Isolines_110809.wmv|instructional video]] that will walk you through the process of setting up and working with isolines in Map Suite.
map_suite_desktop_edition_faq_layers_featuresources.1441778725.txt.gz ยท Last modified: 2015/09/09 06:05 by admin
