map_suite_core_10.3_features_bug_fixes_change_log [2018/07/25 10:21] tgwikiupdate |
map_suite_core_10.3_features_bug_fixes_change_log [2018/07/26 10:17] tgwikiupdate |
ThinkGeo.MapSuite Namespace: | ThinkGeo.MapSuite Namespace: | ||
- | *Supported more "DrawingGraphicsUnit" to follow GDI+ graphics unit | + | *Supported more types of "DrawingGraphicsUnit" follow GDI+ graphics unit |
- | *Supported the TileCache expiration time change to last write time instead of create time | + | *Supported TileCache expire depend on last write time |
- | *Supported some special point types for file GeoDatabase | + | *Supported special point types for file GeoDatabase |
- | *Supported QueryTool(GetFirstFeaturesWellKnownType) | + | *Supported "GetFirstFeaturesWellKnownType" function for QueryTool |
*Supported more projections for example 102003 | *Supported more projections for example 102003 | ||
- | *Supported GRAY band and uint16 source data of JPEG2000 | + | *Supported GRAY band and uint16 source data of JPEG2000 |
- | *Fixed a bug that generic GDI+ throws exception when disposing image | + | *Fixed a bug that generic GDI+ throws exception when disposing image |
- | *Fixed a bug that drawing image pixelated for Jpeg2000 | + | |
- | *Fixed a bug LegendAdormentLayer doesn't work | + | |
- | *Fixed a bug that raster layer casuse memory leak on linux | + | |
*Fixed a bug that WrapDateline of GraticuleFeatureLayer doesn't work | *Fixed a bug that WrapDateline of GraticuleFeatureLayer doesn't work | ||
- | *Fixed a bug that bingmapslayer rotation incorrect | + | *Fixed a bug that Bingmapslayer rotation get incorrect result |
- | *Fixed a bug that when TileType is MultipleTile, some tiles aren't rendered in GeoTiff | + | *Fixed a bug that map can't read the projection text from GeoTiff file |
- | *Fixed a bug for GraticuleFeatureLayer that WrapDateline doesn't work | + | *Fixed a bug that some tiles aren't rendered when tile type is Multiple for GeoTiff |
- | *Fixed a bug that GeoTiff unmanaged wrapper doesn't work correctly | + | *Fixed a bug that unmanaged wrapper doesn't work correctly for GeoTiff |
- | *Fixed a bug that offset of point style doesn't work | + | *Fixed a bug that LegendAdormentLayer doesn't work in certain scenario |
- | *Fixed a bug that layer rotation offset in some special scenario | + | *Fixed a bug that offset of point style doesn't work in certain scenario |
- | *Fixed a bug that WorldStreetsAndImageryRasterLaye cache doesn't work | + | *Fixed a bug that layer rotation offset is incorrect in certain scenario |
- | *Fixed a memory leak bug for Ecw and Jpeg2000 | + | *Fixed a bug that cache doesn't work for WorldStreetsAndImageryRasterLayer in certain scenario |
- | *Fixed a bug that CAD file load failed | + | *Fixed a bug that CAD file load failed in certain scenario |
- | *Fixed a bug that Jpeg2000 crash issue in some scenarios on linux | + | *Fixed a bug that TiledWms doesn't work if the capabilities contains "Post" node |
- | *Fixed a bug that TiledWms can't work when the capabilities contains "Post" node | + | *Fixed a bug that GridFeatureSource render incorrectly if grid size less than 1 pixel |
- | *Fixed a bug that the feature doesn't refresh boundingbox when calling SetWellKnownBinary | + | *Fixed a bug that ScaleBarPrinterLayer render stretch |
- | *Fixed a bug that grid feature source drawing incorrectly when grid size less than 1 pixel | + | *Fixed a bug that TiledWmsOverlay doesn't work if the sending request is incorrect |
- | *Fixed a bug that render stretchs on ScaleBarPrinterLayer | + | *Fixed a bug that Tiff gets incorrect boundingbox |
- | *Fixed a bug that TiledWmsOverlay doesn't work when the sending request is incorrect | + | *Fixed a bug that memory leak for raster layer on linux |
- | *Fixed a bug that tiff gets a incorrect boundingbox | + | *Fixed a bug that JPEG2000 crash issue in certain scenario on linux |
- | *Fixed a memory leak bug on cad feature layer | + | |
- | *Fixed a bug that cache doesn't work for wmts | + | |
- | *Fixed a bug that Jpg2000 image displays blur after the image has been projected at the edge of the image | + | |
- | *Fixed a bug that reprojection result incorrect | + | |
- | *Fixed a bug that wmts layer doesn't show tile in some cases | + | |
- | *Fixed a bug that exception is thrown when GeoFdoRasterSource load data | + | |
- | *Fixed a bug that exception is thrown when WmsRasterLayer load data | + | |
- | *Fixed a bug that GeoFdoRasterSource can't display customer's file correctly | + | |
- | *Fixed a bug that NoaaWeatherStationStyle throws exception when the feature's column value "DisplayPriority" is null or empty | + | |
- | *Fixed a bug that wmts layer can't find correct RowColumn limitation value | + | |
*Fixed a bug that raster layer throws out of memory exception | *Fixed a bug that raster layer throws out of memory exception | ||
- | *Fixed a bug that SpatialIndexName can't contain char "-" in MsSqlFeatureSource | + | *Fixed a bug that crash caused by out of memory exception for CadFeatureLayer |
- | *Fixed a bug that NoaaWeatherStationFeatureLayer doesn't work on MapSuite10.0 | + | *Fixed a bug that memory leak for Ecw and JPEG2000 |
- | *Fixed a bug that transaction in InMemoryFeatureLayer doesn't work | + | *Fixed a bug that draw pixelated image of JPEG2000 |
- | *Fixed a bug that tiled wms layer throws exception when parameters is correct | + | *Fixed a bug that JPEG2000 image displays blur after the image had been reprojected baed on the image edge |
- | *Fixed a bug that the width option of line doesn't work when creating Kml file by MapShape | + | *Fixed a bug that cache doesn't work for WMTS layer |
- | *Fixed a bug that GetServerCapabilitiesXml API in Wms&TiledWms&WMTS layer gets incorrect result | + | *Fixed a bug that WMTS layer doesn't show tile in certain scenario |
- | *Fixed a bug that WMS Client doesn't deal with exception of WMS Server not available | + | *Fixed a bug that WMTS layer can't find correct RowColumn limitation value |
- | *Fixed a bug that exception of MapShapes creating KML | + | *Fixed a bug that "GetServerCapabilitiesXml" get incorrect result for Wms layer, TiledWms layer or WMTS layer |
- | *Fixed a bug that CadFeatureLayer crash caused by out of memory | + | *Fixed a bug that TiledWMS layer throws exception when passed parameters is correct |
- | *Fixed a bug that MapPrinterLayer can't serialize or deserlize | + | *Fixed a bug that WMS Client cannot deal with exception when WMS Server unavailable |
- | *Fixed a bug that geotiff file can't get the projection text | + | *Fixed a bug that WmsRasterLayer throws exception when load data |
- | *Fixed a bug that GeoTiffRasterLayer returns wrong projection described | + | *Fixed a bug that GeoFdoRasterSource throws exception when load data |
- | *Fixed a bug that PostgreSqlFeatureSource throws an "Invalid data type" exception when the parameter is null or string.Empty | + | *Fixed a bug that GeoFdoRasterSource can't display data correct in certain scenario |
+ | *Fixed a bug that NoaaWeatherStationStyle throws exception when feature's column value "DisplayPriority" is null or empty | ||
+ | *Fixed a bug that NoaaWeatherStationFeatureLayer doesn't work in certain scenario | ||
+ | *Fixed a bug that SpatialIndexName can't contain char "-" for MsSqlFeatureSource | ||
+ | *Fixed a bug that transaction doesn't work for InMemoryFeatureLayer | ||
+ | *Fixed a bug that MapPrinterLayer can't get serialized or deserlized | ||
+ | *Fixed a bug that GeoTiffRasterLayer returns wrong projection description | ||
+ | *Fixed a bug that PostgreSqlFeatureSource throws "Invalid data type" exception if parameter is null or string.Empty | ||
+ | *Fixed a bug that the boundingbox of feature don't get updated after SetWellKnownBinary operation | ||
+ | *Fixed a bug that the width option of line save incorrect value when convert MapShapes to KML | ||
+ | *Fixed a bug that KmlLayer throw exception when convert MapShapes to KML | ||
+ | *Fixed a bug that reproject get incorrect result in certain scenario |
