map_suite_data_format_guide [2015/09/25 01:37] admin [Additional Formats using the FDO Extension] |
map_suite_data_format_guide [2017/09/06 05:46] tgwikiupdate |
Line 11: | Line 11: | ||
| ThinkGeo [[http://thinkgeo.com/forums/MapSuite/tabid/143/aft/9903/Default.aspx|TinyGeo]] | Read/write | 6.0 | | | ThinkGeo [[http://thinkgeo.com/forums/MapSuite/tabid/143/aft/9903/Default.aspx|TinyGeo]] | Read/write | 6.0 | | ||
| ESRI [[http://en.wikipedia.org/wiki/ArcGIS#Geodatabase|File Geodatabase]] | Read/write | 7.0 | | | ESRI [[http://en.wikipedia.org/wiki/ArcGIS#Geodatabase|File Geodatabase]] | Read/write | 7.0 | | ||
- | | [[http://en.wikipedia.org/wiki/Keyhole_Markup_Language|KML]] (Keyhole Markup Language) | Read/write | 8.0 | | + | | [[http://en.wikipedia.org/wiki/Keyhole_Markup_Language|KML]] (Keyhole Markup Language) | Read | 8.0 | |
| Microsoft [[http://en.wikibooks.org/wiki/Geospatial_Data_in_SQL_Server|SQL Server Spatial]] 2008 and newer | Read/write | 3.0 | | | Microsoft [[http://en.wikibooks.org/wiki/Geospatial_Data_in_SQL_Server|SQL Server Spatial]] 2008 and newer | Read/write | 3.0 | | ||
| [[http://www.oracle.com/technetwork/database/options/spatialandgraph/overview/index.html|Oracle Spatial]] | Read/write | 3.0 | | | [[http://www.oracle.com/technetwork/database/options/spatialandgraph/overview/index.html|Oracle Spatial]] | Read/write | 3.0 | |
