map_suite_core_10.2_features_bug_fixes_change_log [2017/11/01 03:35] marklee |
map_suite_core_10.2_features_bug_fixes_change_log [2017/11/06 05:03] (current) tgwikiupdate |
ThinkGeo.MapSuite Namespace: | ThinkGeo.MapSuite Namespace: | ||
- | *Support online OSM building data with the ability to cache locally | + | *Supported online OSM building data with the ability to cache locally |
- | *Support 3D rendering for buildings | + | *Supported 3D rendering for buildings |
- | *Support USGS DEM data rendering with embedded styles | + | *Supported USGS DEM data rendering with embedded styles |
- | *Support more Interpolations (NearestNeighbor for example) for PlatformGeoCanvas | + | *Supported more Interpolations (NearestNeighbor for example) for PlatformGeoCanvas |
- | *Support KML projection from WGS84 to other projections | + | *Supported KML projection from WGS84 to other projections |
- | *Support different rendering orders (by Features or by ClassBreaks) for ClassBreakStyle | + | *Supported different rendering orders (by Features or by ClassBreaks) for ClassBreakStyle |
- | *Support different rendering orders (by Features or by ValueItems) for ValueStyle | + | *Supported different rendering orders (by Features or by ValueItems) for ValueStyle |
*Added "GetFeatureIds" API for all FeatureSources and FeatureLayers | *Added "GetFeatureIds" API for all FeatureSources and FeatureLayers | ||
- | *Upgrade FdoRasterRasterLayer&FdoVectorFeatureLayer to use FDO 4.0 | + | *Upgraded FdoRasterRasterLayer&FdoVectorFeatureLayer to use FDO 4.0 |
*Fixed a bug where Proj4Projection.CanReproject returns incorrectly in some classes | *Fixed a bug where Proj4Projection.CanReproject returns incorrectly in some classes | ||
*Fixed a bug where "ArgumentNullException" exception is thrown when GeoHatchBrush’s constructor is called in some scenarios | *Fixed a bug where "ArgumentNullException" exception is thrown when GeoHatchBrush’s constructor is called in some scenarios |
