Added new overloading method for DrawText in GeoCanvas class Enhanced to get better performance for data drawing when shape file contains many inner rings in polygon Enhanced to support Esri srid input for Proj4Projection Enhanced to support Esri coordinate system when create table for FileGeoDatabase Enhanced to use more accurate exception information and exception type Fixed a bug map throw null reference exception in certain scenario Fixed a bug the Sqlite R Tree calculate different result in Windows and Linux Fixed a bug some special invalid saturation and luminance values for GeoColor can pass our validation Fixed a bug vector data won't render all shapes if the width is too big Fixed a bug XyzFileBitmapTileCache lose cache ID in certain scenario Fixed a bug GettingTileCache event won't be fired in correct step Fixed a bug the overlays don't match when print to PDF Fixed a bug white line shows for WMTSlayer Fixed a bug exception is thrown when met invalid tile in WMTSlayer Fixed a bug failed to load dll in FileGeoDatabase for asp.net scenario Fixed a bug ECW render distorted image in special zoomlevel Fixed a bug GeoTiff image jump in certain scenario
