map_suite_desktop_edition [2015/09/14 03:52] admin [Change Logs] |
map_suite_desktop_edition [2017/03/15 03:40] tgwikiupdate |
====== Map Suite Desktop Edition ====== | ====== Map Suite Desktop Edition ====== | ||
Map Suite Desktop Edition is a .NET native set of GIS software controls that lets .NET developers add rich, interactive maps to their Windows desktop applications. Featuring both WPF & Winforms controls, packed with powerful mapping features and support for the most popular data formats, Map Suite Desktop Edition makes GIS accessible to developers of any skill. | Map Suite Desktop Edition is a .NET native set of GIS software controls that lets .NET developers add rich, interactive maps to their Windows desktop applications. Featuring both WPF & Winforms controls, packed with powerful mapping features and support for the most popular data formats, Map Suite Desktop Edition makes GIS accessible to developers of any skill. | ||
+ | <div mockline></div> | ||
Line 11: | Line 13: | ||
- | <div shortcuts> | ||
- | **[[:map_suit_desktop_edition_videos_screenshots|Videos & Screenshots]]** | ||
- | </div> | ||
Line 21: | Line 20: | ||
> [[Map Suite Desktop Edition Quick Start Guide|Quick Start Guide]] | > [[Map Suite Desktop Edition Quick Start Guide|Quick Start Guide]] | ||
- | This guide helps you get you up to speed with integrating the Map Suite Desktop Edition map control into your GIS software. | + | Helps you get you up to speed with integrating the Map Suite Desktop Edition map control into your GIS software. |
> [[Map Suite Style Guide|Style Guide]] | > [[Map Suite Style Guide|Style Guide]] | ||
- | This guide explains how to use styles in Map Suite to beautifully represent your GIS mapping data. The guide includes an overview of styles, a detailed explanation of the various styles that ship with Map Suite, as well as a step by step guide of creating your own custom styles. | + | Explains how to use styles to beautifully represent your GIS mapping data. It includes an overview of styles, a detailed explanation of the various styles that ship with Map Suite, as well as a step by step guide of creating your own custom styles. |
> [[Map Suite Serialization Guide|Serialization Guide]] | > [[Map Suite Serialization Guide|Serialization Guide]] | ||
- | This guide explains how to use our custom serialization class to render your Map Suite objects to XML, or other format etc. This allows your GIS application to easily save things such as Layers, Styles, or even whole maps to XML to be recalled at a later time. The guide includes an overview of serialization system, and detailed explanation of the various classes, as well as information on creating your own serializer. | + | Explains how to use our custom serialization class to render your Map Suite objects to XML, or other format etc. This allows your GIS application to easily save things such as Layers, Styles, or even whole maps to XML to be recalled at a later time. |
> [[Map Suite Desktop Edition Installation Guide|Installation Guide]] | > [[Map Suite Desktop Edition Installation Guide|Installation Guide]] | ||
- | This guide walks you through installing the map control on your system and creating a simple GIS application. | + | Walks you through installing the map control on your system and creating a simple GIS application. |
> [[Map Suite Desktop Edition Deployment Guide|Deployment Guide]] | > [[Map Suite Desktop Edition Deployment Guide|Deployment Guide]] | ||
- | This guide walks you through deploying your GIS software using the map control into a production environment. | + | Walks you through deploying your GIS software using the map control into a production environment. |
> [[Map Suite Desktop Edition Dependencies Guide|Dependencies Guide]] | > [[Map Suite Desktop Edition Dependencies Guide|Dependencies Guide]] | ||
- | This guide introduces the dependencies Map Suite Desktop Edition needs with their features, versions and source websites. | + | Introduces the dependencies Map Suite Desktop Edition needs with their features, versions and source websites. |
> [[Map Suite Data Format Guide|Data Format Guide]] | > [[Map Suite Data Format Guide|Data Format Guide]] | ||
- | This guide walks the various GIS data format that are supported in the map control. It also list any caveats related to the use of that format in your mapping application. | + | Walks the various GIS data format that are supported in the map control. It also list any caveats related to the use of that format in your mapping application. |
> [[Map Suite Performance Guide|Performance Guide]] | > [[Map Suite Performance Guide|Performance Guide]] | ||
- | This guide walks you through various ways you can increase performance in your .Net GIS application. | + | Walks you through various ways you can increase performance in your .Net GIS application. |
> [[Map Suite SQLite|SQLite Guide]] | > [[Map Suite SQLite|SQLite Guide]] | ||
- | This guide walks you through using SQLite as a storage format. | + | Walks you through using SQLite as a storage format. |
Line 156: | Line 155: | ||
We have provided hundreds of .Net code samples in C# & VB.NET to help you get going quickly. We have categorized them to allow you to quickly find what you are looking for. Each code sample includes an overview, complete code online to review and the ability to download the sample to run it yourself. | We have provided hundreds of .Net code samples in C# & VB.NET to help you get going quickly. We have categorized them to allow you to quickly find what you are looking for. Each code sample includes an overview, complete code online to review and the ability to download the sample to run it yourself. | ||
- | We have provided hundreds of .Net code samples in C# & VB.NET to help you get going quickly. We have categorized them to allow you to quickly find what you are looking for. Each code sample includes an overview, complete code online to review and the ability to download the sample to run it yourself. | ||
+ | ===== Videos ===== | ||
+ | > **Desktop Edition Sample App Walkthrough Video Series** | ||
+ | Step through the Desktop Edition sample applications and see how they're put together. We'll demonstrate how to use each app, then take you through every part of the source code and show you how it works.\\ | ||
+ | **Tip**: //You'll want to select "Fullscreen" to properly read the source code.// | ||
+ | <div play medialist> | ||
+ | [[desktopedition:Introduction to the Desktop Edition|{{desktopedition:screenshot:Introduction_to_the_Desktop_Edition.png?180x99|Introduction to the Desktop Edition}}]] | ||
+ | Introduction to the Desktop Edition | ||
+ | <div newline/> | ||
+ | > **Extending Map Suite Video Series** | ||
+ | {{page>map_suit_extending_map_suite_video_series}} | ||
+ | ===== Screenshots ===== | ||
+ | The Desktop Edition screenshots gallery section showcases a wide range of screenshots covering various GIS features of the Desktop Edition map control. | ||
+ | <div medialist imagewithremaker> | ||
+ | {{desktopedition:screenshot:Map_Suite_Desktop_Edition_Screenshot_Gallery_SatelliteImagery.jpg?180|Add rich aerial imagery | ||
+ | Supports JPEG2000, TIFF, MrSid, ECW and more}} | ||
+ | //Add rich aerial imagery | ||
+ | Supports JPEG2000, TIFF, MrSid, ECW and more// | ||
+ | {{desktopedition:screenshot:Map_Suite_Desktop_Edition_Screenshot_Gallery_SQLQuerying.png?180|SQL query feature layers | ||
+ | Get column data | ||
+ | Visually render SQL data}} | ||
+ | SQL query feature layers | ||
+ | Visually render SQL data | ||
+ | {{desktopedition:screenshot:Map_Suite_Desktop_Edition_Screenshot_Gallery_ChartsGraphs.png?180|Integrate charts and graphs on your map | ||
+ | Uses ZedGraph classes}} | ||
+ | Integrate charts and graphs on your map | ||
+ | Uses ZedGraph classes | ||
+ | {{desktopedition:screenshot:Map_Suite_Desktop_Edition_Screenshot_Gallery_ColorFamilies.png?180|Automatic color family generation | ||
+ | Group colors by hue or quality}} | ||
+ | Automatic color family generation | ||
+ | Group colors by hue or quality | ||
+ | {{desktopedition:screenshot:Map_Suite_Desktop_Edition_Screenshot_Gallery_SelectiveDrawing.png?180|Draw or exclude features based on conditions | ||
+ | Render based on data points}} | ||
+ | Draw or exclude features based on conditions | ||
+ | Render based on data points | ||
+ | {{desktopedition:screenshot:Map_Suite_Desktop_Edition_Screenshot_Gallery_RestrictionLayers.png?180|Restrict drawing of features | ||
+ | Fill restricted areas with patterns or bitmaps}} | ||
+ | Restrict drawing of features | ||
+ | Fill restricted areas with patterns or bitmaps | ||
+ | {{desktopedition:screenshot:Map_Suite_Desktop_Edition_Screenshot_Gallery_DotDensity.png?180|Plots points on your map | ||
+ | Point density represents numeric data}} | ||
+ | Plots points on your map | ||
+ | Point density represents numeric data | ||
+ | {{desktopedition:screenshot:Map_Suite_Desktop_Edition_Screenshot_Gallery_RegEx.png?180|Render features based on a regular expression | ||
+ | Puts you in control}} | ||
+ | Render features based on a regular expression | ||
+ | Puts you in control | ||
+ | {{desktopedition:screenshot:Map_Suite_Desktop_Edition_Screenshot_Gallery_ValueRendering.png?180|Render features based on a range of data values | ||
+ | Useful for points & labels}} | ||
+ | Render features based on a range of data values | ||
+ | Useful for points & labels | ||
+ | {{desktopedition:screenshot:Map_Suite_Desktop_Edition_Screenshot_Gallery_ThematicFeatures.png?180|Render features specifically based on a theme | ||
+ | Colorize map features}} | ||
+ | Render features specifically based on a theme | ||
+ | Colorize map features | ||
+ | {{desktopedition:screenshot:Map_Suite_Desktop_Edition_Screenshot_Gallery_Projections.png?180|Project your spatial data | ||
+ | Nearly every known projection is available}} | ||
+ | Project your spatial data | ||
+ | Nearly every known projection is available | ||
+ | {{desktopedition:screenshot:Map_Suite_Desktop_Edition_Screenshot_Gallery_MapRotation.png?180|Draw your maps in any orientation you wish | ||
+ | Real-time rotation}} | ||
+ | Draw your maps in any orientation you wish | ||
+ | Real-time rotation | ||
+ | {{desktopedition:screenshot:Map_Suite_Desktop_Edition_Screenshot_Gallery_PointsUsingBitmaps.png?180|Draw an image at a point | ||
+ | Additional options include vector symbols}} | ||
+ | Draw an image at a point | ||
+ | Additional options include vector symbols | ||
+ | {{desktopedition:screenshot:Map_Suite_Desktop_Edition_Screenshot_Gallery_SampleApps.png?180|Dozens of interactive sample applications | ||
+ | Source code in C#}} | ||
+ | Dozens of interactive sample applications | ||
+ | Source code in C# | ||
+ | <div newline></div> | ||
Line 183: | Line 332: | ||
