map_suite_code_samples [2015/09/09 02:28] admin |
map_suite_code_samples [2015/09/15 06:33] admin [Welcome to the ThinkGeo Wiki Code Samples Collection!] |
Line 2: | Line 2: | ||
- | === Welcome to the ThinkGeo Wiki Code Samples Collection! === | + | ==== Welcome to the ThinkGeo Wiki Code Samples Collection! ==== |
<div marginleft10px floatright > | <div marginleft10px floatright > | ||
{{:Codecommunitywiki.jpg}} | {{:Codecommunitywiki.jpg}} | ||
Line 9: | Line 9: | ||
We've established the ThinkGeo Wiki as a central resource for all of your Map Suite needs, including reference information, example GIS projects, documentation and a whole lot more. One of the premier features is our library of Code Samples. These self-contained sample projects demonstrate the capabilities of Map Suite and show you how to implement a wide variety of features and functionality, many of which are user-requested. | We've established the ThinkGeo Wiki as a central resource for all of your Map Suite needs, including reference information, example GIS projects, documentation and a whole lot more. One of the premier features is our library of Code Samples. These self-contained sample projects demonstrate the capabilities of Map Suite and show you how to implement a wide variety of features and functionality, many of which are user-requested. | ||
- | == Where can I find the Code Samples? == | + | === Where can I find the Code Samples? === |
+ | <div tableborderless> | ||
+ | | [[Map Suite Services Edition All Samples|Services Edition Samples]]|[[Map Suite Desktop Edition All Samples|Desktop Edition Samples]]| | ||
+ | | [[Map Suite Wpf Desktop Edition All Samples|WPF Desktop Edition Samples]]|[[Map Suite MVC Edition All Samples|MVC Edition Samples]]| | ||
+ | | [[Map Suite Web Edition All Samples|Web Edition Samples]]|[[Map Suite Silverlight Edition All Samples|Silverlight Edition Samples]]| | ||
+ | | [[Map Suite Geocoder All Samples|Geocoder Samples]]|[[Map Suite Routing All Samples|Routing Samples]]| | ||
Each Map Suite product in the ThinkGeo Wiki has a section for code samples; the links above will take you to the full list of samples relevant to the product you choose. Alternatively, if you visit the wiki [[Main Page]] and click the "Code Samples" link below any Map Suite product, you'll see that the code samples are categorized to allow you to find the project you need quickly and easily. We have hundreds of samples and are always adding more. | Each Map Suite product in the ThinkGeo Wiki has a section for code samples; the links above will take you to the full list of samples relevant to the product you choose. Alternatively, if you visit the wiki [[Main Page]] and click the "Code Samples" link below any Map Suite product, you'll see that the code samples are categorized to allow you to find the project you need quickly and easily. We have hundreds of samples and are always adding more. | ||
- | You can also use the wiki's built-in [[Special:Search|search function]] to look for projects that suit your needs or interests. | + | You can also use the wiki's built-in search function to look for projects that suit your needs or interests. |
== I have sample code that I would like to share. Can I do that? == | == I have sample code that I would like to share. Can I do that? == |
