map_suite_common_dependencies [2015/09/02 10:00] admin |
map_suite_common_dependencies [2020/05/26 16:21] benbai [Latest Public Release (10.0.0.0)] |
====== Map Suite Common Dependencies ====== | ====== Map Suite Common Dependencies ====== | ||
- | ===== Latest Public Release (9.0.0.0)===== | + | |
- | ===== • Services Edition Required Libraries ===== | + | ===== • Map Suite Core Required Libraries ===== |
<div borderless> | <div borderless> | ||
> **NTS Topology** | > **NTS Topology** | ||
Line 10: | Line 10: | ||
|Location|Project Bin Directory| | |Location|Project Bin Directory| | ||
|Version|1.1.0.0 1.7.3.31740| | |Version|1.1.0.0 1.7.3.31740| | ||
+ | |Licensing|[[https://opensource.org/licenses/LGPL-2.0|LGPL 2.0 License]] [[https://opensource.org/licenses/LGPL-2.1|LGPL 2.1 License]]| | ||
|WebSite|[[http://code.google.com/p/nettopologysuite/downloads/list|Source WebSite]]| | |WebSite|[[http://code.google.com/p/nettopologysuite/downloads/list|Source WebSite]]| | ||
Line 15: | Line 16: | ||
> **Sql CLR Type Topology** | > **Sql CLR Type Topology** | ||
+ | **x64** | ||
|Dlls|Microsoft.SqlServer.Types.dll \\ SqlServerSpatial110.dll(X64)| | |Dlls|Microsoft.SqlServer.Types.dll \\ SqlServerSpatial110.dll(X64)| | ||
+ | |MergeModule|MicrosoftSqlServerSpatial.msm| | ||
+ | |Location|Project Bin Directory SqlServerSpatial110.dll should be deployed accordingly under different circumstances. \\ \\ Case 1: On an X86 system.The X86 version of SqlServerSpatial110.dll (under SqlServerTypes_X86 folder) needs to be copied to “c:\Windows\System32” folder. \\ \\ Case 2: Running under X64 mode on an X64 system,The X64 version of SqlServerSpatial110.dll (under SqlServerTypes_X64 folder) needs to be copied to “c:\Windows\System32” \\ \\ Case 3: Running under X86 mode on an X64 system.The X86 version of SqlServerSpatial110.dll (under SqlServerTypes_X86 folder) needs to be copied to “c:\Windows\SysWOW64” folder.| | ||
+ | |Version|110| | ||
+ | |WebSite|Microsoft® System CLR Types for Microsoft® SQL Server® 2012 from [[http://www.microsoft.com/en-us/download/details.aspx?id=29065|Source WebSite]] | | ||
+ | **x86** | ||
+ | |Dlls|Microsoft.SqlServer.Types.dll \\ SqlServerSpatial110.dll(X86)| | ||
|MergeModule|MicrosoftSqlServerSpatial.msm| | |MergeModule|MicrosoftSqlServerSpatial.msm| | ||
|Location|Project Bin Directory SqlServerSpatial110.dll should be deployed accordingly under different circumstances. \\ \\ Case 1: On an X86 system.The X86 version of SqlServerSpatial110.dll (under SqlServerTypes_X86 folder) needs to be copied to “c:\Windows\System32” folder. \\ \\ Case 2: Running under X64 mode on an X64 system,The X64 version of SqlServerSpatial110.dll (under SqlServerTypes_X64 folder) needs to be copied to “c:\Windows\System32” \\ \\ Case 3: Running under X86 mode on an X64 system.The X86 version of SqlServerSpatial110.dll (under SqlServerTypes_X86 folder) needs to be copied to “c:\Windows\SysWOW64” folder.| | |Location|Project Bin Directory SqlServerSpatial110.dll should be deployed accordingly under different circumstances. \\ \\ Case 1: On an X86 system.The X86 version of SqlServerSpatial110.dll (under SqlServerTypes_X86 folder) needs to be copied to “c:\Windows\System32” folder. \\ \\ Case 2: Running under X64 mode on an X64 system,The X64 version of SqlServerSpatial110.dll (under SqlServerTypes_X64 folder) needs to be copied to “c:\Windows\System32” \\ \\ Case 3: Running under X86 mode on an X64 system.The X86 version of SqlServerSpatial110.dll (under SqlServerTypes_X86 folder) needs to be copied to “c:\Windows\SysWOW64” folder.| | ||
Line 41: | Line 49: | ||
===== • Satellite Assemblies ===== | ===== • Satellite Assemblies ===== | ||
+ | <div borderless> | ||
+ | > **GeoRaster Projection** | ||
+ | |Dlls|proj.dll \\ gdal19.dll| | ||
+ | |MergeModule|MapSuiteGeoRasterProjection.msm| | ||
+ | |Location|SystemRoot\Map Suite 9.0\GeoRasterProjectionX64 \\ SystemRoot\Map Suite 9.0\GeoRasterProjectionX86| | ||
+ | |Version|4.8 \\ 1.9| | ||
+ | |WebSite|[[http://trac.osgeo.org/proj/|Source WebSite]] \\ [[ftp://ftp.remotesensing.org/gdal|Source WebSite]] | | ||
+ | > **MrSid/JP2** | ||
+ | **x64** | ||
+ | |Dlls|lti_dsdk_9.1.dll\\ lti_dsdk_cdll_9.1.dll\\ lti_lidar_dsdk_1.1.dll\\ tbb.dll| | ||
+ | |MergeModule|MapSuiteMrSid.msm\\ Microsoft_VC100_CRT_x64.msm\\ Microsoft_VC100_DebugCRT_x64.msm| | ||
+ | |Location|SystemRoot\Map Suite 9.0\GeoRasterX64| | ||
+ | |Version|9.1.0.4045| | ||
+ | |WebSite|[[https://www.lizardtech.com/developer/|Source WebSite]]| | ||
+ | **x86** | ||
+ | |MergeModule|MapSuiteMrSid.msm\\ Microsoft_VC100_CRT_x86.msm\\ Microsoft_VC100_DebugCRT_x86.msm| | ||
+ | |Location|SystemRoot\Map Suite 9.0\GeoRasterX86| | ||
+ | > **Ecw** | ||
+ | **x64** | ||
+ | |Dlls|NCSEcw.dll| | ||
+ | |MergeModule|MapSuiteEcw.msm\\ Microsoft_VC100_CRT_x64.msm\\ Microsoft_VC100_DebugCRT_x64.msm| | ||
+ | |Version|5.2.1.265| | ||
+ | |WebSite|[[http://download.hexagongeospatial.com/?ProductName=ERDAS%20ECW/JPEG2000%20SDK|Source WebSite]]| | ||
+ | **x86** | ||
+ | |MergeModule|MapSuiteEcw.msm\\ Microsoft_VC100_CRT_x86.msm\\ Microsoft_VC100_DebugCRT_x86.msm| | ||
+ | > **proj 4** | ||
+ | **x64** | ||
+ | |Dlls| proj4X64.dll| | ||
+ | |MergeModule|MapSuiteProj4.msm\\ MapSuitePrjHelper.msm| | ||
+ | |Location|SystemRoot\Map Suite 9.0\Proj4X64| | ||
+ | |Version|4.8| | ||
+ | |WebSite|[[http://trac.osgeo.org/proj/|Source WebSite]]| | ||
+ | **x86** | ||
+ | |Dlls| proj4X86.dll| | ||
+ | |Location|SystemRoot\Map Suite 9.0\Proj4X86| | ||
+ | > **GeoTiff Library** | ||
+ | **x64** | ||
+ | |Dlls|GeoTiffX64.dll| | ||
+ | |MergeModule|MapSuiteGeoTiff.msm| | ||
+ | |Location|SystemRoot\Map Suite 9.0\GeoTiffX64| | ||
+ | |Version|libgeotiff-1.2.5.0 \\ tiff-4.0.2| | ||
+ | |WebSite|[[ftp://ftp.remotesensing.org/pub/geotiff/libgeotiff/|Source WebSite]]| | ||
+ | **x86** | ||
+ | |Dlls|GeoTiffX86.dll| | ||
+ | |Location|SystemRoot\Map Suite 9.0\GeoTiffX86| | ||
+ | > **LibTiff.net Library** | ||
+ | |Source code reference|ManagedGeoTiffRasterSource| | ||
+ | |Version|libtiff.net_src-2.3.626.0| | ||
+ | |WebSite|[[https://github.com/BitMiracle/libtiff.net|Source WebSite]]| | ||
+ | ===== • Extensions ===== | ||
+ | > **FleeStyleExtension** | ||
+ | |Dlls|Ciloci.Flee.dll| | ||
+ | |MergeModule|N/A| | ||
+ | |Location|Project Bin Directory| | ||
+ | |Version|0.9.26.0| | ||
+ | |Licensing|[[https://wiki.thinkgeo.com/wiki/map_suite_dependencies/ciloci_flee/license|Ciloci.Flee License]]| | ||
+ | |WebSite|[[https://wiki.thinkgeo.com/wiki/_media/mapsuite10/extensionsource/ciloci.flee.zip|Source WebSite]]| | ||
+ | > **PdfExtension** | ||
+ | |Dlls|pdfsharp.dll| | ||
+ | |Version|1.32.2608.0| | ||
+ | |WebSite|[[http://pdfsharp.codeplex.com/releases|Source WebSite]]| | ||
+ | > **PostgreExtension** | ||
+ | |Dlls|Mono.Security.dll\\ Npgsql.dll| | ||
+ | |Version|2.0.0.0\\ 2.0.11.93| | ||
+ | |WebSite|[[http://pgfoundry.org/frs/?group_id=1000140|Source WebSite]]| | ||
+ | > **ZedGraphStyleExtension** | ||
+ | |Dlls|ZedGraph.dll| | ||
+ | |Version|5.1.5.28844| | ||
+ | |WebSite|[[http://sourceforge.net/projects/zedgraph/files/|Source WebSite]]| | ||
+ | > **Feature Data Objects(FDO)** | ||
+ | |Dlls|FDO.dll \\ FDOCommon.dll \\ FDOGeometry.dll (55 more dlls......)| | ||
+ | |MergeModule|MapSuiteFdoExtension.msm| | ||
+ | |Location|SystemRoot\| | ||
+ | |Version|3.7.0.0| | ||
+ | |WebSite|[[http://fdo.osgeo.org/content/downloads|Source WebSite]]| | ||
+ | > **FileGeoDatabase** | ||
+ | |Dlls|Esri.FileGDBAPI.dll\\ FileGDBAPI.dll\\ FileGDBAPID.dll\\ FileGdbApiWrapperX64.dll\\ msvcp100d.dll\\ msvcr100d.dll\\ msvcp100.dll\\ msvcr100.dll| | ||
+ | |MergeModule|Microsoft_VC100_CRT_x64.msm\\ Microsoft_VC100_DebugCRT_x64.msm\\ MapSuiteFileGeoDatabaseX64.msm\\ Microsoft_VC100_CRT_x86.msm\\ Microsoft_VC100_DebugCRT_x86.msm\\ MapSuiteFileGeoDatabaseX86.msm| | ||
+ | |Location|SystemRoot\Map Suite 9.0\FileGeoDatabaseX64 \\ or SystemRoot\Map Suite 9.0\FileGeoDatabaseX86| | ||
+ | |Version|1.2.0.136| | ||
+ | |WebSite|[[http://resources.arcgis.com/content/geodatabases/10.0/file-gdb-api|Source WebSite]] \\ [[http://wiki.thinkgeo.com/wiki/Map_Suite_Services_Edition_All_Samples#File_Geodatabase|Wiki Samples]]| | ||
+ | > **Oracle Extension** | ||
+ | **x64** | ||
+ | |Dlls|oci.dll\\ Oracle.DataAccess.dll\\ OracleApiWrapperX64.dll\\ orannzsbb11.dll\\ oraocci11.dll\\ oraociei11.dll\\ OraOps11w.dll| | ||
+ | |MergeModule|MapSuiteOracleDependenciesX64.msm| | ||
+ | |Location|SystemRoot\Map Suite 9.0\OracleX64| | ||
+ | |Version|11.2.0.3.20| | ||
+ | |WebSite|[[http://www.oracle.com/technetwork/database/windows/downloads/index-090165.html|Source WebSite]]| | ||
+ | **x86** | ||
+ | |Dlls|oci.dll\\ Oracle.DataAccess.dll\\ OracleApiWrapperX86.dll\\ orannzsbb11.dll\\ oraocci11.dll\\ oraociei11.dll\\ OraOps11w.dll| | ||
+ | |MergeModule|MapSuiteOracleDependenciesX86.msm| | ||
+ | |Location|SystemRoot\Map Suite 9.0\OracleX86| | ||
+ | |WebSite|[[http://www.oracle.com/technetwork/database/windows/downloads/utilsoft-087491.html|Source WebSite]]| | ||
+ | > **Map Suite Cad** | ||
+ | **x64** | ||
+ | |Dlls|CadDumperX64.dll\\ RasterProcessor_4.00_10.tx\\ RecomputeDimBlock_4.00_10.tx \\ \\ sisl.dll\\ TD_3DSolidHistory_4.00_10.tx\\ TD_Alloc_4.00_10.dll\\ TD_Ave_4.00_10.tx\\ TD_Br_4.00_10.dll\\ TD_DbRoot_4.00_10.dll\\ TD_Db_4.00_10.dll\\ TD_DynBlocks_4.00_10.tx\\ TD_Ge_4.00_10.dll\\ TD_Gi_4.00_10.dll\\ \\ TD_Gs_4.00_10.dll\\ TD_Root_4.00_10.dll\\ TD_SpatialIndex_4.00_10.dll\\ TD_SwigCore_4.00_10.dll\\ TD_SwigCoreMgd.dll\\ TD_SwigDb_4.00_10.dll\\ TD_SwigDbMgd.dll| | ||
+ | |MergeModule|MapSuiteCadX64.msm| | ||
+ | |Location|SystemRoot\Map Suite 9.0\CadX64| | ||
+ | |Version|4.0.0.0| | ||
+ | **x86** | ||
+ | |Dlls|CadDumperX86.dll\\ RasterProcessor_4.00_10.tx\\ RecomputeDimBlock_4.00_10.tx \\ \\ sisl.dll\\ TD_3DSolidHistory_4.00_10.tx\\ TD_Alloc_4.00_10.dll\\ TD_Ave_4.00_10.tx\\ TD_Br_4.00_10.dll\\ TD_DbRoot_4.00_10.dll\\ TD_Db_4.00_10.dll\\ TD_DynBlocks_4.00_10.tx\\ TD_Ge_4.00_10.dll\\ TD_Gi_4.00_10.dll\\ \\ TD_Gs_4.00_10.dll\\ TD_Root_4.00_10.dll\\ TD_SpatialIndex_4.00_10.dll\\ TD_SwigCore_4.00_10.dll\\ TD_SwigCoreMgd.dll\\ TD_SwigDb_4.00_10.dll\\ TD_SwigDbMgd.dll| | ||
+ | |MergeModule|MapSuiteCadX86.msm| | ||
+ | |Location|SystemRoot\Map Suite 9.0\CadX86| | ||
+ | > **S57 Extension** | ||
+ | **x64** | ||
+ | |Dlls|gdal110.dll\\ geos.dll\\ geos_c.dll \\ \\ s57attributes.csv\\ s57expectedinput.csv\\ S57GdalWrapperX64.dll\\ s57objectclasses.csv| | ||
+ | |MergeModule|MapSuiteS57.msm| | ||
+ | |Location|SystemRoot\Map Suite 9.0\S57GdalWrapperX64| | ||
+ | |Version|1.10.0.0| | ||
+ | |WebSite|[[ftp://ftp.remotesensing.org/gdal|Source WebSite]]| | ||
+ | **x86** | ||
+ | |Dlls|gdal110.dll\\ geos.dll\\ geos_c.dll \\ \\ s57attributes.csv\\ s57expectedinput.csv\\ S57GdalWrapperX86.dll\\ s57objectclasses.csv| | ||
+ | |Location|SystemRoot\Map Suite 9.0\S57GdalWrapperX86| | ||
+ | </div> |
