map_suite_core_10.3_features_bug_fixes_change_log
ThinkGeo.MapSuite Namespace:
  • Supported more “DrawingGraphicsUnit” to follow GDI+ graphics unit
  • Supported the TileCache expiration time change to last write time instead of create time
  • Supported some special point types for file GeoDatabase
  • Supported QueryTool(GetFirstFeaturesWellKnownType)
  • Fixed a bug that drawing image pixelated for Jpeg2000
  • Fixed a bug LegendAdormentLayer doesn't work
  • Fixed a bug that raster layer casuse memory leak on linux
  • Fixed a bug that bingmapslayer rotation incorrect
  • Fixed a bug that when TileType is MultipleTile, some tiles aren't rendered in GeoTiff
  • Fixed a bug for GraticuleFeatureLayer that WrapDateline doesn't work
  • Fixed a bug that GeoTiff unmanaged wrapper doesn't work correctly
  • Fixed a bug that offset of point style doesn't work
  • Fixed a bug that layer rotation offset in some special scenario
  • Fixed a bug that WorldStreetsAndImageryRasterLayer cache doesn't work
  • Fixed a memory leak bug for Ecw and Jpeg2000
  • Fixed a bug that CAD file load failed
  • Fixed a bug that Jpeg2000 crash issue in some scenarios on linux
  • Fixed a bug that TiledWms can't work when the capabilities contains “Post” node
  • Fixed a bug that the feature doesn't refresh boundingbox when calling SetWellKnownBinary
  • Fixed a bug that grid feature source drawing incorrectly when grid size less than 1 pixel
  • Fixed a bug that render stretchs on ScaleBarPrinterLayer
  • Fixed a bug that TiledWmsOverlay doesn't work when the sending request is incorrect
  • Fixed a bug that tiff gets a incorrect boundingbox
  • Fixed a memory leak bug on cad feature layer
  • Fixed a bug that cache doesn't work for wmts
  • Fixed a bug that Jpg2000 image displays blur after the image has been projected at the edge of the image
  • Fixed a bug that reprojection result incorrect
  • Fixed a bug that wmts layer doesn't show tile in some cases
  • Fixed a bug that exception is thrown when GeoFdoRasterSource load data
  • Fixed a bug that exception is thrown when WmsRasterLayer load data
  • Fixed a bug that GeoFdoRasterSource can't display customer's file correctly
  • Fixed a bug that NoaaWeatherStationStyle throws exception when the feature's column value “DisplayPriority” is null or empty
  • Fixed a bug that wmts layer can't find correct RowColumn limitation value
  • Fixed a bug that SpatialIndexName can't contain char “-” in MsSqlFeatureSource
  • Fixed a bug that NoaaWeatherStationFeatureLayer doesn't work on MapSuite10.0
  • Fixed a bug that transaction in InMemoryFeatureLayer doesn't work
  • Fixed a bug that tiled wms layer throws exception when parameters is correct
  • Fixed a bug that the width option of line doesn't work when creating Kml file by MapShape
  • Fixed a bug that GetServerCapabilitiesXml API in Wms&TiledWms&WMTS layer gets incorrect result
  • Fixed a bug that WMS Client doesn't deal with exception of WMS Server not available
  • Fixed a bug that exception of MapShapes creating KML
  • Fixed a bug that CadFeatureLayer crash caused by out of memory
  • Fixed a bug that MapPrinterLayer can't serialize or deserlize
  • Fixed a bug that geotiff file can't get the projection text
  • Fixed a bug that GeoTiffRasterLayer returns wrong projection described
  • Fixed a bug that PostgreSqlFeatureSource throws an “Invalid data type” exception when the parameter is null or string.Empty
map_suite_core_10.3_features_bug_fixes_change_log.1532573305.txt.gz · Last modified: 2018/07/26 02:48 by tgwikiupdate
