map_suite_dependencies_licenses [2017/03/21 07:53] tgwikiupdate |
map_suite_dependencies_licenses [2017/03/27 05:25] tgwikiupdate |
Line 8: | Line 8: | ||
* MapSuiteDependency-EntityFramework.10.0.0 (EntityFramework.6.0.0) https://entityframework.codeplex.com/license | * MapSuiteDependency-EntityFramework.10.0.0 (EntityFramework.6.0.0) https://entityframework.codeplex.com/license | ||
* MapSuiteDependency-ErdasRaster.10.0.0.0 https://sgisupport.intergraph.com/infocenter/index?page=licensing_resources | * MapSuiteDependency-ErdasRaster.10.0.0.0 https://sgisupport.intergraph.com/infocenter/index?page=licensing_resources | ||
- | * MapSuiteDependency-EsriFileGeoDatabase.10.0.0.0 [[http://wiki.thinkgeo.com/wiki/_media/wiki/esrifilegeodatabase.license.zip|EsriFileGeoDatabase.License]] | + | * MapSuiteDependency-EsriFileGeoDatabase.10.0.0.0 https://github.com/Esri/file-geodatabase-api/blob/master/FileGDB_API_1.5/License.txt |
* MapSuiteDependency-Fdo.10.0.0.0 http://fdo.osgeo.org/licenceAndGovernance.html | * MapSuiteDependency-Fdo.10.0.0.0 http://fdo.osgeo.org/licenceAndGovernance.html | ||
* MapSuiteDependency-GdalGeoRasterProjection.10.0.0.0 https://trac.osgeo.org/gdal/wiki/RevisedEPSGLicense | * MapSuiteDependency-GdalGeoRasterProjection.10.0.0.0 https://trac.osgeo.org/gdal/wiki/RevisedEPSGLicense | ||
* MapSuiteDependency-GdalS57.10.0.0.0 https://trac.osgeo.org/gdal/wiki/RevisedEPSGLicense | * MapSuiteDependency-GdalS57.10.0.0.0 https://trac.osgeo.org/gdal/wiki/RevisedEPSGLicense | ||
* MapSuiteDependency-GeoAPI.10.0.0 http://geoapi.codeplex.com/license | * MapSuiteDependency-GeoAPI.10.0.0 http://geoapi.codeplex.com/license | ||
- | * MapSuiteDependency-LibGeoTiff.10.0.0.0 http://libtiff.org/ (download address) | + | * MapSuiteDependency-LibGeoTiff.10.0.0.0 https://github.com/BitMiracle/libtiff.net/blob/master/license.txt, https://bitmiracle.github.io/libtiff.net/# |
* MapSuiteDependency-LizardTechMrSid.10.0.0.0 https://www.lizardtech.com/developer/portal-sdk-license | * MapSuiteDependency-LizardTechMrSid.10.0.0.0 https://www.lizardtech.com/developer/portal-sdk-license | ||
* MapSuiteDependency-MicrosoftSqlServerTypes.10.0.0 https://www.microsoft.com/web/webpi/eula/microsoft_sql_server_2012_microsoft_clr_eng.htm | * MapSuiteDependency-MicrosoftSqlServerTypes.10.0.0 https://www.microsoft.com/web/webpi/eula/microsoft_sql_server_2012_microsoft_clr_eng.htm | ||
Line 27: | Line 27: | ||
* MapSuiteDependency-WindowsAPICodePack.10.0.0.0 http://code.msdn.microsoft.com/WindowsAPICodePack/Project/License.aspx | * MapSuiteDependency-WindowsAPICodePack.10.0.0.0 http://code.msdn.microsoft.com/WindowsAPICodePack/Project/License.aspx | ||
* MapSuiteDependency-ZedGraph.10.0.0 http://www.gnu.org/licenses/lgpl-2.1.txt | * MapSuiteDependency-ZedGraph.10.0.0 http://www.gnu.org/licenses/lgpl-2.1.txt | ||
+ | * MapSuiteDependency-HexagonGeospatialEcw https://support.hexagonsafetyinfrastructure.com/infocenter/index?page=licensing_resources | ||
+ | * MapSuiteDependency-UnmanagedProj4Projection.10.0.0 http://proj4.org/license.html | ||
==== Source Code ==== | ==== Source Code ==== | ||
- | * MapSuiteDependency-CilociFlee.10.0.0 http://wiki.thinkgeo.com/wiki/_media/mapsuite10/extensionsource/fleestyleextension.zip | + | * {{http://wiki.thinkgeo.com/wiki/_media/mapsuite10/extensionsource/fleestyleextension.zip|MapSuiteDependency-CilociFlee.10.0.0}} |
