map_suite_core_10.2_features_bug_fixes_change_log [2017/10/31 05:07] tgwikiupdate |
map_suite_core_10.2_features_bug_fixes_change_log [2017/11/06 05:03] (current) tgwikiupdate |
ThinkGeo.MapSuite Namespace: | ThinkGeo.MapSuite Namespace: | ||
- | *Added consuming online OSM building data for 3D rendering support, and can cache the data locally | + | *Supported online OSM building data with the ability to cache locally |
- | *Added support for 3D rendering for buildings | + | *Supported 3D rendering for buildings |
- | *Added interpolation mode feature to DrawScreenImageCore of PlatformGeoCanvas | + | *Supported USGS DEM data rendering with embedded styles |
- | *Added GetFeatureIds API for all FeatureSources and FeatureLayers | + | *Supported more Interpolations (NearestNeighbor for example) for PlatformGeoCanvas |
- | *Added BinaryTile support so that the JsonBinaryTileCache can store the json data base on the tile bounding box | + | *Supported KML projection from WGS84 to other projections |
- | *Added the FileBufferTileCache support so the cache can be stored with specified file | + | *Supported different rendering orders (by Features or by ClassBreaks) for ClassBreakStyle |
- | *Added natively support for USGS DEM data with the ability to render with embedded styles | + | *Supported different rendering orders (by Features or by ValueItems) for ValueStyle |
- | *Added support for projecting KML from WGS84 to other projections | + | *Added "GetFeatureIds" API for all FeatureSources and FeatureLayers |
- | *Added support for different renderring orders (by Features or by ClassBreaks) for ClassBreakStyle | + | *Upgraded FdoRasterRasterLayer&FdoVectorFeatureLayer to use FDO 4.0 |
- | *Enhanced CanReproject property to support external projection and internal projection | + | *Fixed a bug where Proj4Projection.CanReproject returns incorrectly in some classes |
- | *Enhanced GetFeatureIdsCore in SqliteFeatureSource | + | *Fixed a bug where "ArgumentNullException" exception is thrown when GeoHatchBrush’s constructor is called in some scenarios |
- | *Enhanced csv reader on GetFeatureIdsCore | + | *Fixed a bug where FileGeoDatabaseFeatureLayer cannot read its last polyline data correctly |
- | *Enhanced FileBinaryTileCache to JsonBinaryTileCache with the fixed file extension ".json" | + | *Fixed a bug where "System.Reflection.TargetInvocationException was unhandled" exception is thrown when creating table by FileGeoDatabaseFeatureLayer |
- | *Enhanced the ThinkGeo.MapSuite.Json name space to ThinkGeo.MapSuite.Layers | + | *Fixed a bug where WmtsLayer crashed when the WMS server returns 404 error |
- | *Enhanced the Fdo version to 4.0 | + | *Fixed a bug where GoogleMapsLayer draws incorrectly when using single tile mode in certain scenarios |
- | *Enhanced the assembly name of "ThinkGeo.MapSuite.Layers.UsgsDem for Android" | + | *Fixed a bug where the “GeoImage cannot be serialized” exception is thrown in some scenarios |
- | *Fixed a bug the GeoHatchBrush has an incorrect resource name space | + | *Fixed a bug where InMemoryFeatureSource cannot get correct bounding box when building index in certain scenarios |
- | *Fixed a bug the FileGeoDatabaseFeatureLayer has an incorrect value of the last line on Polyline type | + | *Fixed a bug where "Object reference not set to a instance of an object." exception is thrown when Proj4Projection’s parameterless constructor is called |
- | *Fixed a bug the FileGeoDatabaseFeatureLayer has an incorrect column template in embedded resource | + | *Fixed a bug where BingMapsLayer doesn't work on Android Edition in certain scenarios |
- | *Fixed a bug the WmtsLayer crashed when the image request returns 404 error | + | *Fixed a bug where TextStyle doesn't work in FileGeoDatabaseFeatureSource |
- | *Fixed a bug the GoogleMapsLayer get an incorrect tile size with the single tile mode | + | *Fixed a bug where GoogleMapsLayer draw an incorrect request image on Single Tile Mode |
- | *Fixed a bug the image object can't be serialized in GeoImage | + | *Fixed a bug where ClusterPointStyle throws "Object reference not set to an instance of an object" exception in certain scenarios |
- | *Fixed a bug the BuildIndex gets an incorrect bounding box in InMemoryFeatureSource | + | *Fixed a bug where FileGdbApiWrapper returns features with incorrect column names |
- | *Fixed a bug the Proj4Projection constructor will throw "Object reference not set to a instance of an object." exception when the Proj4Projection empty constructor is used | + | *Fixed a bug where MapSuite Product Center can't popup in certain scenarios. |
- | *Fixed a bug for Android environment provider | + | |
- | *Fixed a bug the AdornmentsResource can't be obfuscated | + | |
- | *Fixed a bug the EnvironmentProvider can't get an accurate temporary folder | + | |
- | *Fixed a bug the RasterLayer can't be wrapped | + | |
- | *Fixed a bug TextStyle can't be rendered in FileGeoDatabaseFeatureSource | + | |
- | *Fixed a bug the GoogleMapsLayer draw an incorrect request image on Single Tile Mode | + | |
- | *Fixed a bug the ClusterPointStyle can't get converted base style | + | |
- | *Fixed a bug the Compare returns a nagetive value on FeatureLocationComparer | + | |
- | *Fixed a bug the FileGdbApiWrapper gets features with incorrect column names | + | |
- | *Fixed a bug the product center v10.0 can't be popup | + |
